Author Topic: Noob Corner: Plates for keyboards  (Read 1935 times)
Offline eRadicatedZomBiE
  • It's OK, I'm A Doctor.
« on: Wed, 13 March 2013, 21:15:28 »
Hello all, I'm starting out in the whole mechanical keyboard world and it's great!
I'm trying to learn a little bit about everything.
I'm look at you experts, I would like your input.
I want to learn first about those "poker plates" and plates in general I keep seeing everywhere.
I'll start with a couple questions and go from there,
What are they?
And what do you do with them?
I apologize if this has already been brought up or discussed(could you link me to the discussion?)
Thank you in advance!
CM QFR | WASD V1 | Flico MJ2 LE Blue | Ducky 78 | Ducky DK9008G2 Pro LE  |Phantom |
Ergodox
My WTB Thread
Offline The_Beast
  • I like wood ಠ_๏
Re: Noob Corner: Plates for keyboards
« Reply #1 on: Wed, 13 March 2013, 21:24:02 »
What are they?
Plates are just metal with holes cut in them to support a switch. Since PCB's aren't that thick, they tend to flex. With a plate, that flex is eliminate or reduced which I think makes the board feel a lot more solid than just PCB mounting
To install a plate, you first have to desolder all the switches, install the switches onto the plate and then resolder those switches back onto the PCB. I've always like this picture to explain why to have to desolder:
If you want to read a lot of stuff surf this thread:
http://geekhack.org/index.php?topic=36039.0
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #2 on: Wed, 13 March 2013, 21:25:16 »
What are they?
 They're metal plates that reinforce the pcb to remove any flexing that happens when you type.
 You install your cherry mx switches into them and then solder that onto your pcb for delicious solid typey types.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #3 on: Wed, 13 March 2013, 21:26:23 »
Btb, I got one of your poker plates with this poker I traded my SSK for, beastmode.  Love it.  Now to just get some o' dem switch tools.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #4 on: Wed, 13 March 2013, 21:28:21 »
Soon™
Offline Jocelyn
  • 조셀린
« Reply #5 on: Wed, 13 March 2013, 21:38:15 »
In case OP would like to see  ;)
« Reply #6 on: Wed, 13 March 2013, 21:39:37 »
Are these plates universal(fit all boards)? Or do they have to be designed for certain manufacturers?
Btw thank you all for your quick responses.
Ergodox
My WTB Thread
Offline esoomenona
  • Gnillort?
« Reply #7 on: Wed, 13 March 2013, 21:43:13 »
They have to be designed for different keyboards. WhiteFireDragon actually made a semi-universal plate that works for a bunch of keyboards. Search for Universal TKL plate. Then there are plates for Pokers. And then there are many different plates for the many different layouts you can build with a Phantom.
