Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6214170 times)
Offline Jocelyn
  • 조셀린
« Reply #900 on: Sat, 20 April 2013, 22:45:46 »
They are the same. Mint Green is the color that CC calls them. Green is the shade of green I got from wikipedia. The actual color green. And eth0s has a WASD set with a Skull that's octopink. It looks super hot.
I figured it was something like that. Thank You :)
Offline esoomenona
  • Gnillort?
« Reply #901 on: Sat, 20 April 2013, 22:52:49 »
Best WASD is bet.
Offline Turbo Slaab
« Reply #902 on: Sat, 20 April 2013, 22:58:43 »
I like that candy corn! The orange on mine is really dark, almost red.....
Looking for CC's!
Offline Dubsgalore
« Reply #903 on: Sat, 20 April 2013, 23:00:25 »
stop moose!  :(
you make me soo sad haha
Offline esoomenona
  • Gnillort?
« Reply #904 on: Sat, 20 April 2013, 23:08:28 »
Hush, little baby. Don't say a word.
Moosie's gonna type on his clacks some more.
And if that Candy Corn turns red
Moose is gonna find Slaab and off with his head.
Offline Dubsgalore
« Reply #905 on: Sat, 20 April 2013, 23:18:24 »
hehe
that nursery rhyme has me in tears
Offline Turbo Slaab
« Reply #906 on: Sat, 20 April 2013, 23:22:29 »
Lmao
Looking for CC's!
Offline Bencze
« Reply #907 on: Sun, 21 April 2013, 08:45:50 »
I'm thinking to switch the Caps Lock and Backspace keys on my QFR. Just learning touch typing and read about it somewhere, and it seems like an excellent idea. The problem is, on this keyboard Caps Lock has a led in it, and the keys don't even match.
Any idea how could I proceed? Guess I could just switch them from software, the label will be very annoying but only as long as I look at it, but the led would be annoying.
Anyone with some experience on how to solve this? Maybe I can just disconnect the led? Didn't look under the key so far, wouldn't want to break something, not sure how the led is connected...
-= QFR w/ mx blues - HPE87 w/ mx browns - Ducky 1087XM w/ green alps =-
Offline best.eu
« Reply #908 on: Sun, 21 April 2013, 08:58:32 »
You could just put some tape over the led really.
Offline ping111
« Reply #909 on: Sun, 21 April 2013, 09:00:03 »
You know that just switching the keycaps won't change the input, right?  I switched my capslock and my backspace a while ago, but I did it only on software.
In My Possession:
Max Keyboard Nighthawk X8 Mechanical Keyboard - Cherry MX Brown - Blue LED Backlighting
Wanted:
KBTalking PURE - Tenkeyless - Cherry MX Brown - Green LED Backlighting
Offline Bencze
« Reply #910 on: Sun, 21 April 2013, 09:03:11 »
I can switch from software and that works somewhat. But for starters I will keep pressing them vice versa.
Ideal solution would be to get a backspace key that says caps lock and a caps lock key that says backspace :) not sure if there is such a thing. Maybe blank key caps for both, but I am not sure whether I can buy 2 keys somewhere.
A bit worse solution is to disable caps lock led.
A bit worse to just tape it off as suggested, or ignore it, not too elegant...
« Reply #911 on: Sun, 21 April 2013, 10:25:56 »
You would have to get custom caps made and I believe the only WASD keyboards would do custom caps where you could swap the texts on a Caps Lock and Backspace. I'm sure getting just 2 caps done would be a pain and the shipping from California to Hungary would probably be a nightmare. You could try asking around for people who have Blank/Otaku sets and see if they'll part with their Backspace/Delete.
Since you're in the EU, you could check out QWERKeys and see if they offer any solutions for your problem.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #912 on: Sun, 21 April 2013, 19:02:21 »
Was the Sanctuary set ABS or PBT?
Offline Jocelyn
  • 조셀린
« Reply #913 on: Sun, 21 April 2013, 19:04:59 »
Both I think
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #914 on: Sun, 21 April 2013, 19:14:28 »
Depends on which version it is.  I think there was a Korean spec ed that was dye-subbed PBT and the one done here which was DS abs.
« Reply #915 on: Sun, 21 April 2013, 19:15:09 »
Both I think
Yes you're right. There was a Dyesub PBT and a Doubleshot ABS set.
Damnit KingKlaxon, why you post so fast :P
Offline SmallFry
« Reply #916 on: Sun, 21 April 2013, 19:15:56 »
The dye sub kit was sold only with the LZ-SE's. 150 sets, and I believe $150 but not positive on the price.
Offline Dubsgalore
« Reply #917 on: Sun, 21 April 2013, 19:35:54 »
how many switches should i order for my winkeyless GH60?
i counted 58 for a winkeyless setup, but is that correct?
and then for a 1.5x layout, how many switches should i order?
i counted 60...amirite there too?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #918 on: Sun, 21 April 2013, 19:41:28 »
Just order 70 or even 80, it's never a bad thing to have a few extra switches. If you order exact amounts, you may have a bad time
Offline Dubsgalore
« Reply #919 on: Sun, 21 April 2013, 19:49:12 »
i ordered 70 mx whites for my winkeyless GH60, from Communist,
and for the my second, should i just say 70 also? its gonna be the 1.5x ANSI layout
« Reply #920 on: Sun, 21 April 2013, 20:15:03 »
Sure, like The_Beast said, extras are good incase the switches are bad or you mess up.
Offline Bencze
« Reply #921 on: Mon, 22 April 2013, 08:01:42 »
Thanks for the earlier answers, I will just get blank caps for caps / backspace, cheapest option and it's just fine. I hope I can remove the caps without breaking something.
Other problem:
I had problems with some keys on my dk1087xm. Actually it was the case coming apart and after some wrestling with it no keys get stuck anymore.
But - keys are so difficult to remove on this one, non-character keys i mean, I removed the right Ctrl and a corner of that little plastic thingy that goes into the switch broke. Is it possible to remove such an ALPS switch, if yes how (what tool? i don't have special tools), and if it is possible to just replace it? (I mean everything is possible but realistically, can I do it at home or i should just leave it as it is)
sorry for the stupid questions.
Offline bavman
« Reply #922 on: Mon, 22 April 2013, 08:05:33 »
You broke plastic on the switch itself of the keycap? If its the keycap then you'll have to source another one somewhere. If its the switch then you can desolder it and buy another one (not sure from where) and solder the new one on.
Offline inteli722
« Reply #923 on: Mon, 22 April 2013, 08:06:06 »
Other problem:
To remove an ALPs switch (or any plate-mounted switch for that matter (besides plates specially designed, see Phantom plate)), you have to pull the case apart, and desolder the entire board. While you're at it, you might as well replace every switch with matias switches.
Waiting for: Phantom Plate
Offline Bencze
« Reply #924 on: Mon, 22 April 2013, 08:26:19 »
Just the keycap, there is a little plastic pin on it, not sure how it's called that goes into the middle of the switch (in the hole), a little piece broke and stayed inside the switch. I used the basic cap remover I got with my QFR, but for the wider caps it doesn't work very well (grasping top and bottom instead of sides), next time I should probably just try and remove these kind of keys with a piece of string or something.
In this case it's easier to just try and remove it with a needle, I never did any soldering, it's not important enough to learn now. :) thanks.
« Reply #925 on: Mon, 22 April 2013, 08:50:31 »
Like I said before, no need to apologize. This thread is for question. There's very few stupid questions :D
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #926 on: Mon, 22 April 2013, 11:10:59 »
You do not need to desolder entire board to replace one switch, what the hell are you talking about?
For Alps you can have this problem where the keycap mount breaks inside the stem, much like occasionally the stem will break off on MX switch insid the keycap. How I solve that particular problem is like a cork, take a tiny hook or eye screw like for hanging a picture, thread it into the piece you need to remove and pull, just like a cork. It has a high success rate for me.
Offline L4yercake
« Reply #927 on: Mon, 22 April 2013, 18:09:24 »
Does anyone have the measurements for the switch plate opening? I am unable to locate the thread in which it was posted.
« Reply #928 on: Mon, 22 April 2013, 19:08:16 »
This is a little different, but I think you can get what you need:
Offline Jocelyn
  • 조셀린
« Reply #929 on: Mon, 22 April 2013, 19:30:58 »
What kind of phone am I using? :)
Offline bear95
« Reply #930 on: Mon, 22 April 2013, 19:33:36 »
A smart phone
Offline SmallFry
« Reply #931 on: Mon, 22 April 2013, 19:40:37 »
A smart phone
A smart answer. I think natively, isn't it the Note 2 or something that supports that dual pane phone? Otherwise since its Android, it could be a custom ROM.
Offline ComradeSniper
  • HHKB Pro
« Reply #932 on: Mon, 22 April 2013, 20:53:14 »
Can I purchase only a Poker plate from the GH60 group buy? How difficult is removing the cherry stabs on the Poker PCB and installing Costar stabs to the plate?
Offline Jocelyn
  • 조셀린
« Reply #933 on: Mon, 22 April 2013, 20:54:45 »
1. Yes
2. I'm not 100% sure, but I would think it would be easy. I believe WFD has a video showing how to apply each kind.
Offline esoomenona
  • Gnillort?
« Reply #934 on: Mon, 22 April 2013, 20:55:31 »
Yes, you can. Removing the stabs is easy. Desoldering everything will be the harder part.
  • HHKB Pro
« Reply #935 on: Mon, 22 April 2013, 20:57:45 »
Alright, looks like I'll be hopping in on the group buy last minute and learning how to solder!
Offline bear95
« Reply #936 on: Mon, 22 April 2013, 21:03:10 »
What would you guys consider the best way of practicing to properly solder?
« Reply #937 on: Mon, 22 April 2013, 21:05:07 »
Buy old electronics like a VCR or a cheap keyboard and just start learning. People almost always link this thread as well. I honestly just got thrown in one day. Was at work and was told to do it so I just started to figure it out.
  • HHKB Pro
« Reply #938 on: Mon, 22 April 2013, 21:28:33 »
Awesome guide, thanks.
Offline SmallFry
« Reply #939 on: Mon, 22 April 2013, 22:45:04 »
Wonder who told you the VCR trick... :P
Offline gulu
« Reply #940 on: Tue, 23 April 2013, 00:45:06 »
hi guys, i need advice on my decision for a new keyboard,
should i go for a ducky 9087 g2 pro pbt for around 130usd or cm storm quickfire stealth around 105usd + blank pbt keycaps around 49usd ?
i liked the blank key caps for the quickfire stealth but i think it is abs not pbt, yet was wondering at this price comparison would the ducky be a better buy due to better build quality (than the quickfire)?
thx in advance
« Reply #941 on: Tue, 23 April 2013, 01:22:15 »
thx in advance
I'm not personally familiar with ducky's build quality, but I have several quick fire rapids, and the build quality on them is very good. My only complaint is they have single-sided PCB's.
Bytheway, if you want to replace the keycaps, just buy a quickfire rapid for much cheaper.
The stealth does come with ABS keycaps.
Offline remedyhalopc
« Reply #942 on: Tue, 23 April 2013, 06:10:35 »
Okay. We just installed these crazy cool digital 4k projectors at my theater and my job becomes ingesting movies/building playlists/maintenance instead of threading/building/tearing down 35mm film. We use a command center to control all of this, and it's ridiculous. We spent maybe a cool 2 million for the projectors/audio processors/server tower/computer/IPS monitors and they use a $5 membrane keyboard. It's already driving me nuts. I need a cheap full size mech keyboard. Sound is not an issue. Prefer blues or an alps equivalent. I'd like to spend less than $20 for it, so used is my only option. No crazy layouts, because my manager will be using it too.
I'm sad that I won't get to work with 35mm, but I'm also happy I won't be running into issue after issue with our ****ty projectors that are always having something go wrong. Also the quality is BANANAS.
« Reply #943 on: Tue, 23 April 2013, 06:43:30 »
thx in advance
If this is your first mechanical keyboard, I'd recommend getting the QFR so you get a taste of what the boards are like without spending too much. QFRs are a really good value.
If you're ok with an Alps board, a Del AT101W can be found for around $20. It has tactile black Alps. I got my Focus FK-2001 for $20 as well.
« Reply #944 on: Tue, 23 April 2013, 07:08:06 »
Those are clicky, right?
How high is the actuation on those?
« Reply #945 on: Tue, 23 April 2013, 07:19:26 »
Tactile black Alps aren't Clicky. But the Focus has Clicky White Alps. The actuation is at the top, it's almost instantaneous.
« Reply #946 on: Tue, 23 April 2013, 08:37:52 »
Where can I find a keyboard cover for a Ducky DK9008 Shine II
Something like this but maybe with sides also?? My work is somewhat dusty and I'd like to cover it at night when I'm not here. Also the cleaning people are awful and I don't want them spraying/wiping random cleaners over the keys...
« Reply #947 on: Tue, 23 April 2013, 08:40:08 »
EliteKeyboards sells Keyboard Roofs. You could try those.
« Reply #948 on: Tue, 23 April 2013, 08:48:17 »
roof not cover...maybe I was just using the wrong keyword......you truly are a bad @$$ thanks  ;D
« Reply #949 on: Tue, 23 April 2013, 08:52:25 »
Haha, thanks. Glad to help :D
