Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6231855 times)
« Reply #5700 on: Sat, 04 January 2014, 07:50:29 »
Does anyone know anybody out there that could reball a graphics card in a monitor?
i don't, but you may be able to fix it yourself by reflowing in an oven. IS this an all-in-one PC? most monitors don't have the same sort of GPU in them as a PC would.
For what it's worth, I was able to fix the logic board of my sony FW900 this way, but then thy flyback died and I threw it out anyway after salvageaing it for parts.
Led on esc dead,because bad desoldering :confused:
how to repair? :)
gonna be hard. You can solder to the resistor and power lead on the USB, but then it's on all the time.
There are other possible fixes too, like heating up the lead itself a lot and flowing a ton of solder down there, you can sometimes get it to bond to the pad on the other side of the pcb.
Best of luck.
« Last Edit: Sat, 04 January 2014, 07:52:04 by dorkvader »
Offline Rea
« Reply #5701 on: Sat, 04 January 2014, 13:21:13 »
I just wanted to ask if the Logo (between arrow and function keys) on the HPE 87 is removable or if there is kind of a hole?
Offline do_Og@n
« Reply #5702 on: Sat, 04 January 2014, 13:29:58 »
@dorkvader - I'm going to try the baking process but from what I've been told that is a temp fix.
I would like to get the logic board reballed eventually though.
Thanks for the advise.
Offline HPE1000
  • Keycap Paparazzo
« Reply #5703 on: Sat, 04 January 2014, 17:22:17 »
Do you guys know where 122 cherry mx brown switches can be ordered?
Offline dragonxx21
« Reply #5704 on: Sat, 04 January 2014, 17:56:16 »
http://deskthority.net/marketplace-f11/cherry-mx-taking-pre-orders-t2760-1920.html for exactly 122 browns
http://www.originativeco.com/collections/accessories/products/cherry-mx-switch carries them in packs of 110
classifieds is always an option as well.
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline n7
« Reply #5705 on: Sun, 05 January 2014, 01:28:38 »
I was under the impression that only 6KRO is achievable over USB, but I've seen a few boards that seem to achieve higher rollover with only a single USB plug. I am using a Leopold FC200RT/KB and am able to light up as many as 16 keys (not including modifier keys, which I understand are registered differently) using http://www.microsoft.com/appliedsciences/content/projects/KeyboardGhostingDemo.aspx
Does this mean my keyboard actually has 16KRO over USB, or is there something to this concept I am missing? The board was purchase from elitekeyboards, which even stated on the product page that it only supported 6KRO over USB. I'm a little surprised (not complaining, mind you :))) to see it capable of much more than that.
Offline Pacifist
  • on hiatus
« Reply #5706 on: Sun, 05 January 2014, 03:03:24 »
kro is minum keys you can press at a time
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #5707 on: Sun, 05 January 2014, 10:52:00 »
No way!
Also, please don't answer a question when you have zero clue of the answer.
« Last Edit: Sun, 05 January 2014, 10:56:45 by tjcaustin »
Offline Rea
« Reply #5708 on: Sun, 05 January 2014, 11:45:03 »
Actually he is right...
6KRO describes only that your computer registers 6 Keys no matter which 6 keys you press. Most keyboards with 2KRO can register 6 or even more keys when they are in different parts.
In addition to that you can have NKRO over USB with some Keyboards even without special drivers
« Reply #5709 on: Sun, 05 January 2014, 12:03:32 »
He's right, yeah, but he could have explained it like you did, and not in a vague way.
Offline BlueBär
« Reply #5710 on: Sun, 05 January 2014, 12:37:31 »
Do Cherry relegendable caps come in different profiles or are they all E profile?
« Reply #5711 on: Sun, 05 January 2014, 12:48:36 »
I've seen them for the QWER row.
« Reply #5712 on: Sun, 05 January 2014, 12:52:18 »
Going by the info here they are E only.
Offline BlueBär
« Reply #5713 on: Sun, 05 January 2014, 13:02:06 »
E only would make sense. Looking at the data sheet E appears to have a horizontal surface and they are used in various POS matrix keyboards which would need a horizontal surface. Thanks for the help!
Offline moogle
« Reply #5714 on: Sun, 05 January 2014, 14:27:22 »
what does clipped stabs mean?
how does it differ from regular unmodified stabilizers?
an image would be nice as well ;D
Offline Pacifist
  • on hiatus
« Reply #5715 on: Sun, 05 January 2014, 14:28:44 »
bottom of the slider
clip off excess plastic
it makes it feel better
more bottom out space
there is a thread search sucks so i don't want to go find it
Offline BlueBär
« Reply #5716 on: Sun, 05 January 2014, 14:31:12 »
Check the link in my signature.
Also Pacifist, can you please start using punctuation and your shift keys? It makes your posts quite unreadable.
« Reply #5717 on: Sun, 05 January 2014, 14:32:41 »
Check this video out and the pictures in this thread. Also the link in BlueBar's signature will be helpful.
Clipped stabilizers are Cherry PCB stabilizers that have been clipped so that they feel different. To me the standard Cherry PCB stabilizers feel mushy and not crisp like Costar. Clipping the Cherry stabilizers allows the feeling to be there while retaining the ease of Cherry stabilizers (swapping caps is easier with Cherry stabs).
If you don't want to do the simple Google search to find the thread, then maybe you should at least put a little more detail into your response.
It's posted in the OP, but if you want to easily search Geekhack:
- Go to Google.com
- In the search field type in "Site:geekhack.org <your search phrase here>"
- So in this case, the search phrase would be "Clipped Cherry Stabilizers"
Offline moogle
« Reply #5718 on: Sun, 05 January 2014, 14:35:50 »
thanks!
there's a video too :thumb:
« Reply #5719 on: Sun, 05 January 2014, 14:37:37 »
The two pieces of plastic that you remove act as dampeners, making the stabilisers feel all mushy.
This mod can also be done on Cherry plate mount stabilisers. Some people have said it wouldn't work on plate mount stabilisers, but I have tried it myself and can confirm it makes them feel a hell of a lot better.
« Reply #5720 on: Sun, 05 January 2014, 14:39:25 »
Photekq, refresh my memory, I know we've talked about this before. Did you put tape/cardboard on the bottom of your plate mounted Cherry stabs?
« Reply #5721 on: Sun, 05 January 2014, 14:40:55 »
I did not. The stems of plate mount stabilisers definitely come in contact with the PCB, just like PCB mount stabilisers. You don't need to put any tape/cardboard there.
« Reply #5722 on: Sun, 05 January 2014, 15:03:11 »
Is there a post your geek hack key caps thread? I saw the contest before but i think that was it.
« Reply #5723 on: Sun, 05 January 2014, 15:06:48 »
Not that I know of.
Offline Pacifist
  • on hiatus
« Reply #5724 on: Sun, 05 January 2014, 15:16:47 »
I was thinking of making one
But I only have 8 GH caps, not enough to justify making a thread imo
Offline yasuo
  • spanengan puyeng newbie
« Reply #5725 on: Sun, 05 January 2014, 23:39:47 »
in fact, what size of 1.75 keycap / caps lock needs to stab? :)
Logitech MK220 Colemak DH
Offline tbc
« Reply #5726 on: Sun, 05 January 2014, 23:45:45 »
Does the shine 3 have the new cherry stabs that don't need to be clipped?  apparently they were first used on the zero shine series and people were happy not clipping.
« Reply #5727 on: Mon, 06 January 2014, 08:06:21 »
Don't think 1.75x caps need a stabilizer.
Supposedly some of the newer keyboards such as the Shine 3 come clipped or are molded differently. However I don't own a Shine 3 so I can't confirm this myself.
« Last Edit: Mon, 06 January 2014, 08:13:15 by CPTBadAss »
« Reply #5728 on: Mon, 06 January 2014, 08:12:24 »
Supposedly some of the newer keyboards such as the Shine 3 come clipped or are molded differently. However I don't own a Shinie 3 so I can't confirm this myself.
The clipped stabs were confirmed by someone very familiar with ducky boards.
« Reply #5729 on: Mon, 06 January 2014, 08:12:59 »
Link?
« Reply #5730 on: Mon, 06 January 2014, 08:15:03 »
Link?
I posted it here once before I'm pretty sure, probably when you were MIA  ;D
here ya  go
http://geekhack.org/index.php?topic=40501.msg1182389#msg1182389
« Last Edit: Mon, 06 January 2014, 08:17:38 by SpAmRaY »
« Reply #5731 on: Mon, 06 January 2014, 08:16:24 »
Link?
Link?
« Reply #5733 on: Mon, 06 January 2014, 08:21:36 »
Maybe? It might be glued on so you can try sanding it off or popping it off.
Offline Rea
« Reply #5734 on: Mon, 06 January 2014, 09:51:05 »
Actually I got an answer in another forum and yes it is only glued on but there is a hole under it >:(
But thanks for answering
Offline Trippy
« Reply #5735 on: Mon, 06 January 2014, 13:12:16 »
Hey guy's, I have had a Das Keyboard Ultimate w/ Blues for about three years now. I'm now looking into another keyboard and was wondering what y'all thought. I am looking for a tenkeyless with brown's. So far the options I have considered are a Leopold FC200RT/AB or a CMStorm Quick Fire Rapid. Out of those two what is the best quality or do you have any other recommendations for ~100usd.
« Last Edit: Mon, 06 January 2014, 13:13:54 by Trippy »
Keyboards: DAS Keyboard Ultimate w/ Blues/CM Storm QFR w/ Browns
PC Specs: Intel Core i7 4770k
Cooler Master Hyper 212 Evo
GIGABYTE GA-Z87X-OC
CORSAIR Vengeance 8GB 1600mhz
MSI GTX 660ti Power Edition
120gb Samsung 840 evo, 2 WD Blue 320gb
Fractal Design R4
Corsair HX 850
« Reply #5736 on: Mon, 06 January 2014, 13:16:26 »
Hey guy's, I have had a Das Keyboard Ultimate w/ Blues for about two years now. I'm now looking into another keyboard and was wondering what y'all thought. I am looking for a tenkeyless with brown's. So far the options I have considered are a Leopold FC200RT/AB or a CMStorm Quick Fire Rapid. Out of those two what is the best quality or do you have any other recommendations for ~100usd.
Under $100 I've been recommending the QFR. But if you're willing to bump your budget up $125, you can get a Leopold FC700R from Hendyzone which is really nice. I have a review on the 700R here.
Offline Trippy
« Reply #5737 on: Mon, 06 January 2014, 13:18:59 »
What is the difference between the 700r and the FC200RT/AB?
GIGABYTE GA-Z87X-OC
Fractal Design R4
Corsair HX 850
« Reply #5738 on: Mon, 06 January 2014, 13:22:50 »
As far as I know, there are different body shapes/styles, different color offerings on the case/caps, different spacing on the spacebar stems, and different keycap materials.
I believe the 200RT caps are ABS vs the PBT on the 700R.
Just an FYI, I don't own an 200RT.
Offline Trippy
« Reply #5739 on: Mon, 06 January 2014, 13:30:00 »
I might end up going with the FC200R because of it being cheaper than the 700r and I think the branding on the Quickfire Rapid would bother me.
GIGABYTE GA-Z87X-OC
Fractal Design R4
Corsair HX 850
« Reply #5740 on: Mon, 06 January 2014, 13:35:14 »
Ok. And if anyone's following this, I can't read. Hendyzone's price doesn't include shipping so that makes the 700R boards more expensive.
« Reply #5741 on: Mon, 06 January 2014, 13:35:21 »
Just be sure any spacebars you plan to use in the future are of the 6-post universal variety. Since Leopold cares not for spacebar stabilizer standard spacing.
I also recommend the QFR for the under $100 budget. The branding is now minimal, with just one logo on the back of the keyboard.
Offline Trippy
« Reply #5742 on: Mon, 06 January 2014, 13:39:13 »
Oh really they updated the QFR? Hmm, very compelling.
GIGABYTE GA-Z87X-OC
Fractal Design R4
Corsair HX 850
Offline n7
« Reply #5743 on: Mon, 06 January 2014, 14:00:34 »
The FC200RT/AB does in fact have ABS caps (I am typing on one now). But is it just the 700R has different spacing on the spacebar? I was under the impression that all Leopolds had weird spacing on the spacebar, which meant it would be difficult to use caps designed for other brands. Here is what the spacing looks like on my board. How does it compare to the 700R?
50013-0
« Reply #5744 on: Mon, 06 January 2014, 14:05:35 »
All Leopolds have non-standard spacing on the spacebars, for some reason. But the spacing on the FC200R is fine for Signature Plastics' 6-stem "Universal" 6.25-unit spacebar. They made it compatible with that (and only that) specific model Leopold.
« Reply #5745 on: Mon, 06 January 2014, 17:38:46 »
Not that I know of.
Yeah I only have 7.. Well someone should make one! :D
« Reply #5746 on: Mon, 06 January 2014, 17:40:04 »
Looking for Halverson to get off his ass and post his complete collection.
« Reply #5747 on: Mon, 06 January 2014, 17:46:37 »
hahha WHAT? I DONT EVEN HAVE ANY
« Reply #5748 on: Mon, 06 January 2014, 17:46:49 »
Actually I have a **** asss pic collection that  isnt full
« Reply #5749 on: Mon, 06 January 2014, 17:47:10 »
http://imgur.com/a/tXiWW#0
ENJOY THE BAD PICS AND BAD SPAM
