Author Topic: The Living Soldering Thread  (Read 2488911 times)
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: The Living Soldering Thread
« Reply #300 on: Tue, 04 June 2013, 00:36:48 »
litster has one of the Aoyue stations. iirc he says the only thing he really likes about it is the fume extractor on the iron.
the cheap all-in-one stations are definitely "get what you pay for", and the bigger problem with "all-in-one" is that they may very well be devoting too much of a meager budget to something you just don't do very often. how often are you going to desolder soic packages? do you really need hot tweezers at all? how often are you going to do smt reflow? do you really need hot air at all? etc.
over the years i've definitely found that accuracy, reliability and usability are #1 in tooling, especially high power precision tooling like soldering tools. even when you're careful and you know what you're doing it's still not that hard to burn things when you have a bunch of power flowing into a heater in your hand.
Offline mkawa
« Reply #301 on: Tue, 04 June 2013, 10:12:15 »
folks with 888ds, i just got mine and i noticed that they made the the worst UI choice ever in that CALIBRATING the temperature and SETTING the temperature are almost exactly the same procedure, except that one of them requires pressing the enter button for ONE second (temp set) and the other for TWO seconds (calibration)
FACEPALM
you can tell which mode you're in by the temp display. if it has two dots at the bottom, you're setting the calibration, not the temperature. if it doesn't have two dots, you're setting the temperature. note that there is no "reset to factory" if you do mistakenly recalibrate. it may be possible to wipe the nvram or whatever it keeps the offset in, but i haven't gotten to that part of the manual yet.
my advice: search for amico thermometer on amazon and get a very cheap type K thermometer (25$) in case you need to recalibrate the regulator after mistakenly calibrating it instead of changing the regulator temperature. make sure the type K probe and thermometer you buy goes up to at least 250 deg C.
Offline Internetlad
« Reply #302 on: Tue, 04 June 2013, 11:43:06 »
FACEPALM
makes me feel a bit better about going for the analog dial weller now.
"Beep . . . Beep . . . Beep" -Sputnik I
Offline Rayne
  • For Science!
« Reply #303 on: Tue, 04 June 2013, 12:20:07 »
FACEPALM
yeah, i was almost 100% going to get an 888D, now im kinda second guessing that decision.
Offline mkawa
« Reply #304 on: Tue, 04 June 2013, 13:38:03 »
the care and feeding of the 888d is definitely a bit higher than the analog meters. they cut some corners to get the insanely accurate regulator into the budget station. the accuracy on this thing is higher than the industrial-strength 951 station (which i assume they plan on updating at some point). the flip side to this accuracy is that it's been designed for people who care about accuracy and have the tooling (eg, a tip thermometer) to calibrate.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #305 on: Tue, 04 June 2013, 17:55:37 »
FACEPALM
This really sucks. I don't remember if I ever saw two blinking periods or not. Could you maybe use a kitchen meat thermometer to calibrate?
Offline mkawa
« Reply #306 on: Tue, 04 June 2013, 18:16:38 »
anything that can read up to 200C and is accurate to within 2C there it is about as accurate as the regulator, so you're good. honestly, the factory calibration probably isn't all that accurate as it is. a cheap IR thermometer placed really close to the tip will probably work fine to get it back within the ballpark (and about as accurate as the dial would have been).
Offline The_Beast
  • I like wood ಠ_๏
« Reply #307 on: Tue, 04 June 2013, 18:19:52 »
Oh man, I forgot that my buddy has a IR thermometer, I'll borrow that and check to make sure I didn't mess up my calibration.
Offline mkawa
« Reply #308 on: Tue, 04 June 2013, 18:39:55 »
also remember that anything that actually measures tip temperature is going to be more accurate than the factory calibration or wherever the regular has wandered since it left the factory. ideally you want a contact probe because the built up oxidization and tin or lack thereof can wildly change the temperature at the joint. but really, just remember that you're always guessing with materials and thermo (heisenberg or something)
Offline eRadicatedZomBiE
  • It's OK, I'm A Doctor.
« Reply #309 on: Tue, 04 June 2013, 19:33:30 »
Did you say Heisenberg?
CM QFR | WASD V1 | Flico MJ2 LE Blue | Ducky 78 | Ducky DK9008G2 Pro LE  |Phantom |
Ergodox
My WTB Thread
Offline WhiteFireDragon
    • youtube
« Reply #310 on: Tue, 04 June 2013, 20:24:37 »
I don't think IR gun will be food for measuring tip temps. The readout is an average temp over a certain area, and the area it measures depends the distance away from the object. The tip is too small to point an IR gun at it.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #311 on: Tue, 04 June 2013, 20:25:57 »
Even with a large knife style tip and the IR gun held close to the tip?
    • youtube
« Reply #312 on: Tue, 04 June 2013, 20:36:14 »
How large is the knife tip? I wouldn't imagine any soldering tip is large enough to measure with IR guns. These are more for measuring an area, not a single point, even though the gun has an aiming laser that shoots at a single point. You can try though, but I wouldn't trust accuracy doing this way because you'll pick up temps from the surrounding area as well.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #313 on: Tue, 04 June 2013, 20:40:22 »
It's this tip
Offline mkawa
« Reply #314 on: Tue, 04 June 2013, 20:44:45 »
the temp the regulator uses isn't exactly in the tip either. (or more importantly, on the surface of the tip).
Offline The_Beast
  • I like wood ಠ_๏
« Reply #315 on: Wed, 05 June 2013, 19:00:20 »
Ok, what if you have 63/37 solder, could you ramp up the temperature until the solder melts and calibrate the station to 361F?
Offline mkawa
« Reply #316 on: Wed, 05 June 2013, 19:05:36 »
sure. i mean the point of the point of the last N posts was that ultimately you're just twiddling some knob until you can solder stuff.
Offline Internetlad
« Reply #317 on: Wed, 05 June 2013, 19:55:24 »
Stay out of my project room.
Offline Rayne
  • For Science!
« Reply #318 on: Wed, 05 June 2013, 20:20:01 »
Ok, so I have some soldering experience, I'v been doing little projects here and there for some time. The only solder iron iv used is a cheap $10 radio shack one that i bought like 4 or 5 years ago. I want to upgrade and get one much better than what i have. I was looking into getting the Hakko FX888D, I dont want to spend any more than that. However, the posts above are kind of confusing me. Now this may be a stupid question, but what is the deal with calibrating the temperature? How exactly do you do this and why? I kinda makes me scared to buy a new solder machine because i feel like i wont know how to use it :x
again, sorry if this is a dumb question, i feel like such a noob :P
Offline Internetlad
« Reply #319 on: Thu, 06 June 2013, 00:00:59 »
I assume it comes factory calibrated but you can recalibrate it by hand using the method listed above.
Beside that any tool worth it's salt should come with (or at least have available) a fairly extensive manual. I suspect most of them are available online now because it saves paper and/or is cheaper to produce
Offline Rayne
  • For Science!
« Reply #320 on: Thu, 06 June 2013, 01:02:20 »
oooh ok i get it now. i was thinking calibration was something that need to be done every time you use the machine... this all makes sense now... i feel so dumb lol
Offline mkawa
« Reply #321 on: Thu, 06 June 2013, 01:23:36 »
all the hakko documentation is available online. you have to register for it, which is weird, but yah, it's up there. docs.hakko.com or something.
Offline kaiserreich
  • HHKB Elite
« Reply #322 on: Fri, 07 June 2013, 12:02:25 »
Just received my 888d 220v from taobao. For $75 before shipping, pretty good deal indeed.
The innards looks as real as the teardown pictures that I can find.
Pictures to follow.
Made in a factory 30km from where I stay.
Bought from Shanghai and still save a ton of money.
Globailization at its best.
« Last Edit: Sat, 08 June 2013, 22:07:54 by kaiserreich »
Offline mkawa
« Reply #323 on: Fri, 07 June 2013, 12:44:39 »
hah! hilarious. also remember that it was designed in japan :D
economic geography at its finest.
Offline Internetlad
« Reply #324 on: Fri, 07 June 2013, 12:50:48 »
reminds of me a bit of how rendering and processing plants will buy horse meat from americans for 50 cents a pound and sell it where horsemeat is a delicacy for 15 dollars a pound.
Offline mkawa
« Reply #325 on: Fri, 07 June 2013, 13:35:11 »
contrary to popular belief, paul krugman did some really good work in this prior to globalization becoming a buzzword, and deserves the nobel as much as anyone else with a nobel -- it wasn't just political..
Offline kaiserreich
  • HHKB Elite
« Reply #326 on: Sat, 08 June 2013, 04:48:48 »
Here is the teardown of the FX888D from Taobao
Comparison to a FX888D from other sources
http://runawaybrainz.blogspot.com/2013/03/hakko-fx-888d-solder-station-hi-res.html
« Last Edit: Sat, 08 June 2013, 04:51:16 by kaiserreich »
Offline bpiphany
« Reply #327 on: Sat, 08 June 2013, 06:50:34 »
Except there is no Nobel Prize in economics. I know nothing about economics though...
Offline mkawa
« Reply #328 on: Sat, 08 June 2013, 09:10:00 »
looks unsurprisingly like the same unit. good to know there's a cheaper source IN asia
Offline mkawa
« Reply #329 on: Sat, 08 June 2013, 14:38:24 »
DUDES! GREAT NEWS!
I've made a huge mistake. the process for TEMPERATURE CHANGE is to hold the ENTER button for 1 second.
The process for TEMPERATURE CALIBRATION is to hold the UP button for 2 seconds. phew!!!
ok, now the bad news. i tossed an older tip on my iron and then took an extremely accurate thermistor and stuck it on the tinned and brass-brushed tip. it was 20 degrees off the regulator thermistor. i then calibrated and ta-da! melted solder. this is cool for me because i have an extremely accurate contact thermometer that is rated up to 400C, but may not work for you if you plan on buying the 888d and then blindly trusting the number on the front.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #330 on: Sat, 08 June 2013, 18:50:18 »
Just got done soldering my a.87. All the SMD stuff that came in the kit and all the SMD resistors. Big thanks to everyone in the thread. All I need to do is solder on the switches, diodes and LEDs, but I need a plate and a case to make first!
    • youtube
« Reply #331 on: Sat, 08 June 2013, 19:27:23 »
The white A87 ps2avr? You might want to try and program it first before you install the plate in case any of the components don't work or needs reflow. You won't be able to take them off once the plate is on. I'm stuck at the programming phase before I can put on the plate.
http://geekhack.org/index.php?topic=44504.0
Btw, when you said SMD resistors, I hope those are diodes instead, which is what the switches need. Unless you mean resistors for a backlit keyboard.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #332 on: Sat, 08 June 2013, 19:32:29 »
Yea, it's going to be a while for the white A87 ps2avr since I want to get my phantom completed first.
No, I did the SMD resistors tonight since I already have the LEDs. I didn't feel like doing the through hole diodes tonight so I'll probably do those tomorrow
Offline kaiserreich
  • HHKB Elite
« Reply #333 on: Sat, 08 June 2013, 22:07:10 »
DUDES! GREAT NEWS!
How do you get the Presets? P1, P2, P3 etc?
I can change the temps but getting into the preset mode is pretty damn hard.
It's very interesting how Hakko can fit so many functions into the "UP" "Enter" and on/off switch combination.
Offline mkawa
« Reply #334 on: Sat, 08 June 2013, 23:19:27 »
sign up for doc.hakko.com. the full manual is there (why? i have no idea)
to get to the parameter settings you have to turn the iron on with the enter key held down until it flashes "01" (which is the C or F parameter)
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #335 on: Sun, 09 June 2013, 16:55:35 »
I have a Weller ST1 tip (recommended for switch/diode soldering) new that is of no use to me.
If anyone wants it all I ask is for shipping.  First to PM me gets it.
Offline Internetlad
« Reply #336 on: Mon, 10 June 2013, 17:04:28 »
So I can't seem to find a proper manual for my Weller WES51 other than the 4 pages of toilet paper that comes in the box. Is that seriously it, or does somebody know better?
« Reply #337 on: Mon, 10 June 2013, 17:09:44 »
http://www.testequipmentdepot.com/weller/pdf/wes51.pdf
Offline Internetlad
« Reply #338 on: Mon, 10 June 2013, 17:36:25 »
Thanks. Looked and couldn't find it. Ended up on the page for the WES50.
Offline daerid
    • Rossipedia
« Reply #339 on: Thu, 13 June 2013, 00:50:55 »
Looks like I'm getting a FX888D as a father's day gift to myself and gonna finally be able to put my 'Dox together this weekend. W00t!
Offline daerid
    • Rossipedia
« Reply #340 on: Sat, 15 June 2013, 16:47:56 »
Got it! Quick question though (sorry if its been covered): what temp is the best for soldering this thing?
Offline kaiserreich
  • HHKB Elite
« Reply #341 on: Mon, 17 June 2013, 09:39:18 »
I use 350 for Lead solder, and 450 for lead free.
That's in celcius by the way.
Try not to mix the tips used for Lead and lead-free solder.
Offline mkawa
« Reply #342 on: Mon, 17 June 2013, 10:06:13 »
it depends on your alloy, and yes, do not mix tips across alloys. the standard hobbyist 63/37 (ie, 63% tin, 37% lead) melts at exactly 182C and is euctetic, meaning that there is no transition between solid and liquid (and v.v., there is no hysteresis). this alloy, with a core of rosin flux was by far the most popular solder for many many years. kester's 44 very small diameter solder is still one of the best and has exactly this construction.
with the change in EU regulations in 2000-ish (RoHS lead-free no-clean), non-euctetic formulations and lead-free alloys have been de rigeur in mass production, as leaded soldered items cannot be imported into the EU. the upside of this is of course that we don't have to landfill so much lead. the downside is that standard solders are no longer euctetic, and have much weirder material properties and larger ranges of melting temps. non-rosin flux is also less corrosive (flux is meant to attack and dissolve oxidization on metal surfaces) and hence harder to work with.
the wiki article on solder is quite complete and very information. highly suggest taking a look:
http://en.wikipedia.org/wiki/Solder
Offline Aranair
  • Software Engineer @ PocketMath
    • Tech blog
« Reply #343 on: Mon, 17 June 2013, 10:07:42 »
got all my soldering + desoldering gear.. and probably going to desolder my poker X to add a plate to it.
Anything I should REALLY take note before I start?:P
Present  : HHKB Pro 2 Type-S White | HHKB Pro 2 White Blank | Ergodox EZ
Past      :  Poker 2 Brown | Black Widow Ultimate Blue | Filco TKL Brown
Offline Photoelectric
« Reply #344 on: Tue, 18 June 2013, 09:26:02 »
I've got the recommended desoldering iron from RadioShack so far.  Almost got my first switch out last night (but there's a skinny filament of solder left inside one of the holes, so waiting for other tools to arrive.
Ordered these from Amazon for my 2 Filco TKL projects :)
And of course my Prime ran out a couple days ago, so slow shipping...  But when it all gets here, I'll start desoldering in earnest!  Still need to get a tip tinner--probably at RadioShack on my way home from work today.  Do you think the stock Weller WLC100 tip is sufficiently narrow if I'm careful, or do I need to get a smaller one?
Thanks for everyone's tips in this thread!
« Last Edit: Tue, 18 June 2013, 09:27:38 by Photoelectric »
« Reply #345 on: Tue, 18 June 2013, 10:02:13 »
pun ;)
Offline Tarzan
  • formerly known as Greystoke
« Reply #346 on: Tue, 18 June 2013, 11:20:53 »
euctetic = eutectic.
Offline mkawa
« Reply #347 on: Tue, 18 June 2013, 18:03:25 »
Thanks for everyone's spelling tips in this thread!
Offline alaricljs
  • I be WOT'ing all day...
« Reply #348 on: Tue, 18 June 2013, 18:10:00 »
Wow... part of this is likely to be tip dependent, however I prefer to use the lowest possible temp to get the job done.  I don't do lead free, but my 888 is set to 275C for SMD work.  For KB switches 275C works, sometimes bump it to 300C.  For wire work with 18ga or larger, 325C.
Filco w/ Imsto thick PBT
Offline The_Beast
  • I like wood ಠ_๏
« Reply #349 on: Tue, 18 June 2013, 18:20:33 »
I used to do everything on 5 on the weller WLC, now that I can control temps I use around 550F. It's a little bit hotter than alaricljs uses, but I find it a bit faster than if I'd use a lower temp.
