Author Topic: GH60 Group Buy (Salvage Mode: Enabled - Update in OP)  (Read 2314234 times)
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #250 on: Fri, 22 March 2013, 10:36:00 »
Also want to add this: If you order assembly service, you should not order "DIY" PCBs. DIY means you're going to assemble everything yourself, including the SMD components.
If you need to change your order, please submit a request using this form.
Thanks! :D
should we be putting all other information in the comments section? aka like layout we want and LEDs
i want the hhkb layout, but i think i want a normal right shift instead of a small pure one, just because it's a pain to get a 1.75x shift key for keycap sets. i might map the fn down to one of the meta keys instead.
Offline developej
Re: GH60 Group Buy
« Reply #251 on: Fri, 22 March 2013, 10:36:34 »
don't want to be annoying :D
i live in Serbia, Europe, and we don't have paypal here. i can only pay with VISA Virtuon. will this be possible?
if yes, i will also need help with order form:
Switches and stabilizers (stabilizers are in sets, each set is enough for 1 whole keyboard. Switches are per switch)
Costar stabs, Plate-mounted, PCB-mounted cherry stabs (specify spacebar wire size). The switch color you want. FORMAT: quantity x item
if i want a poker layout, is this how it should look:
61 x mx blue
1 x plate-mounted stabilizers
thanks!
thanks!
Re: GH60 Group Buy
« Reply #252 on: Fri, 22 March 2013, 10:48:36 »
61 x mx blue
thanks!
thanks!
Sorry, not trying to ignore you, but I don't know if that's possible or not. tjcaustin will be invoicing and collecting payments, and he is only accepting payment via Paypal. Perhaps komar007 might be willing to accept your payment, as he is located in Poland, and would be shipping your order. But you would have to ask him directly.
Offline vorn
Re: GH60 Group Buy
« Reply #253 on: Fri, 22 March 2013, 10:50:28 »
Hmm.. also, for the Assembly Service... it's a radio button. I've ordered 2 boards and want them both assembled. so thats $25 x 2. Should this have a Qty field? Or just put that in the Comments/notes?
I think the bulk of the instruction is going to be in the Comments/notes field. Layout, switch configuration, etc. The rest of the fields are mainly useful for consolidating the orders.
« Last Edit: Fri, 22 March 2013, 10:55:11 by vorn »
Offline gropingmantis
Re: GH60 Group Buy
« Reply #254 on: Fri, 22 March 2013, 11:52:29 »
Got my switches all ready and my keycaps. PCB and plate order placed. Now to source a nice case...
Offline aggiejy
Re: GH60 Group Buy
« Reply #255 on: Fri, 22 March 2013, 11:53:17 »
Form filled out! :)
Offline Luke
    • My Technology Blog
GH60 Group Buy
« Reply #256 on: Fri, 22 March 2013, 12:10:33 »
Exactly the same! xD
Offline developej
Re: GH60 Group Buy
« Reply #257 on: Fri, 22 March 2013, 12:43:13 »
61 x mx blue
thanks!
thanks!
ok, thanks!
Offline Brown
  • Mechanical Keyboard Virgin
Re: GH60 Group Buy
« Reply #258 on: Fri, 22 March 2013, 12:45:47 »
Would the ANSI 1.5x or Poker plate be easier to find keycaps for?  So many decisions D:  How many switches would I need?
« Last Edit: Fri, 22 March 2013, 12:54:29 by Brown »
Offline Plater
Re: GH60 Group Buy
« Reply #259 on: Fri, 22 March 2013, 12:46:08 »
Ordered placed, can't wait until I get my hands on these bad boys! And also, Can't wait for the aluminum case!
Offline tjweir
Re: GH60 Group Buy
« Reply #260 on: Fri, 22 March 2013, 13:42:00 »
Ordered 2 x Samwisekoi's layout.
Now to find a buyer for my ErgoDox.
Offline clstyle
Re: GH60 Group Buy
« Reply #261 on: Fri, 22 March 2013, 14:13:18 »
ordered~!!! now i waiting for next step. :D
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: GH60 Group Buy
« Reply #262 on: Fri, 22 March 2013, 15:21:24 »
All of these layout except MAX keys layout is easy to find keys for in GMK modifiers groupbuy :D
GH60 Group Buy
« Reply #263 on: Fri, 22 March 2013, 15:24:33 »
Finally some shameless self promotion I can get behind! ;D
Offline osxoep
Re: GH60 Group Buy
« Reply #264 on: Fri, 22 March 2013, 16:06:38 »
Does anyone know where I can get some custom HHKB style keys?
I mean the way they have other functions printed on the side facing the user.
Like this: http://elitekeyboards.com/proddata/images/th/pdkb400ws_corner1000_th0x0.jpg
[/slightlyofftopic]
HHKB Pro JP with hasu's controller (waiting for MX sliders)
Offline jksteger
Re: GH60 Group Buy
« Reply #265 on: Fri, 22 March 2013, 16:08:58 »
I'm a GH newbie, I want to order one, I want a HHKB 'clone' with Cherry MX Brown switches and MX black for the keyboard but I know nothing about how to configure this.  :eek:
Can someone please help me out.   ;D with what to put in the order form?
Sorry, i'm learning and will get there soon.
Thanks a zillion GH'ers!!!!
Jeremy
Re: GH60 Group Buy
« Reply #266 on: Fri, 22 March 2013, 16:16:50 »
Jeremy
If you want a plate (optional), the one you want is not on the order form, yet. WFD needs to update the form with the "HHKB" plate. Other than that, you need a GH60 PCB (not DIY), 60 switches, and stabilizers (PCB mount Cherry). Assembly service if you don't plan to solder the switches (and install the optional plate) to the PCB. Not sure what you mean by "with Cherry MX Brown switches and MX black for the keyboard."
Offline Winther
Re: GH60 Group Buy
« Reply #267 on: Fri, 22 March 2013, 16:44:50 »
If I want "ISO 1.25x" and a plate, I need plate mounted stabilizers right?
does none of the stabs come with the wires?
will the firmware support nordic letters?
Offline komar007
    • komar's blog
Re: GH60 Group Buy
« Reply #268 on: Fri, 22 March 2013, 16:56:34 »
Is doesn't have to, the translation from standard key codes to actual letter happens on the OS side, so no need to worry.
Offline keymaster
  • Topre Revolution Theorist
Re: GH60 Group Buy
« Reply #269 on: Fri, 22 March 2013, 16:57:46 »
When are these expected to begin being produced? I think I read someone say September or October... Could someone clarify this? :)
Offline komar007
    • komar's blog
Re: GH60 Group Buy
« Reply #270 on: Fri, 22 March 2013, 17:14:55 »
That would be the optimistic side of me that wrote this.
No idea.
Offline jksteger
Re: GH60 Group Buy
« Reply #271 on: Fri, 22 March 2013, 17:19:35 »
Jeremy
Thanks so much, I meant to say a cherry mx black for the spacebar!  d'oah!!!
Thanks so much!
Offline jksteger
Re: GH60 Group Buy
« Reply #272 on: Fri, 22 March 2013, 17:27:26 »
Thanks jdcarpe,
I've filled out the order form with what you suggested!
thanks,
Jeremy
Offline ANDMYGUN
Re: GH60 Group Buy
« Reply #273 on: Fri, 22 March 2013, 18:34:02 »
hey guys, can you tell me if this is right?
GH60 PBC quantity: 1
Poker plate quantity: 1
Switches and stabilizers: 61 x MX Browns,
Assembly service: Yes
I'm unsure about the stabilizers can someone help me out there?
GH60 Group Buy
« Reply #274 on: Fri, 22 March 2013, 18:39:57 »
Correct. For stabilizers, get 1 x Cherry PCB
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #275 on: Fri, 22 March 2013, 19:46:46 »
it says we have to include spacebar wire size.. should i just put 7x?
Offline myndzi
Re: GH60 Group Buy
« Reply #276 on: Fri, 22 March 2013, 22:07:22 »
Sent an update to my order in support of split backspace Pure plate :)
One more question. I can, through this group buy, get everything except the case and keycaps? I see that WFD has a case thing going soon too. Do I need to source some keycaps or can I basically just camp out in this thread and wind up with a complete working keyboard?
It's really cool to see this happen, what with all the people coming together to get it all done. You guys are great.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: GH60 Group Buy
« Reply #277 on: Fri, 22 March 2013, 22:09:22 »
There are enough keycap group buys going on now, along with planned to be done by the time you have this in your hands to not worry about them coming to this gb.
Offline Brown
Re: GH60 Group Buy
« Reply #278 on: Fri, 22 March 2013, 22:43:00 »
Would you be able to use Costar (Plate Mount) Stabilizers on it or no?
GH60 Group Buy
« Reply #279 on: Fri, 22 March 2013, 23:33:40 »
Sorry, for Poker layout (any with 1.25) get 6.25x wire.
Also, for 1.50 layouts, get 7x wire.
Yes, plate mount stabs including Costar will work with all these plates. You might need to do a little bit of sanding or grinding, as the plate is 0.0625" thick, and Costar spec is for 0.060"
Offline vardhana
Re: GH60 Group Buy
« Reply #280 on: Sat, 23 March 2013, 07:18:04 »
Jeremy
Will be order form updated?
WFD said;
blablabla...
EDIT: oops what am I thinking, I'm second-guessing myself haha. There's already a Pure-style plate with 1.5x modifiers that will work in a HHKB layout. It just doesn't have a split backspace. If you truly want a split backspace for the 1.5x pure plate, mention this in the comments section of your order. if there are more than a couple, I can make a separate plate for it. Dorkvader already PM'ed me about this.
I'm confused.
What should people who want truly HHKB layout (split Backspace) plate do?
Wait for form update? Order with comment?
« Last Edit: Sat, 23 March 2013, 07:19:42 by vardhana »
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #281 on: Sat, 23 March 2013, 07:24:48 »
Alright cool jd. I'm getting 1.5 ANSI plate, so should I mention a 7x wire in the switch/stabilizer section? And how hard are 7x spacebars to find? :0
Offline stoic-lemon
Re: GH60 Group Buy
« Reply #282 on: Sat, 23 March 2013, 08:32:29 »
What are people thinking for switch layouts on these? I have downloaded one of the mockups and thought about where I want my browns and blues etc. I'm just wondering what other people doing? Anyone have a crazy switch layout planned?
Offline Acanthophis
Re: GH60 Group Buy
« Reply #283 on: Sat, 23 March 2013, 09:09:06 »
Is there a way to review one's order?
Offline eon
Re: GH60 Group Buy
« Reply #284 on: Sat, 23 March 2013, 09:33:39 »
If I want a 1.5 ansi layout with 1.75 shift, seems only the universal plate fits, right ?
Poker MX Red - Photos
Re: GH60 Group Buy
« Reply #285 on: Sat, 23 March 2013, 09:36:01 »
I'm confused.
For now, order with comment, please.
Yes, ask for 7x wire in the switch/stabilizer section. You can find 7x spacebars (and 1.5x mods) with the tsangan kits on every keycap set GB.
Sent you a PM with your current order.
Yes, this is correct. You can also put your desired layout in the comments section, in case others want a plate with the same option, we will know how many are interested.
« Last Edit: Sat, 23 March 2013, 09:38:24 by jdcarpe »
Offline eon
Re: GH60 Group Buy
« Reply #286 on: Sat, 23 March 2013, 09:55:01 »
What do you mean by the comments section ? There's a thread for that ? THanks
Offline Jocelyn
  • 조셀린
Re: Re: GH60 Group Buy
« Reply #287 on: Sat, 23 March 2013, 09:56:33 »
On the order form :)
Offline whiskytango
  • Don't touch the trim
Re: GH60 Group Buy
« Reply #288 on: Sat, 23 March 2013, 13:32:13 »
There's this option on the order form: ANSI 1.5x (pure shift) plate quantity, short R-shift, WKL and HHKB compatible
Isn't this what you're talking about?
« Last Edit: Sat, 23 March 2013, 14:58:16 by whiskytango »
Offline eon
Re: GH60 Group Buy
« Reply #289 on: Sat, 23 March 2013, 13:52:40 »
Right that should do it, thanks. This plate isn't listed on this thread though
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
Re: GH60 Group Buy
« Reply #290 on: Sat, 23 March 2013, 19:54:36 »
JD could I get an order review as well. I should check it and in a few days I'll make sure I've got it updated/correct. A lot of info on here has got me thinking I jumped the gun on my order.  :p
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #291 on: Sat, 23 March 2013, 20:57:30 »
If we want Dragon's case for the hhkb layout and top, are we going to have to order everything seperate? i am hearing that if we want to get Dragon's future case (which looks like the best option for the hhkb layout) we will have to order all gh60 parts separate and un-assembled, and then build it ourselfs? what is going to be the actual process?  do i need to order the case first or the parts? how will they be integrated together?
GH60 Group Buy
« Reply #292 on: Sat, 23 March 2013, 21:24:12 »
Sent you a PM with your order. :)
You should order the GH60 parts now, and you can order WFD's case later, when he starts the GB for it. It will have an integrated plate available, but you can also use these plates with his case, as they have the standoffs for it. If you use the plate (or no plate) from this GB, all you would have to do to install it in his case is use a few screws to assemble it. Or you could wait, and someone will be able o assemble everything, including the integrated plate, for you after the cases ship.
« Last Edit: Sat, 23 March 2013, 21:31:34 by jdcarpe »
Offline poopmat
Re: GH60 Group Buy
« Reply #293 on: Sat, 23 March 2013, 21:26:40 »
i feel like a retard
so pardon my ignorance
 i want to get something like a poker with clear switches
i dont know what to order
pls help
thanks
REΛLFORCE 103u, Ergodex DX1, IBM model M, Daskeyboard II, QFR brown,
GH60 Group Buy
« Reply #294 on: Sat, 23 March 2013, 21:37:20 »
pls help
thanks
If you want the same setup as a Poker, you should order the GH60 PCB, 61x MX Clear switches, 1x Cherry PCB mount stabilizers, and assembly service (if desired). Poker plate is optional. You would have to source a case for it outside the GB.
Offline Trueno86
Re: GH60 Group Buy
« Reply #295 on: Sun, 24 March 2013, 01:24:15 »
I think I messed up my form, should have read the thread first (the switches and stabilizers section) Should I submit a new one?
Offline duq
  • Connoisseur
GH60 Group Buy
« Reply #296 on: Sun, 24 March 2013, 01:28:24 »
There is a second link to modify orders in the original post.
Offline realex
Re: GH60 Group Buy
« Reply #297 on: Sun, 24 March 2013, 05:32:41 »
someone talented should come up with nicer logo so we can have shadovved go to work on massive sticker production.
Offline Broadmonkey
Re: GH60 Group Buy
« Reply #298 on: Sun, 24 March 2013, 07:45:29 »
There has already been an IC for some time now:
http://geekhack.org/index.php?topic=38906.0
Offline Fred
Re: GH60 Group Buy
« Reply #299 on: Sun, 24 March 2013, 08:00:45 »
So can we get split backspace on any plate or how does it work?
