Author Topic: Post Your LZ-GH !  (Read 96173 times)
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: Post Your LZ-GH !
« Reply #100 on: Mon, 24 June 2013, 23:22:48 »
This entire thread makes my newly modded Filco look mediocre. UNNOTIFIED!... but I won't :))
THIRD PAGE!
Offline okooko
  • afk.
« Reply #101 on: Mon, 24 June 2013, 23:36:38 »
THIRD PAGE!
MMMM DAT AS$
anyone got 2, so you can take a photo of a reflection of a reflection....inception...
Offline calavera
« Reply #102 on: Mon, 24 June 2013, 23:37:36 »
LZception.
Where are all the other colors besides black? I only saw one or two.
Offline okooko
  • afk.
« Reply #103 on: Mon, 24 June 2013, 23:42:21 »
LZception.
atakp had a grey one first few posts, then the proto orange posted by DrugER and TJ red one I think...
All colors should be covered. Turkishrambos one would be identical to mine, so I can't wait...
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #104 on: Mon, 24 June 2013, 23:51:39 »
THIRD PAGE!
MMMM DAT AS$
Why you do this to me, brah... now I'm going to be checking back here more often to see these pics... :))
Offline emptythecache
  • out.
« Reply #105 on: Sat, 29 June 2013, 13:08:13 »
Enjoy your potato!
Offline Rendom
« Reply #106 on: Sat, 29 June 2013, 13:28:11 »
Enjoy your potato!
Looks great!
QFR - MX Blue
  • out.
« Reply #107 on: Sat, 29 June 2013, 14:01:38 »
I need some 1x windows keys :/
Offline bazemk1979
« Reply #108 on: Sat, 29 June 2013, 15:20:21 »
I practically love the 1.5 - 1 - 1.5 - 7 layout.... as for the x1 keys just add the x1 modifiers from the purple set dude!
  • out.
« Reply #109 on: Sat, 29 June 2013, 15:26:32 »
I didn't get the mod set, only the esc and cmyk. The current cap set is temporary anyway, my GMK dolch set will be going on this board, and hopefully it will come with 1x blank keys right away.
Offline bazemk1979
« Reply #110 on: Sat, 29 June 2013, 15:35:49 »
it wont, there will be sidegrade keys for purchase, hopefully they come together with the dolch though, x1 keys for R1 and R4 in blanks and windowed, 1.75 shift  and not sure if he has anything else in mind.
  • out.
« Reply #111 on: Sat, 29 June 2013, 16:26:30 »
yeah i know, but if they have the molds and the plastic, i don't know why those supplementary sets wouldn't be available at the same time.
Offline bazemk1979
« Reply #112 on: Sat, 29 June 2013, 16:34:32 »
I hope they will be available at the same time, that way I can add some more to my order, already added 2 sticker sheets and 65g springs :)
Offline megaxpop
« Reply #113 on: Sat, 06 July 2013, 06:15:37 »
so kool! >.<
Offline bazemk1979
« Reply #114 on: Sat, 06 July 2013, 10:50:01 »
^ thanks  :)
is 0508 the correct reference, I can't find a place to buy some.
they are every where all over the ebay.... 0508 or 2012 marked with both. I just ordered 2 packs of 250 each for the upcoming Trixk board. What you want is 1.2K Ohm for the for the 1.8-2.4V LED's and 820 Ohm for the 3-3.4V LEds.
http://www.ebay.com/itm/290940624271?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_6195wt_1161    1.2K Ohm
http://www.ebay.com/itm/300850253874?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_6195wt_1161     820 Ohm
Don't forget they are 2 stages of modding the leds though, speaking of if you get the round ones, and you just want to make them fit not interfering with keyacap bottoming out then you only need to shave off the wire sides, this mod wont give you the ability to remove the top cover of the cherry switch for later down the road stem and spring swap. Only benefit you will have is flush leds that wont came in way with bottoming out.
The full blown mod would be, shaving off the the leds all around and shaving off the top cover of the cherry housing, this will give you flush leds and removable top cover to swap springs and stems in future.
« Last Edit: Sat, 06 July 2013, 10:53:40 by bazemk1979 »
Offline elton5354
« Reply #115 on: Sat, 06 July 2013, 11:40:39 »
I think alaricls used 1.2k ohm for the red LEDs and they're REALLY dim.  If you want them brighter, use a lower ohm resistor, like 1k or something.
Offline Turkishrambo
« Reply #116 on: Sun, 07 July 2013, 22:05:35 »
this thread needs more pics!
Offline alaricljs
  • I be WOT'ing all day...
« Reply #117 on: Mon, 08 July 2013, 08:16:08 »
How dim is really dim?  I used the values that Redline specified after double checking them with some math.  If the LED light is just a spec of color in the LED with no real luminescence then you need to reset the KB firmware and you'll get full brightness.  Aside from the resistor values there is whatever Redline did to control brightness since they have a 50%/100% brightness toggle in their control program.  There were a couple PCBs I tested that came up with nearly pointless brightness levels and a reset always fixed it.
Filco w/ Imsto thick PBT
Offline YoungMichael88
  • HHKB Wannabe
« Reply #118 on: Thu, 11 July 2013, 13:55:27 »
The rest of my resistors came in today. But one spool in unlabeled. They each have "122" on them. Can anyone confirm these are 1.2k? How can I know for sure? The time has come to get started on this beast.
Offline alaricljs
« Reply #119 on: Thu, 11 July 2013, 13:58:27 »
typically 1201 would be 1.2k, 7320 would be 732 Ohms
First 3 digits are the first 3 digits of the resistance, 4th digit is the # of zeros after... 1203==120,000
In your case I'd expect they decided to use less ink and do 2 digits plus # of zeros:  122==1200  Which is 1.2k :)   Of course to know for certain, you measure.
  • HHKB Wannabe
« Reply #120 on: Thu, 11 July 2013, 14:07:24 »
As usual, he has all the answers! Thank you sir.
« Reply #121 on: Fri, 12 July 2013, 20:23:36 »
FINALLY COMPLETE!!!!
A vision has finally become reality.
Sorry for potato pics :P
« Reply #122 on: Fri, 12 July 2013, 20:24:07 »
Oh man I remember you talking about this. Looks really good dude
« Reply #123 on: Fri, 12 July 2013, 20:27:42 »
sup son?
Yeah, i originally got green LEDs with my order because i thought the toxic set wouldnt take this long. Finally the orange LEDs came and i got down to business. Could not be happier!
Also for people who ordered WKL, make sure you solder on the leds the correct way for the ctrl/alt keys. Had to resolder mine thinking they all went the same way ~_~
« Last Edit: Fri, 12 July 2013, 20:29:23 by Turkishrambo »
Offline jil_jil32
  • Tokyo Press <3
« Reply #124 on: Fri, 12 July 2013, 21:04:10 »
Full ORANGE LEDs is the way to go! It's coool bro!
« Reply #125 on: Sat, 13 July 2013, 01:32:17 »
That nighttime orange glow is awesome!
Offline pmh1410
« Reply #126 on: Sat, 13 July 2013, 05:04:01 »
Very nice your LZ-GH ;)
Offline tom88jerry
« Reply #127 on: Sat, 13 July 2013, 06:51:18 »
Very nice LZ-GH!
The led color looks like lava......
Offline AKIMbO
  • HHKBro
« Reply #128 on: Sat, 13 July 2013, 07:22:47 »
Looking good.  A true Geekhack themed LZ-GH.
| KBD75 (box reds)
Offline jil_jil32
  • Tokyo Press <3
« Reply #129 on: Sat, 13 July 2013, 12:35:39 »
He might want a Hack Orange Skull to complete the theme ^______^
Offline Photoelectric
« Reply #130 on: Sat, 13 July 2013, 13:10:53 »
HO would be too red for that in my opinion!  I think it's great with all black/orange caps--very symmetrical clean look!
« Reply #131 on: Sat, 13 July 2013, 13:21:41 »
Haha id buy one but i wouldnt spend too much on it :P
« Reply #132 on: Sun, 14 July 2013, 22:53:03 »
Just got a new camera, trying to take some decent pictures in the worst lighting conditions evar.
still learning all the terms and what everything does, dont grill me too hard xD Not even focused right X.x
« Reply #133 on: Sun, 14 July 2013, 22:59:16 »
I know it's been said by others but that Orange and Black is very nice!
« Reply #134 on: Sun, 14 July 2013, 23:05:16 »
Thanks bro! Just trying to keep the thread alive... i want more people to be posting. Especially some metal grey and red boards
Offline Glissant
« Reply #135 on: Wed, 17 July 2013, 15:43:40 »
I wasn't sure if I should post this here, in the group buy thread or in both, but I decided to post it just here.
My LZ-GH is an 86 in a black aluminum case with stock clear switches and full RED LEDs. Currently wearing full Red on Gray Klaxon.
Here is the beginning of my LZ-GH adventure. It took a little time because I made a mistake when I first wanted to put it together. I soldered my corner switches before putting in stabs *facepalm.
Here I have desoldered the corner switches, and I am ready to go.
28465-0
Soldering switches
28467-128469-2
Not all switches are soldered on the bottom of the board.
28471-3
Soldering the LEDS
28473-4
SMD soldering with solder iron isn't hard
28475-528477-6
Does everything work?
28479-7
YES! Everything works :)) .
28481-828483-9
Very happy with the board. Now I just need to figure out if I can toggle the LEDs without the TrIK program xD.
« Last Edit: Sat, 20 July 2013, 16:08:42 by Glissant »
Offline tom88jerry
« Reply #136 on: Wed, 17 July 2013, 15:50:55 »
Very nice job  ;D
Soldering switches
Soldering the LEDS
YES! Everything works :)).
  • out.
« Reply #137 on: Wed, 17 July 2013, 16:02:23 »
Glissbro, I think the different LED modes are set to `+ (1-4). I downloaded the TRiK program to figure that out, but once I was in there, I didn't have to change anything to get that functionality on my board.
Offline Dianoda
« Reply #138 on: Wed, 17 July 2013, 16:26:48 »
LED control should be whatever key the macro ("M" in TRiKer) is set to + 1/2/3/4 to cycle through the various LED modes - when my board arrived the "M" macro key was set to the "pause/break" key, so maybe try that (I was under the impression "pause/break" was the default key assigned to macro duty).
Offline Glissant
« Reply #139 on: Wed, 17 July 2013, 16:32:51 »
ECbro, thanks for the suggestion :) I found out that Pause + 1234(5) set the LED modes for me. No idea how to even change that or anything else like an FN layer on this beast, but I'm fine for now.
Dianoda, thank you. I just found that myself, so now I can control the LEDs at least ^^.
« Reply #140 on: Wed, 17 July 2013, 16:41:52 »
Thanks! i didnt know this because the guide is in korean. I was opening the program to turn on LED's each time.
If anyone can translate how everything works that would be awesome.
  • HHKB Wannabe
« Reply #141 on: Wed, 17 July 2013, 17:42:36 »
WE DEMAND ENGLISH!! Hehe but seriously..... Please......
Offline Glissant
« Reply #142 on: Thu, 18 July 2013, 02:44:10 »
English would be extremely helpful, so I hope someone can do that for us
Offline WhiteFireDragon
    • youtube
« Reply #143 on: Thu, 18 July 2013, 03:07:45 »
Glissant, those red LEDs on a silver plate, as well as red hue in the dark look uber nice!
Btw, that weller iron is too hot. The dial should be on setting 3 max for just switches and the stock tip. Less risk of frying/lifting pads. Trik PCBs are good quality though so not much of a risk as cheaper ones.
Offline Kabuks
« Reply #144 on: Fri, 19 July 2013, 12:16:57 »
Does anyone know what the default keymapping is to swap LED modes?
Offline alaricljs
« Reply #145 on: Fri, 19 July 2013, 12:18:08 »
either tilde + 1-4 or Pause + 1-4   I've had both.  Resetting the firmware (Esc while plugging it in) should make it Pause but will also break your keymap a little (modifiers will be wrong)
Offline Kabuks
« Reply #146 on: Fri, 19 July 2013, 12:20:09 »
Thanks Sir. :)
Offline eth0s
  • Peace & Love
« Reply #147 on: Fri, 19 July 2013, 12:55:44 »
Holy crap that looks awesome!
Offline tadbitnerdy
« Reply #148 on: Fri, 19 July 2013, 13:33:34 »
Mine is in the mail!
Offline bazemk1979
« Reply #149 on: Fri, 19 July 2013, 17:19:40 »
It looks like the temp is set around 5 ish? ugh that's around 500C ? NO! bad boy!
