Author Topic: GH60 Group Buy (Salvage Mode: Enabled - Update in OP)  (Read 2271299 times)
Offline Dsan
Re: GH60 Group Buy
« Reply #50 on: Thu, 21 March 2013, 08:51:25 »
Noob question -> Is there a way to see if the pcb is working without having switches soldered?I'm planning on buying all the components for the GH60 gradually,starting with case/pcb/plate and finally switches.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: GH60 Group Buy
« Reply #51 on: Thu, 21 March 2013, 09:23:22 »
Hey wow on so many levels! Thanks to all who made this so sweet and so soon!
We'll have to get Retro DSA as well as Retro Blue and Retro Green out to match this pace, AND we'll have to support all of those nice layouts!
Speaking of which, that 'samwisekoi' layout is meant to allow an embedded arrow pad.  I'll find and post a mockup, perhaps in Retro Green a la the Nuclear Data keyboard.
Anyhow, thanks very much!  Order coming soon.
 - Ron I samwisekoi
Offline TheSoulhunter
  • ~ BOOO ~
Re: GH60 Group Buy
« Reply #52 on: Thu, 21 March 2013, 09:23:54 »
Order placed...
A Ghost From The Past
Offline llovro
Re: GH60 Group Buy
« Reply #53 on: Thu, 21 March 2013, 09:32:49 »
How is with assembly for Europe? Is anyone going to do it? And stabilizers aren't included, are they?
« Last Edit: Thu, 21 March 2013, 11:22:25 by llovro »
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: GH60 Group Buy
« Reply #54 on: Thu, 21 March 2013, 09:33:53 »
Offline komar007
    • komar's blog
Re: GH60 Group Buy
« Reply #55 on: Thu, 21 March 2013, 09:34:55 »
How is with assembly for Europe? Is anyone going to do it? And stabilizers aren't incleded, are they?
I'm doing it.
The stabilizer problem is not solved yet. We'll see...
Offline pasph
Re: GH60 Group Buy
« Reply #56 on: Thu, 21 March 2013, 09:36:12 »
What about GHPad integration?
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: GH60 Group Buy
« Reply #57 on: Thu, 21 March 2013, 09:42:41 »
Buy some Cherry/GMK doubleshot modifiers, we have you covered for just about any possible layout you wish as long as you like purple!
Offline The_Beast
  • I like wood ಠ_๏
Re: GH60 Group Buy
« Reply #58 on: Thu, 21 March 2013, 09:46:00 »
What switches and in what layout need to be rotated?
We'll try to have no switches rotated at 90 degrees. Only 0 and 180.
"We'll try" and "there are" are two different things. Are there any 90 degree switches anywhere on the board? If so what layouts and what switches?
I just wanna know so I can design a plate with the correct rotation of phantom cutouts
Offline komar007
    • komar's blog
Re: GH60 Group Buy
« Reply #59 on: Thu, 21 March 2013, 09:46:56 »
4-I/O extension port + all 5 rows are broken out.
We'll worry later, but it must be possible to integrate somehow. In the worst case just a ribbon cable between the boards somewhere inside the joined case.
Offline komar007
    • komar's blog
Re: GH60 Group Buy
« Reply #60 on: Thu, 21 March 2013, 09:49:38 »
PM'd
Offline The_Beast
  • I like wood ಠ_๏
Re: GH60 Group Buy
« Reply #61 on: Thu, 21 March 2013, 09:49:48 »
Would it be possible to have just another USB connection going to the computer for the GHpad? I'm not loving the idea of an attached GHpad to my GH60
Offline komar007
    • komar's blog
Re: GH60 Group Buy
« Reply #62 on: Thu, 21 March 2013, 09:53:36 »
Of course, that's the main option!
Ribbon only in case of a common case, where it can be nicely hidden.
Offline The_Beast
  • I like wood ಠ_๏
Re: GH60 Group Buy
« Reply #63 on: Thu, 21 March 2013, 09:55:25 »
Gottcha, thanks bub :P
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #64 on: Thu, 21 March 2013, 10:09:19 »
Are we supposed to be able to acquire cases on our own? i kinda want one of The_Beast's cases
Re: GH60 Group Buy
« Reply #65 on: Thu, 21 March 2013, 10:10:52 »
Yes. Or you could go caseless.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
Re: GH60 Group Buy
« Reply #66 on: Thu, 21 March 2013, 10:11:51 »
Use cardboard
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #67 on: Thu, 21 March 2013, 10:12:28 »
cardboard case sounds nice
Offline ishumprod
Re: GH60 Group Buy
« Reply #68 on: Thu, 21 March 2013, 10:12:39 »
or go cardboard-case style ! that's the swaggy way, will post pics once i get my poker pcb and plate so i can get measurements and build one =P
edit : got ninja'd like a newb
home-made TKL rubber dome keyboard !
Offline zeththedarkmage
Re: GH60 Group Buy
« Reply #69 on: Thu, 21 March 2013, 10:52:07 »
Will there be an solderless option for people like me who don't know how to use a soldering iron that will have it all put together minus the case and the keycaps?
Offline komar007
    • komar's blog
Re: GH60 Group Buy
« Reply #70 on: Thu, 21 March 2013, 10:53:10 »
There is (in the first post). I'll add more info soon.
Offline esoomenona
  • Gnillort?
Re: GH60 Group Buy
« Reply #71 on: Thu, 21 March 2013, 10:56:17 »
I'm hoping someone may answer the questions regarding the plates soon. There have three or four people ask the same thing. I was ready to be like fourth in line to order, but things are a bit unclear...
Re: GH60 Group Buy
« Reply #72 on: Thu, 21 March 2013, 10:59:48 »
Could you make a Pure 1.5x plate? Or would you say the Universal plates would be just as sturdy? And in that case, why not just offer those plates to help increase orders and decrease costs? (And yes, I understand the stab dilemma between the two)
It's in the order form. "ANSI 1.5x (pure shift) plate quantity"
Some people may not want the "Universal" plate, because they want to use plate-mount stabilizers.
Question that may solve my own above: for the ISO and ANSI HHKB layouts, is there a space available for the outside 1.5x key?
Yes, the hole is there in the plate. If you get the HHKB cover option when you order the case, it simply covers that hole.
« Last Edit: Thu, 21 March 2013, 11:01:44 by jdcarpe »
Offline rknize
    • metaruss
Re: GH60 Group Buy
« Reply #73 on: Thu, 21 March 2013, 11:09:20 »
I assume that the SMD-soldered option will be pick-and-place and not hand-soldered by one of you?
Russ
Re: GH60 Group Buy
« Reply #74 on: Thu, 21 March 2013, 11:10:09 »
You assume correctly, sir.
Offline rknize
    • metaruss
Re: GH60 Group Buy
« Reply #75 on: Thu, 21 March 2013, 11:15:02 »
Great.  Do we need to keep the GB open for ~2 months?
Russ
Offline elton5354
Re: GH60 Group Buy
« Reply #76 on: Thu, 21 March 2013, 11:17:39 »
What's the difference between plate-mount stabs and pcb-mount?
Re: GH60 Group Buy
« Reply #77 on: Thu, 21 March 2013, 11:22:37 »
I month until orders close, 3 weeks to get all payments...seemed reasonable to me. You need this like NAO, or what?
Um, well, plate mount Cherry stabs mount to the stab holes in the plate. PCB mount Cherry stabs mount to some holes in the PCB. Costar stabs use a different design, and ONLY mount to a plate.
Offline elton5354
Re: GH60 Group Buy
« Reply #78 on: Thu, 21 March 2013, 11:28:11 »
Yeah, I mean if I were to order the universal plate or the specific plate. What are the difference between the 2 if I were to use the different stabilizers
Re: GH60 Group Buy
« Reply #79 on: Thu, 21 March 2013, 11:35:24 »
Some people just prefer one over the other. I personally prefer Cherry plate mount, because every once in a while, while removing keycaps on a board with PCB mount Cherry stabs, the stab will pull out of the PCB and I have to reinsert it.
Some people prefer Costar. Some people don't have a preference. If you would rather have the convenience of a universal plate, and don't care about which stabilizers you use, then you have the option go that route.
Offline fruktstund
Re: GH60 Group Buy
« Reply #80 on: Thu, 21 March 2013, 11:48:01 »
I've been thinking for a couple of hours now, and the best layout for me seems to be a ANSI WKL with 1.75x right shift and a function key to the right of that, HHKB style. I don't really like PCB mounted Cherry stabilizers though, so if the HHKB layout uses a 7x spacebar (which it seems to do), will this plate also have the holes for the outer bottom row 1.5x keys?
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: GH60 Group Buy
« Reply #81 on: Thu, 21 March 2013, 11:51:34 »
Here is a layout for the GH60 "samwisekoi" -- including arrow keys.
[edit] I changed Shift_L to ISO 1.25 and added the tilde key.  WFD modified the 'samwisekoi' plate to match.  I will try to make all the 'special' keycaps available in the Klaxon/GH60/RGBY GB to come soon.[/edit]
 - Ron | samwisekoi
« Last Edit: Tue, 26 March 2013, 11:30:29 by samwisekoi »
Re: GH60 Group Buy
« Reply #82 on: Thu, 21 March 2013, 11:56:28 »
WFD, I'd like to change Shift_R to ISO 1.25 and add the tilde key.  Can this be done for that version of the plate?
 - Ron | samwisekoi
It's not the plate. The PCB doesn't support a 1.25 R_Shift. That wasn't in our design.
My bad.  Shift_L.
 - Ron | samwisekoi
:D
« Last Edit: Thu, 21 March 2013, 11:59:36 by jdcarpe »
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: GH60 Group Buy
« Reply #83 on: Thu, 21 March 2013, 11:57:23 »
WFD, I'd like to change Shift_L to ISO 1.25 and add the tilde key.  Can this be done for that version of the plate?
 - Ron | samwisekoi
My bad.  Shift_L.
 - Ron | samwisekoi
Offline nebo
Re: GH60 Group Buy
« Reply #84 on: Thu, 21 March 2013, 12:05:09 »
Oh man, I really want this but I want my phantom too and I can't have both! More keys or an awesome HHKB w/ clears? Decisions decisions.
Offline komar007
    • komar's blog
Re: GH60 Group Buy
« Reply #85 on: Thu, 21 March 2013, 12:07:10 »
You already know which decision is the right one...:D
Offline Acetrak
  • ssk.ℜ
  • gnawm_
Re: GH60 Group Buy
« Reply #86 on: Thu, 21 March 2013, 12:07:43 »
Both!
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
Re: GH60 Group Buy
« Reply #87 on: Thu, 21 March 2013, 12:09:06 »
both multiplied by two :D
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #88 on: Thu, 21 March 2013, 12:13:53 »
going to get 1 hhkb now and 1 poker one possibly later...need to find the best plate for the hhkb
Offline nebo
Re: GH60 Group Buy
« Reply #89 on: Thu, 21 March 2013, 12:14:55 »
You already know which decision is the right one... :D
Both!
Welcome to GH where if you don't own all the GBs you own none of them.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: GH60 Group Buy
« Reply #90 on: Thu, 21 March 2013, 12:16:23 »
ansi 1.5x
Offline Moosecraft
  • HHKB Pro
Re: GH60 Group Buy
« Reply #91 on: Thu, 21 March 2013, 12:31:54 »
Gonna place an order on sunday :)
Offline RickyJ
Re: GH60 Group Buy
« Reply #92 on: Thu, 21 March 2013, 12:36:40 »
A huge THANK YOU for unsoldered option!!! Yes it's more tedious, but also more fun for me.  Will have to scan the local craigslist for a used toaster oven and get some paste, been a few years since I did production like that! :D
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Re: GH60 Group Buy
« Reply #93 on: Thu, 21 March 2013, 12:37:31 »
You can always do it with a good soldering iron!
Offline CommunistWitchDr
  • >implying keyboards
Re: GH60 Group Buy
« Reply #94 on: Thu, 21 March 2013, 12:37:42 »
I might have to start selling off my boards to buy more of these. It's all the stuff I like about my poker and pure, without the annoying parts.
Also, when it says "the switch color you want" is that any cherry color? Like can we do clears/grays/greens?
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #95 on: Thu, 21 March 2013, 12:41:32 »
considering selling my das for another one of these...i want 2
Offline tricheboars
  • Keyboards are Important!
Re: GH60 Group Buy
« Reply #96 on: Thu, 21 March 2013, 12:41:51 »
Placed order for 2 SMD presoldered GH60 PCBs, 1 Ansi 1.5x Plate, 2 sets of costar stabs, 1 set of mx green switches, 1 set of mx red switches.
i was not sure if 7bit has MX Green Switches. If this is not possible that is cool, I can adapt.
This is very very exciting stuff. I am curious about assembly service. I could be interested in having that done to one of my boards depending on cost.
THANK YOU ALL VERY MUCH YOU MAKE THIS THE BEST WEBSITE ON THE NET.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: GH60 Group Buy
« Reply #97 on: Thu, 21 March 2013, 12:42:59 »
Hope so, I want to try milk/white switches.
Re: GH60 Group Buy
« Reply #98 on: Thu, 21 March 2013, 12:43:39 »
I know man, I want a linear (gray) and clicky (green or white) for sure, and maybe a tactile non clicky (clear).
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #99 on: Thu, 21 March 2013, 12:44:59 »
ansi 1.5x
should i get ansi 1.5x or ansi 1.5 pure shift? i think i need to get the ansi 1.5 pure shift plate right? the real hhkb has a small 1.75 shift i think
