Author Topic: [IC] Acrylic Case for Phantom & Filco & QFR (Confirmed!!)  (Read 78278 times)
Offline takaki
Re: [IC] Acrylic Case for Phantom & Filco [Maybe QFR as well]
« Reply #50 on: Mon, 20 May 2013, 03:52:29 »
My bad that it should be 92 keys instead of 96, 96 refers to the 7bit kind of configuration
Going to view the colours in a couple of hour's time and I forgot to bring my camera to work, damn. Gonna work with colour codes and phone camera.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #51 on: Mon, 20 May 2013, 05:38:03 »
Yippee, bring on the Potato Pics  8) .  Make sure you take heaps or what can be stored on your SD card.
Offline SmallFry
« Reply #52 on: Mon, 20 May 2013, 07:51:15 »
Alrighty, thank you. Sorry to annoy ya.
Offline takaki
« Reply #53 on: Mon, 20 May 2013, 08:56:52 »
Just got out of office, the amount of colors available is a little bit over what I've expected.
Now to play with colour combinations, will upload some pictures later.
There is even some matt finished acrylic sheets available. Not sure if you guys will like Matt or glossy better.
Any votes?
« Reply #54 on: Mon, 20 May 2013, 09:05:03 »
I would prefer matte since I would mark up glossy finishes with my fingerprints.
Offline keymaster
  • Topre Revolution Theorist
« Reply #55 on: Mon, 20 May 2013, 09:15:09 »
Matte since glossy looks bad unless it's always clean.
Offline Latin00032
« Reply #56 on: Mon, 20 May 2013, 10:58:23 »
Do they have a smoke matte?
Offline takaki
« Reply #57 on: Mon, 20 May 2013, 12:41:18 »
Smoke meaning slight grey colour right ? I've seen the Matt black, it is a quite grey in colour, but I just couldn't picture a matt surface and "smoke" colour together.
Here is a potato picture of all the pieces of colour samples thrown at me today at the office, give me a little time to sort it the pictures out.
If you take take a look at PLF524 (bottom left), is it the kind of matt smoke you are looking for? Greyish matt stuff that isn't really transparent, about 80% opaque.
« Last Edit: Mon, 20 May 2013, 12:43:30 by takaki »
Offline Dsan
« Reply #58 on: Mon, 20 May 2013, 12:54:31 »
Do you have an ETA for payments?I'd really like one of these cases :D
Offline Rule16
  • R.I.P. SmallFry
« Reply #59 on: Mon, 20 May 2013, 14:19:03 »
Oooooo the neon green (d-m-993) and neon orange (idunno its got a bigass sticker on it :( ) are hawt.... But would only go well with backlighting probablly... This wouldnt fit a ducky shine ii tkl would it?
« Last Edit: Mon, 20 May 2013, 14:21:27 by Rule16 »
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline Jupiter
« Reply #60 on: Mon, 20 May 2013, 18:20:41 »
Do you have any time frame or rough estimate for these?
(Going to be) building Phantom - Red MDPC / White Heatshrink Pexon Cable - WoR/RoW Klaxon - Shiny Titanium Spacebar - Titanium Zerg key
Offline Megaweapon
« Reply #61 on: Mon, 20 May 2013, 18:38:06 »
That green would work great with the toxic set caps.
Ancer Research Groop DFK191ABA11 • IBM Model M13 Part 92G7461 (white) • Rosewill RK-9000
Matias Tactile Pro 3 • Apple Extended Keyboard II (ALPS)
• Rosewill RK-9000I
Offline Latin00032
« Reply #62 on: Mon, 20 May 2013, 19:10:10 »
I'll take that grey 80 percent opaque.
Hopefully, you get some better pictures so I can see the difference.
« Last Edit: Mon, 20 May 2013, 20:13:43 by Latin00032 »
Offline keymaster
« Reply #63 on: Mon, 20 May 2013, 19:26:44 »
I really like the see-through black/dark gray. I think those will have mass appeal whereas something like a bright yellow will only have small amount of interest.
Offline Rayne
  • For Science!
« Reply #64 on: Mon, 20 May 2013, 19:40:36 »
OMG this soo much, i would buy the crap out of that color
Offline takaki
« Reply #65 on: Mon, 20 May 2013, 20:15:10 »
Most of the colour there on the table are only available as the top and bottom layer. The centre layer uses a different thickness of acrylic and the colours available for the centre portion is definitely not going to be as much as the top and bottom layer.
as for any final dates, I would really want to use to finalise the design with a fit test on the phantom.
Offline bazemk1979
« Reply #66 on: Mon, 20 May 2013, 20:41:53 »
would be nice to have some cases for full boards too, CM XT , Filco , Ducky.... bunch of people with 104 boards around here
Offline takaki
« Reply #67 on: Mon, 20 May 2013, 21:44:06 »
can definitely look into doing up a 104, I am just worried about the fit wise, are all the profiles of the different keyboard's plates+pcb of the same dimensions ? etc etc
Offline Moomoo
« Reply #68 on: Mon, 20 May 2013, 22:50:01 »
Get this going nao!
Offline takaki
« Reply #69 on: Tue, 21 May 2013, 01:48:53 »
In due time, in due time :)
Offline pasph
« Reply #70 on: Tue, 21 May 2013, 05:26:45 »
+1 for 104 keys case
Offline Elrick
  • Hype Master
« Reply #71 on: Tue, 21 May 2013, 06:12:54 »
When you said 104 setup my heart skipped a beat.  PLEASE do it.
Totally happy if the Acrylic Case can hold a Cherry G80-3000 series board.  Have heaps of those and would probably buy two for now with the possibility of getting more later.
I will of course buy one TKL case for a spare filco board laying around but definitely want a beautiful 104 case for some Cherry Goodness.
This Group Buy is starting to get EXCITING.....  :o
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #72 on: Tue, 21 May 2013, 06:23:32 »
Interested if they are available for QFR!
Offline bazemk1979
« Reply #73 on: Tue, 21 May 2013, 07:35:11 »
that's a good question, I know that Filco, Rosewill and soon upcoming CM XT are made by Costar. Here is the trick, Rosewill uses mini USB detachable, Filco has the attached cord, while the CM XT will have detachable USB plug and not mini USB.
I guess when time comes for you to give the 104 boards a shot, for example I have a Rosewill board and when CM XT comes out will have at least few of those in different switches. If you need us to open them up and take measurements we can do that.
EDIT: Imagine how many people would love to get rid of the Rosewill casing just because of the logo on them, also will give Rosewill users to check the mini usb for solder joint failure and they can redoit and add some guerila glue to it to be trouble free for a very long time.
« Last Edit: Tue, 21 May 2013, 07:37:39 by bazemk1979 »
Offline BimboBB
« Reply #74 on: Tue, 21 May 2013, 08:08:11 »
104/105 would be nice. my filco case looks a bit used already.
Offline takaki
« Reply #75 on: Wed, 22 May 2013, 09:15:13 »
Thank you guys so much for the suggestion and possible help on getting the measurement done!! Will definitely consult you guys for it when we move on to the 104 case!
First we need to get this TKL settled. I'm going to receive the colour samples tags in the next day or two, I really don't like my potato picture taken at the laser guy's office. Will post some that I took later but first things first.... QFR support huh ? So I've gotten myself one QFR to test things out...Sweet box mmhmm
Keyboard exposed
Do not remove ??
IT FITSSSSSSSSSSSSSSSSSS and it fits quite nicely like how the filco does.
« Last Edit: Wed, 22 May 2013, 09:17:16 by takaki »
Offline Latin00032
« Reply #76 on: Wed, 22 May 2013, 09:17:32 »
Woo hoo!!!
That's the keyboard I have.
Yay! It will work.
So it fits the Filco as well as the QFR. Is this correct?
Offline takaki
« Reply #77 on: Wed, 22 May 2013, 09:23:50 »
Yes but you might have to get a new cable or we come out with a solution for the lack of 4 pin connector to USB male cable.
Offline Permeability
Re: [IC] Acrylic Case for Phantom & Filco & QFR (Confirmed!!)
« Reply #78 on: Wed, 22 May 2013, 09:36:45 »
Awesome, we just need to find out if it fits a board with a plate in it :D
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
Offline whiskytango
  • Don't touch the trim
« Reply #79 on: Wed, 22 May 2013, 10:35:59 »
Do you have a picture of the inside of the case where the hole for the USB connection will be? Might it possible to simply mount the daughter board from the QFR into this case?
Offline takaki
« Reply #80 on: Wed, 22 May 2013, 12:15:49 »
Time frame is I can start accepting orders from next week :)
Offline takaki
« Reply #81 on: Wed, 22 May 2013, 12:16:54 »
Possible, it is a pcb that converts the 4 pins to female mini b
Offline nebo
« Reply #82 on: Wed, 22 May 2013, 12:27:54 »
Awesome!
Just realised that there are already proper terms for the casing designs like
Standard, Arrclus, Winkeyless, Winkeyless_Arrclus.
I will look into it but winkeyless is going to be complicated considering the fact that there are 1.5x and 1.25x variations of winkeyless, do let me know which one you are interested in.
I am trying my best to make the order as customizable as possible but likewise, more customizations means more cost, do keep that in mind.
The current feel of the interest in colours, do let me know which colours you guys are interested in so I can get colour samples taken for you guys to choose.
Translucent/Transaparent :
Blue
Red
Orange
Smoked Black/Grey
Purple
Pink
Opaque:
Black
Silver
Orange?
Blue?
*added more colours :D
I missed this earlier. I think most people interested in winkeyless only care about 1.5 mods
Offline Rayne
  • For Science!
« Reply #83 on: Wed, 22 May 2013, 19:21:39 »
YAY cant wait! I'm so excited for these :D
Offline Jupiter
« Reply #84 on: Wed, 22 May 2013, 19:58:02 »
Sweeeeeet! I just need to make the impossible decision on what colors!
Offline eRadicatedZomBiE
  • It's OK, I'm A Doctor.
« Reply #85 on: Wed, 22 May 2013, 20:26:51 »
I'm in for a case
CM QFR | WASD V1 | Flico MJ2 LE Blue | Ducky 78 | Ducky DK9008G2 Pro LE  |Phantom |
Ergodox
My WTB Thread
Offline bazemk1979
« Reply #86 on: Wed, 22 May 2013, 21:26:16 »
in for a case like  I said previously, OP what sort of modifying we have to do to the case for the QFR cable to fit, or we have to have short cable connected that will stick out of the case with a mini USB female at the end?
Offline Latin00032
« Reply #87 on: Wed, 22 May 2013, 22:22:21 »
Do you have any pictures to give me an idea of how the USB cable will work with a Filco or QFR?
« Reply #88 on: Wed, 22 May 2013, 22:23:32 »
Don't the QFR's have removable cables?
Offline bazemk1979
« Reply #89 on: Wed, 22 May 2013, 22:25:42 »
yes it has, but will they be able to leave a cut out hole to fit the QFR exposed female mini usb is the question.
« Reply #90 on: Wed, 22 May 2013, 22:30:46 »
That makes more sense :))
Offline takaki
« Reply #91 on: Wed, 22 May 2013, 22:37:07 »
I can have screw holes drilled at the bottom layer to mount the daughterboard so you can still use back the old mini usb port.
Either that or you can ditch the whole cable and mini usb port completely and get a custom "filco" cable made.
The current design allows filco users to use back their old filco usb cable and there are some specific holes created so you can just snug fit the cable like the original filco case. The hole is rather small and it doesn't seem to be able to fit something like a micro usb port.
I will definitely look into this more specifically and come out with a better design to solve this cable issue.
Offline Sai
« Reply #92 on: Wed, 22 May 2013, 22:39:58 »
any news on 1.5 wkl layout as well ?
Offline takaki
« Reply #93 on: Wed, 22 May 2013, 22:41:30 »
It works exactly the same as how it would work on the filco.. the final phase of this prototyping is only anchoring on the design of the bottom layer to accommodate teensy, filco and QFR cabling issues. And yes also about the colour combinations.  I'll post pictures after I'm done with work today.
Offline takaki
« Reply #94 on: Wed, 22 May 2013, 22:42:29 »
definitely looking into it, so far it seems like there are only 2 interest indicated for 1.5x winkeyless top panel.
Offline Sai
« Reply #95 on: Wed, 22 May 2013, 22:44:59 »
need more people on 1.5x WKL !!!
Offline Rendom
« Reply #96 on: Wed, 22 May 2013, 23:24:37 »
can I join in the club? : p
QFR - MX Blue
Offline Sai
« Reply #97 on: Wed, 22 May 2013, 23:49:47 »
yes. you can. :P
Offline Rayne
  • For Science!
« Reply #98 on: Thu, 23 May 2013, 00:39:22 »
I wish i had a WKL board :(
Offline jabar
« Reply #99 on: Thu, 23 May 2013, 00:49:02 »
Can you do the 96 key 7bit layout?
e: or is that the PRF/jcarpe custom one?
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
