Author Topic: Post Your LZ-GH !  (Read 96174 times)
Offline eth0s
  • Peace & Love
Re: Post Your LZ-GH !
« Reply #150 on: Fri, 19 July 2013, 17:21:23 »
Mine is in the mail!
Mine is in a box, yet to be assembled.   :(
Offline Glissant
« Reply #151 on: Fri, 19 July 2013, 17:23:01 »
It was set to four. It was pretty perfect for me and as you can see everything works and looks adequate.
Offline tadbitnerdy
« Reply #152 on: Fri, 19 July 2013, 19:04:10 »
I had mine set to four when assembling the ErgoDox.  Worked perfectly for me, too :)
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #153 on: Sat, 20 July 2013, 21:13:39 »
What is a good temperature? I thought it was like listening to music and you just set it to 11 and forget it :p
Offline Turkishrambo
« Reply #154 on: Sat, 20 July 2013, 21:21:29 »
for SMD soldering i use 210 or so. so i htink for an iron 250 would do the trick. My solder iron is a dial though. i set it to 3 of 5
Offline tadbitnerdy
« Reply #155 on: Sat, 20 July 2013, 21:24:21 »
Why not just make '10' hotter?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #156 on: Sat, 20 July 2013, 21:58:18 »
On the WLC100 I was using 3.5.
Filco w/ Imsto thick PBT
« Reply #157 on: Sat, 20 July 2013, 21:58:46 »
I turn it up to 5 to heat up and then go down to about 3.5 as well on the WLC100.
Offline YoungMichael88
  • HHKB Wannabe
« Reply #158 on: Sat, 20 July 2013, 22:32:28 »
Offline Batmann
« Reply #159 on: Wed, 24 July 2013, 16:38:59 »
And here is mine:
So it's no longer black because I had to fix a dent on the top left corner,
I wet sanded it to get the flat surface back, I then filled with an aluminium/epoxy putty where it was needed and finally got it powder coated pearl white.
I am very happy with result and the dent is completely gone :D
Powder coating sort of smoothed the edges and made for a more glossy classic look
I can detail the process with some pictures (not so many) if some of you have a dent issue and are interested.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #160 on: Wed, 24 July 2013, 16:40:41 »
I would be very interested in the process both from a learning perspective and because I want a white case some day.
  • HHKB Wannabe
« Reply #161 on: Wed, 24 July 2013, 21:04:12 »
This has been my afternoon/evening. Resistors resistors resistors
« Reply #162 on: Wed, 24 July 2013, 21:12:20 »
i couldnt imagine doing the resistors without a SMD rework machine.. that would take me so long.
Dat white LZ-GH is HOT!
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #163 on: Wed, 24 July 2013, 23:20:18 »
And here is mine:
That turned out really well. Now you have a one of a kind LZ-GH :p
Offline Glissant
« Reply #164 on: Wed, 24 July 2013, 23:32:29 »
It doesn't take that much time for me to do it, but I'm sure it would've been a fair bit quicker with the "right" type of equipment. I sure appreciate being able to see small components still, and hope I won't lose that ability anytime soon.
Offline esoomenona
  • Gnillort?
« Reply #165 on: Wed, 24 July 2013, 23:38:14 »
That's beautiful, Batmann. Great choice and job.
Offline codyeatworld
« Reply #166 on: Thu, 25 July 2013, 00:29:21 »
So I built mine up and was gonna share it tonight. but I forgot the wire in the spacebar -__-
Ill share mine whenever I get around to redoing it.
and btw batman that white looks really good! I was thinking they were going to replace yours completely.
Offline rurushu
« Reply #167 on: Thu, 25 July 2013, 01:22:08 »
And here is mine:
very interested to know... can make a thread for it??? I think it will be very very useful for others as well!!!!
Offline ItsBc
  • BARACOOT
    • Portfolio
« Reply #168 on: Thu, 25 July 2013, 02:19:23 »
That is awesome Batmann. :)
Offline Batmann
« Reply #169 on: Thu, 25 July 2013, 04:18:53 »
Thanks for the kind words  :)
I'll make a thread in the making stuff together section when I'll have all the pictures gathered
Offline rurushu
« Reply #170 on: Thu, 25 July 2013, 04:46:28 »
thanks batmann!!!! you're every dented keyboard owner's savior!!!
Offline Batmann
« Reply #171 on: Thu, 25 July 2013, 05:00:25 »
haha, I'll try my best to make it clear so it can help out!
« Reply #172 on: Thu, 25 July 2013, 11:15:51 »
Got mine done up finally.
First time lubing and stickering switches. I might have to redo a few switches but thats okay I'm really happy with it. I'm gonna crack her open again when my leds come in the mail.
Vintage Blacks - Black Stickers - Limmys lube kit + Victorinox for springs
Cable by nubbinator
« Last Edit: Thu, 25 July 2013, 12:43:22 by codyeatworld »
  • HHKB Wannabe
« Reply #173 on: Thu, 25 July 2013, 17:51:41 »
After many long hours I have what I call my sunset themed LZ-GH. Klaxon set.
The blue and red LEDs make a purple/pink reflection off the plate. Kinda neat.
EDIT: POTATO WOW!
« Last Edit: Thu, 25 July 2013, 18:01:50 by YoungMichael88 »
  • HHKB Wannabe
« Reply #174 on: Thu, 25 July 2013, 23:31:46 »
In the light no LEDs and in the dark
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #175 on: Fri, 26 July 2013, 08:09:03 »
that yellow-orange-red-pink fade looks really cool, nice work
Offline naokira
  • The King in the North
« Reply #176 on: Fri, 26 July 2013, 08:25:41 »
Question:
How come your leds does not come through the keycap (underglow effect).
I have a Thick PBT russian dyesub and the leds on my Poker II shine through it.
Is it because its a light colored keycap or just the brightness of the led itself?
Because on the stock blackish thick PBT that is included on my poker doesn't shine through.
FaceW in LZ-CE
  • HHKB Wannabe
« Reply #177 on: Fri, 26 July 2013, 12:05:58 »
It shines through the cap just a little bit in the legends but hardly at all. It's probably because the red double shot underneath is dark.
Offline naokira
« Reply #178 on: Fri, 26 July 2013, 12:14:55 »
Question:
I see. Thanks for the info! Did you test it using PBT caps?
FaceW in LZ-CE
  • HHKB Wannabe
« Reply #179 on: Fri, 26 July 2013, 12:32:17 »
No, I have only ever put the Klaxon set on. I can't imagine it being any different than any other fully backlit board tho.
Offline hoggy
  • * Ergonomics Moderator
« Reply #180 on: Tue, 30 July 2013, 10:49:06 »
After seeing so many nice examples...
Offline baldgye
  • Will Smith Disciple
« Reply #181 on: Tue, 30 July 2013, 10:50:33 »
awesome board, really love that colour combination, if it was ISO it'd be perfect :P
Offline Moosecraft
  • HHKB Pro
« Reply #182 on: Tue, 30 July 2013, 11:56:16 »
Really clean and nice looking :D
Offline okooko
  • afk.
« Reply #183 on: Tue, 30 July 2013, 23:08:14 »
Post has been updated, thanks to Hoggy for reminding me, all pics should be linked correctly to posts
Offline hoggy
« Reply #184 on: Wed, 31 July 2013, 13:28:05 »
Thanks guys.  It's nice to see so many of them here.
I'm having problems installing the software, does anyone still have a zip file in their download folder that they could send me? - one that worked for them.  The one I'm having issues with is dated 13.05.07.
  • HHKB Wannabe
« Reply #185 on: Wed, 31 July 2013, 13:58:48 »
I guess I'm lucky. I just plugged the keyboard into my Mac and everything worked perfectly. No programming needed at all. Thank you again Mac.
« Reply #186 on: Wed, 31 July 2013, 14:10:09 »
I didn't have any problems with w8 or mac os x.
What happens when you try to install it?
Offline hoggy
« Reply #187 on: Wed, 31 July 2013, 14:26:08 »
(W7.)  I get - Error: Unable to locate application file 'LKMacro.msi'
« Reply #188 on: Wed, 31 July 2013, 15:08:01 »
I simulated this error by trying to install with setup.exe, do you get the same error when you try to install with TRiKer.msi?
Offline hoggy
« Reply #189 on: Wed, 31 July 2013, 15:45:05 »
No... It works!
Can't believe I didn't even try that.
Thanks! :D
Offline rknize
    • metaruss
« Reply #190 on: Fri, 16 August 2013, 01:21:15 »
Finally finished it.  Grey model with clear stems, Originative 55g springs, and the full Krytox/Victorinox treatment.
Russ
  • HHKB Wannabe
« Reply #191 on: Fri, 16 August 2013, 02:28:49 »
Lookin' good. I like the blue.
Offline keyit
« Reply #192 on: Fri, 16 August 2013, 03:39:56 »
that grey finish is quite the looker
boop
Offline ishpeck
  • Life without MX Blues is no kind of life at all.
    • The Ishpeckian Network
« Reply #193 on: Fri, 16 August 2013, 17:01:48 »
That is dead sexy.
Totally reminds me of the old MIT LISP Machines; http://xahlee.info/kbd/lisp_keyboards.html
Bravisimo!
0:=λfx.x
« Reply #194 on: Sat, 17 August 2013, 03:34:34 »
That is dead sexy.
Bravisimo!
Xah Lee!  LOL
« Reply #195 on: Sat, 17 August 2013, 08:51:46 »
Is that yellow on black? What is this magic? :eek:
Offline Photoelectric
« Reply #196 on: Sat, 17 August 2013, 09:15:03 »
I think it's orange: the SkiData imitation set. ;)  A very nice keyboard!
Offline rknize
    • metaruss
« Reply #197 on: Sat, 17 August 2013, 09:43:24 »
Yeah, it's SkiData.  That keyboard finish is really hard to capture.  It's a bit darker IRL.
Russ
« Reply #198 on: Sat, 17 August 2013, 10:08:26 »
So in other words.... orangeish?
« Reply #199 on: Sun, 18 August 2013, 03:52:38 »
I was going to say ... how did I miss some keycaps with yellow :eek:
But yeah, does look orangeish.
