Author Topic: [IC] Acrylic Case for Phantom & Filco & QFR (Confirmed!!)  (Read 79769 times)
Offline takaki
« on: Sat, 18 May 2013, 12:07:21 »
Brought forward to interest check thread to get a feel of the interest level so I can see if I can get a better pricing for everyone.
http://geekhack.org/index.php?topic=38765.0
87 key top plate
96 key type.
jdcarpe/Profosist's custom layout
Current intended / final production features
- Hole at the bottom to allow reprogramming of the teensy chip without having to take out the casing.
- Optional 1cm tall rubber feets (same height increment when you actually used the stands on your keyboard instead of a weird angled acrylic block
- Custom laser engraving of your choice
- Customizable colours
- Able to use your own plate, case specific plate not required.
- Able to fit the big as hell stock filco cable
- a sexy as hell casing
More customizations means higher prices, but I would get the quotes for you guys, just ask for the feature you are interested in :)
Simple google form here.
https://docs.google.com/forms/d/1cZodsH33_sdaSRfCt1oar-ez9FzPe3ReM7bbuNDeJfc/viewform
The current ball park figure is 50-60usd without shipping, I hope we can go lower with significant numbers, this is a budget casing after all. :) Prototype is already out, waiting for the WFD's plate to reach me to get the final fitting done.
Your comments and everything is much appreciated, I understand that this looks like what litster has done before and there was a woe with MKC. Well I just wish for myself to get one for my phantom build as well as hoping to make this affordable for everyone to get as well.
« Last Edit: Wed, 22 May 2013, 09:26:39 by takaki »
Offline HannibalChew
  • Formerly PixelScript
    • gaffworks
Re: [IC] Acrylic Case for Phantom & Filco [Maybe QFR as well]
« Reply #1 on: Sat, 18 May 2013, 13:33:22 »
Wow 50-60USD! That's an amazing price! I would defiantly be interested if i had a TKL board :(
Offline bazemk1979
« Reply #2 on: Sat, 18 May 2013, 13:35:48 »
im in for at least couple of them depending on the color options :)
the area above the arrow keys will be covered with acrylic to cover the exposed PCB right?
« Last Edit: Sat, 18 May 2013, 13:37:21 by bazemk1979 »
Offline takaki
« Reply #3 on: Sat, 18 May 2013, 13:53:02 »
Do refer to the first picture for the 87 key variant! the 87 key type will have the acrylic to cover the top part above the keys.
Can do some engraving there as well.
Offline LechnerDE
« Reply #4 on: Sat, 18 May 2013, 13:55:02 »
I'd buy at least one.
Would be awesome if there was an option for the GH60 as well ;)
Offline keymaster
  • Topre Revolution Theorist
« Reply #5 on: Sat, 18 May 2013, 14:00:21 »
I'd be interested in a black, silver, or possibly charcoal colors (87-key).
Offline Sai
« Reply #6 on: Sat, 18 May 2013, 14:07:55 »
it should be possible to get the case without the LED holes, am i right?
i don't really like the led holes like in filco.
Offline bazemk1979
« Reply #7 on: Sat, 18 May 2013, 14:24:15 »
ofcourse hopefully you can make them to fit QFR boards
« Reply #8 on: Sat, 18 May 2013, 16:18:39 »
Can't wait to see this case.
Offline SmallFry
« Reply #9 on: Sat, 18 May 2013, 16:21:37 »
If you've been able to track down the files, and are willing to share them, I'd love to be able to use them. :)
Edited: Meant to sound like I was saying please.
« Last Edit: Sun, 19 May 2013, 00:47:26 by SmallFry »
Offline reality404
« Reply #10 on: Sat, 18 May 2013, 16:22:50 »
Thanks for the interest check and for designing the case.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #11 on: Sat, 18 May 2013, 16:32:13 »
Cool :D
SmallFry! <3
Offline Latin00032
Re: [IC] Acrylic Case for Phantom &amp; Filco [Maybe QFR as well]
« Reply #12 on: Sat, 18 May 2013, 16:56:13 »
I'm interested.
It would be great if there were different colored acrylic cases. Like smoke grey, transparent red, transparent blue.
I would love a smoke grey case.
A smoke grey case would look better with my dsa key caps. The slight curve on the standard tenkeyless filco case makes the top dsa keys look weird. A straight case would make them look better.
Offline nebo
« Reply #13 on: Sat, 18 May 2013, 17:09:38 »
Interested, but would be be possible to have the old "Winkeyless_Arrclus"  layout?
Offline gliy
« Reply #14 on: Sat, 18 May 2013, 18:18:44 »
Have you been able to track down the files at all?
He mentioned that he would talk to the guy this Monday about the designs.
Offline affect656
« Reply #15 on: Sat, 18 May 2013, 18:30:42 »
I'm interested.
Smoke Grey with clear switches and white leds would be awesome
I like linear.
Offline Rayne
  • For Science!
« Reply #16 on: Sat, 18 May 2013, 18:41:08 »
super interested in one of these for my filco, cant wait to see what kind of color options would be available! :D
and the engraving seems like an awesome idea as well.
Offline Rendom
« Reply #17 on: Sat, 18 May 2013, 19:01:36 »
Why can't you just buy it here though? Instead of taking someones work? lol
QFR - MX Blue
Offline Rule16
  • R.I.P. SmallFry
« Reply #18 on: Sat, 18 May 2013, 19:18:00 »
I'm interested.
I don't understand this, why does it matter what colour the switches are when the keycaps are going to cover them?
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline Turkishrambo
« Reply #19 on: Sat, 18 May 2013, 19:33:36 »
is the prof/jd layout just a different plate from the regular 96 key? Otherwise the same?
Offline gnubag
« Reply #20 on: Sat, 18 May 2013, 20:51:58 »
2 more switches in the function row.
« Reply #21 on: Sat, 18 May 2013, 21:46:34 »
haha sorry i didnt notice, thanks.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #22 on: Sat, 18 May 2013, 22:06:14 »
This might get real interesting.  Please use differing colours between the layers.  That is what makes acrylic more unique than any other material for this type of keyboard manufacture.
Plus they're way cheaper than aluminum.
Please put some colour samples up so that we can vote on what to select.  Or can this Group Buy be truly colour customized for each customer?
Offline KuhnTang
  • Game of Thrones
« Reply #23 on: Sun, 19 May 2013, 00:04:24 »
I would like at least one.
Offline takaki
« Reply #24 on: Sun, 19 May 2013, 00:10:30 »
Just realised that there are already proper terms for the casing designs like
Standard, Arrclus, Winkeyless, Winkeyless_Arrclus.
I will look into it but winkeyless is going to be complicated considering the fact that there are 1.5x and 1.25x variations of winkeyless, do let me know which one you are interested in.
I am trying my best to make the order as customizable as possible but likewise, more customizations means more cost, do keep that in mind.
The current feel of the interest in colours, do let me know which colours you guys are interested in so I can get colour samples taken for you guys to choose.
Translucent/Transaparent :
Blue
Red
Orange
Smoked Black/Grey
Purple
Pink
Opaque:
Black
Silver
Orange?
Blue?
*added more colours :D
« Last Edit: Sun, 19 May 2013, 00:14:41 by takaki »
Offline Jocelyn
  • 조셀린
« Reply #25 on: Sun, 19 May 2013, 00:11:54 »
Blue
Red
Orange
Smoked Black/Grey
Opaque:
Black
Silver
Orange?
Blue?
No Pink or Purple QQ
Offline SmallFry
« Reply #26 on: Sun, 19 May 2013, 00:12:40 »
I have the means to cut this myself, so I'd rather not wait for the GB. Also, this may permit me to try and cut it out of wood etc.
Offline takaki
« Reply #27 on: Sun, 19 May 2013, 00:15:09 »
Offline Rendom
« Reply #28 on: Sun, 19 May 2013, 00:24:41 »
Can't wait? Then do it yourself instead of demanding for someones work?  :-\
QFR - MX Blue
Offline Jocelyn
  • 조셀린
« Reply #29 on: Sun, 19 May 2013, 00:26:03 »
Added :O :D
Thanks! I'm going to buy a TKL now lol
Offline SmallFry
« Reply #30 on: Sun, 19 May 2013, 00:26:29 »
Demanding is a bit harsh, but not waiting for the GB is not the only reason as I said. I'd love to test out cutting this out of wood or some high density plastic that I have at school.
Offline Rendom
« Reply #31 on: Sun, 19 May 2013, 00:39:08 »
I understand. Maybe a "please" when  you ask for these things? No beef against you, just wasn't happy when someone takes another person's work like that.
QFR - MX Blue
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #32 on: Sun, 19 May 2013, 00:39:23 »
Who wants to wire up a teensy for me? uh? uh?
Offline SmallFry
« Reply #33 on: Sun, 19 May 2013, 00:40:33 »
Good point, I meant to sound like I was saying please. Ah the joys of the internet. :P
Offline gliy
« Reply #34 on: Sun, 19 May 2013, 00:43:11 »
No one is attempting to take his work, people are asking if he is willing to share his files, what is the point of doing the same work twice? It's his choice to give them out, or to keep them private.
Also I don't think hes done a prototype for the phantom yet, just for a filco.
Offline Rendom
« Reply #35 on: Sun, 19 May 2013, 00:45:03 »
It seriously sounds like you were demanding.  :p Ah internet!
QFR - MX Blue
Offline cyberwave
« Reply #36 on: Sun, 19 May 2013, 00:59:58 »
support local product!
Offline takaki
« Reply #37 on: Sun, 19 May 2013, 01:25:39 »
I've done this case for the phantom in mind. The QFR and the filco compatibility is just a bonus feature since phantom is made to be compatible with Filco and QFR layouts.
I just don't have everything of the phantom to do the fit test and give the assurance/guarantee for phantom. This issue will settled once I have the plate with me, or I can get an acrylic plate made --> more cost but definitely cheaper than the Stainless steel version.
smallfry, i just wish you could stop asking me every other day, as of now, the files won't be released publicly. That said I don't even have the files on my computer :)), it is all at the manufacturing site. Making a trip there tomorrow.
Offline Kayliss
« Reply #38 on: Sun, 19 May 2013, 01:30:02 »
Looks interesting, submitted form for one because I need a purple case!  :))
Offline takaki
« Reply #39 on: Sun, 19 May 2013, 01:39:21 »
Do you guys prefer transparent/translucent colours or opaque colours ?
Offline Kayliss
« Reply #40 on: Sun, 19 May 2013, 01:46:32 »
I think it's nice to have a mix of both. My preference would be opaque base clear middle and translucent colour on the top or something like that :O
Offline habitualapse
« Reply #41 on: Sun, 19 May 2013, 01:52:25 »
I'd def be in for at least one in translucent black, but i'm anxious to see what other options pan out.
Filco MJ2 Ninja Brown TKL
Offline deSheol
  • Thorpe
« Reply #42 on: Sun, 19 May 2013, 01:57:42 »
Both works fine!
Offline Rayne
  • For Science!
« Reply #43 on: Sun, 19 May 2013, 02:42:21 »
I think i would personally like the transparent ones better, im deffinetly in for a purple one, and possibly one other color, just not sure witch one yet. hmmm... decisions, decisions.
Offline Elrick
  • Hype Master
« Reply #44 on: Sun, 19 May 2013, 03:46:11 »
Blue
Red
Orange
Smoked Black/Grey
Purple
Pink
Opaque:
Black
Silver
Orange?
Blue?
Now that's what I'm talking about.  I would love a bright sandwich coloured baby ie., Opaque Silver on TOP and Transparent Smoked Grey in the middle with Transparent Red on the Bottom of the Case.
That would be my keyboard case to fit a spare Filco TKL.  Please let us know if you can also build a full 104 keyboard case, I will be willing to pay whatever for that  8) .
Offline Elrick
  • Hype Master
« Reply #45 on: Sun, 19 May 2013, 03:53:18 »
Just noticed your Google Form, all filled out - Thanks for running this  ;) .
Please can you show us some samples of the Acrylic if that's not too much of a hassle?  Currently my version of a colour might not be the version you are currently arranging to buy.
Just need to be sure what's exactly available to use, I don't see I would change the order but I need to see some samples so that I might consider paying for another keyboard case.
« Last Edit: Sun, 19 May 2013, 03:56:49 by Elrick »
Offline takaki
« Reply #46 on: Sun, 19 May 2013, 06:56:18 »
I understand that, that's why I'm getting the interest check done so I could get the manufacturer to prepare some colour samples for me to view and take photo. :)
Offline Jupiter
« Reply #47 on: Sun, 19 May 2013, 07:00:56 »
Definitely interested in this!
One question: is the only difference between the two layouts the top acrylic layer? As in, would we be able to the the whole case and then both top layers to build and test different layouts?
I only ask as I'm still not sure on what I want (96 or 87 key :P )
(Going to be) building Phantom - Red MDPC / White Heatshrink Pexon Cable - WoR/RoW Klaxon - Shiny Titanium Spacebar - Titanium Zerg key
« Reply #48 on: Sun, 19 May 2013, 07:14:29 »
Just a note takaki : In prof's layout there is no gap between the f key clusters, whereas in your 96-key case there is. Just letting you know.
Offline pasph
« Reply #49 on: Sun, 19 May 2013, 19:00:59 »
Brown color?
