Author Topic: [IC] Acrylic Case for Phantom & Filco & QFR (Confirmed!!)  (Read 78279 times)
Offline takaki
Re: [IC] Acrylic Case for Phantom & Filco & QFR (Confirmed!!)
« Reply #200 on: Thu, 13 June 2013, 21:33:56 »
I would much prefer an extra layer to cover the cutout. I do not want my case open to liquid, dust, or anything else. However, if it doesn't fit, it doesn't fit.
Highly doubt liquid is a problem because the case is elevated from the desk with the two 10mm feets. Anyway, I've decided to make the cover up and feets optional.
Finalised on the design, will be creating the Group buy thread soon.
Offline lightsout714
« Reply #201 on: Thu, 13 June 2013, 22:04:41 »
Oh man here we go. Lets talk money!! Whats the final cost boss? (I know I know wait for GB thread.)
Offline Sai
« Reply #202 on: Thu, 13 June 2013, 22:17:07 »
will you be updating pictures of all the prototype ?   ;D
Offline takaki
« Reply #203 on: Fri, 14 June 2013, 00:11:54 »
I will create a separate log for the whole process of coming out with this at making stuff together
Offline frenchie4111
« Reply #204 on: Sat, 15 June 2013, 15:50:34 »
I am very very excited for this. Let's get this ball rolling.
Filco MJ2 TKL
Offline takaki
« Reply #205 on: Mon, 17 June 2013, 03:33:38 »
Currently I have a suggestion to do tap and die for the screws instead of having a nut at the back to secure the acrylic sheets. what do you guys think ?
Offline baldgye
  • Will Smith Disciple
« Reply #206 on: Mon, 17 June 2013, 03:48:45 »
Would a tap and die help make it more compact?
Offline takaki
« Reply #207 on: Mon, 17 June 2013, 03:58:03 »
Are you looking for a minimalistic kind of casing or something that is as tall as the current filco/QFR casing? The thickness/compactness of the casing affects the typing feel/experience.
The main aim for the tap and die is to take the nuts out of the casing so everything is flushed at the bottom instead of having nuts sticking out. Rubber feets will be included to avoid having the base come into contact with the table. This address to scratching and possibly water issues, I love my table and my keyboard.
« Last Edit: Mon, 17 June 2013, 05:05:07 by takaki »
Offline baldgye
« Reply #208 on: Mon, 17 June 2013, 04:48:54 »
Ahhh I see, and yeah I personally do love the hight and angle of the full filco case (feet up) so something like that would be great. But yeah tap and die sounds all kinda of better, as I do like my desk lol
Offline Rayne
  • For Science!
« Reply #209 on: Mon, 17 June 2013, 05:07:00 »
yeah tha tap and die sounds like a great idea
Offline UniClown
« Reply #210 on: Mon, 17 June 2013, 13:42:14 »
This. I would much prefer a flush bottom.
Offline whiskytango
  • Don't touch the trim
« Reply #211 on: Mon, 17 June 2013, 15:18:57 »
are we talking about cutting threads into the acrylic for the screw to screw into from the top? Don't you think this would strip out rather easily?
Have you considered a binding post (also called Chicago screw) type fastener? Here is an example
Edit: Steel ones would be even better. The heads of the screw and post still look to be pretty low profile.
« Last Edit: Mon, 17 June 2013, 15:22:20 by whiskytango »
Offline takaki
« Reply #212 on: Tue, 18 June 2013, 03:30:32 »
I'll go down to the screw factory outlet tomorrow to take a look at the binding post type of fastener and compare it to the nut design.
