Author Topic: GH60 Group Buy (Salvage Mode: Enabled - Update in OP)  (Read 2314225 times)
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #100 on: Thu, 21 March 2013, 12:46:09 »
considering selling my das for another one of these...i want 2
I know man, I want a linear (gray) and clicky (green or white) for sure, and maybe a tactile non clicky (clear).
i just got a poker with clears like 2 days ago. i want either greens/whites or tactile greys on my gh60...can't decide..why not just get 2!
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #101 on: Thu, 21 March 2013, 12:48:24 »
going to get 1 hhkb now and 1 poker one possibly later...need to find the best plate for the hhkb
ansi 1.5x
look what i mean
Offline tricheboars
  • Keyboards are Important!
Re: GH60 Group Buy
« Reply #102 on: Thu, 21 March 2013, 12:48:41 »
Offline elton5354
Re: GH60 Group Buy
« Reply #103 on: Thu, 21 March 2013, 12:56:11 »
will there be a case made for hhkb ansi?
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: GH60 Group Buy
« Reply #104 on: Thu, 21 March 2013, 12:58:04 »
Ordered two populated boards and one plate; will come back and order more...
 - Ron | samwisekoi
w
Offline osxoep
Re: GH60 Group Buy
« Reply #105 on: Thu, 21 March 2013, 12:59:19 »
Ahhh. I'm looking forward to a 1.5x ISO HHKB.
I'm not sure on what stabilisers to use though. Or switch colour, maybe whites (if possible).
And I want to wait and see how much The_Beast's case will be.
HHKB Pro JP with hasu's controller (waiting for MX sliders)
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #106 on: Thu, 21 March 2013, 13:01:07 »
that's what i was asking....WhiteFireDragon himself is making a case that can have a top for hhkb ansi...so i think so
Offline Moosecraft
  • HHKB Pro
Re: GH60 Group Buy
« Reply #107 on: Thu, 21 March 2013, 13:09:00 »
Would I have to order a separate plate if i buy WhiteFireDragons case?
Offline elton5354
Re: GH60 Group Buy
« Reply #108 on: Thu, 21 March 2013, 13:11:34 »
His case is only for WKL ANSI
http://img.photobucket.com/albums/v288/WhiteFireDragon/keyboard/case/GH70-ASMBL_2.png
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #109 on: Thu, 21 March 2013, 13:13:42 »
"4) modular top cover - The top cover has 3 different designs, allows you to choose a winkeyless cover, HHKB style, or standard full keys"
http://geekhack.org/index.php?topic=39599.0
Offline Permeability
Re: GH60 Group Buy
« Reply #110 on: Thu, 21 March 2013, 13:14:49 »
These will be using PCB Mount switches right?
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
Offline fruktstund
Re: GH60 Group Buy
« Reply #111 on: Thu, 21 March 2013, 13:14:49 »
Look at the second post of this thread.
Quote from: WhiteFireDragon
Here are some possible layouts, rendered with my case design
In the second post you have some possible layouts. These are rendered with his case design.
Both PCB mounted and plate mounted switches will be possible to use, although I believe you won't be able to use plate-mounted switches if you choose to not have a plate.
« Last Edit: Thu, 21 March 2013, 13:17:15 by fruktstund »
Offline elton5354
Re: GH60 Group Buy
« Reply #112 on: Thu, 21 March 2013, 13:14:59 »
Nice.
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #113 on: Thu, 21 March 2013, 13:18:42 »
yeah i really want that aluminum case or the hhkb layout. i think it would be sexy. i am still trying to find the right plate. someone suggested 1.5x ANSI but i think we need a shorter shift bar..
I think he is making a GB at some point
Offline elton5354
Re: GH60 Group Buy
« Reply #114 on: Thu, 21 March 2013, 13:28:05 »
then get the universal plate?
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #115 on: Thu, 21 March 2013, 13:32:51 »
universal plate for hhkb ansi layout? i don't think that would work
Offline TheQsanity
  • SmallFry Lovin'
Re: GH60 Group Buy
« Reply #116 on: Thu, 21 March 2013, 13:35:24 »
Daumn this happened quick.
SmallFry! <3
Offline WhiteFireDragon
    • youtube
Re: GH60 Group Buy
« Reply #117 on: Thu, 21 March 2013, 13:36:09 »
Wow I just posted the OP, woke up and it's on page 4 already. My inbox is flooded so give me time to catch up with posts in here and PMs. Also, if you have a non-personal question, just post it in here rather than PM me, some people might have the same question.
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #118 on: Thu, 21 March 2013, 13:39:42 »
i shot you a pm just take your time haha
everyone has been waiting for this for a long time
Re: GH60 Group Buy
« Reply #119 on: Thu, 21 March 2013, 13:41:08 »
It's okay, buddy. Glad you got to rest. komar and I have been answering questions as best we can. :)
Offline TheQsanity
  • SmallFry Lovin'
Re: GH60 Group Buy
« Reply #120 on: Thu, 21 March 2013, 13:53:52 »
One question please:
I have yet to receive my prototype (with prof). What are the differences from this and the prototype? Can the prototype use all these different layouts and fit the plates?
SmallFry! <3
Re: GH60 Group Buy
« Reply #121 on: Thu, 21 March 2013, 13:59:06 »
The prototype lacks the option of split backspace. Also, several of the switches (mostly bottom row and modifiers) are rotated 90 degrees on prototype. The only 90 degree rotated switch on the final revision should be the ISO enter switch, unless komar has something to add otherwise.
Edit: also, the extra pins of the 32u4 controller are broken out to pads on the final revision, which the prototype lacks.
Offline komar007
    • komar's blog
Re: GH60 Group Buy
« Reply #122 on: Thu, 21 March 2013, 14:00:59 »
That's right.
If you don't have a problem with rotated switches, the prototype's fine.
I think I won't have to rotate anything. It seems everything fits. Except for some overlapping holes, but that's better than rotated switches I think.
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #123 on: Thu, 21 March 2013, 14:04:00 »
I have a question about the 2 PCB options. And the assembly service. If I have no experience at all jnapdlering and don't have access to soldering, what hold I be ordering? I think km going to be ordering the assemg service, but what is the extent of the assembly service?
Re: GH60 Group Buy
« Reply #124 on: Thu, 21 March 2013, 14:06:30 »
Order the assembled PCBs ($40) and assembly service ($25). DIY PCBs are ONLY if you want to do everything, including SMD soldering, yourself.
Also, the assembly service consists of installing switches in the plate (if used), and soldering them to the PCB. Firmware will be flashed to your controller. If a case is purchased (if it ships with these), then installation into the case is included. And testing to ensure everything works properly.
« Last Edit: Thu, 21 March 2013, 14:19:09 by jdcarpe »
Offline RickyJ
Re: GH60 Group Buy
« Reply #125 on: Thu, 21 March 2013, 14:12:46 »
You can always do it with a good soldering iron!
Oh believe me, that's not a problem. I just miss smd production, lol. Hand soldering 0603 size discrete components, fine pitch chips, etc no problem. Would just like to play with paste and baking again. :)
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #126 on: Thu, 21 March 2013, 14:17:21 »
Ok cool. Are a few LEDs going to be an option? Can I as that in the comments?
And there is no update on the tracking number :( I hope I get it tomorrow!
Re: GH60 Group Buy
« Reply #127 on: Thu, 21 March 2013, 14:20:23 »
Only 1 LED is supported, on Caps Lock. Not sure about color options...
Offline The_Beast
  • I like wood ಠ_๏
Re: GH60 Group Buy
« Reply #128 on: Thu, 21 March 2013, 14:21:34 »
These are months from shipping. You understand GB take time
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #129 on: Thu, 21 March 2013, 14:24:36 »
Aww boo I wish I could get 4 on my wasd keys
I bought a poker from jdcarpe last week... We are talking about that. I heard the gh60s are coming in September/October
Re: GH60 Group Buy
« Reply #130 on: Thu, 21 March 2013, 14:24:39 »
He was referring to the Poker I sold him.
Technically, you bought it yesterday. That's when I received your payment. :P
Offline komar007
    • komar's blog
Re: GH60 Group Buy
« Reply #131 on: Thu, 21 March 2013, 14:29:37 »
Most probably there will be wasd leds.
Offline The_Beast
  • I like wood ಠ_๏
Re: GH60 Group Buy
« Reply #132 on: Thu, 21 March 2013, 14:29:48 »
Gottcha, assumed that since this was the Gh60 thread....
Re: GH60 Group Buy
« Reply #133 on: Thu, 21 March 2013, 14:31:56 »
Yay for hole drilling! :D
Offline Glissant
Re: GH60 Group Buy
« Reply #134 on: Thu, 21 March 2013, 14:42:08 »
Got in my order finally. Let me know if I need to clarify my stab and wire wishes. My GH60 arsenal shall be grand (well three in total isn't really GRAND, but..)!!
I hope many people get in on this as I think it's a really awesome little keyboard. And custom stuff is always cool ;).
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #135 on: Thu, 21 March 2013, 14:44:34 »
YAAA! I will put it in the comments section that I want wasd LEDs...maybe some more.jd I like how the poker has some of the modifier keys with LEDs. Pretty cool
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
Re: GH60 Group Buy
« Reply #136 on: Thu, 21 March 2013, 14:45:20 »
OK, semi-big order placed with form; I'm down for 3 of these plus 1 do-the-smd-yourself kit (which ill mess up likely); I'm building one for someone though if that sounds a bit much lol. Looks like ill have a 60% keyboard army; like a mini-jdcarpe collection lolol.
let me know if i messed up the form instructions around the stabs.
with so many people involved it sounds like this could run extremely smooth; I just wish you collected payment a week or two earlier than what you have set.  This is the keyboard I've been waiting for unless the ergodox does actually work out (i have my doubts about it). No KMAC for me (*ducks*).
Re: GH60 Group Buy
« Reply #137 on: Thu, 21 March 2013, 14:49:10 »
By the way, "Forum name" means your name on the forum. We know the forum is called Geekhack. We have several orders from "Geekhack."  ;D
Offline elton5354
Re: GH60 Group Buy
« Reply #138 on: Thu, 21 March 2013, 14:53:47 »
what are the options for the switches?
Offline MarkPharaoh
Re: GH60 Group Buy
« Reply #139 on: Thu, 21 March 2013, 14:55:08 »
lol.
Man, there are so many options to choose from! Kind of want a HHKB layout to go with my actual HHKB, but the ANSI WKL would also rock.
Current: HHKB Pro 2, 87u 55g 10AE, FC600C, Model M 1391401
Offline Dubsgalore
Re: GH60 Group Buy
« Reply #140 on: Thu, 21 March 2013, 15:08:09 »
Are can we get any type of switch? I'm looking at grey and whites
    • youtube
Re: GH60 Group Buy
« Reply #141 on: Thu, 21 March 2013, 15:10:06 »
Over 80 PCBs ordered in 12 hours, and almost the same amount for plates.
I'll submit my order later depending on WFD's case progress. :D
1/3 of the PMs I got was regarding the case, so I'll just say it to everyone. I'm not going to integrate any of the cases in this GB. Mine specifically, it just has too many parts and many options, which will complicate the ordering. I also don't want my case to delay this GB at all, so it's going to stay separate.
Is the HHKB ANSI not on the order form?
ISO or ANSI 1.5x plate is compatible with 3 layouts: WKL, HHKB, and normal 1.5x bottom row modifier. They all use this same plate, but the specific layout will depend on which top case cover you choose. Obviously if you use a stock poker/pure case, you can't have a WKL or HHKB layout since you can't cover up those certain keys. So in the order form, if you want a WKL or HHKB, then you need to pick the ANSI or ISO 1.5x plate. That was mentioned in the order form, but I hope this clarifies that.
What switches and in what layout need to be rotated?
If you look at the PCB pic in the OP, all of the switches are either not rotated or rotated at 180degree. This doesn't affect your caps. The Only one that as a 270degree rotation is the ISO-enter, which is suppose to be rotated anyways.
Offline duq
  • Connoisseur
Re: GH60 Group Buy
« Reply #142 on: Thu, 21 March 2013, 15:15:14 »
WFD, is there any option for a plate similar to your WFD150?
http://img.photobucket.com/albums/v288/WhiteFireDragon/keyboard/plates/th_HHK150.png
Id be interested in that so I would be confident in the switches staying in place adverse to using the universal ansi.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: GH60 Group Buy
« Reply #143 on: Thu, 21 March 2013, 15:18:56 »
So the $25 option comes with everything you need just not soldered together? Just want to make sure I wouldn't have to source diodes and such myself.
Re: GH60 Group Buy
« Reply #144 on: Thu, 21 March 2013, 15:22:45 »
Yes, components included.
Offline phetto
  • HHKB JP
Re: GH60 Group Buy
« Reply #145 on: Thu, 21 March 2013, 15:26:51 »
Wooooohoo!!
    • youtube
Re: GH60 Group Buy
« Reply #146 on: Thu, 21 March 2013, 15:28:33 »
Switches and stabilizers
I was a little reluctant to include switches and stabilizers with this GB at first, because it'll just further complicate ordering, choices, invoice, and organization/management. But I figured it'll be a tad cheaper and easier to have a centralized place to get stuff.
7bit will just send 1 large order directly to us. Feel free to get it directly from him. We're not in control of how much they cost, choices, and when they're available. But ordering large amounts in a GB can be cheaper for everyone. Refer HERE for direct info and which switch choices are available. Then just fill out which ones you want in the order form.
As for stabilizers, I only have plate-mounted cherries, but I believe alaricljs will get a bunch of PCB-mounted cherry stabilizers soon. You can get Costars directly from WASDkeyboards, or if there are enough orders for the costars at the end, we'll put a large order for those as well. The problem is the spacebar wires. They can't be bought anywhere, so they'll have to be made. I'll post a guide so you can make your own. I'll make as many as I can, but it takes me ~10 minutes each, so I don't think I'll be making 200+ of them.
Offline rknize
    • metaruss
Re: GH60 Group Buy
« Reply #147 on: Thu, 21 March 2013, 15:31:29 »
I don't think the OP specifies what the plates are made out of.  Can we assume SS?
Russ
Offline Winther
Re: GH60 Group Buy
« Reply #148 on: Thu, 21 March 2013, 15:38:56 »
a few noob questions:
Does/will the firmware support nordic ISO characters aswell?
I might be wrong, but havent there been talk about LED option in the escape key too?
What stabilizers do Ducky keyboards use? Is cherry?
I think thats all for now, will probably drop an order in the next few days.. :P great work on this!
« Last Edit: Thu, 21 March 2013, 16:46:19 by Winther »
Offline london00
Re: GH60 Group Buy
« Reply #149 on: Thu, 21 March 2013, 16:00:17 »
Order submitted, thanks for making this happen and organizing it.
