Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6231810 times)
« Reply #5550 on: Wed, 18 December 2013, 18:22:44 »
I have never seen a dedicated numpad with only 5 rows.
Offline Nixietube
« Reply #5551 on: Wed, 18 December 2013, 18:24:44 »
this one has 5 but is so big it could have held 6...
« Reply #5552 on: Wed, 18 December 2013, 18:26:31 »
GHPad. It's not ready yet, but there will be a group buy once the PCB is tested and finished.
Offline Nixietube
« Reply #5553 on: Wed, 18 December 2013, 18:34:08 »
thanks, i guess i'll wait for that or have to live with the leopold extra row
« Reply #5554 on: Wed, 18 December 2013, 18:39:03 »
I am looking for a seperate numbpad with cherry mx blue switches that visually fits a poker. I really like the  Leopold FC 210TP  but the top row seems out of place. Is there a numbpad like the one i am looking for?
What do you mean by "visually fits"? Layouts look similar? Same color? Same profile?
The numblock has one row "too much" to fit with a keyboard that has no dedicated F key row
The overall design is great... just to many rows.
Off the top of my head? GHPad:
Seen top right from Komar
And the Filco Tenkeypad:
Picture from my review
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5555 on: Wed, 18 December 2013, 19:00:44 »
I know the difference between PCB and Plate mounted switches.  Basically the PCB mounted ones have extra plastic tabs that hold the switch to the PCB.  If a PCB has the holes for PCB mounted switches, you can use them with or without a plate.
I am wondering if the same thing is true for PCB vs Plate mounted stabilizers?  Is it exactly the same principle or is there any other reason why you could not use a PCB mount stabilizer with a plate?
« Reply #5556 on: Wed, 18 December 2013, 19:08:02 »
You can use a PCB mounted stabilizers on a plate mounted board; it just needs receiving holes in the PCB for the legs. Just can't use a plate mounted stabilizer on a PCB stabilizer mount only PCB.
My KMAC has Cherry PCB stabilizers on a plate.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5557 on: Wed, 18 December 2013, 19:16:37 »
Thank you.  So does Coster do pcb mounted stabs or are they all plate mounted?
« Reply #5558 on: Wed, 18 December 2013, 19:22:16 »
Does Coster do pcb mounted stabs or are they all plate mounted?
Costar stabilizers are only Plate Mount.
Offline Candyflip
« Reply #5559 on: Wed, 18 December 2013, 19:30:47 »
While you are at it Captain can you tell what is the switch tool and any reviews on it and how it works?
« Reply #5560 on: Wed, 18 December 2013, 19:37:10 »
Can you tell what is the switch tool and any reviews on it and how it works?
The_Beast designed MX switch opening tools.
How it works:
http://geekhack.org/index.php?topic=44749.0#post_Guide
http://geekhack.org/index.php?topic=44749.msg930193#msg930193
Review:
It works. You open switches with it. I like it.
Offline Candyflip
« Reply #5561 on: Wed, 18 December 2013, 19:42:11 »
How it works:
Review:
 Any idea where to buy it, can't see any group buy or sale tt
« Reply #5562 on: Wed, 18 December 2013, 19:42:42 »
How it works:
Review:
Classifieds. There's no GB right now.
Offline Pacifist
  • on hiatus
« Reply #5563 on: Wed, 18 December 2013, 20:00:41 »
How it works:
Review:
+1 Classifieds. Be fast tho, its really popular.
But the binder clip mod is just as good. Kinda hard to make at first, but once you finish it is really good
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5564 on: Wed, 18 December 2013, 20:13:40 »
How it works:
Review:
Still looking for one as well.  Pacifist, you beat me by like 2 mins on the last one that went up.  :)  Not sure that the binder clip is 'just as good' because you can mangle a switch pretty good with one of those things.  But...  They do work...
« Reply #5565 on: Wed, 18 December 2013, 20:18:22 »
You can mangle a switch with a bad Beast switch tool too. If made and used properly, either will work great and won't mess up the tops.  I've never had a problem with my binder switch tool.  The only problematic switch tops are the replacement tops and Beast's tool has a hard time with those too.
Offline adhoc
« Reply #5566 on: Thu, 19 December 2013, 05:35:22 »
I've ordered a kb from EK via USPS and I have a question. Tracking says it's been cleared on our customs here, so it should arrive fairly shortly. I'm not home a lot, however, so I'm wondering how will they deliver the keyboard to me? Do they just send it back to USA if I'm not at home or leave it at local post office or what do they do with the package in such a case?
I'm from Slovenia and we obviously have no USPS offices here.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #5567 on: Thu, 19 December 2013, 05:42:39 »
Some speculation:
USPS won't be the ones ultimately delivering the keyboard to you; they're working with a local delivery service. In the event that you're not home, they might reattempt delivery or your keyboard will hang out at the offices of the local service for some set number of days before being transferred back into USPS's possession.
« Last Edit: Thu, 19 December 2013, 05:47:55 by riotonthebay »
Offline adhoc
« Reply #5568 on: Thu, 19 December 2013, 05:45:06 »
Yeah, I just googled that they work with our local post office and that I'll be able to pick the package up there in case I'm not home
Offline McWilloughby
« Reply #5569 on: Fri, 20 December 2013, 13:05:05 »
Does anyone have any tips for removing shift keys on a G80-3000 (clears)? I just got an RGBY set in the post and I just can't get my two shift keys off with my keypuller. It isn't one of the wire ones, its the standard two prong plastic one that comes with a QFR. I've never had trouble removing the shift keys from another board but I guess it doesn't help that they are clears..
« Reply #5570 on: Fri, 20 December 2013, 13:23:06 »
clears can be tricky they seem to not want to let go.....and your also dealing with a PCB Mount board so if you pull too hard you might just pull the switch apart.
my suggestion is to get a wire puller but tread lightly
Offline BlueBär
« Reply #5571 on: Fri, 20 December 2013, 13:28:18 »
Eh plastic keypullers... Try pushing down carefully the stabilizers with a screwdriver or something similar, they like to break when you are pulling to hard on them. Pull on the end on which you are pushing down the stabilizer and if you could get it to move a bit on one side, do the same on the other side. Rinse and repeat.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5572 on: Fri, 20 December 2013, 13:32:58 »
I know this is not a 'simple question' but I don't want to start a new topic for a question that will probably have like two answers.
Which internal components will get the hottest on a keyboard?  I touched the chip on a usb hub once while it was plugged in and almost burnt my finger.  It was much hotter than I was expecting (obviously, or I wouldn't have touched it.  haha).  Will the controller be the hottest element or will the resistors get hotter?  What would be the top 3 hottest elements on the board and what temperatures do you think they could get to?
Offline yasuo
  • spanengan puyeng newbie
« Reply #5573 on: Sat, 21 December 2013, 00:20:43 »
how upload file.dwg in GH? :)
Logitech MK220 Colemak DH
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #5574 on: Sat, 21 December 2013, 06:30:43 »
In the editor, click "Attachments and other options" (highlighted in red below):
You should then see the menu for the attachments and other options (highlighted in red below):
Hope this helps. ;)
Offline yasuo
« Reply #5575 on: Sat, 21 December 2013, 06:52:53 »
Hope this helps. ;)
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #5576 on: Sat, 21 December 2013, 06:57:34 »
Hope this helps. ;)
You're welcome! :thumb:
Offline do_Og@n
« Reply #5577 on: Sat, 21 December 2013, 09:53:32 »
Does anyone know if Denture cleaning tablets will get the legends off of the Leopold F660C keycaps?
« Reply #5578 on: Sat, 21 December 2013, 11:49:53 »
Why risk it when you can just get a new set?
Offline BlueBär
« Reply #5579 on: Sat, 21 December 2013, 12:05:11 »
Denture cleaning tablets are generally used to remove the dirt off the keycaps. They shouldn't attack the legends, just don't leave them too long in there. Or do you want to get them off?
Offline do_Og@n
« Reply #5580 on: Sat, 21 December 2013, 12:06:59 »
Just trying to get rid of the legends. After they start to wear it drives me nuts.
« Reply #5581 on: Sat, 21 December 2013, 12:17:09 »
I've been using denture tabs to clean keycaps for ages. I haven't seen any of my legends fade or be attacked. If you're looking to remove legends, I don't think the denture tabs are the way to go.
« Reply #5582 on: Sat, 21 December 2013, 12:22:21 »
Thanks guys, I tried what you said BlueBär but to no avail, it works on my blacks but not clears sadly :\ I think I'll just wait until I get a wire puller. The tops of the switches come off almost every time I take a cap off (without breaking it) and it's pretty easy to put back together, I don't think it would be worth breaking the stabs though.
Offline do_Og@n
« Reply #5583 on: Sat, 21 December 2013, 14:03:07 »
Thanks, I'll try something else. I've got an extra set of Black Topre caps I can throw on there but that will only cover so many of them. Hate to have mismatched keycaps.
Offline HPE1000
  • Keycap Paparazzo
« Reply #5584 on: Sat, 21 December 2013, 15:40:38 »
EDIT: Didn't read the FAQ sorry lol
« Last Edit: Sat, 21 December 2013, 15:44:21 by HPE1000 »
Offline HPE1000
  • Keycap Paparazzo
« Reply #5585 on: Sat, 21 December 2013, 16:07:10 »
After some research I think I want to buy these, I want to know if anyone knows if there would be anything wrong with putting these on a poker.
http://www.ebay.com/itm/100-x-LED-3mm-UV-Purple-Ultra-Bright-Round-Top-LEDs-Light-Lamp-RC-Car-PC-T1-/151022044759?pt=LH_DefaultDomain_0&hash=item23299d8657
Specs are as follows:
Size   3mm Round Top Clear
Luminosity/Brightness   2,000-3,000 mcd
Forward Voltage   3.0-3.4v
Current   20mA
Wavelength   395-405nm
Viewing Angle   20-30 Degrees
Mount Style   Through Hole (DIP)
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5586 on: Sat, 21 December 2013, 16:30:36 »
Current   20mA
I think you will have to file off the top of those because they are round.  Here is basically the same thing but it is 2x3x4mm rectangular so you do not have to modify.  These are pink instead of purple though.  You can search on ebay for 2x3x4mm and you will get mainly these LEDs.  Check the forward voltage and resistance though as not all are the same...
  • Cherry Peasant
  • keycult.com
« Reply #5587 on: Sat, 21 December 2013, 18:31:22 »
Current   20mA
The stock LEDs on my keyboard are round. Is there a particular reason they can't be on a Poker?
Offline MJ45
  • HHKB Pro
« Reply #5588 on: Sat, 21 December 2013, 19:22:40 »
Current   20mA
Another thing to consider is possible eye damage from UV leds, most led equip t devices warn to avoid looking directly at the led light source.
« Reply #5589 on: Sat, 21 December 2013, 20:08:05 »
Are the A87 pcb files open source? If so, where can they be found?
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5590 on: Sat, 21 December 2013, 20:28:51 »
Current   20mA
Not really.  I hear you can run into problems with thicker keycaps because the bottom of the keycap apparently hits the top of the LED.
« Reply #5591 on: Sat, 21 December 2013, 20:36:53 »
That's why the LEDs are ground down on an angle on my KMAC. Old school
« Reply #5592 on: Sat, 21 December 2013, 22:44:10 »
I don't think they are.
Wasn't that why LZ had to make their own PCB?
Offline dndlmx
« Reply #5593 on: Sun, 22 December 2013, 05:08:43 »
When was the last clack factory sale? I haven't received any of those notifications in a while.
Offline domoaligato
« Reply #5594 on: Sun, 22 December 2013, 05:35:19 »
elitekeyboards.com had one in the form of a contest not that long ago.
you might signup for there newsletter and watch there site.
Offline adhoc
« Reply #5595 on: Sun, 22 December 2013, 05:56:09 »
I know this isn't really keyboards related, but may I ask where do people get these pictures of keyboards for their forum signatures? I'd like that as well :D
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #5596 on: Sun, 22 December 2013, 06:10:02 »
The keyboard pixel art things?  Over at http://geekhack.org/index.php?topic=19113.0
 :thumb:
Offline adhoc
« Reply #5597 on: Sun, 22 December 2013, 06:27:30 »
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #5598 on: Sun, 22 December 2013, 06:32:18 »
You're welcome! :D
And congrats on 100 posts!
Offline adhoc
« Reply #5599 on: Sun, 22 December 2013, 06:34:53 »
Hehe cheers :)
