Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6009194 times)
Offline yasuo
  • spanengan puyeng newbie
« Reply #10100 on: Fri, 17 October 2014, 11:08:59 »
what mean keytravel?
what keyboard with less keytravel
and how make it?
 :thumb:
Logitech MK220 Colemak DH
« Reply #10101 on: Fri, 17 October 2014, 11:15:04 »
I guess it's not such a simple question after all :P
Keyboard is love, keyboard is life.
I just want to enjoy my feeling :D.
I'm in it for making hacking and engineering.
I also love to make the hack.
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« Reply #10102 on: Fri, 17 October 2014, 11:47:41 »
I like making hack.
I got boards.
Offline BlueBär
« Reply #10103 on: Fri, 17 October 2014, 11:49:15 »
and how make it?
 :thumb:
Keytravel is the distance you can press down a key. For Cherry MX that's 4mm, you could reduce it with o-rings.
You cheeky bugger I see what you did there! Wait I'm confused it actually might just be my font rendering... I'm confus :-X
« Reply #10104 on: Fri, 17 October 2014, 13:20:23 »
I think he is referring to the MCHCK.
and how make it?
 :thumb:
Keytravel or "key travel" is the amount of travel between the "rest" state and the bottom out. It's usually 4mm or 4.1mm.
Alps are less at 3.7mm or so.
Scissor switch keyboards, cherry ML, and topre short throw are even less at about 2.1mm.
« Last Edit: Fri, 17 October 2014, 13:21:55 by dorkvader »
« Reply #10105 on: Fri, 17 October 2014, 13:22:14 »
I thought it was because you said "I like making hacking...", where you presumably meant "I like making, hacking,...", so he was taking a jab at that and saying he loves to make hack.  But I dunno.   ^-^
Offline yasuo
« Reply #10106 on: Fri, 17 October 2014, 22:13:15 »
and how make it?
 :thumb:
i plan make less actutaion travel like this ;D
http://www.khangfixesit.com/2012/03/mechanical-keyboard-o-ring-mod.html
and how make it?
:thumb:
i still confused key travel and acutation i think key travel when you press letter to letter :))
« Last Edit: Fri, 17 October 2014, 22:15:25 by yasuo »
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #10107 on: Fri, 17 October 2014, 22:17:33 »
and how make it?
 :thumb:
and how make it?
:thumb:
Key travel is from when a key is at rest to fully depressed.  Actuation is when the switch registers the keystroke.  For Cherry MX the key travel is 4mm with actuation happening at 2mm.  The Kaliah switches in the new Razer boards I believe are 3.8 or 3.7mm travel.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #10108 on: Fri, 17 October 2014, 22:18:38 »
What is the cheapest method of converting a DIN 5 (AT) connector to USB or PS/2?
« Reply #10109 on: Fri, 17 October 2014, 23:21:00 »
Din5 to ps/2 converter. About $2.
Ps/2 to USB converter. Think the cheapest active I've seen is $5 but mine cost around $12.
Offline yasuo
« Reply #10110 on: Fri, 17 October 2014, 23:51:20 »
and how make it?
 :thumb:
and how make it?
:thumb:
thx but i mean like this actually btw
http://geekhack.org/index.php?topic=51892.0
is there existed small cherry keycap?
and teensy only support 1 LED?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #10111 on: Sat, 18 October 2014, 01:33:54 »
Does anyone know of a way to convert Mini-DIN-5 to PS/2? Also have one of those that I cannot connect to anything.
Offline BlueBär
« Reply #10112 on: Sat, 18 October 2014, 06:26:38 »
Oh so you want a smaller keycap? I don't think that exists for MX.
Mini-Din-5 or AT? Can you post a picture of the connector?
Offline yasuo
« Reply #10113 on: Sat, 18 October 2014, 06:36:32 »
yup :)) like matias arrow keys but more wide
btw where pins led in teensy 2.0 for wire/resistor it's same with the switch and how control on/off
« Last Edit: Sat, 18 October 2014, 06:46:06 by yasuo »
« Reply #10114 on: Sat, 18 October 2014, 08:11:37 »
They exist
Problem is that mx switch is still bigger, so you can't space them as closely as matias.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #10115 on: Sat, 18 October 2014, 08:13:45 »
They exist
Woah! What board is that?
« Reply #10116 on: Sat, 18 October 2014, 08:15:48 »
They exist
Pinnacle Deko fastaction keyboard.
Probably my fav keyboard with cherry switches.
album here:
https://www.flickr.com/photos/dork_vader/sets/72157641884809274/
Offline yasuo
« Reply #10117 on: Sat, 18 October 2014, 08:43:28 »
They exist
cool 14/15mm woulde be cool old cherry have 16mm i think
They exist
You can not just leave, before answering :-X
or LED not really matter
Offline MOZ
  • Busy making stuff
« Reply #10118 on: Sat, 18 October 2014, 08:48:08 »
Really cool battlestation board. What purpose does the LED screen serve?
Offline yasuo
« Reply #10119 on: Sat, 18 October 2014, 08:52:51 »
so LED caps not really matter :D
Offline frosty
  • jukebox hero
« Reply #10120 on: Sat, 18 October 2014, 10:13:38 »
What are the screw sizes for the poker 2? Are they easy to get? Are the sizes of washer important or do we just get roughly same sized one?
Offline yasuo
« Reply #10121 on: Sat, 18 October 2014, 10:36:02 »
What is cable have 7 wires/poles?
While I am not sure which ones use 7 specifically.  But USB 3.0 uses 9.  This link is for all 7 wire din connectors.  There are other styles as well.  Many to choose from if you aren't to picky about size and such.
din quite hard find btw, i try rj45 too big, is there other choice shape like usb
Offline Melvang
« Reply #10122 on: Sat, 18 October 2014, 10:41:10 »
You could take a look at DB-9 connectors.  Shouldn't be that tough to find.
Offline yasuo
« Reply #10123 on: Sat, 18 October 2014, 10:56:19 »
it's easier find indeed but too big for just connect two halves :eek:
« Reply #10124 on: Sat, 18 October 2014, 11:11:33 »
hard to say, but I think it outputs useful information.
This was a video editing keyboard, so it's easy to imagine a whole host of things. The driver CD only has Win2000 and WinXP drivers though.
I would also like to note it does NOT work properly (no upcodes are being sent from the adapter, confirmed with debug mode and hid listen) with a soarer, but will work (somewhat: 104 normal keys work fine all the rest depend on the adapter being used) with other converters. No idea why yet.
I'll be publishing what I know once I know more. Unlike the WEY, these aren't really common enough to publish a WIP as I don't think anyone else has one (IIRC ivan and spamray gutted theirs) and could help test.
I believe they are M2 "fine" (or normal, M2 coarse is extremely rare) Washer size is not really important: anything close will be fine.
If you like I can verify this and get the length after work. PM me if no-one else answers.
« Last Edit: Sat, 18 October 2014, 11:13:14 by dorkvader »
« Reply #10125 on: Sat, 18 October 2014, 11:20:20 »
It's in the FAQ in the OP:
Does anyone know what size screws the Poker/Pure case uses?
CPTBadAss, please put this info in the OP:
Poker/Pure cases use M2-4mm (0.4mm pitch) machine screws to mount the PCB to the case. McMaster-Carr part # 92000A011
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #10126 on: Sat, 18 October 2014, 11:55:22 »
« Reply #10127 on: Sat, 18 October 2014, 15:34:48 »
That looks like a mini-DIN6 with a missing pin.
Some keyboards such as the Northgate Omnikey 101 use a detachable cable with a male mini-DIN6 (not PS/2!) plug at one end and a male AT (180 degree DIN 5) plug at the other. A male-male mini-DIN6 or PS/2 cable will not work in that setup.
- Franklin Roosevelt 1933
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #10128 on: Sat, 18 October 2014, 16:35:58 »
It matches up perfectly to this:
« Reply #10129 on: Sat, 18 October 2014, 17:42:43 »
The missing pin (pin 2) is not connected. It's a mini DIN-6 missing a pin and will likely work just fine with a USB adapter.
see here:
https://en.wikipedia.org/wiki/PS/2_port
Many lexmark IBMs are also missing pin6, which is also not connected.
Offline frosty
  • jukebox hero
« Reply #10130 on: Sat, 18 October 2014, 18:41:52 »
Thanks JD and dorkvader
Offline mozaiq
« Reply #10131 on: Sun, 19 October 2014, 05:52:20 »
A quick question regarding the programmability of the Poker II:
Assume I program '&', which is shift+7 to the 'a' key. Further assume that Pn lock is activated. Now if I press 'a' I will get '&' and if I press Pn+'a' I will get 'a'. So far, so good. Now what will be the result if I press shift+'a'? And what do I have to press to get 'A', Pn+shift+'a' I assume?
Offline Dubsgalore
« Reply #10132 on: Sun, 19 October 2014, 06:03:30 »
what korean spring is a tad heavier then mx reds? i forgot :)
Offline BlueBär
« Reply #10133 on: Sun, 19 October 2014, 06:04:11 »
1. Now what will be the result if I press shift+'a'?
2. And what do I have to press to get 'A', Pn+shift+'a' I assume?
1. Shift+shift+a or maybe just a? I don't know :-X
2. Yes.
62g-65g.
Offline Dubsgalore
« Reply #10134 on: Sun, 19 October 2014, 06:04:57 »
62g-65g.
thanks homie
Offline yasuo
« Reply #10135 on: Sun, 19 October 2014, 06:30:35 »
btw to make led on/off with handwiring need transistor? :-X
« Reply #10136 on: Sun, 19 October 2014, 12:04:10 »
gate of transistor goes to LED control pin on microcontroller.
Source goes to 5V ofcourse
drain goes to LED supply lines, where the resistors and LEDs are.
Offline yasuo
« Reply #10137 on: Sun, 19 October 2014, 12:11:52 »
moz right really need transistor :eek: cant just write on scripts on/off for caps lock.etc?
the schematic for feet led is resistor to gnd and wire to pb6,right? where place transistor?
« Reply #10138 on: Sun, 19 October 2014, 12:15:50 »
Transistors are usually fast enough to switch the LEDs on/off even with PWM signals, so everything you can control with a normal LED control pin with your firmware of choice (led modes etc) you can use the transistor with.
Transistor can go anywhere. You can solder wires to it and put it under the PCB somewhere.
FET should work, MOSFET is probably fine. If you need more help make a thread and I'll look at your design.
LED control pin can be almost any pin. Check what firmware you are using.
Offline yasuo
« Reply #10139 on: Sun, 19 October 2014, 12:33:00 »
1.Transistors are usually fast enough to switch the LEDs on/off even with PWM signals, so everything you can control with a 2.normal LED control pin with your firmware of choice (led modes etc) you can use the transistor with.
3.LED control pin can be almost any pin. Check what firmware you are using.
thx :thumb:,
1.i just know
2.really thx i think solder on teensy
3.i use teensy may use gh60 firm like matt3o thread
scheme
so what mean pb6 for led in teensy?
no need make thread :D
« Last Edit: Sun, 19 October 2014, 12:37:19 by yasuo »
Offline Elocutive
« Reply #10140 on: Sun, 19 October 2014, 16:43:05 »
What keyboard has nixdorf switches in it?
LZCE- Black, red, ergo clears
Wanting Skeldon
« Reply #10141 on: Sun, 19 October 2014, 16:59:30 »
Nixdorf keyboards like the Softkey.
Offline HPE1000
  • Keycap Paparazzo
« Reply #10142 on: Sun, 19 October 2014, 17:01:28 »
Any way to tell if a zenith zkb2 has green alps or not? By model number on back or anything, or does a keycap need removed to tell?
« Reply #10143 on: Sun, 19 October 2014, 19:03:28 »
that one used cherry switches (with the clear top)
Keyboards with actual nixdorf (non cherry) switches are very uncommon. Here is an example:
https://www.flickr.com/photos/triplehaata/sets/72157640956847424/
« Reply #10144 on: Sun, 19 October 2014, 19:09:23 »
Crap, I was thinking of the Nixdorf Cherry since that's what most people mean.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #10145 on: Sun, 19 October 2014, 19:51:58 »
What screws do GONs use (more specifically MX Mini)?
« Reply #10146 on: Sun, 19 October 2014, 21:35:28 »
Check GON's Q&A thread in his forum
that question gets answered like every other page
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10147 on: Sun, 19 October 2014, 21:45:01 »
fine meany head
thanks...
Offline FRD
« Reply #10148 on: Sun, 19 October 2014, 22:03:50 »
« Last Edit: Tue, 02 December 2014, 14:40:34 by FRD »
« Reply #10149 on: Sun, 19 October 2014, 22:23:48 »
Could anyone with Ducky Mini provide a picture of a single switch w/o keycap?
I'm wondering w/e the switch is rotated upside down with LED on top of it (like on most other baclighting keyboards, Ducky's included) or was it kept in normal position with LED at the bottom of the switch.
The Mini's keycaps have printing at the bottom part of keycap (as apposed to Shine 3 and even Shine 4 top part of keycap printing). So i guess they went with the latter, but would like someone to confirm it.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=113_1361&products_id=28247&zenid=2baba418eaa33e76f2c57b3738c3a353
(scroll down)
LED at the bottom of the switch - you can tell by the position of the legends.
