Author Topic: Flat cables  (Read 2417 times)
Offline Lastpilot
  • Power stance
Flat cables
« on: Sun, 17 March 2013, 20:21:03 »
I'm thinking about plopping down $8 for this flat USB cable from lacie: http://www.adorama.com/VDLAFCBL.html?gclid=CJiSr62LhbYCFQmFnQod7i4Aqw
But before I do, I'm have to ask what are your experiences with flat cables? Do they have a long lifespan?
Offline bavman
Re: Flat cables
« Reply #1 on: Sun, 17 March 2013, 20:52:32 »
I don't think lifespan would really be an issue since cables don't really get moved around to cause tearing unless its really old (plus I doubt flat cables would wear faster for just the reason they are flat unless your twisting them a lot). I think your main problem would be that if it gets twisted it won't look good, which isn't as big a deal with rounded cables.
But I don't think you'll have any problems with decreased lifespan.
Offline The_Beast
  • I like wood ಠ_๏
Re: Flat cables
« Reply #2 on: Sun, 17 March 2013, 20:55:14 »
Wat?
Offline Leslieann
Re: Flat cables
« Reply #3 on: Sun, 17 March 2013, 20:58:01 »
While I don't have flat USB cables, I do have a bunch of flat cat5e cables.
I tend to think the flat ones are just as good if not better for durability (the wires can't pinch each other if crushed), but there is a tradeoff.
At 10 feet on Cat5, they seem to work just fine, but on longer runs, I would be concerned with interference as I suspect flat cables typically aren't shielded as well. On USB though, you have shorter runs and less cross traffic, so you can get away with less shielding it seems, as some usb cables are pure junk but still manage to function.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Lastpilot
  • Power stance
Flat cables
« Reply #4 on: Mon, 18 March 2013, 10:38:51 »
Thanks for the responses guys. Will order :)
Offline Neal
  • Skype: iNewbcake
Re: Flat cables
« Reply #5 on: Mon, 18 March 2013, 17:47:18 »
My old in-ear earbuds had one, and I quite liked it. still somehow tangles up in your pockets though. :/
Lasted for 3 years or so of every day use, still works. But I changed earbuds.
Offline Michael
  • Formerly Bro Caps
Re: Flat cables
« Reply #6 on: Mon, 18 March 2013, 18:32:42 »
Offline Mandolin
  • Crystal Connoisseur
Re: Flat cables
« Reply #7 on: Wed, 01 May 2013, 03:23:25 »
But what's the point in flat cables? change the routine?
The color is pretty, though.
Artisan keycap Maker
Working on
- Custom keycaps
- Artkeycaps V2 sale
- Due chihuahua and demoncat orders
- Boobiecaps
- Optic fiber embedded keycaps
- Others
