Author Topic: GH60 Group Buy (Salvage Mode: Enabled - Update in OP)  (Read 2263822 times)
Re: GH60 Group Buy (INVOICING)
« Reply #1800 on: Tue, 28 May 2013, 16:21:34 »
Switches bought through this GB will ALL be PCB mount (MX1A-xxxx/NW). Even if you specified plate mount, you're getting PCB mount switches, as we stated long ago this would be the default and only option.
« Last Edit: Tue, 28 May 2013, 16:26:29 by jdcarpe »
Offline Latin00032
« Reply #1801 on: Tue, 28 May 2013, 16:24:52 »
I thought they were pcb mounted but pate supported. If that makes any sense.
Offline esoomenona
  • Gnillort?
« Reply #1802 on: Tue, 28 May 2013, 16:26:56 »
PCB mount or plate mount are just colloquial names assigned to the fact that one has mounting pins and the other does not. All switches from this GB will be PCB mount switches.
If you're discussing the actual mounting of them, the PCB supports the mounting pins, and plates support either/or. I think it's important for the switches here to be PCB mount, seeing as the PCB supports it, and because not everyone is going to use a plate.
« Reply #1803 on: Tue, 28 May 2013, 16:29:32 »
All MX switches mount to a plate with no issues. These have the two plastic pins for PCB mounting on supported PCBs (of which the GH60 PCB is one). If you want to mount these PCB-mount switches on a PCB that doesn't have the proper holes for the plastic pins, you just snip off the plastic pins and proceed. Plate or no plate, you can use these switches with the GH60 PCB.
Offline Muffet
  • Man of many paths
« Reply #1804 on: Tue, 28 May 2013, 16:52:04 »
Contemplating if I want to deal with LEDs considering I don't have keys for backlighting.
Wait, what keys besides caps can have leds?!
[/quote]
Woopsie! I meant caps, not keys, silly me.
     Painted QFR    Cherry ML for Work
Offline Leslieann
« Reply #1805 on: Tue, 28 May 2013, 16:52:55 »
All are plate supported.
The only difference is extra pcb supports on the pcb ones.
If a board has the holes, you are better off using them, if it does not, you can always grind them off.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline osxoep
« Reply #1806 on: Tue, 28 May 2013, 17:00:18 »
ow my bank account.
paid :)
edit: hang on. My order was changed on the sheet.
I ordered 2 PCBs, 1 ISO 1.5x Pure Shift + PCB and Plate stabs and 65x MX greens.
But the order sheet says a "true" HHKB plate.
tjcaustin could you have a look at this?
HHKB Pro JP with hasu's controller (waiting for MX sliders)
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #1807 on: Tue, 28 May 2013, 17:19:18 »
Paid.
Offline domoaligato
« Reply #1808 on: Tue, 28 May 2013, 18:11:40 »
That layout is possible. That would be the Max Keys plate, though the Left shift and the key next to it would be switched around. Or you could just do it without a plate.
I thought the Universal ANSI plate could do all the layouts including the max keys layout?
My main concern was the pcb switch positions. Thanks!
Offline gnubag
« Reply #1809 on: Tue, 28 May 2013, 18:22:48 »
if i see it correctly your enter and scroll lock don't work out. the 1u would be on the left and the  1.25 on the right
Offline MKULTRA
  • telling it how it is
« Reply #1810 on: Tue, 28 May 2013, 20:29:28 »
WOW that invoice.  Whew.  Will pay shortly.
EDIT:  I also ordered assembly, I don't see that on my invoice?
« Last Edit: Tue, 28 May 2013, 20:31:06 by MKULTRA »
Offline Latin00032
« Reply #1811 on: Tue, 28 May 2013, 20:42:03 »
I meant to include the plate mounted stabilizer set. I can't tell if it was included. I don't think it was and I was already invoiced.
I'm petty sure that's the only thing I'm missing.
Offline Trueno86
« Reply #1812 on: Tue, 28 May 2013, 21:05:50 »
Paid!  Thanks for all the hard work!
Offline mkaito
« Reply #1813 on: Wed, 29 May 2013, 00:22:23 »
Just received the invoice. It's due immediately? I'll need 2-5 days to move money around before I can send payment. I'm a couple dollars short on my Paypal balance.
Thank you for your hard work!
Offline 4LI4Z
« Reply #1814 on: Wed, 29 May 2013, 04:05:58 »
Where are we supposed to get that invoice, via email or on geekhack?
Because I haven't got anything by now and the list says I'm invoiced.
BLING BLING GOLD SPRING
ErgoClear Filco MJT2 TKL || Apple EK II || Hall Effect Keypad || Cherry G81 HAD || IBM M SSK
Offline zoidbergslo
« Reply #1815 on: Wed, 29 May 2013, 05:53:42 »
check your paypal account
Filco Tenkeyless
Offline GeorgeK
« Reply #1816 on: Wed, 29 May 2013, 06:30:46 »
I've found in the past that I've had invoices to pay in my paypal account that I hadn't been notified about any other way...
Offline 4LI4Z
« Reply #1817 on: Wed, 29 May 2013, 10:57:52 »
Alright, thank you. Paid!
Offline nebo
« Reply #1818 on: Wed, 29 May 2013, 11:13:30 »
This is my pending layout, was going to go for a hhkb style but I really do need the arrow keys and I don't want them on a fn layer... Suggestions open, I'll post the firmware whenever I have my board and it is working if people want it.
http://imgur.com/XOc822j
Offline simkev
« Reply #1819 on: Wed, 29 May 2013, 11:58:54 »
paid
JAG ÄR LIVRÄDD FÖR ATT LEVA & JAG ÄR DÖDSRÄDD FÖR ATT DÖ
| Poker X - Ergo Clears & Red Alert 2.0 | Majestouch 2 TKL - Browns & Blue Cream Cheese |
Offline elton5354
« Reply #1820 on: Wed, 29 May 2013, 12:06:20 »
Can I add more to my order if I already paid?
« Reply #1821 on: Wed, 29 May 2013, 13:22:23 »
Pretty sure we're firm on if you're paid already, your order is locked. But I sent you a PM and copied TJ, who is doing the invoicing.
Sorry for not replying earlier, I've been out of the office all morning on the road.
Offline polarpigs
« Reply #1822 on: Wed, 29 May 2013, 14:48:31 »
Hi! My invoice had shipping (international price) added to it but I really dont know where I'll be by the time this ships (will be in California if it's September.) This caused my order to be 150.37 :/ Can I, instead, have a shipping invoice resent for when the board is ready to ship to me or when a shipping time is confirmed? Because I really don't want to pay extra if i'm going to be in the USA by the time this ships :/
Thanks~
« Reply #1823 on: Wed, 29 May 2013, 14:52:25 »
Thanks~
Sent you a PM.
Offline reality404
« Reply #1824 on: Wed, 29 May 2013, 17:58:30 »
Paid thanks.
« Last Edit: Wed, 29 May 2013, 18:01:35 by reality404 »
Offline osxoep
« Reply #1825 on: Wed, 29 May 2013, 18:15:02 »
Just wondering about this
Offline tradet
« Reply #1826 on: Thu, 30 May 2013, 03:34:39 »
Paid!
Now there's only a few months of waiting left!
Offline mkaito
« Reply #1827 on: Thu, 30 May 2013, 09:51:58 »
My bank worked fast for once, so money moved early. Just paid the invoice. Thanks for your work!
ETA is still at some point between July and September?
Offline aggiejy
« Reply #1828 on: Thu, 30 May 2013, 10:14:16 »
It's been a couple days since I paid... still cringing when I hear footsteps as I'm pretty sure my wife is going to sneak up behind me with a Model M...
Offline domoaligato
« Reply #1829 on: Thu, 30 May 2013, 11:00:35 »
that is why I sold all my kbt race's
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #1830 on: Thu, 30 May 2013, 13:33:17 »
I haven't got mine yet, but I fear the wife seeing it... Glad my Filco case is plastic.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #1831 on: Thu, 30 May 2013, 15:43:38 »
i lol'd because my wife doesn't know yet that i got these and i'm sure she wouldn't be happy if she found out!
honestly the bill wasn't that bad, i didn't register in how expensive the cherry stabs would be until i got the bill but when you take those out this was a damn good deal for how much i got.
bravo to the GH60 team and good luck!
Offline Laladila
« Reply #1832 on: Thu, 30 May 2013, 17:10:45 »
Mmm I didn't receive my invoice can you check please ?
TIA
Offline mauri
« Reply #1833 on: Thu, 30 May 2013, 17:13:09 »
TIA
Not all the invoices are sent yet, the order confirmation sheet has invoicing column but can't tell if it's in realtime
I AM BABAR KING OF THE ELEPHANTS
Offline Laladila
« Reply #1834 on: Thu, 30 May 2013, 17:15:40 »
Oups I missed that info thanks for the info I'm gonnna check the Confirmation list
Offline domoaligato
« Reply #1835 on: Thu, 30 May 2013, 18:03:22 »
Thanks! I will probably go with the gh60 max keys layout with the mx locks until I can determine if the layout works for me.
I am a die-hard counterstrike player. (since 1.3!) this is for cs + voice chat. the toggles are for voice toggle basically.
Offline beauthegamer
« Reply #1836 on: Fri, 31 May 2013, 01:34:26 »
Paid. Anticipation rising!
Filco Majestouch 2 Ninja with wood blue case and reds | HHKB Pro II non-printed black | Phantom with ergo clears
Offline gnubag
« Reply #1837 on: Fri, 31 May 2013, 01:41:53 »
done and done
Offline battletux
« Reply #1838 on: Fri, 31 May 2013, 01:42:33 »
Paid!  :p
Can't wait for the bits to get here. Now to source a case and keys for them.
Offline LechnerDE
« Reply #1839 on: Fri, 31 May 2013, 02:24:06 »
Just got my invoice and paid it.
One question though:
I ordered 2 different plates and chose 1x assembly service. I wrote in the order form which of the two I want to have assembled, but this information doesn't show in the confirmation spread sheet anymore.
How does the assembly guy know which switches to solder on which PCB/plate combo?
Offline Dsan
« Reply #1840 on: Fri, 31 May 2013, 02:39:33 »
Paid,thank you! :D
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1841 on: Fri, 31 May 2013, 02:42:00 »
This:
I want 1 board with these specifications assembled by you guys:
1x GH60 PCB
1x ISO 1,25 Plate
1x Costar stabs, Plate-mounted
+ white Cherry MX switches ordered via 7Bit on Deskthority.net
The rest of my order is for me to build a second board:
1x GH 60
1x ISO universal plate
1x PCB mounted cherry stabs (spacebar 6,25)
is still in the comments.
Offline Tranquilite
« Reply #1842 on: Fri, 31 May 2013, 02:46:34 »
Paid. I was secretly hoping the shipping cost would be cheaper because I only purchased a PCB, but them's the breaks. At least i can rest assured that mine will most likely ship sooner because I didn't order any plates/extras.
Offline LechnerDE
« Reply #1843 on: Fri, 31 May 2013, 02:51:08 »
This:
1x GH60 PCB
1x ISO 1,25 Plate
1x GH 60
Good, this is still in there :)
Thanks for replying so fast!
Offline bugsaint
« Reply #1844 on: Fri, 31 May 2013, 03:07:00 »
Invoice recieved, however my shipping costs are $21?  Isn't my board being assembled and shipped within the EU from komar?  Switches were ordered from 7bit.
Offline Kmynis
« Reply #1845 on: Fri, 31 May 2013, 03:31:00 »
Already paid. Really excited about this little adventure
HHKB Type-S
Filco TKL MX Red
Offline pasph
« Reply #1846 on: Fri, 31 May 2013, 03:39:17 »
Paid
« Last Edit: Fri, 31 May 2013, 04:13:18 by pasph »
Offline cyberwave
« Reply #1847 on: Fri, 31 May 2013, 03:41:27 »
wow! shipping for this little monster costs a bomb! :eek:
Offline GeorgeK
« Reply #1848 on: Fri, 31 May 2013, 03:53:10 »
Just received my invoice, thanks.  Can I double (triple) check that where it says 'GH60 plate' that is in fact an ANSI Universal plate?  Once that's confirmed I'll pay straight away - thanks.
George
Offline bugsaint
« Reply #1849 on: Fri, 31 May 2013, 04:25:00 »
PAID
