Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6232388 times)
0 Members and 6 Guests are viewing this topic.
Offline Fullcream
« Reply #5350 on: Wed, 04 December 2013, 02:36:45 »
I'm sorry this is not keyboard related.
How to insert image into a post?  After I click insert image I paste the code in between  the two [img] things.
Using Flickr there is two options for the code. either </> or picture of a thumbtack code. When either is used the picture does not show up in the "preview post" option and there is just a very small icon or thumbnail where image is supposed to be and clicking on it makes it continuously load and nothing happens. Does the "preview post" option always do this? and the image will just work anyway or am I doing it wrong?
Offline yasuo
  • spanengan puyeng newbie
« Reply #5351 on: Wed, 04 December 2013, 02:50:57 »
I hope helps :) I think copy no2,no 1 just link :D
« Last Edit: Wed, 04 December 2013, 02:53:23 by yasuo »
Logitech MK220 Colemak DH
Offline Fullcream
« Reply #5352 on: Wed, 04 December 2013, 03:53:01 »
^^ Thanks. I just ended up using Imgur and seems to work fine
Offline mauri
« Reply #5353 on: Wed, 04 December 2013, 05:51:14 »
I'm wondering, my new ducky stopped working on my computer after rebooting. It flashes lights and doesn't work. It works on my laptop and the usb ports are fine since my other keyboards work thru them.
Any ideas?
I AM BABAR KING OF THE ELEPHANTS
Offline BlueBär
« Reply #5354 on: Wed, 04 December 2013, 05:54:11 »
Did you reboot your PC again? Did you try the other USB ports anyways?
Offline mauri
« Reply #5355 on: Wed, 04 December 2013, 05:57:44 »
Yes i rebooted and tested other usb ports
Offline BlueBär
« Reply #5356 on: Wed, 04 December 2013, 06:02:53 »
That's weird... Did you install any new software? Since it works on your laptop and used to work on your PC and the USB port is not the issue that makes me think that it's a software issue. Check your mainboard drivers for updates.
Offline LechnerDE
« Reply #5357 on: Wed, 04 December 2013, 07:32:45 »
Im interested in IMSTO's blue PBT dyesub set:
http://imsto.cn/index.php?route=product/product&path=59&product_id=61
Wasn't this available for ~75$ a couple of months ago? I don't wanna pay premium on this thing...
There's a price check thread. Please ask there.
Thanks for the tip, I wasn't aware of this thread.
« Reply #5358 on: Wed, 04 December 2013, 09:08:45 »
things.
The code to put a picture in a forum is:
Code: [Select]
[Img]pictureurlhere[/img]
For flickr pictures, I go and find the link that has sizes. So its under the picture's options -> other sizes. Find the size you like, I usually go for the 500 pixel option. Then copy that link as your url. Don't think you can just input flickr's options since those are HTML (I think) and the forum uses bbcode. If youre previewing an HTML picture link, that could be causing your non-loading picture issue.
« Last Edit: Wed, 04 December 2013, 09:16:11 by CPTBadAss »
Offline yasuo
« Reply #5359 on: Wed, 04 December 2013, 09:54:49 »
What is usually the size of the screws on the kibord?
« Reply #5360 on: Wed, 04 December 2013, 09:59:58 »
Don't think there is a standard screw size. The Poker/Pures use these screws. Forget what size my KMAC and Epsilon use...I'll have to check later.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #5361 on: Wed, 04 December 2013, 10:02:14 »
you need one more post for 6k there CPT.
« Reply #5362 on: Wed, 04 December 2013, 18:47:30 »
I couldn't find the KMAC or Epsilon screw sizes in a quick search. But I found screw sizes for the LZ-GH and what The_Beast used for his case.
LZ-GH = M3 6mm
The_Beast's case = http://geekhack.org/index.php?topic=44778.0
Offline yjfknt
« Reply #5363 on: Wed, 04 December 2013, 19:13:03 »
How would I go about changing the plate on a plate mounted board? Would I have to de-solder everything?
Offline dragonxx21
« Reply #5364 on: Wed, 04 December 2013, 19:16:17 »
You'd need to desolder all the switches in order to be able to snap them off the previous plate.
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
« Reply #5365 on: Thu, 05 December 2013, 14:26:54 »
Just a quick update for ya'll. If you didn't know, all posts are limited to 40,000 characters. The OP of this thread is very close to reaching that limit. As a result, I will be taking over the second post. I hope Strelok and the rest of you are ok with that. The question will be preserved of course but I'll need the other 39,900 characters or so to keep expanding the FAQ. And yes I have the ability to modify his post.
Offline yjfknt
« Reply #5366 on: Thu, 05 December 2013, 16:10:02 »
Follow up question, would there be a point to get aluminum case if I don't get an aluminum plate?
« Reply #5367 on: Thu, 05 December 2013, 16:11:13 »
Would there be a point to get aluminum case if I don't get an aluminum plate?
What point are you looking for? Many keyboards have a stock metal plate to begin with.
Edit: Not sure exactly what you're asking, need some clarification.
« Last Edit: Thu, 05 December 2013, 16:16:14 by CPTBadAss »
« Reply #5368 on: Thu, 05 December 2013, 16:18:36 »
You mean like, an alu case with an acrylic plate?
If you're willing to put the cash down for an alu case, the $35 (at imsto's site) for an alu plate should be pocket change :/
Offline yjfknt
« Reply #5369 on: Thu, 05 December 2013, 16:20:55 »
I'm thinking about getting a poker II, and an aluminum case so it's sturdier and sounds better? but I'm not sure what plate poker has originally.
« Reply #5370 on: Thu, 05 December 2013, 16:22:50 »
EDIT: CPT gave a better answer.
« Last Edit: Thu, 05 December 2013, 16:26:06 by TacticalStache »
« Reply #5371 on: Thu, 05 December 2013, 16:23:28 »
Poker II has a metal plate. Not exactly sure what metal it is but it should be stainless steel. Aluminum plates are super light and it's very easy to tell if its aluminum or not. Judged on other stock plates I've seen, it's probably not aluminum. I own an aluminum TKL plate and I've worked with a KMAC, Epsilon stainless steel and acrylic plates, and QFR stainless steel plate. It will be fine if you swap out the case to an aluminum one.
« Reply #5372 on: Thu, 05 December 2013, 17:13:38 »
You should really just get a Poker II, given the number of questions asked about them.  :P
And the plate appears to be steel to me as well.
« Reply #5373 on: Thu, 05 December 2013, 21:09:42 »
Can Alps be opened without desoldering?
« Reply #5374 on: Thu, 05 December 2013, 21:17:49 »
Yes.
« Reply #5375 on: Thu, 05 December 2013, 21:20:10 »
Yes.
yup, just figured it out.  now have to figure out how to reassemble this damn thing
« Reply #5376 on: Thu, 05 December 2013, 22:17:13 »
Yes.
Haha, yeah, that can be tricky.  Magnets or holding the board at a 90 degree angle can help.
« Reply #5377 on: Thu, 05 December 2013, 23:10:05 »
Yes.
Turned a flaky switch into a broken switch :))  Time to desolder  :rolleyes:
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5378 on: Fri, 06 December 2013, 10:44:14 »
Yes.
That sucks.  :(
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5379 on: Fri, 06 December 2013, 10:45:09 »
Is there a good description of how Alps switches are different (feel, sound, etc) from MX switches (or others) somewhere on here?
« Reply #5380 on: Fri, 06 December 2013, 11:55:13 »
I have a review of a Mr. Interface Switch try bag here and a review on the Dell AT101W from Akimbro's tour. There should be some Blue Alps reviews coming as well from Akimbo's Blue Alps tour. And the DT Wiki has some good info. I've also tried many of the common Alps and most of the MX switches if you want to discuss it in PMs or a different thread.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5381 on: Fri, 06 December 2013, 12:15:52 »
Great thanks, that gets me going...
Next question.  Are Alps keycaps available anywhere because I do not see them nearly as often as MX and even Topre...
Offline MKULTRA
  • telling it how it is
« Reply #5382 on: Fri, 06 December 2013, 12:17:29 »
Not at the moment.  Gotta harvest from boards.
Offline Melvang
« Reply #5383 on: Fri, 06 December 2013, 12:18:48 »
Unless you want to get a whole lot of practice doing stem mods
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5384 on: Fri, 06 December 2013, 12:31:37 »
Haha, alright then.  Guess I just need to keep an eye out if I want to build and Alps board.
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #5385 on: Fri, 06 December 2013, 12:32:04 »
There is a IC from alps caps though! Post your interest there too!
« Reply #5386 on: Fri, 06 December 2013, 12:34:55 »
Also Matias is currently creating tooling to make ALPS keycaps.
Offline Melvang
« Reply #5387 on: Fri, 06 December 2013, 12:38:04 »
If I am not mistaken are not all alps caps compatible with each other?  Like slightly different stems.  This could just be from some of the clones but a touch of clarification might be needed on this one.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5388 on: Fri, 06 December 2013, 12:44:39 »
Thanks, I will go find this...  :)
« Reply #5389 on: Fri, 06 December 2013, 14:53:57 »
Interest check is here. Problem is there's so many little differences for different boards and calavera wasn't sure what boards he should cover. Just making an ANSI 1.25x set isn't as easy as it seems since most Alps boards have slight variations in layouts. Also, he's busy.
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #5390 on: Fri, 06 December 2013, 20:15:44 »
whats the nearest MX switch to ML in regardss to stiffness and clickyness?
"Obviously, windows are central to Windows. But what is a window?"
Offline Fullcream
« Reply #5391 on: Fri, 06 December 2013, 20:20:37 »
ML feels like a short throw MX brown with off center friction issues. Also ML is not clicky. only has a bump.
« Reply #5392 on: Fri, 06 December 2013, 20:35:47 »
Could try Jailhouse Blues, but it's not a stock switch.
    • Force Project X
« Reply #5393 on: Fri, 06 December 2013, 20:55:29 »
Right on. thanks guys.
Offline yasuo
« Reply #5394 on: Fri, 06 December 2013, 20:57:42 »
See in ripster imgur
« Reply #5395 on: Fri, 06 December 2013, 21:01:33 »
Some info from the OP. Includes some ripster info.
Offline 1pq
  • Hipster Doofus
« Reply #5396 on: Sun, 08 December 2013, 01:24:07 »
Has anyone tried lubed blues with a slightly heavier spring (65g? or maybe the stock clear spring?)? I feel like this might be a really nice switch, but I'd definitely like to know if others have done this and what they think before I try modding anything.
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
« Reply #5397 on: Sun, 08 December 2013, 01:30:56 »
The lubed Blue on my tester feels like a Brown to me. I don't feel a click anymore and I'm not a huge fan. I know Binge really likes his 65g lubed Blues on his 2TU. I tried them but unfortunately I don't remember exactly how they feel. Hopefully he chimes in.
« Reply #5398 on: Sun, 08 December 2013, 01:32:47 »
CHIME!  My lubed 65g blues feel the most blue.  Stock blues are not nearly as crisp to the touch.  Kaliet did some serious magic. :D  Super crisp, great weight.
Offline 1pq
  • Hipster Doofus
« Reply #5399 on: Sun, 08 December 2013, 01:36:52 »
Cool, thanks. How do they compare to the feeling over ergo-clears? Just "sharper" tactility?
