Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6337893 times)
« Reply #250 on: Sat, 16 March 2013, 09:03:01 »
A little subjective Lunartuna but I'll take a shot at this.
First off I was under the impression it was PCB mounted. Second, it's got the weird 75% layout. I have a G84-4100 and it's really hard to adapt to the layout. I really don't like the dedicated arrow keys. Or the stock keys really; the side printing makes it look cluttered. And because of the odd layout, this means a lot of the keysets that are popular (Red Alert, CCnG, etc) cannot be used unless there are specialty keys made/found.
If I'm spending $100, I'd rather get a poker/pure or even the new found Filco deals.
« Reply #251 on: Sat, 16 March 2013, 09:10:37 »
I would say that the Choc mini layout takes hardly any adaptation at all.  Everything is in the right place except for the arrows and sixpack.  I think it doesn't get any love simply because it just isn't the new hot thing anymore.
Offline Lunartuna
  • Good bye money!
« Reply #252 on: Sat, 16 March 2013, 09:34:19 »
Going by the pics on this guys ebay store...
http://www.ebay.ca/itm/Noppoo-Choc-Mini-84-Mechanical-Keyboard-Cherry-MX-Black-/250856182331?pt=PCA_Mice_Trackballs&hash=item3a6831923b&_uhb=1#ht_8941wt_1163
Looks plate mounted? I'm a newb still.
Also it looks like he has a newer version?
I might pick one up.
Shine 2 TKL - Choc Mini
« Reply #253 on: Sat, 16 March 2013, 09:59:11 »
You're right, it's plate mounted. I'm not sure about the new version though.
Offline Lunartuna
  • Good bye money!
« Reply #254 on: Sat, 16 March 2013, 10:15:57 »
I really like the layout, and I don't plan on putting a whole matching set of keycaps on it. I'll use my ducky for that.
This would be a board for at work that I will stick random novelty caps on row 1, probably an arrow key set and the various other random caps like the ones from the GH Jan pack.
I've read that it has wacky firmware but will that matter if I mess with it?
« Reply #255 on: Sat, 16 March 2013, 10:17:59 »
Cool. Sounds like it's a good match for you. You can use AutoHotKey to program the board as you like.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #256 on: Sat, 16 March 2013, 10:27:57 »
Do cherry profile 1.75x R Shifts exist, and if so are they all ABS? I'm on the lookout if something like this exists, but have a feeling all of them have been made by SP.
Edit - An 1800 R Shift would work I think, but is this cherry profile?
http://item.taobao.com/item.htm?spm=a230r.1.10.13.VBzjrN&id=15962128659
You don't want those keys they are terrible quality. I am not sure who made them but they have some really odd profile too. It's like DCS but higher, but not as high as OEM.
To my knowledge there is no proper Cherry RGB with 1.75 shift yet. For standard color (light grey, medium grey, beige, black) you can get them off 1800 in ABS, PBT (light color only) or POM (black only).
« Reply #257 on: Sat, 16 March 2013, 10:30:11 »
I have a question for you Mr. Ivan. What's the easiest way for me to get Cherry Doubleshots for my Filco 104 MJ2?
« Reply #258 on: Sat, 16 March 2013, 10:34:19 »
White on black, you need 2 keyboard which can be found on ebay often. First you need either 8113H**US or 8200H**US for the bottom row and full touch caps lock, then you need something like a MY8000H**US for the doubleshots of function and nav keys.
Black on white/grey just buy a set from originative. Finding vintage in this colorway with 1.25 and fulltouch caps lock is a ballbreaker.
« Last Edit: Sat, 16 March 2013, 10:37:01 by IvanIvanovich »
« Reply #259 on: Sat, 16 March 2013, 10:37:53 »
I think I like the white on black more than the black on white. SmallFry's got some on his Phantom and its super hot.
Offline blueasjim
« Reply #260 on: Sat, 16 March 2013, 11:43:40 »
Okay, I have a question, perhaps dumb, I'm not sure.
But if I were to buying a KBC Poker (for example) and then purchased a case like this, would I be able to take the KBC 'guts' out and implant them in this Aluminum case? Is that feesible, or do I have to build an entire board around these types of cases? I just ask because I'm not certain how great I am at piecing together switches and such and if I have to manually make one myself.. ima need to practice. o.O
Vortex KBT PURE [MX Red] | CM Storm [MX Blue] | CM Storm [MX Red]
Offline laffindude
« Reply #261 on: Sat, 16 March 2013, 11:48:44 »
A few caps + 5 screws are all that stand in your way to swapping cases.
Offline blueasjim
« Reply #262 on: Sat, 16 March 2013, 11:59:49 »
Awesome. Thanks for the clarification. Really helps. Now for the round 3 buy (hopefully). :D
Offline WhiteFireDragon
    • youtube
« Reply #263 on: Sat, 16 March 2013, 11:59:50 »
That case you linked was made exactly for that poker you mentioned.
Offline blueasjim
« Reply #264 on: Sat, 16 March 2013, 12:01:04 »
Oh, I didn't know that. Awesome, thank you. :)
Offline eRadicatedZomBiE
  • It's OK, I'm A Doctor.
« Reply #265 on: Sat, 16 March 2013, 19:24:53 »
what size spacebar fits a WASD v1?
CM QFR | WASD V1 | Flico MJ2 LE Blue | Ducky 78 | Ducky DK9008G2 Pro LE  |Phantom |
Ergodox
My WTB Thread
Offline The_Beast
  • I like wood ಠ_๏
« Reply #266 on: Sat, 16 March 2013, 19:26:17 »
6.25 unit
Ergodox
My WTB Thread
Offline Sniping
« Reply #268 on: Sat, 16 March 2013, 21:28:53 »
What do people mean when they say proxy?
Offline Jocelyn
  • 조셀린
« Reply #269 on: Sat, 16 March 2013, 21:34:21 »
When someone in one location of the world buys an item for someone located elsewhere and ships it to them.
« Reply #270 on: Sat, 16 March 2013, 21:48:31 »
Say you want to get a Leopold FC700R. Right now the most reliable way is to buy it from a retailer in Australia. But I live in the USA. How do I handle shipping and money differences? The easiest way is to have someone help you buy it, called a proxy. I pay my buddy $XX. He goes and buys the thing for me and ships it to me.  That way you don't have to convert money or deal with shipping. You can just have someone help you buy.
Offline Gupgup
« Reply #271 on: Sat, 16 March 2013, 22:33:37 »
Could someone give me an example of how to put an image in my signature? I've been trying but I can't get it to show up, it is probably really easy haha. Sorry and thanks!
Gupgup
Offline The_Beast
  • I like wood ಠ_๏
« Reply #272 on: Sat, 16 March 2013, 22:36:36 »
Gupgup
You should just not put on in your sig
they're annoying IMO
Offline Dubsgalore
« Reply #273 on: Sat, 16 March 2013, 22:37:15 »
my question....how do you build a gh60?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #274 on: Sat, 16 March 2013, 22:43:06 »
Simple way: Solder switches, install into case, install caps
Hard way: Install switches onto plate, solder switches, install into case, install caps
Offline Dubsgalore
« Reply #275 on: Sat, 16 March 2013, 22:49:40 »
next step for me: learn how to solder.
« Reply #276 on: Sat, 16 March 2013, 22:50:38 »
Some pics of how a custom board looks without a case. The_Beast's directions can be applied to this. This is SmallFry's Phantom.
Side View
Bottom View
Offline SmallFry
« Reply #277 on: Sat, 16 March 2013, 22:51:57 »
HEY! I didn't say you could post those! :P
Offline The_Beast
  • I like wood ಠ_๏
« Reply #278 on: Sat, 16 March 2013, 22:53:32 »
That solder joint on 14 looks a bit small don't ya think?
I am dissapoint
Offline SmallFry
« Reply #279 on: Sat, 16 March 2013, 23:09:47 »
It was the angle I took the picture at. The joint is solid.
« Reply #280 on: Sun, 17 March 2013, 08:00:45 »
He just has way too much solder on the rest of the joints, so it looks like too little in comparison.
:P
« Reply #281 on: Sun, 17 March 2013, 09:07:51 »
Yes, generally too much.  Thankfully keyboards are very forgiving.
Offline Tarzan
  • formerly known as Greystoke
« Reply #282 on: Sun, 17 March 2013, 09:41:13 »
I'm sure I'll have another round of questions once I accumulate enough Poker/Phantom parts to attempt a build, but my question today is about the complete opposite end of the keyboard spectrum; 122-key Unicomp keyboards.
Background: I want to use AutoHotKey to remap/add functions for some of the keys on a Unicomp 122-key Model M (#BO40B56).  I downloaded and installed AHK on my work laptop, seems to work fine and I tried a few sample scripts I've found online, the board works well using the PS2 port on the docking station.
Question: AHK suggests adding a new keyboard profile to the application once it's installed, to use as a template for key-mapping.  Are there sources for these templates already created for this 122-key unit?  I don't want to have to create one from scratch if there's a library of existing samples somewhere.
Offline Lunartuna
  • Good bye money!
« Reply #283 on: Sun, 17 March 2013, 16:42:02 »
Hey leave the guys soldering alone!
At least he solders, I just sit here thinking about it.
« Reply #284 on: Sun, 17 March 2013, 18:18:36 »
Just giving him a hard time.
Thinking about it won't get that solder melted! Get yourself an iron and some solder and start practicing. LOL.
Offline Lastpilot
  • Power stance
« Reply #285 on: Sun, 17 March 2013, 18:38:20 »
Offline Lastpilot
  • Power stance
« Reply #288 on: Sun, 17 March 2013, 19:07:51 »
Has anyone ever sold/made colored (anodized) aluminum plates that would fit a Filco board (i.e. with 2 holes for the led's?) Or is it just simpler to break off the led's.
« Reply #289 on: Sun, 17 March 2013, 19:19:48 »
The Phantom ANSI125 plate would fit a Filco. It was black anodized aluminum. And had holes for the LEDs.
Offline ping111
« Reply #290 on: Sun, 17 March 2013, 20:49:22 »
The Logitech LX-300 - is it mechanical?
In My Possession:
Max Keyboard Nighthawk X8 Mechanical Keyboard - Cherry MX Brown - Blue LED Backlighting
Wanted:
KBTalking PURE - Tenkeyless - Cherry MX Brown - Green LED Backlighting
Offline The_Beast
  • I like wood ಠ_๏
« Reply #291 on: Sun, 17 March 2013, 20:53:16 »
Nope, logitech only has one mechanical keyboard on the market right now, the G710
    • youtube
« Reply #292 on: Sun, 17 March 2013, 21:03:38 »
What about the Filco controller though? Phantom plates don't accommodate to that, that's why I designed my universal TKL plates. Fits both Filco and Phantom, but it just hasn't been anodized yet.
Offline Lunartuna
  • Good bye money!
« Reply #293 on: Mon, 18 March 2013, 17:26:57 »
On the KBT Pure, is there anyway to move the arrow cluster on the function layer to where they are on the Poker?
Offline ping111
« Reply #294 on: Mon, 18 March 2013, 17:30:27 »
Are there CoolerMaster StormTrigger TKL keyboards with non-proportional backlighting?  The proportions, for switch/backlight, is red/red, blue/blue, and brown/white.
In My Possession:
Wanted:
« Reply #295 on: Mon, 18 March 2013, 17:46:35 »
Can you clarify? This question doesn't make a lot of sense to me.
« Reply #296 on: Mon, 18 March 2013, 17:47:25 »
Unfortunately, no. What you want is called GH60. :P
« Reply #297 on: Mon, 18 March 2013, 17:49:33 »
That shameless promotion. I'm loving it haha.
« Reply #298 on: Mon, 18 March 2013, 17:51:55 »
Is there something special about "the cheat" keyboards that makes them so expensive? Or were there limited quantities sold?
Ergodox
My WTB Thread
« Reply #299 on: Mon, 18 March 2013, 17:53:31 »
Check this link out. It's a Korean custom and there's a limited amount of them.
