Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6229402 times)
« Reply #9650 on: Wed, 03 September 2014, 21:07:03 »
the little faces were not working earlier
Seems like if you quote a picture, the faces don't work.
« Reply #9651 on: Wed, 03 September 2014, 21:11:05 »
This is a very well known thing.  And I believe that if you quote a quote of a picture, it works.  Or something like that.  There's some way to have a picture quoted and have everything work just dandy.
Offline BlueBär
« Reply #9652 on: Thu, 04 September 2014, 05:37:27 »
well it seems as though gh refuses to let me post the picture but the MX spring definitely has a bigger diameter
I meant the diameter of all Alps springs should be the same, only their length might differ. MX springs have a bigger diameter and don't fit into Alps switches (and vice versa afaik).
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #9653 on: Thu, 04 September 2014, 06:39:16 »
ah sorry, read your reply wrong :thumb:
« Reply #9654 on: Thu, 04 September 2014, 07:22:11 »
Reported fohat.digs' post to bring it to the mods'/admins' attention. PMing or a friendly report seems to do  more for fixing problems than complaining idly.
I thought that multiple people have been complaining about this for years, literally.
A parallel nuisance is the inability to attach a photo in a PM.
- D Trump 2026-10-24
« Reply #9655 on: Thu, 04 September 2014, 08:25:09 »
I use imgur or Flickr so I don't really know. I'm not that into the GH attachment since it will lose photos and it's good to have a backup in case anything happens again to GH in my opinion.
« Reply #9656 on: Thu, 04 September 2014, 14:18:13 »
So is the forum completely crapping out or what? Every other thread I try and load stops part of the way through and if I try and go back a page it does the same thing in every thread......maybe I need to clear my cache....also still getting 504 errors.
« Reply #9657 on: Thu, 04 September 2014, 14:22:07 »
It's working fine for me; just loading slowly. Was doing that yesterday.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #9658 on: Thu, 04 September 2014, 14:58:32 »
Been doing it for me for a couple of days.
« Reply #9659 on: Thu, 04 September 2014, 15:04:46 »
no problems here
« Reply #9660 on: Thu, 04 September 2014, 15:41:30 »
Some people might like the ability to attach files to PMs for things like hex files and CAD drawings. :)
Offline philstahlfeld
« Reply #9661 on: Thu, 04 September 2014, 16:37:32 »
So I really like using programmer Dvorak, but I'm going to be pair programming with someone who uses QWERTY and we'll be doing so on multiple machines. My ideal solution would be to have a keyboard that I can carry around with me that has programmer Dvorak and QWERTY that I can toggle with a button or a switch. Is there a keyboard out there that I can do this with? Ideally, I'd like to just be able to flash different layouts to the keyboard.
Offline BlueBär
« Reply #9662 on: Thu, 04 September 2014, 16:42:43 »
The WASD V2 can do that afaik. Apart from that you could go for a programmable keyboard like a Phantom - that would require some soldering work though.
« Reply #9663 on: Thu, 04 September 2014, 18:29:49 »
It looks like the WASD V2 can do Dvorak, Colemak, Mac mode, and QWERTY mode, but not programmer Dvorak :/
http://www.wasdkeyboards.com/media/v2-user-guide.pdf
Offline BlueBär
« Reply #9664 on: Thu, 04 September 2014, 18:39:19 »
Ah okay well then an option is a programmable keyboard. With one of those you could set programmer dvorak on one layer and QWERTY on another and switch between the two with a key combination. You could also get a custom controller for a Filco for example - works the same way but is less work as you don't have to solder.
Offline minho
  • i'm kind of back
« Reply #9665 on: Fri, 05 September 2014, 01:50:47 »
Does anyone know exactly how close Cherry and SP DCS profiles are? I'm considering getting the mods from http://www.pimpmykeyboard.com/deals/greentea-set/ to go with some WoB Cherry doubleshots alphas I have, and wasn't sure how well they would match in terms of feel and appearance.
« Reply #9666 on: Fri, 05 September 2014, 05:22:20 »
dcs is SP's copy of the Cherry profile. They're very similar. The feel will be a bit off but the heights and the shapes should be fine. If someone reminds me, I can take a picture comparing the two profiles this afternoon.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #9667 on: Fri, 05 September 2014, 11:25:05 »
When shipping bare PCB's with nothing on them (enablers) is there any reason why I would need to put them in ESD bags or would regular ziploc bags work fine?
Offline BlueBär
« Reply #9668 on: Fri, 05 September 2014, 11:41:11 »
If there's nothing on them there's nothing that could get fried so I don't see an issue with that.
« Reply #9669 on: Fri, 05 September 2014, 11:49:36 »
I'd prefer ESD just to be on the safe side. I've received most of my PCBs with ESD bags.
Offline Melvang
« Reply #9670 on: Fri, 05 September 2014, 11:57:25 »
The reason I ask is because of the general caution people around here take when shipping stuff.  For what its worth Enablers have landed and they were just shrink wrapped in a heavy plastic.
Offline minho
  • i'm kind of back
« Reply #9671 on: Fri, 05 September 2014, 13:05:25 »
If you could take a picture of that and a picture comparing the thicknesses underneath, that would be really awesome!
« Reply #9672 on: Fri, 05 September 2014, 13:13:44 »
Grey Clover is SP, everything around it is GMK.
« Reply #9673 on: Fri, 05 September 2014, 13:58:42 »
right is SP, left 2 are GMK
the cherry mount is the same thickness as ALPS mount, so don't fret about that.
Offline frosty
  • jukebox hero
« Reply #9674 on: Sat, 06 September 2014, 04:37:59 »
edit: nvm it fixed itself again.
« Last Edit: Sat, 06 September 2014, 04:41:27 by frosty »
Offline BlueBär
« Reply #9675 on: Sat, 06 September 2014, 04:42:09 »
There are a few server issues right now, the admins are working on it.
Offline jorgenslee
« Reply #9676 on: Sat, 06 September 2014, 08:56:04 »
If an mx blue switch lost it clickiness, is it because of the stem or the left? I once experience an mx clear lost most of its tactility because of a bad left. I was able to fix by replacing the bottom switch. Is it the same with  mx blue? I was hoping it is because I have enough switch bottom and I have order from techkeys an mx blue.
« Reply #9677 on: Sat, 06 September 2014, 09:05:15 »
Could be wear in the housing or the stem I think. It definitely can't hurt to try swapping out the bottoms.
For some reason though, I have a nagging feeling it's now likely the stem. But that's just my gut feeling at this moment.
Offline Lastpilot
  • Power stance
« Reply #9678 on: Sat, 06 September 2014, 17:23:11 »
How does one go about programming a 38GT?
Edit: Nevermind, I think this is it
http://www.otd.kr/bbs/board.php?bo_table=aikon_down&sca=Firmware&sfl=wr_10&stx=&nca=
« Last Edit: Sat, 06 September 2014, 17:37:22 by Lastpilot »
Offline minho
  • i'm kind of back
« Reply #9679 on: Sun, 07 September 2014, 03:15:31 »
Thanks for some badass pictures (get it).
« Reply #9680 on: Sun, 07 September 2014, 04:59:55 »
The MX blues click is caused by that little white bit hitting the bottom of the switch.
Loss of that could be due to a small hair, fibre, grain of sand or liquid getting into the switch and dampening the internal movement.
If you are getting a replacement switch, you are probably looking to desolder the existing switch - so just replace the entire switch.  They are plentiful, so you won't need to replace it again in a hurry.
Offline jorgenslee
« Reply #9681 on: Sun, 07 September 2014, 07:41:12 »
Ahh ic, Thanks. I'm getting some mx blue switch from techkeys. For .06/piece it is a nice deal. I do hope there is some way to fix a non-clicky blue.
Offline ChThoniC
« Reply #9682 on: Mon, 08 September 2014, 00:00:28 »
What's the current recommended tenkeyless with cherry browns?
The last one I got says 3-5 months to ship from amazon http://www.amazon.com/gp/product/B007VDKLLM/ref=wms_ohs_product?ie=UTF8&psc=1
Offline suparnemo
« Reply #9683 on: Mon, 08 September 2014, 00:07:16 »
Elitekeyboards no longer seems to have any leopolds. Any idea what is going on anyone?
« Reply #9684 on: Mon, 08 September 2014, 00:49:28 »
QFR, Filco, Kul, Ducky. Great username btw, I love that band :).
Seems like they stopped carrying Leopolds in favor of the KUL boards.
Offline Kaibz
« Reply #9685 on: Mon, 08 September 2014, 09:05:01 »
Is it possible to mod or add a LCD like this one https://www.pjrc.com/tech/8051/board5/lcd_128x64.html to the Ergodox or is it impossible because the Teensy can not deal with a keyboard AND a lcd or because there are not enough pins on the teensy to deal with it (as numlock and vernum have to be dealt with) or is it even because the Ergodox pcb is not designed to "accept" a lcd?
(I'm asking this because i'd like to recreate the behaviour of a logitech G13 http://gaming.logitech.com/en-us/product/g13-advanced-gameboard with an Ergodox (for the left hand) and i wonder if it's that's even possible)
Sharing the knowledge
Offline frosty
  • jukebox hero
« Reply #9686 on: Mon, 08 September 2014, 09:33:04 »
i think with a ton of hardwiring and other stuff you can, but it's not worth it.
« Reply #9687 on: Mon, 08 September 2014, 09:34:04 »
I don't know if the Teensy will drive the LCD but I think you could get it running with an Arduino or Raspberry PI. Then you could integrate it into your setup. Or make a cousin case for it.
Definitely untrue. What's not worth it to you could be someone's biggest wish and worth investing the time and effort into.
Offline Kaibz
« Reply #9688 on: Mon, 08 September 2014, 11:30:36 »
Thanks a lot for your answers, i was hoping that a chip that could control a full keyboard and a lcd at the same time would exist.
I'm actually going though a lot of threads looking for "LCD" and 'Keyboard" and i can't find much, as you have all been here for a long time i was wondering if you had heard about a project about a custom keyboard with integrated lcd on geekhack?
Offline frosty
  • jukebox hero
« Reply #9689 on: Mon, 08 September 2014, 12:14:51 »
never thought of it that way. sorry! haha but yea good luck in your journey for the lcd panel thingy, rmb to post pictures if you get it!
« Reply #9690 on: Mon, 08 September 2014, 12:45:11 »
I can't recall of a thread that has that.
I'm at microcenter and they're selling an RPi addon that's got an lcd screen. That might work.
« Last Edit: Mon, 08 September 2014, 12:54:53 by CPTBadAss »
Offline Kaibz
« Reply #9691 on: Mon, 08 September 2014, 13:01:43 »
I'm going to have a look at that.
Of course i will post everything i find if i complete it.
Thanks again for the help.
« Reply #9692 on: Mon, 08 September 2014, 13:04:55 »
At microcenter, they've got a modded ducky zero out as a tester.
Sorry for the potato.
Offline jorgenslee
« Reply #9693 on: Mon, 08 September 2014, 22:57:07 »
What is KMAC? How do you know that a keyboard is a KMAC? I saw the IC of codyeatworld on KMAC PCB + Plate which will be produce by GON. I was wondering what really makes it a KMAC? Is it the PCB? Case? Or both? Sorry for the stupid question though.
« Reply #9694 on: Mon, 08 September 2014, 23:22:10 »
Is that an actual keycap set?
If not, why hasn't someone done one yet?
Offline Melvang
« Reply #9695 on: Mon, 08 September 2014, 23:25:28 »
Blanks in corresponding color?
« Reply #9696 on: Mon, 08 September 2014, 23:30:43 »
The legends!  "BLACK SWITCH", "RED SWITCH" and so on.
Offline nahka
  • Did you see that, Fio?
« Reply #9697 on: Tue, 09 September 2014, 00:23:20 »
Do the ISO sets in group buys usually include the letters Ö Ä Å or just 2 blanks?
  Poker II
    Reds
Offline ComradeSniper
  • HHKB Pro
« Reply #9698 on: Tue, 09 September 2014, 00:27:11 »
I've noticed that occasionally after I walk around on carpet for a bit and then touch my Kingsaver, I'll get a static discharge and the keyboard will stop working for a few seconds, then go back to normal. Is that harmful to the keyboard at all?
An update on this just in case anyone ever experiences a similar issue:
A few days ago I remembered that I had switched the keyboard's USB connection to the powered hub instead of directly into my computer. Switched it back to the computer and I haven't had the problem a single time since. Must've been a grounding issue with the hub.
Offline Melvang
« Reply #9699 on: Tue, 09 September 2014, 00:38:42 »
Would there be any sort of limitations I should be aware of if I wanted to use an unpowered USB hub for a mouse and keyboard?
By unpowered I mean just drawing power completely from the one USB port and not another usb port or wall wart.
IE would LED lighting on keyboard and "gamer" mouse such as Naga be to taxing?
