Author Topic: Cherry MX Laptop?  (Read 10592 times)
Offline gameaholic
Cherry MX Laptop?
« on: Mon, 03 June 2013, 23:06:21 »
Why are there no cherry mx gaming laptops yet?  I'm sure we've all thought of it before.  Would you buy one?  If not which laptops today have the best keyboards?
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline keymaster
  • Topre Revolution Theorist
Re: Cherry MX Laptop?
« Reply #1 on: Mon, 03 June 2013, 23:07:29 »
The keyboard profile may be too high, especially now since the trend is ultra-thin laptops. I'd love to see a Cherry ML or short-throw Topre laptop, though.
« Reply #2 on: Mon, 03 June 2013, 23:09:35 »
I would think cherry ML would be very doable and awesome to have in a laptop.
« Reply #3 on: Mon, 03 June 2013, 23:42:54 »
Most notebooks have scissor switch keyboards, which are about 1/2 cm high at most.
Not sure about MY switches, but MX switches are much higher than that, and then add the keycap on top of that.
A notebook with a mechanical keyboard would also be heavier, cost more, and look quite clunky compared to other slimmer designs out there.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #4 on: Mon, 03 June 2013, 23:46:35 »
Scissor switches found on most laptops aren't that bad.
I don't think I would buy one, I'd rather just carry a 60% with me
« Reply #5 on: Mon, 03 June 2013, 23:47:33 »
But ML switches don't seem to be that much different than scissor switches.
I just need to suck it up and do this.
Offline davkol
  •  Post Editing Timeout
« Reply #6 on: Mon, 03 June 2013, 23:50:54 »
Some vintage laptops had ALPS switches. However, they had cases as thick as modern R series thinkpads, or even thicker. That's very thick.
Offline Goodfella
« Reply #7 on: Tue, 04 June 2013, 00:00:07 »
I also think size tends to be the biggest draw back, especially when you can pack a keyboard in your bag with your laptop. I am currently looking for a decently small leather messenger bag to stash my 11.6" hp lappy and my poker.
QFR | QFR | QFR | Pure LED
Offline fateswarm
« Reply #8 on: Tue, 04 June 2013, 01:00:34 »
Because gamers figure out easily that they need good mice (from FPS gaming) but they are ignorant of the fact there are good and bad keyboards. It explains how Logitech, who I regard the Wizard of the input devices world, they literally make magic out of plastic and steel, have a rich range of mice and only 1 or 2 good keyboards (1 rather, and the form factor is for show-offs) (and of course no word for Topre switches).
I will admit that I'm way too many years in computer hobbyism to have learned of good keyboards a few months ago. It took me around 10 years between I figured out I need a good mouse and needing a good keyboard. I will expect the majority of humans are in a same or worse boat since I'm not even a common consumer, I read about those things way more than the average.
« Last Edit: Tue, 04 June 2013, 01:03:11 by fateswarm »
Offline clockwork
« Reply #9 on: Tue, 04 June 2013, 02:53:07 »
The modern laptop keyboard module is about 6mm thick from top of keycap to backside of plate (really a semi-flexible metal sheet). It's pretty amazing you get 2mm of travel from that total thickness, though it cheats a bit by relying on the rest of the laptop to provide most of the rigidity needed.
For comparison, the ML switch module itself is 9.6mm (for 3mm travel) and the MX switch module is 18.5mm (for 4mm travel). Neither of these include the keycap thickness above the stem or the required rear covering (since they're both through hole PCB mounted switches). For comparison, my relatively fat little Lenovo X220 (a 12.6" subnotebook, but definitely not an Ultrabook) has a base thickness of ~19mm in the keyboard area not including the screen, or 25mm including the screen. The HDD and motherboard are almost entirely located under the keyboard. A MX switch plus keycap is about as thick as the notebook is when closed.
In short, to use MX switches, you'd have to be OK with a 2" thick laptop without being able to use that extra thickness for better cooling or more expandability (though you could stack a couple HDDs/SSDs in the wrist rest area).
Offline kalessi22
« Reply #10 on: Mon, 08 June 2015, 18:21:00 »
Now, there is a laptop with a mechanical keyboard. It's called the MSI GT80 Titan. You can read more about it here: http://www.anandtech.com/show/8669/msi-gt80-titan-a-beastly-notebook-with-a-cherry-mx-keyboard.  ;)
Offline swimmingbird
  • keyset hoarder
« Reply #11 on: Mon, 08 June 2015, 18:44:53 »
Yep what this guy said.
It is so large though it's not really fair to call it a laptop lol
Offline Altis
« Reply #12 on: Tue, 09 June 2015, 13:46:52 »
I'm not sure I'd even want a laptop with MX Cherry switches. I just got a Lenovo T450S and the keyboard on it is excellent for a laptop... highly recommend it. It's also lighter and a bit thinner than I had expected.
Offline notscott
« Reply #13 on: Tue, 09 June 2015, 21:15:55 »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #14 on: Tue, 09 June 2015, 23:08:34 »
Yeah that MSI laptop is just stupid. Basically it's just portable around the house, though I'm not sure why'd you want to pay 3 times as much just to carry it from room to room sometimes (and if you're actually gaming you gotta move the rest of your setup and find multiple places that are actually comfortable)
« Reply #15 on: Tue, 09 June 2015, 23:36:31 »
its been done in a laptop before.
  • keyset hoarder
« Reply #16 on: Wed, 10 June 2015, 00:50:08 »
For the amount of money that thing costs you could buy/build an X99 SLI rig and a couple of tvs to use in home streaming with
Plus a wireless GON for true pleasure ( ͡° ͜ʖ ͡°)
