Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6214072 times)
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #600 on: Mon, 08 April 2013, 08:31:46 »
Well of course that isn't a good price for only a spacebar. I was merely giving an example not really suggesting you should buy it.
Yes GMK can make 7x spacebar. It is hard to say if the current buy will succeed but it is not looking great right now.
Offline SmallFry
« Reply #601 on: Mon, 08 April 2013, 09:46:37 »
Would that be a POM spacebar also, or is it ABS?
Offline llovro
« Reply #602 on: Mon, 08 April 2013, 11:03:08 »
Yeah, sorry. I didn't take your example as a suggestion. Still thanks.
Offline Internetlad
« Reply #603 on: Mon, 08 April 2013, 11:08:47 »
Aliens?
"Beep . . . Beep . . . Beep" -Sputnik I
« Reply #604 on: Mon, 08 April 2013, 11:09:59 »
Generally Cherry use the same material for the entire set so it should be POM, but occasionally they use ABS so I can't make a gaurantee.
If you're looking for aliens maybe you should try some space invaders.
Offline codyeatworld
« Reply #605 on: Mon, 08 April 2013, 11:25:30 »
I'm about to ship out some Dolch Pac caps, how should I pack it? As in should I really wrap up the spacebar and large keys? I've been sent keys in some clever packages.
I have never shipped anything in my life... Besides RMA :)
From cali to florida
« Last Edit: Mon, 08 April 2013, 11:29:21 by hellocodes »
« Reply #606 on: Mon, 08 April 2013, 11:34:03 »
Bubble wrap and baggies. Put everything in a bubble mailer. Or if you're really paranoid, those little flat-rate boxes, wrapping, and stuffing like plastic bags/peanuts/styrofoam.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #607 on: Mon, 08 April 2013, 11:43:13 »
So as a general consensus do you guys prefer heavy or light keyboards for something that does not commute?
Offline inteli722
« Reply #608 on: Mon, 08 April 2013, 11:46:55 »
I like heavy keyboards for stationary keyboards (and mobile keyboards). They feel more solid/well built.
Waiting for: Phantom Plate
« Reply #609 on: Mon, 08 April 2013, 16:39:43 »
I think merely being heavy isn't the whole story.  More than anything else, they need to be solid.  A stable footing makes it feel planted.  That means an even base with good rubber feet.  Good construction is also imporant.  Everything needs to be tight so it doesn't rattle, ping and vibrate.  With those two things, the keyboard could be fairly light and still "feel" like a heavy board.
Offline Internetlad
« Reply #610 on: Mon, 08 April 2013, 17:46:10 »
weight often denotes quality. Best way to test the quality of a power supply is to pick up the cables in one hand and the supply in the other.
On the other hand I've seen Chinese electronic knockoffs with a chunk of metal in them to make them seem more sturdy haha.
« Reply #611 on: Mon, 08 April 2013, 17:50:54 »
That used to be true, it's not true at all anymore.
Offline Gupgup
« Reply #612 on: Mon, 08 April 2013, 18:00:14 »
How do I get power to the esc key led on a Poker when both of the silver O rings came off? No solder is able to stick when these are off, as you of course know :D
Gupgup
Offline Melvang
« Reply #613 on: Mon, 08 April 2013, 18:21:25 »
I am not really an electronics guy but I do have a basic knowledge.  Correct me if I am wrong guys.  But I think you will have to scratch off the top protective layer above the trace and solder a wire from the trace to the LED leads.  To my knowledge Radio Shack sells fiber glass abrasive pens which this job is pretty much what they were made for.  I could be way off base but that would be where I would start thinking of heading.
Melvang
Offline Gupgup
« Reply #614 on: Mon, 08 April 2013, 18:24:41 »
Melvang
Thank you! I thought this could be done, as someone has told me this before, but I didn't know for sure!
I'll be getting one of those very soon for sure. Is there any other way?
Gupgup
« Reply #615 on: Mon, 08 April 2013, 19:08:33 »
Melvang
Gupgup
I thought this was a "Simple Questions" thread... :P
Offline Gupgup
« Reply #616 on: Mon, 08 April 2013, 19:14:36 »
Melvang
Gupgup
Well I didn't see a "Harder Questions" thread so I resorted to here :D :p
« Reply #617 on: Mon, 08 April 2013, 19:33:08 »
Melvang
Gupgup
Right?? These kids and they're absurdly long questions. I don't even know where to look for an answer. Help me jdcarpe!!
« Reply #618 on: Mon, 08 April 2013, 19:46:36 »
Melvang
You're correct.  You can do it with an Exacto knife as well, it's just recommended that you be careful with it when doing so.  If you want a quick and dirty solution and can see the traces, you can just bridge the trace with a small gauge wire where the land broke off to where the trace(s) leads.  I had a land pop off of my RK-9000 when I was swapping switches and had another with a questionable land.  I just did the wire bridge instead of exposing the trace on the PCB.
Offline affect656
« Reply #619 on: Tue, 09 April 2013, 03:53:47 »
Recently moved to Seoul, Korea from the states. Where/what exact places/deals can I take advantage of while I'm here for the next year that I couldn't if I was located back state side? Like what exactly is more readily available living here?
I like linear.
Offline llovro
« Reply #620 on: Tue, 09 April 2013, 08:39:34 »
Would it be somehow possible to make a spacebar like this:
« Reply #621 on: Tue, 09 April 2013, 08:44:37 »
Are you asking about the graphic? You could conceivably get a white spacebar and dyesub something like that on it.
Offline llovro
« Reply #622 on: Tue, 09 April 2013, 08:47:19 »
Yeah about the graphics. It sucks that I can't get this done on black spacebar :( You can't dyesub light stuff on dark stuff or something like that, right?
Offline Tarzan
  • formerly known as Greystoke
« Reply #623 on: Tue, 09 April 2013, 08:47:39 »
I think WASD keyboard offers a service for silk-screening an image on keycaps.  Look at the Walt Di$ney image spanning multiple keys in the link:
http://www.wasdkeyboards.com/index.php/gallery2/customer-creations
(My favorite: the green on black keyboard with the SPAAAACE key...  :-)  )
« Reply #624 on: Tue, 09 April 2013, 08:50:49 »
Correct. It needs to be dark on light.
« Reply #625 on: Tue, 09 April 2013, 08:52:02 »
Some people have been able to somehow dyesub onto dark keys, maybe by doing a double shot first, then dyesubbing the "first shot," while the "second shot" is the dark base.
Except that WASD only does laser etching. So you have a monochrome image. No color.
Offline lazerpointer
  • ya gotta stay phresh
« Reply #626 on: Tue, 09 April 2013, 15:15:08 »
Is the Ducky DK9087G2 PRO really PCB mount? I thought all the Duckys were plate mount.
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=215
^^^ It's listed here as "Switch Mount Type --- PCB"
i type, therefore i geekhack
Offline Gupgup
« Reply #627 on: Tue, 09 April 2013, 15:55:36 »
I have two simple questions!
1) Does the ErgoDox have LED compatibility?
2) Where does everyone get their LEDs from?
Thanks :D
Gupgup
Offline SmallFry
« Reply #628 on: Tue, 09 April 2013, 16:08:03 »
The eDox has 2 LEDs, FN(I think) and Caps Lock.
Get LEDs from Digikey etc.
« Reply #629 on: Tue, 09 April 2013, 16:10:02 »
According to these pics, it's plate mounted. And I've confirmed this with missalaire who owns that board.
2) I imagine McMasterCarr would have them as well. Seems like a lot of people order from eBay though.
« Last Edit: Tue, 09 April 2013, 16:31:13 by CPTBadAss »
Offline SmallFry
« Reply #630 on: Tue, 09 April 2013, 16:13:08 »
McMaster Carr doesn't have them. They have small bulbs, but those won't work with a keyboard.
« Reply #631 on: Tue, 09 April 2013, 16:14:24 »
Thanks bro :D. Can you elaborate on the etc in your comment before? I'm not familiar with sites like Digikey.
« Reply #632 on: Tue, 09 April 2013, 16:15:49 »
I get my LEDs from eBay. Seller called IC.TOUCH. He ships fast.
Get the 2x3x4 rectangular LEDs. Water clear.
Offline WhiteFireDragon
    • youtube
« Reply #633 on: Wed, 10 April 2013, 04:46:04 »
I get my LEDs from mouser and digikey if I need to buy them by specs, mainly wavelength and brightness. You also get them faster. Ebay is by far the cheapest, but most are from China and you'll have to wait a couple weeks. You can't really pick and choose which brightness you want, and you can't choose which shade of a color you want (wavelength). US does not have purple or pink, and only ebay has pink.
mcmaster carr has tons of selection more for hardware, digikey and mouser are better for electronics.
« Last Edit: Wed, 10 April 2013, 04:47:42 by WhiteFireDragon »
Offline Tarzan
« Reply #634 on: Wed, 10 April 2013, 07:40:15 »
Second the recommendation for Mouser, they have fantastic customer service.  I also ran across the site below when searching for specialty LEDs, they are based in Missouri and seem to have a decent selection.  Haven't ordered from them, so I can't speak to delivery times/service.
http://www.superbrightleds.com/cat/through-hole/
They don't have purple, but they do have violet, and pink:
http://www.superbrightleds.com/cat/through-hole/filter/Color,Violet,136,4646:
http://www.superbrightleds.com/moreinfo/through-hole/5mm-pink-led-45-degree-viewing-angle-300-mcd/295/1222/
A bit pricy, though...
« Reply #635 on: Wed, 10 April 2013, 08:28:48 »
I use Digikey
Offline MJ45
  • HHKB Pro
« Reply #636 on: Wed, 10 April 2013, 10:13:39 »
What spec deter mime's the LEDs brightness fv or wavelength or both?
Offline babyhands
« Reply #637 on: Wed, 10 April 2013, 10:17:22 »
Are we still doing simple questions simple answers? if so:
What is this sticker mod i am seeing on some keyboards? Like putting stickers under the switches or something? What does this do? And what does lubing the spring do? It seems like lube on a spring would do nothing?
« Reply #638 on: Wed, 10 April 2013, 10:37:39 »
The stickers go between the top and bottom halves off the switch housing. It reduces movement of the switch housing itself, which eliminates any "wobble" of the switch.
Lubing the sliders of the stem makes the switches feel smoother, and reduces or eliminates any "grittiness" feel of the switches. Lubing the springs reduces or eliminates any squeaking sound coming from the spring movement inside the switch.
Offline Melvang
« Reply #639 on: Wed, 10 April 2013, 10:40:03 »
What branch was/are you in JD?
« Reply #640 on: Wed, 10 April 2013, 10:46:47 »
Air Force. 1N373A. E-5/SSgt. Also, thank you for your service, Petty Officer! :D
Offline Melvang
« Reply #641 on: Wed, 10 April 2013, 10:59:04 »
Thank you sir.  I was an Avaition Structural Mechanic on SH-60 F and SH-60 H Seahawks.  It may be a 30 year old design on the airframe but it is still an amazing bird.
Offline Melvang
« Reply #642 on: Wed, 10 April 2013, 11:00:36 »
So what is the prefered method for attaching images to a post?
Offline Jocelyn
  • 조셀린
« Reply #643 on: Wed, 10 April 2013, 11:01:47 »
Host image then {img}http://link.jpg{/img} but change curly brackets to square brackets.
« Last Edit: Wed, 10 April 2013, 11:03:43 by Jocelyn »
« Reply #644 on: Wed, 10 April 2013, 11:03:35 »
Lol. Didn't work.
Code: [Select]
[IMG]http://thisisyourhost.com/whatever.png[/IMG]
Offline Jocelyn
  • 조셀린
« Reply #645 on: Wed, 10 April 2013, 11:04:32 »
Lol. Didn't work.
Yeah, I'm on Tapatalk so I couldn't preview. I fixed it :)
What's funny is that your code shows up as a photo on Tapatalk lol
« Last Edit: Wed, 10 April 2013, 11:06:07 by Jocelyn »
« Reply #646 on: Wed, 10 April 2013, 11:06:42 »
You can also specify the height and width of your image, or, if you just specify one of the other, the system will adjust the size based on that dimension and keeping the ratio.
For instance:
Code: [Select]
[IMG width=320 height=240]http://thisisyourhost.com/whatever.png[/IMG]
[IMG width=320]http://thisisyourhost.com/whatever.png[/IMG]
[IMG height=240]http://thisisyourhost.com/whatever.png[/IMG]
Now that is funny. :)
Offline SmallFry
« Reply #647 on: Wed, 10 April 2013, 11:11:19 »
For instance:
Code: [Select]
I just type the code out when I'm on my tablet. Works easier for me.
« Reply #648 on: Wed, 10 April 2013, 11:13:19 »
WTF are you talking about? :P
Offline SmallFry
« Reply #649 on: Wed, 10 April 2013, 11:14:28 »
Like on the forum you can hit the button and paste a link or on mobile there's a button to host. I just type the tags out.
