Author Topic: GH60 Group Buy (Salvage Mode: Enabled - Update in OP)  (Read 2251874 times)
Offline GeorgeK
Re: GH60 Group Buy (INVOICING)
« Reply #1700 on: Sun, 26 May 2013, 03:24:26 »
I got a lot of PMs, mostly on order changes. I suppose you can still change orders (just fill it out HERE instead of PMing me), but once you've been invoiced, there will no more changes. We need stable numbers for quotes and invoicing.
Oooh - didn't realise final tweaks were still allowed.  In that case I've submitted a small change (one more PCB with SMD presoldered).
Thanks
George
Offline agor
« Reply #1701 on: Sun, 26 May 2013, 08:03:22 »
How is the status on Clear Switches? Especially for EU Orders - will you order them via 7bit, or do I have to do something?
KBD8X II - MX 5000 - Realforce 88UB - Phantom - GH60
Offline GeorgeK
« Reply #1702 on: Sun, 26 May 2013, 08:31:33 »
If they aren't available then Pexon is running a groupbuy for them right now
Offline Jocelyn
  • 조셀린
« Reply #1703 on: Sun, 26 May 2013, 08:37:31 »
Yes, but those are plate mount. I know they'll work fine, but it's not as ideal imo.
Offline GeorgeK
« Reply #1704 on: Sun, 26 May 2013, 10:47:34 »
Good point...  I forgot about that (mainly as I have a load of PCB mount housings that I could swap them with!)
Offline kaiserreich
  • HHKB Elite
« Reply #1705 on: Sun, 26 May 2013, 11:13:26 »
Please at least add some sort of a hard board when shipping Plates. Thick cardboards are useless.
The ones used by Beast for the Poker plates are great.
I previously had a shipment of a single Phantom plate with just bubble wrap, the condition it arrived in was ridiculous, and the Phantom GB organizers had to ship me another one.
It will definitely add weight to the shipment, but who wants a damaged plate?
Offline ForestFunK
« Reply #1706 on: Sun, 26 May 2013, 12:31:20 »
Maybe the bubble wrap is not that good of an idea
Qpad-MK-50 | ReɅlforce 88u
Offline esoomenona
  • Gnillort?
« Reply #1707 on: Sun, 26 May 2013, 12:35:34 »
I've folded cardboard around plates and it seems to be good in protecting them.
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #1708 on: Sun, 26 May 2013, 12:37:25 »
i can vouch for this, the moose himself shipped me a plate internationally wrapped in cardboard and it arrived perfectly
Offline Glissant
« Reply #1709 on: Sun, 26 May 2013, 12:44:53 »
Does it matter if switches are pcb or plate mounted if you are using a plate though?
Offline naokira
  • The King in the North
« Reply #1710 on: Sun, 26 May 2013, 12:46:37 »
You have to remove two pins if you want to use a pcb mount switch to a plate.
FaceW in LZ-CE
Offline esoomenona
  • Gnillort?
« Reply #1711 on: Sun, 26 May 2013, 12:46:46 »
It's not of great importance. Though some people prefer to use PCB mount with a plate if the PCB permits both.
Offline SmallFry
« Reply #1712 on: Sun, 26 May 2013, 12:47:55 »
Not with this PCB. :)
« Reply #1713 on: Sun, 26 May 2013, 12:49:54 »
Depends on the case. If you're using a plate from this groupbuy then you'd be best off using pcb since the plate isn't actually attached to anything. It's held in position by the switches. If you're using a user-designed case that comes with a custom plate that is screwed into the case then you won't need pcb mount switches.
Offline osxoep
« Reply #1714 on: Sun, 26 May 2013, 12:55:08 »
Nope. You can use either with a plate.
HHKB Pro JP with hasu's controller (waiting for MX sliders)
Offline mauri
« Reply #1715 on: Sun, 26 May 2013, 13:09:49 »
Wasnt it so that universal plates require pcb mounted switches?
I AM BABAR KING OF THE ELEPHANTS
Offline gnubag
« Reply #1716 on: Sun, 26 May 2013, 13:15:35 »
it is better to use them for the modifiers but you have to use pcb mount stabs with the uni plates.
Offline iAmAhab
  • Established member
« Reply #1717 on: Sun, 26 May 2013, 13:20:04 »
Here is hoping that my poker 2 with browns arrives before my invoice. Want to try browns out on a board before I commit to them.
The sample set from WASD did not really do much for me. I've only tried blacks, but I really enjoy them.
Offline mauri
« Reply #1718 on: Sun, 26 May 2013, 13:22:57 »
I stand corrected. It was also said that pcb mounted switches + plate make the structure very solid.
Offline Loligagger
« Reply #1719 on: Sun, 26 May 2013, 13:40:02 »
Invoice paid, thanks to everyone running this groupbuy.
Offline aggiejy
« Reply #1720 on: Sun, 26 May 2013, 14:00:23 »
Regarding packing the plates... I recommend buying a roll or two of this:
http://www.amazon.com/office-products/dp/B004RX1ATQ
It's cheap, and delivery people *do* pay attention that those most of the time.
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
« Reply #1721 on: Sun, 26 May 2013, 14:02:04 »
Is invoicing just though paypal? I still haven't received an invoice yet and I'm beginning to worry.
HHKB Pro 2   SmallFry Keyboard
Offline WhiteFireDragon
    • youtube
« Reply #1722 on: Sun, 26 May 2013, 14:02:35 »
This looks like the original black aluminum plates. Aluminum isn't as strong as stainless steel like the ones in this GB.
Btw, I received a prototype of the universal plate, pics will come soonish.
That only applies to PCBs that do not have proper holes for the pins, but not in this case. It's not a huge deal, but I recommend using PCB-mounted switches. Those two plastic pins provide a rock-solid mount of the switches, even though there's already a plate. It might a few extra minutes to install PCB-mounted switches, but you're only building this once so might as well take the extra step.
No, it makes no difference. Use PCB-mounted switches either way. If you have a custom-designed case where the plate is mounted into the case, then it still must hold up the PCB, only attached by the switches. If you're using the original plastic poker case, the PCB is mounted onto the case, and the plate is still held up by at the switches.
Offline Jocelyn
  • 조셀린
« Reply #1723 on: Sun, 26 May 2013, 14:04:17 »
Can't wait to see!!!  :)
Offline elton5354
« Reply #1724 on: Sun, 26 May 2013, 14:37:30 »
Check the spread sheet.
https://docs.google.com/spreadsheet/ccc?key=0AraAg2A1x5csdGhmV2xKd2h5SmZQUFFSa3ZSZ3BjWkE#gid=0
You are all the way down in the middle of the list.
Offline Leslieann
« Reply #1725 on: Sun, 26 May 2013, 16:16:09 »
Mine was the same way, though not as bad. I have to do some serious work to straighten it out before I can use it (haven't had time).
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
    • youtube
« Reply #1726 on: Sun, 26 May 2013, 16:19:26 »
Prototype plate came bent like a banana. Beast's signature bent plate from his source, in comparison to a phantom plate I got made from a local company.
But nothing 5 minutes of unbending can't fix.
Mounted on a prototype GH60 PCB
  • HHKB Pro
« Reply #1727 on: Sun, 26 May 2013, 16:42:26 »
Thanks, I did not realize there is a section for invoicing on the spreadsheet. My apologies.
Offline komar007
    • komar's blog
« Reply #1728 on: Sun, 26 May 2013, 16:47:27 »
The plate looks great!
Offline Jocelyn
  • 조셀린
« Reply #1729 on: Sun, 26 May 2013, 16:50:38 »
Offline elton5354
« Reply #1730 on: Sun, 26 May 2013, 16:51:51 »
Are you going to bend each and every plate? :P
    • youtube
« Reply #1731 on: Sun, 26 May 2013, 16:59:33 »
Are you going to bend each and every plate? :p
This is just a prototype plate that Beast help cut. But the final run will be from my own local company. The cut quality is better, and it's not bent, so ready to be soldered. I'd be crazy if I spent 5-10 min to unbend 550 plates before shipping. Refer to here for quality differences:
http://geekhack.org/index.php?topic=39410.msg900874#msg900874
Offline tadbitnerdy
« Reply #1732 on: Sun, 26 May 2013, 17:02:58 »
 :eek:  INVOICING!
(w00t)
Offline Nask
« Reply #1733 on: Sun, 26 May 2013, 17:06:32 »
Wallet is ready to pay :)
Keyboards: IBM SSK | Noppoo Choc Mini MX-Blue | PLU ML-87 MX-Brown | CM QFR Mx-Red | CM Novatouch
Offline fydo
  • Meow!
« Reply #1734 on: Sun, 26 May 2013, 17:17:31 »
Earlier in the thread I think people were talking about automatically changing Plate-mount switch orders to PCB-mount. Is that still happening? If not, can you please change my switches to PCB-mount in my order? Thanks! :D
« Last Edit: Sun, 26 May 2013, 17:31:23 by fydo »
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
Offline kaiserreich
  • HHKB Elite
« Reply #1735 on: Sun, 26 May 2013, 18:31:22 »
@wfd,
They are indeed aluminum plated from the 1st GB.
Bending them back into shape did not work.
I sincerely hope the steel are strong enough.
That being said, my order is probably going into a box anyway. That should be good enough for me.
Offline nebo
« Reply #1736 on: Mon, 27 May 2013, 01:15:31 »
If I haven't been invoice yet, is it possible to change what plate I ordered?
Offline GeorgeK
« Reply #1737 on: Mon, 27 May 2013, 01:53:49 »
The plate does look awesome!
On another note, I see my order hasn't been updated - I don't mean to pester but I don't want it to still be wrong when I get my invoice through, thanks.
Offline zenuty
« Reply #1738 on: Mon, 27 May 2013, 02:17:35 »
WOW AWAESOME  :)) :))
LINE ID : zenuty
Skype ID : zenuty
www.facebook.com/zenuty
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1739 on: Mon, 27 May 2013, 02:25:41 »
ALSO:
So all the invoices have not gone out correct?
Correct, I woke up to a water heater trying to flood my house so I've not had time to create/send more.
Offline mauri
« Reply #1740 on: Mon, 27 May 2013, 05:38:12 »
With cherry pcb mounted stabs can you have the switch anywhere you want right?
Offline Jmneuv
« Reply #1741 on: Mon, 27 May 2013, 06:21:51 »
pcb mounted is what you use with the universal plate, if that's what you were asking;
Offline mauri
« Reply #1742 on: Mon, 27 May 2013, 06:33:19 »
I know, but the location of the spacebar switch, can it be altered as I please, so that the cherry g80 series 6x spacebars fit.
Offline txepox
« Reply #1743 on: Mon, 27 May 2013, 07:08:59 »
Several weeks ago, I changed my order.
Looking at order confirmation form, my order is still highlighted. I am not sure what I am doing wrong . Can somebody help me?
Offline mauri
« Reply #1744 on: Mon, 27 May 2013, 07:21:44 »
Doesn't look highlighted for me, but I guess you haven't specified whether you want pcb or plate mounted switches
    • youtube
« Reply #1745 on: Mon, 27 May 2013, 07:28:27 »
^ Sorry, it looks like the cells shifted but the highlight was still there. Basically every column was off by one. Your order is correct. I went back to clear all highlights since I have to go back and retally all the stabs.
Any old highlights means that the stabilizers were not ordered correctly, or it doesn't match the plate. There are quite a few of these, so at this point I'm just going to use my best judgement to change incorrect stabilizer orders.
Again, here are stabilizer conditions:
- you must specify stab type (PCB-mounted cherry, plate-mounted cherry, or Costar), and spacebar wire size (6.25x or 7x)
- universal plate must use PCB-mounted cherry. They can use 6.25x or 7x spacebars wires
- any 1.5x plates must use 7x spacebar wires
- any 1.25x plates must use 6.25x spacebar wires
- costar stabs do not come in 7x wire size
Offline Jmneuv
« Reply #1746 on: Mon, 27 May 2013, 08:33:44 »
Now i understand, you probably mean the bump in the wire that goes around the switch.
I found this mashby photo on the internet: here the bump is very wide, so that should allow various switch positions.
http://www.flickr.com/photos/mashby/8615184096/in/set-72157632855279271
Offline mm87
« Reply #1747 on: Mon, 27 May 2013, 23:04:40 »
Got my invoice, but I think my shipping should be $11 (Czech Republic) instead of $21.
Offline nebo
« Reply #1748 on: Tue, 28 May 2013, 00:02:33 »
Just got my invoice, but earlier today I removed switches from the order advised by this post, but they're still invoiced.
Offline cgbuen
    • cgbuen.io
« Reply #1749 on: Tue, 28 May 2013, 00:15:05 »
PM'd tjc about some order issues. Hope you can get around to looking it over soon!
