Author Topic: A video soldering a QFP44 SMD MCU  (Read 11016 times)
Offline GON
  • Skype ID : GonsKeyboardWorks
    • GONsKeyboardWorks
« on: Tue, 21 May 2013, 23:53:29 »
I took this video to show how to solder a QFP44 MCU.
I'm so sorry not to speak in English nor to have added English captions.
In fact, I'm not a fluent English speaker.(Writing is one thing, Speaking's another. ;))
And not accustomed to the whole function of YouTube...
Later, I promise I will record video in English so that you GH members could easily understand. ;)
Even though I have made/assembled/tuned HUNDREDs of keyboards for others, I myself don't have a full-tuned Custom Keyboard now.
So Ironical!
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: A video soldering a QFP44 SMD MCU
« Reply #1 on: Wed, 22 May 2013, 00:02:47 »
Do you mind if I link this in the soldering beginners thread?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Wed, 22 May 2013, 00:02:48 »
Is this an A.87 PCB?
Offline GON
    • GONsKeyboardWorks
« Reply #3 on: Wed, 22 May 2013, 00:05:26 »
Not at all.
It's my pleasure if this video can help others. ;)
Link as you want. ;)
So Ironical!
Offline GON
    • GONsKeyboardWorks
« Reply #4 on: Wed, 22 May 2013, 00:05:53 »
Yes, it's A.87 PCB
So Ironical!
Offline kaiserreich
  • HHKB Elite
« Reply #5 on: Wed, 22 May 2013, 04:22:10 »
Lovely drag soldering :)
What is the size of the tip being used ? (diameter)
Offline Rendom
« Reply #6 on: Wed, 22 May 2013, 05:31:42 »
sound so handsome  :-*
QFR - MX Blue
Offline GON
    • GONsKeyboardWorks
« Reply #7 on: Wed, 22 May 2013, 05:36:11 »
The tip used in the video is HAKKO T15-CF3 - 3mm in dianeter.
So Ironical!
Offline GON
    • GONsKeyboardWorks
« Reply #8 on: Wed, 22 May 2013, 05:36:39 »
So Ironical!
Offline Leslieann
« Reply #9 on: Wed, 22 May 2013, 05:54:34 »
Fantastic technique, my luck I would end up soldering half the pins together and the other half wouldn't get anything at all.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline The_Beast
  • I like wood ಠ_๏
« Reply #10 on: Wed, 22 May 2013, 05:58:06 »
What solder iron did you use? What was the temp?
I hope the SMD goes as smoothly on my A.87!
Offline GON
    • GONsKeyboardWorks
« Reply #11 on: Wed, 22 May 2013, 06:03:11 »
The iron used in the video is HAKKO FM-206 station + FM-2027 iron + T15-CF3 tip.
I usually set the temp to 350 Celsius.
So Ironical!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #12 on: Wed, 22 May 2013, 06:05:28 »
Thanks! If you had a HAKKO FM-206 station, why didn't you hot air SMD solder? Seems a bit odd since everyone seems to prefer to hot air SMD solder over an iron.
Offline GON
    • GONsKeyboardWorks
« Reply #13 on: Wed, 22 May 2013, 06:43:54 »
Of course, I have an FM-2029 hot air pencil.
In fact, I have HAKKO FR-803 Hotair rework station with various nozzles, too.
I solder small SMD parts with hot air, but not QFP44.
The best soldering quality for QFPs can be done with a proper iron tip.
You will be able to know it if you take a closer look at the toes and hills of the QFP leads with a magnifier.
So Ironical!
« Reply #14 on: Wed, 22 May 2013, 06:47:34 »
I also only use tip-and-wire to do them now.  I attempted a hot air solder of a TQFP44 and I over-temp'ed it.  Destroyed the flash as far as I can tell.
Offline GON
    • GONsKeyboardWorks
« Reply #15 on: Wed, 22 May 2013, 06:54:51 »
http://www.kbdmania.net/xe/index.php?_filter=search&mid=photo&search_target=nick_name&search_keyword=GON_&page=2&document_srl=4962270
Here in the link above  you can see two soldered QFPs.
One is soldered with an iron tip by me.
The other is soldered by SMT machine.
Which one do you think is better? ;)
So Ironical!
Offline Wraul
« Reply #16 on: Wed, 22 May 2013, 12:18:26 »
Very nice soldering GON.
I wish I could produce solder joints that looks that good.
I will keep practicing.
Offline GON
    • GONsKeyboardWorks
« Reply #17 on: Wed, 22 May 2013, 14:15:43 »
Practice makes Perfection. ;)
So Ironical!
Offline adamseto
« Reply #18 on: Sat, 25 May 2013, 10:03:22 »
Pro assemble of Mechanical Keyboard :v
Name : Lê Duy Hùng ( Alex )
Cell phone : (+84) 979 13 49 53
Email : thanchetdemnoel@gmail.com
BBM : 2AA9E38E
OEM : Filco full red SW/Filco Camouflage full Brown SW/Realforce 108UDK/Realforce 87U Silent/Cherry ESA-3000-HASRO
Custom : KMAC2 VintageBlack 62g/360C Black 60G Gold/TheCheat Vintage Black 62G/Dolphin Vintage Black 60G/LZ-STAN
