Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6228283 times)
« Reply #10000 on: Sun, 12 October 2014, 02:06:18 »
PARTYY TIIIIME!!!!!!!!
« Reply #10001 on: Sun, 12 October 2014, 02:06:55 »
wtf Lastpilot!!??!?!?
Jerk
Offline Lastpilot
  • Power stance
« Reply #10002 on: Sun, 12 October 2014, 02:07:33 »
It's okay man you one-upped me and got 10001
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #10003 on: Sun, 12 October 2014, 02:11:51 »
I feel like you two have a strong developing bromance.  The adventures of Hoffman and Lastpilot.
Offline Lastpilot
  • Power stance
« Reply #10004 on: Sun, 12 October 2014, 02:13:38 »
He asked me to help him by posting #9999. I did him this favor, and then I collected my fee. BWAHAHAHAHA
« Reply #10005 on: Sun, 12 October 2014, 02:15:02 »
You want in?  ;)
-__-
Offline Lastpilot
  • Power stance
« Reply #10006 on: Sun, 12 October 2014, 02:16:48 »
Sent you should be our getaway driver. Hoffman and I will go steal vespers 23ub.
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #10007 on: Sun, 12 October 2014, 02:19:13 »
You want in?  ;)
Maybe...my mom told me not to trust strangers.
I did spend a lot of time at the track.  I can be an Asian version of the Transporter. :cool:
« Reply #10008 on: Sun, 12 October 2014, 02:21:06 »
Whoa, let's get this straight. I get the 23ub, you get a smack to the head with the 4704 107-key.
Offline Lastpilot
  • Power stance
« Reply #10009 on: Sun, 12 October 2014, 02:21:34 »
Stop posting with just your index finger
« Reply #10010 on: Sun, 12 October 2014, 02:37:16 »
Rowdy you know you want to be the owner of reply #10000
Heh I thought about it, but them I haven't contributed much to this thread anyway.  Besides, I've been away from this keyboard settupping a newer workstation for my other half.
Offline divito
« Reply #10011 on: Sun, 12 October 2014, 08:35:26 »
Sister wants full-size keyboard with white backlighting (to use Bang Good's LED covers) and green switches. MK shows Vortex or Code, but looking for other potential options.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline hanshan
« Reply #10012 on: Sun, 12 October 2014, 10:28:40 »
Anyone know where I could get one or two Model M circuit boards & led sets (for converting terminal kb to pc use?)   Thanks.
« Reply #10013 on: Sun, 12 October 2014, 11:03:22 »
ebay
Offline frosty
  • jukebox hero
« Reply #10014 on: Sun, 12 October 2014, 11:18:23 »
Is 70% Isopropyl Alcohol good enough to clean the flux? Or do I need alcohol of higher concentration?
Offline phoenix1234
« Reply #10015 on: Sun, 12 October 2014, 12:08:19 »
70% Isopropyl Alcohol is good enough for some type of rosin flux but you should have 90% or 99%.
I like linear switches
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #10016 on: Sun, 12 October 2014, 14:33:16 »
I'd recommend 99%, or at least 90%, as most rosin flux can be pretty darn hard to remove, many people have issue with even 99% ISO.
Offline uns211
« Reply #10017 on: Sun, 12 October 2014, 16:15:23 »
I've tried 91% and 99.9% IPA and I recommend the latter.
« Reply #10018 on: Sun, 12 October 2014, 16:17:03 »
I wouldn't recommend using beer on your keyboard at all.
Offline whentheclouds
« Reply #10019 on: Sun, 12 October 2014, 17:43:40 »
who is "microsoft windows" and how on earth did he amass over 6000 posts of trolling?
« Reply #10020 on: Sun, 12 October 2014, 17:46:17 »
He's a user on GH who posts a lot. Not really keyboard related.
« Reply #10021 on: Sun, 12 October 2014, 17:56:23 »
hmm, ok. still strange that he'd choose a niche keyboard forum to extol the virtues of windows 98 and IE
- D Trump 2026-10-24
Offline pr0ximity
« Reply #10023 on: Sun, 12 October 2014, 21:51:25 »
Do all Model F keyboards have die cast metal cases? From what I understand the 4704 models do, but I'm wondering specifically if models like the 122-keys or unsavers do. Apparently F-122's have "black metal undersides", but what about the top?
« Reply #10024 on: Sun, 12 October 2014, 21:53:39 »
It's just the 4704s with metal tops, unless there are some less known models with them too. AT, F122, XT all have plastic tops.
Offline HPE1000
  • Keycap Paparazzo
« Reply #10025 on: Sun, 12 October 2014, 22:36:15 »
I have seen a couple F XT listed on ebay recently with the sellers claiming they are all metal. I even messaged one and the guy said twice it was all metal but I didn't buy it because there was no way it was.
There ARE two all metal F XT models that I know of but they are clearly marked and identifiable as all metal.
Offline intelli78
« Reply #10026 on: Mon, 13 October 2014, 13:11:44 »
Are the sliders in the HHKB Type-S the same as the purple silent Realforce sliders, aside from the plastic color? Or do they employ a different silencing technique?
Offline ajx
« Reply #10027 on: Mon, 13 October 2014, 17:30:09 »
is there any cover/roof keyboard for KBT Pure?
thanks
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #10028 on: Mon, 13 October 2014, 17:36:21 »
thanks
http://www.elitekeyboards.com/products.php?sub=access,roofs&pid=rf_hhek
should work, although you might want to check the dimensions
Offline ajx
« Reply #10029 on: Mon, 13 October 2014, 19:09:28 »
Pure 290 x 102 x 38 mm
HHKB  294 x 110 x 39.9mm
Roof 290 x 103 x 13mm
Offline ajx
« Reply #10030 on: Tue, 14 October 2014, 05:39:02 »
Nerverminds, it would cost me about 90$ to import it lmao
Too expensive for a simple roof keyboard
Offline henz
  • What?
« Reply #10031 on: Wed, 15 October 2014, 01:43:09 »
Does gon cases have switch top removal?
Offline BlueBär
« Reply #10032 on: Wed, 15 October 2014, 05:16:49 »
Nope, he doesn't like that feature as with tight caps you can pull the switch top out by just pulling the keycap.
Offline asgeirtj
« Reply #10034 on: Wed, 15 October 2014, 06:53:13 »
I'm looking for a non backlit 104/5 keyboard with cherry stabilizers, is ducky pro and NerD my only option?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
« Reply #10035 on: Wed, 15 October 2014, 07:16:29 »
Well the whole Ducky line uses Cherry stabilizers. So Zero, Shine 2, Shine 3, the Year of the X (except year of the horse) boards are all options too. Leopold boards use Cherry. I think Keycool has them.
Offline asgeirtj
« Reply #10036 on: Wed, 15 October 2014, 08:27:11 »
I'm looking for
I'm looking for a full size, non-backlit board , and the Ducky Premier DK9008P seems the best choice for me because of the availability and iso option.  It is the only ducky which isn't loaded with LEDs, only the wasd keys has them but surely they must be disablable.  Are the caps on these cherry or oem profile? http://www.jimms.fi/tuote/DK9008P-BFIPHZHB2
« Reply #10037 on: Wed, 15 October 2014, 08:28:09 »
Offline BlueBär
« Reply #10038 on: Wed, 15 October 2014, 08:29:17 »
You can disable LEDs on all backlit boards that I know of.
Offline Firebolt1914
  • POM Overlord
« Reply #10039 on: Wed, 15 October 2014, 09:29:01 »
When will the sprit spring orders close? Am I already way too late?
« Reply #10040 on: Wed, 15 October 2014, 09:32:04 »
You should probably ask that in the relevant thread.
  • POM Overlord
« Reply #10041 on: Wed, 15 October 2014, 09:35:26 »
I have and no replies. Might as well ask it again :S
« Reply #10042 on: Wed, 15 October 2014, 09:41:50 »
Agreed. I can't speak for sprit (I have no idea as well.) and I think only sprit and his proxies can only speak for his dates.
Offline yasuo
  • spanengan puyeng newbie
« Reply #10043 on: Wed, 15 October 2014, 10:00:15 »
Click clack's user is pioner cc's? is same man with bro caps?
Logitech MK220 Colemak DH
Offline esoomenona
  • Gnillort?
« Reply #10044 on: Wed, 15 October 2014, 10:01:43 »
« Last Edit: Fri, 04 September 2015, 11:19:05 by esoomenona »
« Reply #10045 on: Wed, 15 October 2014, 10:03:22 »
ClickClack aka ClackFactory makes the Click Clack keycaps. User Bro Caps who makes Bro Caps keycaps is different from ClickClack. Bro Caps the user doesn't make Click Clack keycaps and ClickClack the user doesn't make Bro Caps the keycaps.
Offline yasuo
« Reply #10046 on: Wed, 15 October 2014, 10:15:36 »
thanks :)) is CC's always skull?
Offline heedpantsnow
  • Old enough to know better
« Reply #10047 on: Wed, 15 October 2014, 10:17:23 »
No, he's made plain colored and multi colored keys (double shot or triple shot, molded out of multiple colors of plastic).
I'm back.
« Reply #10048 on: Wed, 15 October 2014, 10:21:58 »
Also, a few ogres and eagles and such. :D
Offline BlueBär
« Reply #10049 on: Wed, 15 October 2014, 10:23:16 »
There's blank keys, leaf keys aka 4:20, Gumrots, WASD clusters,... More info here: http://geekhack.org/index.php?topic=39794.0
