Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6009194 times)
Offline FRD
« Reply #10150 on: Mon, 20 October 2014, 00:29:11 »
« Last Edit: Tue, 02 December 2014, 14:40:33 by FRD »
Offline whentheclouds
« Reply #10151 on: Mon, 20 October 2014, 05:32:34 »
the legends on that set you linked is downright ugly. having translucent legends just isn't worth it imo. good news is, there are plenty of alternatives depending on your budget. GMK doubleshot sets are generally unmatched in the aesthetics department, and also the quality department according to the majority here, but one will set you back a fair ~$120+. there are plenty of other cheaper non-GMK sets, but i'm not a fan of the ones that don't use Cherry legends and/or have SA profile
question: why has my post count stopped updating? this one did, but i'm sure i stayed at 110 posts for my last 3-5 posts. not a big deal, just curious if some part of the code is not working properly
« Last Edit: Mon, 20 October 2014, 05:34:24 by whentheclouds »
Offline trizkut
« Reply #10152 on: Mon, 20 October 2014, 05:40:29 »
posts in the off-topic forum don't count
« Reply #10153 on: Mon, 20 October 2014, 05:46:37 »
ooh, gotcha
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #10154 on: Mon, 20 October 2014, 06:55:17 »
The missing pin (pin 2) is not connected. It's a mini DIN-6 missing a pin and will likely work just fine with a USB adapter.
see here:
https://en.wikipedia.org/wiki/PS/2_port
Many lexmark IBMs are also missing pin6, which is also not connected.
It's physically incompatible with the PS/2 port.
Offline frosty
  • jukebox hero
« Reply #10155 on: Mon, 20 October 2014, 07:42:54 »
Has KBC/KBT/Vortex stop producing Pures already?
Offline BlueBär
« Reply #10156 on: Mon, 20 October 2014, 08:22:04 »
Probably since the Pure Pros came out but I don't think there ever was an official announcement.
Offline frosty
  • jukebox hero
« Reply #10157 on: Mon, 20 October 2014, 08:34:23 »
Thnx.
Offline Hordak
« Reply #10158 on: Mon, 20 October 2014, 14:43:11 »
Is it true that PFU will restart production of blank, colored keycaps for the HHKB & Realforce and if so, when?
« Reply #10159 on: Mon, 20 October 2014, 21:22:32 »
PFU (Pana Facom Usac) doesn't produce the keycaps for the HHKB, I am pretty sure Topre does. I don't think they will restart production, but I don't know for sure. Does anyone else know different?
« Reply #10160 on: Mon, 20 October 2014, 21:24:05 »
Topre does production.
They're not going to do anymore, since no manufacturers have ordered any.
If you can muster up a few thousand orders, let me know.
Offline exitfire401
  • The Force is Re/\l
« Reply #10161 on: Mon, 20 October 2014, 21:24:43 »
I've had a friend in Japan asking some store owners, haven't heard any good news on that front yet  :'(
Offline Hordak
« Reply #10162 on: Tue, 21 October 2014, 09:48:40 »
Ok thanks guys, that sucks. We should add it to massdrop.
Offline a_ak57
« Reply #10163 on: Tue, 21 October 2014, 13:38:05 »
Is the Poker II the kind of board that you can change stems/springs without soldering (just opening it from the top)?
« Reply #10164 on: Tue, 21 October 2014, 13:39:00 »
No, the board is plate mounted and doesn't have the specialized cutouts to allow for this swap.
« Reply #10165 on: Tue, 21 October 2014, 14:34:29 »
No, but the OG poker is. AKA the Poker X
Offline a_ak57
« Reply #10166 on: Tue, 21 October 2014, 14:41:09 »
Ah, I see.  I could have sworn I read something about the Poker being capable, and I guess that is indeed correct (just without the "II").  Thanks both of you.
Offline wes1099
  • Technology and Dog Enthusiast
« Reply #10167 on: Tue, 21 October 2014, 17:24:31 »
Where does one buy springs other than originative? Originative has been out of all except 55g and 50g limited.
[Leopold FC660C]     [GON NeRD 60]    [Infinity Keyboard]    [ Model M Silver Label]
[Topre 45g Silent]     [Gateron Black]    [Cherry MX Black]     [Model Number 1390636]
        [May 20, 1987]
Offline Smasher816
  • HHKB Master
« Reply #10168 on: Tue, 21 October 2014, 17:28:59 »
Here? (if you don't mind waiting for the next batch) http://geekhack.org/index.php?topic=55888.0
Offline Zeal
    • Zeal Generation Inc.
« Reply #10169 on: Tue, 21 October 2014, 19:05:50 »
You might have to wait ~6 months before R3 Springs GB starts...
I've stocked quite a few  60-68g springs in my store. Might have one 50, 55 & 85g pack left too.
Shipping will be expensive though (if you only purchase one pack of springs). But if you're also looking for switches, I have pretty much all but 2 Cherry switches in stock.
Offline nikron
« Reply #10170 on: Tue, 21 October 2014, 22:44:11 »
What makes a keycap "Dolch"?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #10171 on: Tue, 21 October 2014, 22:46:05 »
If it looks like this it's Dolch.: http://i.imgur.com/eAY8J.jpg
Offline yasuo
  • spanengan puyeng newbie
« Reply #10172 on: Tue, 21 October 2014, 22:49:45 »
how to coloring pbt keycaps? i want keep color just trying to cover letters/blank
Logitech MK220 Colemak DH
Offline BlueBär
« Reply #10173 on: Wed, 22 October 2014, 03:08:46 »
Depends on the printing methode. Dyesu is hard/impossible to remove. If it's lasered you could try acetone or some light sanding?
Offline yasuo
« Reply #10174 on: Wed, 22 October 2014, 03:20:01 »
yup laser, I've tried acetone but it does not work amplas make the texture broken
Offline BlueBär
« Reply #10175 on: Wed, 22 October 2014, 03:57:51 »
I don't think you can remove laser printing without removing a little bit of material :(
Offline Veridis
« Reply #10176 on: Wed, 22 October 2014, 04:06:50 »
Noob question here: What profile are "Artisan" keycaps? Those that have faces in them, or are made of different matterials.
If they are OEM profile, would they look out of place on a keyboard with cherry profile keycaps?
Ducky Shine 3 TKL (MX Brown) | CM Rapid-i (MX Brown) | Realforce 87u 45g Uniform | CM Novatouch | Ducky Zero TKL (MX Brown) | Das Keyboard III (MX Blue)
Offline BlueBär
« Reply #10177 on: Wed, 22 October 2014, 04:35:08 »
Since most of them don't have a regular flat surface you can't really say they have a specific profile. Some of them go very well with Cherry profile caps, some not so much, it depends which profile was used as the base of the keycap.
Offline yasuo
« Reply #10178 on: Wed, 22 October 2014, 04:43:04 »
lol, little coloring is good choiche  i think what good paint for coloring keycap
Offline BlueBär
« Reply #10179 on: Wed, 22 October 2014, 06:11:26 »
Painting the keycaps will wear off and dying them, which is a better solution, won't cover printing.
« Reply #10180 on: Wed, 22 October 2014, 07:19:06 »
http://deskthority.net/wiki/Cherry_G80-1813#Dolch
Originally, the Dolch color way came from network sniffers. There's also inet network sniffers and other companies which made the system in that colorway but Dolch is the most well known one. AFAIK, a network sniffer is a type of portable computer system.
Recently, there has been some keycap sets made in the colorway which is referred to as Dolch.
« Reply #10181 on: Wed, 22 October 2014, 12:05:51 »
there is also a cardiac monitor. I think the inet was used for more than just network sniffing. I hope to one day figure it out.
« Reply #10182 on: Wed, 22 October 2014, 15:19:47 »
i have a new end game item
Offline Lain1911
  • God of the Wired
« Reply #10183 on: Wed, 22 October 2014, 20:04:24 »
I've got a QFR and a Poker 2. I switch out the keyboards and keep the QFR cord depending on what I am doing. When I switch to the Poker 2 no worries type away. When I switch back to the QFR I get a "USB not recognized" and have to replug the usb from the computer even though it's the original QFR cord. IS there a work around here?
Also small random question when I start a new topic on GH it times me out 90% of the time but my thread still posts. Others having this problem? Is there already a thread on this?
Thanks
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #10184 on: Wed, 22 October 2014, 20:05:56 »
Yeah lots of people are having this problem, but just remember that most of the time your thread posted so don't just try again, check and see if it went through
« Reply #10185 on: Wed, 22 October 2014, 20:11:14 »
Yep!  We'll just have to put up with the behaviour until we can find a solution to the problem.   :thumb:
Offline pksk
« Reply #10186 on: Wed, 22 October 2014, 20:22:35 »
What do owners of smaller keyboard (i.e Poker II) do when a key you need to use isn't on your board? (for example, the Poker II doesn't have a key for ~).
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10187 on: Wed, 22 October 2014, 20:33:40 »
FN layer
Offline pksk
« Reply #10188 on: Wed, 22 October 2014, 20:44:42 »
Ah yes, of course. Thanks!
Offline yasuo
« Reply #10189 on: Thu, 23 October 2014, 04:00:11 »
not paint i mean dyeing :D
btw there any 1.75 keycaps R1(R4)
« Last Edit: Thu, 23 October 2014, 04:02:05 by yasuo »
« Reply #10190 on: Thu, 23 October 2014, 05:56:14 »
Not that I know of.
Does this problem happen with another cable?
Offline BlackWidowMan777
« Reply #10191 on: Thu, 23 October 2014, 06:34:22 »
Is it possible to upload an image to a PM? It's on my computer so no url.
« Reply #10192 on: Thu, 23 October 2014, 06:35:22 »
You can't attach anything to PMs unfortunately. In order to do so, you'll have to upload it to imgur or another service like that. Alternatively, most users have a little button where you can send them an email.
« Reply #10193 on: Thu, 23 October 2014, 06:50:26 »
can u suggest which one to use...imgur the best?
« Reply #10194 on: Thu, 23 October 2014, 06:55:13 »
I use imgur and flickr.
« Reply #10195 on: Thu, 23 October 2014, 07:12:57 »
turned out imgur is perfecto. thanks a bunch!
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #10196 on: Thu, 23 October 2014, 14:43:34 »
How thick are switch tools from the_beast?  Just want to gauge cost for making my own.
Offline Elocutive
« Reply #10197 on: Thu, 23 October 2014, 15:32:23 »
60% keyboard with an alps compatible PCB that would fit in a poker case?
LZCE- Black, red, ergo clears
Wanting Skeldon
Offline BlueBär
« Reply #10198 on: Thu, 23 October 2014, 15:35:41 »
Duck Mini. Should be pretty much the only one though.
« Reply #10199 on: Thu, 23 October 2014, 15:53:57 »
It's the only one until GON's ALPS 60% PCB gets off the ground
It's been in development for a REALLY long time though, since before I was a member here.
