Author Topic: GH60 Group Buy (Salvage Mode: Enabled - Update in OP)  (Read 2263663 times)
Offline Jocelyn
  • 조셀린
Re: Re: GH60 Group Buy (12 HOURS LEFT)
« Reply #1350 on: Tue, 23 April 2013, 00:24:07 »
who wants to be a pal and gift me one? i'll name my first child after your username!
I'll be more than happy to buy you one, but I want his name to be Lionel instead of bavman.
Rofl!!!
« Reply #1351 on: Tue, 23 April 2013, 00:25:42 »
i mean i hate kids, but i dont hate them THAT much.
Offline WhiteFireDragon
    • youtube
« Reply #1352 on: Tue, 23 April 2013, 00:29:31 »
You guys are killing me and jdcarpe with the never ending order changes.
I may be able to get the electronics components cheaper, so out the door price for the DIY kit could be around ~$15, maybe more, maybe less. I hate saying this, but if this could affect your decision, fill out a request for order change.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #1353 on: Tue, 23 April 2013, 01:02:10 »
Well the options keep changing!!! Every time I check this thread there is a new or changed option.
Either way I don't think any of us can thank you two enough for all the hard work.
 :p
    • youtube
« Reply #1354 on: Tue, 23 April 2013, 01:06:14 »
Either way I don't think any of us can thank you four enough for all the hard work.
Offline elton5354
« Reply #1355 on: Tue, 23 April 2013, 01:06:41 »
This will probably be my last order change then.
Offline Jocelyn
  • 조셀린
« Reply #1356 on: Tue, 23 April 2013, 01:08:11 »
OMG I don't want to be "that" person, but can I add a GH60 plate? I'll add it to my order now, but will not be upset if it's too late :)
Edit - Submitted
« Last Edit: Tue, 23 April 2013, 01:11:34 by Jocelyn »
Offline camelCase
  • Don't look at my toes.
« Reply #1357 on: Tue, 23 April 2013, 01:09:20 »
I just made my last order update adding a universal ANSI, no more changes I promise. You should enforce the order cutoff so you don't keep getting swamped, after my order is updated, of course  ;) I was wondering if I missed something for the assembly option? For people who ordered assembly service and more than one plate, how/where do they specify what switch layout they want? For instance I have a pure 1.25 plate and a universal, but I'm going for a poker layout on the universal ANSI. Will this be sorted when we move to the assembly stage? This really requires an amazing amount of planning and work, thank you for making something of this scale possible.
edit: Found the answer to my assembly question. Switch layout is specified at the assembly stage.
« Last Edit: Tue, 23 April 2013, 04:58:05 by camelCase »
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #1358 on: Tue, 23 April 2013, 01:17:05 »
Ordered.  HHKB stylee + universal plate just in case.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #1359 on: Tue, 23 April 2013, 01:19:05 »
So universal plate will work for any layout or any 1.25 layout? Is universal also a max switch placement plate?
SmallFry! <3
Offline elton5354
« Reply #1360 on: Tue, 23 April 2013, 01:21:57 »
In addition, there will be 2 more “universal” plates available. These plates’ main feature is the support for any possible hybrid layout from above. You’ll also be able to completely change layout using the same plate, by desoldering only a few switches and shifting them over (or adding/subtracting switches) rather than desoldering all switches and installing a new plate
does anyone read anymore?
Offline GeorgeK
« Reply #1361 on: Tue, 23 April 2013, 01:22:24 »
Any layout at all - if you look at the other plates you can see that the holes all fit within the universal's
Offline TheQsanity
  • SmallFry Lovin'
« Reply #1362 on: Tue, 23 April 2013, 01:35:24 »
Sorry for being dumb. I just wasn't clear to me.
SmallFry! <3
Offline stoic-lemon
« Reply #1363 on: Tue, 23 April 2013, 02:10:38 »
I didn't specify a spacebar wire size with my request for a Costar set. Do I need to? I'm getting the Samwisekoi plate if that matters.
Offline GeorgeK
« Reply #1364 on: Tue, 23 April 2013, 02:47:42 »
Not at all! It took me ages to figure out what I wanted (which is the only reason I know...) and even then I went for the universal plate because I'm still not fully decided!
Edit:
If you've ordered the Sawwisekoi plate then I assume they'll put you down for a 6.25 spacebar wire (as that's what you'll need)
Edit 2:
I'm tempted by a Samwisekoi (ish) layout with the short right shift on the right and a 1x key to the left of it but 1.25x mods across the whole bottom (maybe!)...
« Last Edit: Tue, 23 April 2013, 03:05:09 by GeorgeK »
Offline HannibalChew
  • Formerly PixelScript
    • gaffworks
« Reply #1365 on: Tue, 23 April 2013, 03:18:50 »
Just made a last change to my order, hope its not too late!
Offline Dgsbllx
Re: GH60 Group Buy (CLOSED)
« Reply #1366 on: Tue, 23 April 2013, 03:25:43 »
Crap, just seen 12 hours but time zones have screwed me over. Let me in!
Edit: wooo just seen my name on the bottom of the order confirmation, so I'm going to assume I'm in. Thank you very much  ;D
« Last Edit: Tue, 23 April 2013, 03:30:13 by Dgsbllx »
    • youtube
« Reply #1367 on: Tue, 23 April 2013, 03:34:53 »
Ordering is DONE. First two days had 78 orders submitted, last two days had 98. Basically all the action happens at the very beginning or at the very end.
tjcaustin, you're summoned.
  • Kitteh Overlord
  • Say WHAAT...
« Reply #1368 on: Tue, 23 April 2013, 03:42:47 »
My wallet hurts...
Offline osxoep
« Reply #1369 on: Tue, 23 April 2013, 04:41:25 »
Once I get to a computer I'm going to look up the totals. Maybe ~550 pcbs total?
HHKB Pro JP with hasu's controller (waiting for MX sliders)
Offline mauri
« Reply #1370 on: Tue, 23 April 2013, 04:56:25 »
I guess I shudn't post it here, but did anyone order their switches from 7bit recently, are you supposed to get some kind of confirmation and when is the payment due?
I AM BABAR KING OF THE ELEPHANTS
Offline LechnerDE
« Reply #1371 on: Tue, 23 April 2013, 05:03:55 »
Yeah, I ordered the switches for my GH 60 like 2 weeks ago. I got the invoice the same day. If I am not mistaken you'll have to pay within 7 days via paypal.
Offline vorn
« Reply #1372 on: Tue, 23 April 2013, 05:14:02 »
lol, I was also curious. I just copied the column values and added a "+" at the end of every line. The total I arrived at was 491. Wasn't as curious about the PCB kits, but that would definitely push it well over 500 I'm imagining.
Offline GeorgeK
« Reply #1373 on: Tue, 23 April 2013, 05:37:46 »
If you copy and paste into excel it unhides row 2
Edit: And as a result you can see that
PCB Assembled: 491
DIY Kit: 39
Bare PCB: 179
Total: 709
Although that 179 must include some from somewhere else as there aren't that many orders in that column...
Edit 2: Maybe there are actually...
« Last Edit: Tue, 23 April 2013, 05:42:57 by GeorgeK »
Offline Muffet
  • Man of many paths
« Reply #1374 on: Tue, 23 April 2013, 06:00:24 »
I'm guessing though I did not specify I need a 7x wire for the Ansi 1.5x that it is assumed?
Also I know when the payment deadline is, but do we have an idea of when invoices will be sent out? I am assuming after all orders have been sorted and organized quotes will be need where these will be manufactured and then invoices?
     Painted QFR    Cherry ML for Work
Offline v4mp1
« Reply #1375 on: Tue, 23 April 2013, 06:09:22 »
I have submitted a order change  :-X
Offline mauri
« Reply #1376 on: Tue, 23 April 2013, 06:12:46 »
Oh god, I'm a retard, I must've used a wrong email ;_;
Offline pix3l_fodder
« Reply #1377 on: Tue, 23 April 2013, 07:00:18 »
I guess with the lack of Costar x7 spacebar wires ill have to use Cherries instead.
Just to confirm my order is correct:
2x Assembled PCB
1x 1.25 ISO plate
1x 1.5x short right shift ISO plate
2x Cherry stab set (7x wire and 6.25x wire)
Offline v4mp1
« Reply #1378 on: Tue, 23 April 2013, 07:08:11 »
Is costar 6.25 sapcebar wire not compatible with 1.5x short right shift ISO plate?
Offline mkaito
« Reply #1379 on: Tue, 23 April 2013, 07:21:32 »
1.5x mod layouts have one less mod key to the right of the keyboard, which is why you need a 7x spacebar to fill the bigger gap.
« Reply #1380 on: Tue, 23 April 2013, 07:22:35 »
The WKL, HHKB iso spacebar from what ive been told is a 7x.
Offline v4mp1
« Reply #1381 on: Tue, 23 April 2013, 07:48:14 »
So where can i buy a 7.00 wire for costar stabilizers?
Is the 7.00 where i can buy here only compatible with cherry stabs?
« Last Edit: Tue, 23 April 2013, 07:49:54 by v4mp1 »
Offline Jocelyn
  • 조셀린
« Reply #1382 on: Tue, 23 April 2013, 07:49:04 »
I could really care less if I wind up getting a second plate (GH60), but I did put in a change to add one and would love to know if it was added or not. It's not currently showing on the order sheet.
« Reply #1383 on: Tue, 23 April 2013, 07:50:20 »
Just for clarification, if you're planning on a 1.5x layout of any kind, Costar stabilizers will not be in your future. The only spacebar wire available for Costar is 6.25. There will be no 7x spacebar wire for Costar.
This should go without saying, but if you're using a plate, you can use any of the three types of stabilizers. If you're not using a plate, or using an acrylic plate or Universal plate, you need Cherry PCB mount stabilizers.
It seems the stabilizers have caused the most confusion.
I haven't made any updates from the order changes spreadsheet since yesterday evening. I've been battling a cold. I'll work on them today. Not sure what WFD has done, as I haven't checked yet.
« Last Edit: Tue, 23 April 2013, 07:53:04 by jdcarpe »
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1384 on: Tue, 23 April 2013, 07:52:51 »
Any word on this price change?
Offline v4mp1
« Reply #1385 on: Tue, 23 April 2013, 07:54:00 »
I could make a costar 7x spacebar wire on my own?
Offline Jocelyn
  • 조셀린
Re: Re: GH60 Group Buy (CLOSED)
« Reply #1386 on: Tue, 23 April 2013, 07:58:39 »
That's promising, Thank You for the reply, and I hope you feel better soon.
PS - I haven't been sick in over five years. Number of years I haven't "been" with any guys? Five lol
It must be their fault. Probably for trying to get you out of your nerd cave. It's cold out there, gotta be careful. Mean guys...
Lol I found it to be ironic and had never thought about it before. Anyway I love all people and wasn't trying to bash men :)
« Last Edit: Tue, 23 April 2013, 08:03:20 by Jocelyn »
Offline mkaito
« Reply #1387 on: Tue, 23 April 2013, 08:00:53 »
  • Kitteh Overlord
  • Say WHAAT...
« Reply #1388 on: Tue, 23 April 2013, 08:14:24 »
Easy killer!  ;D I think most men have earned a little bashing here and there. It's all in good fun.
Offline fydo
  • Meow!
« Reply #1389 on: Tue, 23 April 2013, 10:29:10 »
Uh oh! I hope you're feeling better soon.
I sent a last-minute order modification to WFD via PM yesterday, but I don't think it has been applied. Should I have sent that to you instead, jdcarpe? I just wanted to have 65x Cherry MX Clears instead of the 65x Cherry MX Greys.  Thanks!
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
Offline agor
« Reply #1390 on: Tue, 23 April 2013, 10:34:08 »
Hope my order is clear that I want Ergo Clears. It says "Clears/Greys" in the comments, and that I'm about to source the springs myself :)
KBD8X II - MX 5000 - Realforce 88UB - Phantom - GH60
Offline Dubsgalore
« Reply #1391 on: Tue, 23 April 2013, 10:36:28 »
My Order is on the Order Confirmation Spreadsheet :)
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #1392 on: Tue, 23 April 2013, 10:42:00 »
was it expected there to be this many GH60 sold? like holy **** i did a SUM on the spreadsheet and was a bit shocked. i was expecting 2/3 that
Whoever has to sort these out deserves a metal, like literally we should start handing out metals to these group buy organizers.
Offline daerid
    • Rossipedia
« Reply #1393 on: Tue, 23 April 2013, 11:05:49 »
Holy EFFF 370 boards?!?
Damn I love this forum
Offline rknize
    • metaruss
« Reply #1394 on: Tue, 23 April 2013, 11:14:44 »
Why not round it off with breakfast at Milliways.
Russ
Offline aggiejy
« Reply #1395 on: Tue, 23 April 2013, 12:06:44 »
Indeed! I would not have guessed such interest in 60% boards without dedicated arrow keys. :)
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1396 on: Tue, 23 April 2013, 12:16:53 »
My order looks good except it doesn't show "Universal 10x spacebar (special order)" and I guess no one will be custom bending 7x costar wires so that could be removed and then everything will be about square :p
Offline domoaligato
« Reply #1397 on: Tue, 23 April 2013, 12:20:30 »
After WFD's informative post about the universal plates requiring cherry pcb stabilizers I had submitted a request to have my 3 changed to meet this requirement. now they show as cherry plate stabilizers?
Offline Glod
    • YouTube Channel
« Reply #1398 on: Tue, 23 April 2013, 12:21:11 »
who needs dedicated arrow keys? not i! but im sure someone will take the GH60 plate or similar and make dedicated arrow keys, i'm feeling it will happen
« Reply #1399 on: Tue, 23 April 2013, 12:21:23 »
Just so you know, the $25 assembly fee doesn't include opening every switch to replace springs. That will definitely be extra.
Fixed that for you.
Done. Universal 10x isn't in the plate section, so it's in your comments.
Took care of it.
And thanks! :)
« Last Edit: Tue, 23 April 2013, 12:24:07 by jdcarpe »
