Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6196149 times)
« Reply #11300 on: Mon, 02 February 2015, 19:39:18 »
Has anyone done a video comparison between two identical F keyboards, one with and one without floss mod?
If so link please?
Shoutouts to PunksDead
« Reply #11301 on: Mon, 02 February 2015, 19:41:47 »
aren't F's completely different than M's?
« Reply #11302 on: Mon, 02 February 2015, 19:43:23 »
Rofl yeah. You're totally right and I'm an idiot. Let me try this again.
Edit: I can't find anything comparing two Fs so hopefully that video of the SSK gives you enough of an idea. Also I found this video from Salcan
« Last Edit: Mon, 02 February 2015, 19:51:45 by CPTBadAss »
Offline byker
  • Literally Canada
« Reply #11303 on: Mon, 02 February 2015, 19:43:28 »
what adapter do i need to plug my hhkb to my ipad?
is it just the camera usb adapter?
OTG cable, not sure if it is the camera usb adapter. You can get otg cables for like $4 on amazon
Offline byker
  • Literally Canada
« Reply #11304 on: Mon, 02 February 2015, 19:45:06 »
If you want something sleeker, I think pexon is making all in one cables for keyboards on tablets now? A bit pricer though I imagine.
« Reply #11305 on: Mon, 02 February 2015, 19:46:28 »
i'll ask tj, since he's a state away.
dont think i've seen lightning OTG cables tho
by the looks of it, yeah, it's just a cable adapter. and everything amazon has looks like it has terribad reviews.
anyway, thanks for the answer.
« Last Edit: Mon, 02 February 2015, 19:50:02 by demik »
Offline user 18
« Reply #11306 on: Mon, 02 February 2015, 19:46:41 »
iPad is a little more complicated because it doesn't have standard USB ports. The camera adapter kit should work just fine.
Avatar by ashdenej
Offline byker
  • Literally Canada
« Reply #11307 on: Mon, 02 February 2015, 19:47:55 »
Ooops, sorry demik, forgot about lightening. I was thinking android/minusb devices.
« Reply #11308 on: Mon, 02 February 2015, 19:49:25 »
yeah, i figured.
no problem, i already own an OTG cable from tj.. just no android tablet :P
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #11309 on: Mon, 02 February 2015, 19:59:03 »
Thanks CPT.  I am planning on doing the floss mod to at least my XT, probably going to do the AT as well when I get it mounted into the new keyboard tray.  I do keep hearing that the floss mod has a more profound effect on F's than it does on M's and was curious to an idea on what to expect.
Offline intelli78
« Reply #11310 on: Mon, 02 February 2015, 20:00:56 »
3) EK had them made for their store/business. There was no GB.
Small correction in case anyone cares-- I believe the caps came from Leopold, who dealt directly with GMK.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #11311 on: Mon, 02 February 2015, 21:18:49 »
I am following this guide for when I solder in LEDs for my bface, and right now I am picking up some more LEDs, and I came upon a question that I couldn't find googling, maybe my search was poorly worded, but I am using 820 ohm resistors for the pink LEDs, and I would like to have caps lock as a different color, maybe green or red, or even blue. Well, I hade them pre-soldered and gorgot to ask for the caps lock resistor soldered at a different ohm rating, and I was wondering what would happen if I put a red led in with a 820  ohm resistor?
– 820 Ohm : generally used for white/pink LED
– 910 Ohm : generally used for blue/green LED
– 1300 Ohm : generally used for red/yellow/orange LED
« Reply #11312 on: Tue, 03 February 2015, 05:53:40 »
I think worst case scenario is that the LED is just dim. Plug it in and find out?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #11313 on: Tue, 03 February 2015, 06:05:58 »
That's what I thought would happen, and it's not here yet, or else I would have tried it with a button cell.
« Reply #11314 on: Tue, 03 February 2015, 06:06:53 »
Ah ok. Let us know what happens when you get it in hand :).
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #11315 on: Tue, 03 February 2015, 06:08:10 »
I need to order the red LEDs any way, so I might buy a throughole resistor for all three of those ratings and test.
Offline cannonking
« Reply #11316 on: Tue, 03 February 2015, 11:24:47 »
Where should I post to find someone (preferably in Europe) who can assemble my Duck Octagon for me when it comes in a few weeks? I was going to get margo to do it but it seems he isn't taking any more builds for the foreseeable future :(.
Offline whentheclouds
« Reply #11317 on: Tue, 03 February 2015, 11:33:04 »
Signature is located in Sweden and would probably be willing to do it for you, going by his forum posts and our short convo. i really want to do it myself as well, but i'm getting cold feet thinking about having to choose a decent solder kit, and the many possible things that can go wrong during the process (zero prior experience here)
« Reply #11318 on: Tue, 03 February 2015, 12:03:43 »
Maybe just make a thread in keyboards? I don't know if Signature does assembly.
Offline Melvang
« Reply #11319 on: Tue, 03 February 2015, 16:58:50 »
Is there a suggested type or brand of floss for floss modding an F?
« Reply #11320 on: Tue, 03 February 2015, 17:15:03 »
I use Oral-B "super" floss, you want the fluffy part in the middle.
I recommend putting the floss into the spring, then cutting off the top at the right level. Shorter floss does less sound deadening, perhaps feels incrementally lighter, but it has to be well over the midpoint, because that is where the spring buckles!
You can get about half a dozen cuts out of each length of floss.
« Last Edit: Tue, 03 February 2015, 17:17:09 by fohat.digs »
- D Trump 2026-10-24
« Reply #11321 on: Tue, 03 February 2015, 17:18:31 »
Paging skcheng...
We need some floss over here, stat! :))
Offline HPE1000
  • Keycap Paparazzo
« Reply #11322 on: Tue, 03 February 2015, 18:20:34 »
Can anyone confirm whether unicomp includes the spacebar wires with their spacebars they sell?
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #11323 on: Tue, 03 February 2015, 19:02:29 »
I'm out of the loop, what's with the "good situation" thing? my only guess is from the chinese guy's classified ad talking about the condition of his items.
GON NerD TKL DTA Edition
Offline billnye
  • ability man
« Reply #11324 on: Tue, 03 February 2015, 19:07:06 »
good situation confirmed
Offline Michael
  • Formerly Bro Caps
« Reply #11325 on: Tue, 03 February 2015, 19:07:15 »
good situation
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #11326 on: Tue, 03 February 2015, 19:10:09 »
gucci situation
Offline intelli78
« Reply #11327 on: Tue, 03 February 2015, 20:33:48 »
Yes they include a stabilizer wire (1). Source: I just bought a spacebar from them last week.
Offline HPE1000
  • Keycap Paparazzo
« Reply #11328 on: Tue, 03 February 2015, 20:34:30 »
Perfect, thanks!  :thumb:
Offline Melvang
« Reply #11329 on: Tue, 03 February 2015, 21:28:08 »
Anyone know if there is anywhere to look at what fonts and legends are available for use via SP with double shots and dyesub?
« Reply #11330 on: Tue, 03 February 2015, 22:02:15 »
For dyesub, I believe you just send them an svg, and they use that.
Here is what is available in double shot, although you have to pay extra for each legend you use (per keycap), and I think that fee ranges from $25/ea to $45/ea.
Offline hasu
  • @tmk
« Reply #11331 on: Wed, 04 February 2015, 00:30:21 »
Is there Alps 60% PCB fits for AEK layout? If it is compatible to poker case dimension it'd be appreciated.
I'm working on Alps 60% from AEK or AEK II cut mounting plate.
Thanks.
« Reply #11332 on: Wed, 04 February 2015, 07:49:01 »
Thanks.
https://geekhack.org/index.php?topic=67815.0
I think Ron's new 60% PCB should work.
You answered your own question :))
« Last Edit: Wed, 04 February 2015, 08:12:19 by CPTBadAss »
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #11333 on: Wed, 04 February 2015, 08:42:16 »
Not sure why it didn't click while typing it, i think i just thought, "It can't be this simple"
Offline byker
  • Literally Canada
« Reply #11334 on: Thu, 05 February 2015, 01:22:02 »
Does anyone remember how much the Bro Caps Stumps went for on the New Years sale? It was one price for a random cap. I got invoiced for several other caps from a previous sale, so I cannot see the specific price, but maybe someone who got only the random cap can let me know? Cheers!
Offline hasu
  • @tmk
« Reply #11335 on: Thu, 05 February 2015, 03:57:08 »
Thanks.
Thanks. Interesting project, I'll watch and learn.
AEK has pretty weird bottom row like; 1.5, 1.25, 1.5 space 1.5, 1.25, 1.5
It seems I'll have to design my own PCB supports AEK layout and fits in Poker case.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #11336 on: Thu, 05 February 2015, 10:33:57 »
Are desko boards my or ml switches? I bought a board for the caps, and to my knowledge they are compatible with mx right,
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #11337 on: Thu, 05 February 2015, 10:51:19 »
MY, and yeah
« Reply #11338 on: Thu, 05 February 2015, 10:52:38 »
MY, and yeah
Aren't there MX Desko boards too though?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #11339 on: Thu, 05 February 2015, 10:52:44 »
MY, and yeah
Thanks, now all I need is matching winkeys :-(
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #11340 on: Thu, 05 February 2015, 10:53:52 »
MY, and yeah
Desko may have made MX boards, but the ones with the BoW caps and dyesub mods are all MY
Offline rainb1ood
  • so pretty so plastic
« Reply #11341 on: Thu, 05 February 2015, 16:20:44 »
Hi! Posting for a friend who asked me this question and I didn't know the answer despite googling.
What are these two keys beside the spacebar? The keys with the looping icon. He bought this Century Black Pawn while visiting in Japan.
http://www.century.co.jp/products/pc/img/ck-67cmb_08_big.gif
« Reply #11342 on: Thu, 05 February 2015, 16:44:31 »
Those are the "circle jerk" keys.
« Reply #11343 on: Thu, 05 February 2015, 16:53:01 »
I believe it's so you can switch between the different Japanese character input types? But I'm not 100%.
Offline hasu
  • @tmk
« Reply #11344 on: Thu, 05 February 2015, 17:41:10 »
They are 無変換(muhenkan/no conversion) and 変換(henkan/conversion) key. Probaby they emit scan code 0x8a and 0x8b acording to USB spec, though I never have used JIS keyboard and I can't explain how to use them.
Further reading
http://en.wikipedia.org/wiki/Japanese_input_methods
Offline rainb1ood
« Reply #11345 on: Thu, 05 February 2015, 17:44:28 »
Thank you hasu!
Offline jonathanyu
« Reply #11346 on: Thu, 05 February 2015, 18:58:14 »
The functions of those keys are depend on the keyboard, different keyboard have different function even though they are all jis layout.  In the jis layout keyboard that I have used in the past, the left one is used to input Hiragana, and the right one is used to transfer Hiragana into Kanji.  And they have no function while inputting English.  But the function really depends on the keyboard.
Offline Melvang
« Reply #11347 on: Thu, 05 February 2015, 21:39:52 »
So I have this AT I converted with an xwhatsit, and it is having a minor issue that doesn't prevent me from using it but doesn't feel right.  The swithes feel like there is boat loads of extra friction in them.  They are still smooth just very tight.  They still actuate, though I had one keystroke physically stick in the down position.  It is the entire board and they all feel the same and sound right.  Any ideas?
« Reply #11348 on: Thu, 05 February 2015, 22:18:18 »
Sounds like the plates are tightened down too much or they're not properly aligned. I had a similar issue when I rebuilt my 6019284 incorrectly.
Offline Melvang
« Reply #11349 on: Thu, 05 February 2015, 22:45:28 »
Thanks, I will look into that.
On this note, is there anywhere that is safe or ok to lube via krytox on an AT modded to ANSI with M caps?
« Last Edit: Thu, 05 February 2015, 22:50:01 by Melvang »
