Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6010302 times)
0 Members and 6 Guests are viewing this topic.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1250 on: Fri, 03 May 2013, 09:25:42 »
Right sort of the difference between Costar and iOne. Costar cheap shortcutting is the exception, while at iOne it is almost the rule. Though exactly right, if a customer comes in and says I want it build to D grade, OEM will do it but will probably not be so quick to say yes we make that like they would their A grade customers.
Offline eRadicatedZomBiE
  • It's OK, I'm A Doctor.
« Reply #1251 on: Fri, 03 May 2013, 12:43:42 »
I'm look for a certain stabilizer:
I keep seeing multiple names for them, can you help me with a correct name and where to buy them? Sorry if this is a re-post. I checked the search bar for the answer but every one of them show these:
and for a bonus question, I'll throw a poll question out: which one is better?
CM QFR | WASD V1 | Flico MJ2 LE Blue | Ducky 78 | Ducky DK9008G2 Pro LE  |Phantom |
Ergodox
My WTB Thread
« Reply #1252 on: Fri, 03 May 2013, 12:47:05 »
Both are plate mounted. Top pic is Plate Mounted Cherry. Bottom pic is Plate Mounted Costar. Like most things in keyboards, your last question is subjective. There's no "better". I prefer Costars slightly.
« Reply #1253 on: Fri, 03 May 2013, 12:47:43 »
The ones you are looking for are Cherry PCB mount stabilizers.
And they are both good, it's just personal preference! :D
Edit:
There is no plate in that top picture, sir. That is the PCB! :P
« Last Edit: Fri, 03 May 2013, 12:49:29 by jdcarpe »
« Reply #1254 on: Fri, 03 May 2013, 12:49:09 »
Like JD said, it's personal preference. I know a lot of people say that swapping caps on Costar stabs is a pain since you need to deal with the little inserts. The Cherry mounted stuff is a bit less work. But I find the Costar stabs to be a little crisper and it makes my MX Blues feel nice. ^__^
Offline Turbo Slaab
« Reply #1255 on: Fri, 03 May 2013, 12:49:51 »
Not a huge fan of cherry stabilizers unless I'm removing keycaps. Too mushy for my tastes.
Looking for CC's!
« Reply #1256 on: Fri, 03 May 2013, 13:07:43 »
Sorry about my use of "better" I just meant which do you prefer.
Ergodox
My WTB Thread
« Reply #1257 on: Fri, 03 May 2013, 13:11:18 »
Brand name. Filco is seen as the best quality, non-custom keyboard by some. But in reality, it's the same as a CM storm except that the Filco is a premium brand and demand a higher price to maintain a level of prestige among buyers
I thought the Filco had a slightly nicer PCB.
Um.. I'd say more than slightly... the QFR pcb is the absolute worst PCB I've ever worked with..
« Reply #1258 on: Fri, 03 May 2013, 13:12:53 »
cherry stabs create more points of friction, and the left and right doesn't go down as closely when you bottom the key out, so they grind against the sides.
Offline Kayliss
« Reply #1259 on: Sat, 04 May 2013, 13:02:29 »
Any suggestions on where to find Topre colored keycap sets other than EK? These for example http://elitekeyboards.com/products.php?sub=access,toprekeys&pid=xf0100kt11n
Offline Turbo Slaab
« Reply #1260 on: Sat, 04 May 2013, 13:04:27 »
You could try the classifieds. I believe EK is the main, if not the only, distributor. Hence the high prices.
Looking for CC's!
Offline Kayliss
« Reply #1261 on: Sat, 04 May 2013, 13:21:45 »
Thanks I was afraid that may be the case.
Offline DasHHKBProM
« Reply #1263 on: Sat, 04 May 2013, 13:51:09 »
So I was looking to purchase the hhkb silent from EK, then I saw this youtube video
in comparison to the keys and the abs keyboard casing , looking at the one on the left, it is hella yellow and imo ugly as hell
though these may be the regular hhkb and not the type s anyone know how long before it turns this shade of yellow if only exposed to florescent office lights
that being said has any one who ones a type s had a problem with their white keyboard turning yellow
I really want the type s for work, ....wish it came in black  :mad:
« Reply #1264 on: Sat, 04 May 2013, 13:51:33 »
has anyone seen an Orange PBT set anywhere?
I've never seen a PBT set that's orange. The Orange Crush Madness set might be in PBT though.
I think the case is beige and the color balance in that video is horrible. If you do buy old boards though, they do yellow. But you can reverse it by using retr0brite
« Last Edit: Sat, 04 May 2013, 14:04:19 by ray4jc »
Offline DasHHKBProM
« Reply #1267 on: Sat, 04 May 2013, 14:20:48 »
Hmm.... do you know off hand if the fastner locations are the same on type s as reg pro2 I might just swap case and keys.
20907-0
« Reply #1268 on: Sat, 04 May 2013, 14:32:06 »
Thanks guys... I will be ordering the orange keys along with the stupid $200 worth of plastic flowers for the stupid windows that my mom wants.
« Reply #1269 on: Sat, 04 May 2013, 14:32:36 »
I have only seen an HHKB once in person and it wasn't mine so I couldn't take it apart. Hopefully someone else knows. :D
Offline Jocelyn
  • 조셀린
« Reply #1270 on: Sat, 04 May 2013, 14:34:21 »
Get Red Thick Cherry PBT instead. I have the blanks and love them :)
http://item.taobao.com/item.htm?spm=a230r.1.0.110.26urvG&id=20744664158
Offline WhiteFireDragon
    • youtube
« Reply #1271 on: Sat, 04 May 2013, 14:39:52 »
Red blanks? Anywhere with 1 red blank, thick PBT top row? Need it for the Esc key.
Offline Jocelyn
  • 조셀린
« Reply #1272 on: Sat, 04 May 2013, 14:42:04 »
I have looked all over Taobao several times and they ALL have stuff printed on them. You'd think they'd keep some blank, but noooooooo. I'll let you know if I find any in the future...
Offline linziyi
  • The one with many questions
« Reply #1273 on: Sat, 04 May 2013, 15:20:34 »
Question: how does topre feels like?
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline SmallFry
« Reply #1274 on: Sat, 04 May 2013, 15:22:40 »
Sex.
« Reply #1275 on: Sat, 04 May 2013, 15:23:37 »
« Reply #1276 on: Sat, 04 May 2013, 15:25:09 »
This has been asked a lot of times but to me, they feel like rubber domes with a solid bottom out instead of mushy. They also have a distinct actuation point in the middle. But this is subjective and will feel different to everyone. If you're viewing this thread, search for "Topre" and see other comments that people have said about them.
Offline Turbo Slaab
« Reply #1277 on: Sat, 04 May 2013, 15:27:01 »
The best description I was told, was that it felt like clay breaking down when you press it. The resistance at the top and it just falls after that.
Looking for CC's!
Offline linziyi
« Reply #1278 on: Sat, 04 May 2013, 15:33:31 »
Just got my QF TK couple days ago, any suggestions on topre keyboard? (Poor guy here, maybe not suitable for buying topre? I heard they are more expensive.)
Ducky DK9008G2 Pro
« Reply #1279 on: Sat, 04 May 2013, 15:35:34 »
An HHKB is $270 on Elitekeyboards.com and a Realforce is $240..If you're worried about price, I would shy away from buying Topre boards.
Offline Jocelyn
  • 조셀린
« Reply #1280 on: Sat, 04 May 2013, 16:05:43 »
Get one of these :P
http://geekhack.org/index.php?topic=43134.0
Offline Tym
« Reply #1281 on: Sat, 04 May 2013, 16:43:29 »
If anyone could help me I need the length and widths of the 6.25x and 7x space bars from the top down, thank you!
Offline Tym
« Reply #1282 on: Sat, 04 May 2013, 16:45:29 »
In mm please!
Offline Rule16
  • R.I.P. SmallFry
« Reply #1283 on: Sat, 04 May 2013, 17:36:48 »
Do the Ducky Shine II and Year of the Dragon have same build quality? Or is year of the Dragon better?
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
« Reply #1284 on: Sat, 04 May 2013, 17:38:23 »
Nah it's the same build quality Year of the Dragon is just a promotional branded version of a Shine 2
Offline SmallFry
« Reply #1285 on: Sat, 04 May 2013, 17:47:40 »
In mm please!
What profile?
Offline Rule16
  • R.I.P. SmallFry
« Reply #1286 on: Sat, 04 May 2013, 17:55:10 »
Sweet thanks, I might end up getting a Filco instead anyways... was just curious.
Dvorak Only Zone
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #1287 on: Sun, 05 May 2013, 00:39:28 »
Does the GH community have their own Farcebook page?
Offline ComradeSniper
  • HHKB Pro
« Reply #1288 on: Sun, 05 May 2013, 01:07:07 »
Offline WatchMaker
« Reply #1289 on: Sun, 05 May 2013, 02:41:07 »
do the keyboards with 2 USB plugs have 100% NKRO ?
can anyone vouch?  i ask bcuz ive seen product not live up to the claims they made.
btw i read this post: http://geekhack.org/index.php?topic=10063.30
but it was written back when keyboards had 1 USB
Offline Melvang
« Reply #1290 on: Sun, 05 May 2013, 03:20:53 »
I do believe that this all depends on the individual keyboard.  The Das Keyboard I have does have 2 USB plugs but the second one is just for the 2 USB ports on the side of the keyboard.
« Last Edit: Sun, 05 May 2013, 05:05:52 by Melvang »
Offline Melvang
« Reply #1291 on: Sun, 05 May 2013, 07:20:59 »
Any suggestions on what size hole to drill through the PCB on my Das Keyboard to and an LED to my ESC key?  Also, tips on soldering leads to the LED since there are not pads or trace for the LED would be greatly appreciated.  Going to move my HD activity LED from the case to behind my ESC key to go with my Ti Skull keycap.
Melvang
« Reply #1292 on: Sun, 05 May 2013, 10:01:00 »
Cool idea, that'll be tough.  I assume you don't have the tiny drill bits necessary to make usual hole diameters.  I'd say just go with the smallest you can find.  You're going to have to be REALLY careful, though.
Offline linziyi
« Reply #1293 on: Sun, 05 May 2013, 15:45:40 »
USB NKRO seems to have minor issue... Was using QF TK to type my paper in Latex, and instead of typing "\[", it types "\\[" in USB NKRO mode.
Ducky DK9008G2 Pro
Offline Dubsgalore
« Reply #1294 on: Mon, 06 May 2013, 08:32:52 »
Where can i find a Switch Top Remover Tool :)
« Reply #1295 on: Mon, 06 May 2013, 08:36:47 »
The_Beast made a run of them and the thread can be found here. I heard a rumor that he'd be doing a R2 but he's super busy between his GH60 case, lube station, and other stuff. If you see this Beast, I'm sorry I spoke for you in advance ^__^
I've also heard that tweezers can work in a pinch.
« Reply #1296 on: Mon, 06 May 2013, 08:39:14 »
and apparently forks too....I do not speak from experience but from reading the forum....
Offline esoomenona
  • Gnillort?
« Reply #1297 on: Mon, 06 May 2013, 08:40:03 »
Which keyboard do you refer to that has 2 USB plugs?
Offline Dubsgalore
« Reply #1298 on: Mon, 06 May 2013, 09:03:32 »
Hope there is a R2! :)
Offline Melvang
« Reply #1299 on: Mon, 06 May 2013, 10:09:10 »
what do you guys think?  Put the HD activity LED or the PC power LED behind the ESC key on my Das?
