Author Topic: GH60 Group Buy (Salvage Mode: Enabled - Update in OP)  (Read 2263064 times)
Offline miscsubbin
Re: GH60 Group Buy
« Reply #350 on: Mon, 25 March 2013, 16:41:35 »
Hey I'm pretty new here and I was wondering if something like this would ever show up again (I'm not in the position to be buying a new keyboard now). If not,  what would I need to buy now that I wouldn't be able to in the future? PCB, plate, case (let's hope not)? That way I could buy as little as possible, and then finish it when I have the money.
Thanks, a lot.
Offline cobraj
Re: GH60 Group Buy
« Reply #351 on: Mon, 25 March 2013, 16:56:40 »
Thanks, a lot.
Sounds about right.
But if you are really strapped for cash, you can do without the plate, but then just note that you have to buy PCB-mounted switches then. (Plate-mounted switches will not work without a plate).
Tinlong has an interest check for plastic cases, so they should be a lot cheaper than the aluminium ones. Not nearly as nice, but cheaper :P
Offline elton5354
GH60 Group Buy
« Reply #352 on: Mon, 25 March 2013, 18:24:20 »
Can someone tell me the size of the LED required to fit in a cherry switch LED hole? Thanks.
Offline gnubag
Re: GH60 Group Buy
« Reply #353 on: Mon, 25 March 2013, 18:30:44 »
t1 aka 3mm
« Last Edit: Mon, 25 March 2013, 20:43:52 by gnubag »
Re: GH60 Group Buy
« Reply #354 on: Mon, 25 March 2013, 18:59:08 »
That's T1
Offline gnubag
Re: GH60 Group Buy
« Reply #355 on: Mon, 25 March 2013, 20:43:40 »
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
Re: GH60 Group Buy
« Reply #356 on: Mon, 25 March 2013, 21:05:19 »
I would like to add LEDs to my keys but I have mine being pre-built. Is this possible?
Offline LifeZ
  • LifeZone
Re: GH60 Group Buy
« Reply #357 on: Mon, 25 March 2013, 22:02:38 »
GH60 GREAT!
ALL LAY-OUT Compatible
....GOOD
I drawing to GH60 mix layout..
LZ Limited
Offline Lugoues
Re: GH60 Group Buy
« Reply #358 on: Tue, 26 March 2013, 00:20:34 »
UPDATE:
 Also Samwisekoi requested his layout changed, so it now has a split L-shift (1.25x + 1x). The OP will now reflect these changes, and the order form will now have that additional dedicated HHKB plate.
Noooooo  :-[
Hmmm... now what do I pick
Offline ItsBc
  • BARACOOT
    • Portfolio
Re: GH60 Group Buy
« Reply #359 on: Tue, 26 March 2013, 03:43:08 »
Thank you very much!
Also, FYI to all, I am going to open up a Klaxon/GH60++/RGBY Mods group buy to support all of the GH60 configurations.
 - Ron | samwisekoi
awesome  :-*
Offline BimboBB
Re: GH60 Group Buy
« Reply #360 on: Tue, 26 March 2013, 05:52:28 »
UPDATE:
There has been a few requests for a dedicated HHKB plate, so I just added one for ANSI. It has split backspace and R-shift. Also Samwisekoi requested his layout changed, so it now has a split L-shift (1.25x + 1x). The OP will now reflect these changes, and the order form will now have that additional dedicated HHKB plate.
HHKB ANSI...............................................................................Samwisekoi
@WFD
can you make this "dedicated HHKB-plate" for ISO as well? (i mean including a split backspace)
Offline blueasjim
Re: GH60 Group Buy
« Reply #361 on: Tue, 26 March 2013, 08:08:40 »
If there's an assembly service, will this include soldering? I'm very interested in this but no skill in soldering.  :eek:
Thanks
Vortex KBT PURE [MX Red] | CM Storm [MX Blue] | CM Storm [MX Red]
Offline Sai
Re: GH60 Group Buy
« Reply #362 on: Tue, 26 March 2013, 08:18:51 »
Thanks
yes. it will include
Re: GH60 Group Buy
« Reply #363 on: Tue, 26 March 2013, 08:19:07 »
Thanks
Yes, assembly service gets you an assembled GH60, no soldering required.
Offline blueasjim
Re: GH60 Group Buy
« Reply #364 on: Tue, 26 March 2013, 08:22:06 »
Thanks
Whoa. I'm not seeing a down side to this at all!
I will place order once we get home. Thx for swift replies jd & Sai
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: GH60 Group Buy
« Reply #365 on: Tue, 26 March 2013, 08:29:21 »
No.  It does not support LEDs
Re: GH60 Group Buy
« Reply #366 on: Tue, 26 March 2013, 08:33:40 »
The GH60 does not support full backlighting. This was done by design, as backlighting was not one of the objectives of the project.
As of Rev. A of the PCB, the only LED supported is Caps Lock. In the final revision, there may be the option to add LEDs to the WASD cluster and Esc, but nothing has been finalized, yet.
Offline Luke
    • My Technology Blog
Re: GH60 Group Buy
« Reply #367 on: Tue, 26 March 2013, 08:55:31 »
Beat me to it :D
Offline edrago
Re: GH60 Group Buy
« Reply #368 on: Tue, 26 March 2013, 09:24:53 »
If anyone can help me and give some directions I would be grateful.
It's possible to make something similar to the Zelia Neo 87? Image References
I know that I should get only a PCB, without plate. How hard would be to find a case for it?
Thanks in advance
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: GH60 Group Buy
« Reply #369 on: Tue, 26 March 2013, 09:31:15 »
Thanks in advance
Not really, that's a significantly larger keyboard than the GH60, being a tenkeyless.
Offline edrago
Re: GH60 Group Buy
« Reply #370 on: Tue, 26 March 2013, 09:39:02 »
I don't mean the layout as is, I have no problem with something like Poker (I have a Choc Mini ATM). I just wanted to know if was possible that "flat"design or how I could achieve it, I don't know how to describe it.
Thks for the reply.
Re: GH60 Group Buy
« Reply #371 on: Tue, 26 March 2013, 09:42:52 »
Thks for the reply.
If you want something "flat" like that, your best bet is to try and find a Vortex CNC Pure case. It is a low profile design, similar to the one in those pictures, although not quite as low. The GH60 PCB will fit perfectly in the Pure CNC case.
You would order the GH60 PCB, switches, and stabilizers, and then try to find one of those Pure CNC cases.
This picture from Mashby shows the profile of the Pure CNC case quite well:
Side-by-Side with Keyboard by Michael Ashby, on Flickr
« Last Edit: Tue, 26 March 2013, 09:50:10 by jdcarpe »
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: GH60 Group Buy
« Reply #372 on: Tue, 26 March 2013, 10:41:33 »
Neo style case would be kind of cool, it's just a block of plastic with an angle to it more or less, then all that would be needed asides from cutting a block of some material at an angle would be a notch for the usb connector and some holes drilled and tapped to secure the pcb to it.
Offline CTollemache
Re: GH60 Group Buy
« Reply #373 on: Tue, 26 March 2013, 10:48:27 »
Just went in for a GH60, poker plate, and some plate mounted stabs. I think I joined geekhack at just the right time! It's like the ultimate keyboard. Now to sit on the classifieds for a poker...
Offline SmallFry
Re: GH60 Group Buy
« Reply #374 on: Tue, 26 March 2013, 10:52:23 »
Thks for the reply.
It's crazy to me that he takes all of his photos with an iPotato 4.
Re: GH60 Group Buy
« Reply #375 on: Tue, 26 March 2013, 10:59:40 »
Right?? It shocks me every single time. I even asked him about it pointblank and he said nope, I'm on Team Potato.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: GH60 Group Buy
« Reply #376 on: Tue, 26 March 2013, 11:31:27 »
I have updated the GH60 'samwisekoi' mockup to match the change WFD made to the plate.
http://geekhack.org/index.php?topic=41464.msg829197#msg829197
Thanks WFD et al!
 - Ron | samwisekoi
Offline BunnyLake
  • The OG HHKB Master
  • X
Re: GH60 Group Buy
« Reply #377 on: Tue, 26 March 2013, 12:00:22 »
jsut bumbled my way through my order, lets hope i didnt muck that up
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #378 on: Tue, 26 March 2013, 12:10:12 »
gonna post my order tonight so hopefully someone can check it out for me
Re: GH60 Group Buy
« Reply #379 on: Tue, 26 March 2013, 15:21:34 »
I'm assuming that that SMD soldering isn't exactly the easiest thing is it?  Since I'm working on a small budget, I'm trying to see if I could do it on my own to cut cost.  The PCB, plate, and stabilizers is already pushing it a little for me.
Re: GH60 Group Buy
« Reply #380 on: Tue, 26 March 2013, 15:27:33 »
Actually, it's really, extremely difficult. Especially the crystal. You don't want to try and save $15 that way.
Offline whiskytango
  • Don't touch the trim
Re: GH60 Group Buy
« Reply #381 on: Tue, 26 March 2013, 15:33:39 »
I think the time saved alone makes it worth the extra $15. I am thinking about getting an extra kit in the DIY flavor just as a challenge. Sort of like building a model airplane. But I am also getting one or two assembled so that I know they will work. But yeah, go look at the instructions on doing the SMD work earlier in the thread. No way is it worth trying to save $15 over
Edit: See the 3rd post here for instructions.
« Last Edit: Tue, 26 March 2013, 15:35:40 by whiskytango »
Re: GH60 Group Buy
« Reply #382 on: Tue, 26 March 2013, 15:34:59 »
Alright, thanks.  The video made it look doable, but I was hesitant.  There's a hackerspace near me with an SMD station, so I figured it might be possible for me to do it, but if it's that tough, it definitely would make more sense to spend the $15 and get it done for me than to cheap out and hope I don't screw up.
Looks like I'll need to scrounge up a little more cash or sell off my Das to get this.
Part of the fun to me is putting the work into it.  The time saved doesn't really factor in since it's a fun, stress relieving project.  My back may hurt from it, but there's a satisfaction of doing it myself.  If I could save $15 while also having fun with it, it's worth it.  If, on the other hand, it will be nearly impossible to do and cause me frustration, I'll get it done for me.
« Last Edit: Tue, 26 March 2013, 15:37:10 by nubbinator »
Offline nebo
Re: GH60 Group Buy
« Reply #383 on: Tue, 26 March 2013, 15:42:27 »
Who is doing the assembly services? If I were to sell my phantom I'd want to keep my switches I ordered.
Re: GH60 Group Buy
« Reply #384 on: Tue, 26 March 2013, 15:45:40 »
WFD and I are assembling US orders, komar is doing int'l. Unless you contact someone else to do it, that is.
Offline nebo
Re: GH60 Group Buy
« Reply #385 on: Tue, 26 March 2013, 15:46:54 »
Alright, looks like I might need to somehow get a hold of TP which is super easy these days....
Re: GH60 Group Buy
« Reply #386 on: Tue, 26 March 2013, 15:59:55 »
SmallFry is your best hope there.
Offline bvtton
    • bvtton
Re: GH60 Group Buy
« Reply #387 on: Tue, 26 March 2013, 17:13:19 »
ordered!  :) will we be receiving an email confirmation or something? (successfully submitted the form, but just want to make sure the order went though)
Offline tradet
Re: GH60 Group Buy
« Reply #388 on: Tue, 26 March 2013, 17:34:18 »
Oh my goodness. I discovered the open group buy with 13 pages already!
This should be a valid order I hope? 2 switches for a space and 64 other keys for the GH60 max keys layout (hope I counted correctly). I don't want to solder the SMD parts, but I think it'd be fun to solder the switches and stuff.
Code: [Select]
-1x GH60 PCB SMD presoldered
-1x GH60 (max keys) plate
-1x cherry (plate-mounted) stabilizer set, 6.25x spacebar wire
-4x MX gray switches (2 for a space?)
-68x MX clear switches (counted 64 keys, 4 extra)
Also when flashing the microcontroller, will a mini-B USB cable suffice?
Offline Rule16
  • R.I.P. SmallFry
Re: GH60 Group Buy
« Reply #389 on: Tue, 26 March 2013, 20:15:33 »
Are the plates the phantom style? I'm interested in getting clears in this, but I'm not sure if I'd want ergo clears or not... I'll probably get this anyways just because its 60% w/ backplate and I don't have to mod the clears in.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #390 on: Tue, 26 March 2013, 20:18:01 »
jd, looking back at your poker sale post, you said you had i believe said 'red, green and magenta' as led options for colors. and i know someone said wasd, esc, caps lock and some other keys (winkeys) might become available as an option...should i be putting down those colors in the comments section?
Offline WRXChris
Re: GH60 Group Buy
« Reply #391 on: Tue, 26 March 2013, 20:28:45 »
I'm so torn between layouts and can't decide which plate to order!  I would love an HHKB layout, but that really limits the compatible keysets.  I think I'm gonna have to go with the ANSI 1.5. Ugh, decisions, decisions!
Offline yearn4
  • formerly known as 4en
Re: GH60 Group Buy
« Reply #392 on: Tue, 26 March 2013, 20:32:09 »
are these going to use micro or mini usb?
Offline gnubag
Re: GH60 Group Buy
« Reply #393 on: Tue, 26 March 2013, 21:27:09 »
    In addition to the PCB, you will need the following to complete the build:
    • Switches
    • Stabilizers
    • Case
    • Keycaps
    • Plate (optional)
    • mini-B USB cable.
    [/list]
    Offline Rule16
    • R.I.P. SmallFry
    Re: GH60 Group Buy
    « Reply #394 on: Wed, 27 March 2013, 00:07:03 »
    Never-mind about the first question, this one is much more important, how would one program this keyboard? =This one decides DEFINITELY if I get it or not, because I don't want to take it apart and I don't know any programming=
    Dvorak Only Zone
    Offline duq
    • Connoisseur
    Re: GH60 Group Buy
    « Reply #395 on: Wed, 27 March 2013, 01:16:13 »
    Would be able to see the spread sheet being populated? It would be nice to see what we have ordered so we can verify we're getting what we want.
    Offline WhiteFireDragon
      • youtube
    Re: GH60 Group Buy
    « Reply #396 on: Wed, 27 March 2013, 01:28:02 »
    Mini update: some stats after 6 days
    185 PCBs ordered
    169 plates ordered
    When I have time, I'll make a separate form to post your orders. I think I caught up with all PMs, but if I missed yours then send another one.
    Offline Broadmonkey
    Re: GH60 Group Buy
    « Reply #397 on: Wed, 27 March 2013, 03:30:51 »
    Read reply #2 on the first page!
    Offline Tym
    Re: GH60 Group Buy
    « Reply #398 on: Wed, 27 March 2013, 05:10:33 »
    You wont get an email confirmation, but as long as the form said order submitted they got it :D You'll get the invoice whenever they are sent out.
    Offline Dgsbllx
    Re: GH60 Group Buy
    « Reply #399 on: Wed, 27 March 2013, 05:20:12 »
    Right I don't understand why the plates and names shown in post 2 don't match to the names on the order form.
    I want an exact cherry replica of a HHKB, so am I ordering the ' true" HHKB plate'?
    Cheers
