Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6231839 times)
Offline Candyflip
« Reply #5650 on: Mon, 30 December 2013, 12:01:54 »
what difference Filco Majestouch 2 and ninja? just keycap?
indeed just the keycaps
Offline HPE1000
  • Keycap Paparazzo
« Reply #5651 on: Mon, 30 December 2013, 12:29:11 »
I believe the case badge is blacked out on the ninja as well..
« Reply #5652 on: Mon, 30 December 2013, 13:21:10 »
ayup
keycaps on the ninja are side-printed, and the badge on the case is mettalic black instead of silver.
Offline HPE1000
  • Keycap Paparazzo
« Reply #5653 on: Mon, 30 December 2013, 17:46:41 »
Is it normal for cherry stabilizers to "leak" something? This is the first/only board I currently have with cherry stabs and they do this, I have wiped it a couple times before and it keeps coming back.
Offline Photoelectric
« Reply #5654 on: Mon, 30 December 2013, 18:18:14 »
Probably stabilizer grease for the metal bar / moving parts.
« Reply #5655 on: Mon, 30 December 2013, 18:42:18 »
Does your hand sweat while you game/code/whatever?
Could be that.
Offline HPE1000
  • Keycap Paparazzo
« Reply #5656 on: Mon, 30 December 2013, 18:49:18 »
Could be that.
It doesn't drip if that is what you are asking lol  :))
Offline Sai
« Reply #5657 on: Tue, 31 December 2013, 02:25:26 »
i see people use thorpe for topre. any explanation for it ?
(dont mind my sig, i am still a topre noob) :D
« Last Edit: Tue, 31 December 2013, 02:34:22 by Sai »
Offline Zeal
    • Zeal Generation Inc.
« Reply #5658 on: Tue, 31 December 2013, 02:31:47 »
^Add on to that question.
How do you pronounce Topre? Tou-prey? Tou-per?
Offline ComradeSniper
  • HHKB Pro
« Reply #5659 on: Tue, 31 December 2013, 04:35:33 »
It's short for Tokyo Press, so I believe it's pronounced Toe-Preh.
Someone misspelled it a while back and the name stuck.
« Reply #5660 on: Tue, 31 December 2013, 05:22:33 »
This thread in particular.
It kinda stuck after that.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #5661 on: Tue, 31 December 2013, 08:17:55 »
Is there any actual evidence that MX whites are infact factory lubed?  Or is this just a preconceived notion due to the usual behavior of using lube on clicky switches?  If they are in fact not factory lubed could the muffled click be due to a totally different material of the stem/slider to something more like UHMW or a nylon type that is considered self lubricating?
« Reply #5662 on: Tue, 31 December 2013, 08:27:36 »
captain has decided to say they are not factory lubed and I honestly do not know if we have anything other than anecdotal evidence to go either way.
I am of the opinion they are lightly factory lubed and that the hit or miss click is due to issues with the lube, I also believe the slider is a different material.
I just opened one that was in my desk and it definitely has lube on it.  ::)
« Last Edit: Tue, 31 December 2013, 08:32:48 by SpAmRaY »
« Reply #5663 on: Tue, 31 December 2013, 08:32:09 »
I, on the other hand, believe it's magic.
« Reply #5664 on: Tue, 31 December 2013, 08:33:30 »
^^ I am changing my answer to this....
Offline nzhao20
« Reply #5665 on: Tue, 31 December 2013, 10:24:37 »
How hard would it be to solder back on a usb connector like this
http://a248.e.akamai.net/origin-cdn.volusion.com/ctjx3.3omzd/v/vspfiles/photos/CBL-117-2.jpg%3F1368732341
Do you have to individually solder each of the little pin like things to its respective place on the controller or just solder all of them to the controller.
Could you do this with a weller WLC100
Offline BlueBär
« Reply #5666 on: Tue, 31 December 2013, 10:36:45 »
Please post a picture of the damage. You have to solder each pin to the correct solder pad. That iron will work well.
Offline nzhao20
« Reply #5667 on: Tue, 31 December 2013, 14:57:39 »
The connector fell off, that's why i was asking because i would have to solder on the base and the 4 little connector things.
Offline nzhao20
« Reply #5668 on: Tue, 31 December 2013, 16:41:22 »
Like how would you do this
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5669 on: Tue, 31 December 2013, 16:55:04 »
You broke the pads off the board, so you are going to have to carefully figure out where each pad goes and then direct wire those connections.
Try to write down what you see of the piece that is connected to the USB port still because you are are going to have to remove that, so try to understand where everything goes as you remove that...
Offline nzhao20
« Reply #5670 on: Tue, 31 December 2013, 17:04:08 »
Do I put the connector on and then solder or solder and try to stick it on
« Reply #5671 on: Tue, 31 December 2013, 18:15:54 »
Looks like you need to figure out which traces it was soldered to that broke.  Then re-create those traces with thin copper wires.  I'm not a USB connector specialist--hopefully someone who makes cables routinely can weigh in (or someone who knows about USB traces).
As to how to "stick" your connector back onto the PCB, you could probably glue it on with some epoxy glue under it. You can try this thread too:
http://geekhack.org/index.php?topic=42824.1590
And some high resolution photos of the connector and the PCB would be great to include as well.
« Reply #5672 on: Tue, 31 December 2013, 18:22:01 »
If I'm being honest, you're screwed. For an amateur to repair this is near impossible. You might as well buy a new one. Working on it will likely only leave you frustrated. The traces are so small, and the damage so severe, that I personally wouldn't even attempt a repair.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5673 on: Tue, 31 December 2013, 18:33:42 »
Looking at this again, you may not actually as bad off as I originally thought.  If I remember correctly, all  of the connections for that usb port is on the end.  Those pads seem to be in good shape.  If that is the case, then I would not recommend removing the part of the pcb that is attached to the usb, and instead use that to glue it back on.
If someone else can confirm that the 4 solder joints at the 4 corners of the usb is only for mounting to the board and the actual connections are the ones at the end, I think you may have a shot at fixing this.
Offline nzhao20
« Reply #5674 on: Tue, 31 December 2013, 18:42:14 »
Brian at EK said he was willing to fix it under the warranty. Should I just not do anything to avoid further damage?
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5675 on: Tue, 31 December 2013, 18:49:54 »
Yes, do that...  By far the best option...
« Reply #5676 on: Tue, 31 December 2013, 20:16:08 »
Ok, nevermind, I think I know what happened!
« Last Edit: Tue, 31 December 2013, 20:21:05 by Photoelectric »
« Reply #5677 on: Wed, 01 January 2014, 20:54:03 »
Where does the olivetti set come from, and where can I buy one?
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #5678 on: Wed, 01 January 2014, 20:56:34 »
« Reply #5679 on: Wed, 01 January 2014, 20:57:33 »
You can buy a set from Originative:
http://www.originativeco.com/collections/keysets/products/classic-beige-with-blue-legends
I've got that already, it's on my MJ2 with reds. That's why I daily drive it now lol.
I want an original one now.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #5680 on: Wed, 01 January 2014, 21:03:17 »
I see.  Let's wait for someone else to chime in with an answer for you. ;)
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #5681 on: Wed, 01 January 2014, 21:37:25 »
Be patient and willing to spend $400+ for it
« Reply #5682 on: Wed, 01 January 2014, 21:49:38 »
I agree with this. I didn't see any lube in the MX White switches I took apart. I no longer believe that the MX Whites have extra lube in them from the factory.
So you are saying mx whites are not factory lubed?
If they still do, then it must be incredibly hard to notice. He's saying he doesn't believe that they are.
The new one that I opened didn't have any extra lube on it. I've come across some of Lysol's old posts saying that all the MX switches come lubed from the factory so I'm not sure if the Whites have this typical lubing PLUS the supposed lube that an MX White supposedly has. If I were at home, I'd open more Whites up to see if they have lube on them.
But for now, I'm going to say I don't believe that MX Whites have extra lubing. Nor does it say that there is lubing in the DT wiki entry. And I don't see any lube in the DT Wiki picture.
Olivetti is a manufacturer of telecommunication devices like phones and tablets as well as computers. They've made typewriters and keyboards in the past. I'm not sure if they still make keyboards.
Olivetti asked Cherry to make a custom line of G80-3000s for them. The subline was called a G80-3011. It has the Olivetti keycap color scheme. I believe this is what inspired the set from Originativco.
« Last Edit: Wed, 01 January 2014, 21:52:18 by CPTBadAss »
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #5683 on: Wed, 01 January 2014, 21:52:42 »
I recently opened about a hundred (new) whites and they were all lube-less. It seems safe to say that they're no longer pre-lubed, even if they once were.
Offline yasuo
  • spanengan puyeng newbie
« Reply #5684 on: Thu, 02 January 2014, 00:25:57 »
Led on esc dead,because bad desoldering :confused:
49658-0
how to repair? :)
Logitech MK220 Colemak DH
« Reply #5685 on: Thu, 02 January 2014, 02:06:52 »
So what was the difference in the ones that had varying clicks?
If I remember correctly you posted that about half of yours had a different click sound.
  • Cherry Peasant
  • keycult.com
« Reply #5686 on: Thu, 02 January 2014, 08:32:50 »
Yep, about 45 with a hard, mx green-like click, 45 with the correct soft click, and 10 with no click at all. I spent some time comparing all three and found no noticeable difference between the three. (I don't have any tools for precise measurement, though.) Thechemist also believes that the bottom housing has something to do with it, and that replacing it can sometimes change the click; I was able to confirm this to a small degree, but nothing dramatic changed using 5 spare bottom housings on a clicking, soft-clicking, and non-clicking white stem/spring.
That's why my current theory is that it's black magic. (Clack magic?)
Offline MKULTRA
  • telling it how it is
« Reply #5687 on: Thu, 02 January 2014, 08:34:03 »
how to repair? :)
Follow the broken trace to where it leads next, then bypass with some wire.
Offline stancato9
« Reply #5688 on: Thu, 02 January 2014, 19:57:09 »
Anyone know where these blue topre caps are from?
They look similar to the ones on Elitekeyboards but they say "These keycaps fit Topre Realforce keyboards only!"
Hmm.
Poker 2 - MX Red
Offline BlueBär
« Reply #5689 on: Thu, 02 January 2014, 20:01:05 »
I think just some of the set is incompatible with the HHKB (i.e. right shift) but the Alphas and Spacebar fit.
« Reply #5690 on: Thu, 02 January 2014, 20:05:55 »
I still think they are lubed, that also makes sense as to why some click differently or not at all.
Offline stancato9
« Reply #5691 on: Thu, 02 January 2014, 20:16:13 »
Yeah, I thought that too. I guess they are from this set.
Poker 2 - MX Red
Offline yasuo
« Reply #5692 on: Fri, 03 January 2014, 11:35:18 »
what leopold release yellow version? :)
« Reply #5693 on: Fri, 03 January 2014, 11:47:27 »
Ducky has the yellow keyboard, not Leopold.
Offline yasuo
« Reply #5694 on: Fri, 03 January 2014, 11:50:26 »
I thik leopold fc700R release yellow version,soon :))
« Reply #5695 on: Fri, 03 January 2014, 18:17:24 »
Link?
A yellow FC660[C|M] would be nice :)
Offline HPE1000
  • Keycap Paparazzo
« Reply #5696 on: Fri, 03 January 2014, 19:13:49 »
Can you remove cherry plate mounted stabilizers without taking all the switches off the board? Do you just have to desolder the spacebar switch or would the whole board need taken apart?
Offline yasuo
« Reply #5697 on: Fri, 03 January 2014, 20:58:35 »
Link?
I know from distributor in my country FC700R Yellow :)
even i not found link on goggle/leopold.kr.etc :confused:
my friend in GH he will post soon,when the goods have arrived :D
« Reply #5698 on: Fri, 03 January 2014, 20:59:15 »
You would need to desolder the spacebar switch.
Offline do_Og@n
« Reply #5699 on: Fri, 03 January 2014, 21:01:52 »
Does anyone know anybody out there that could reball a graphics card in a monitor?
