Author Topic: Pre-made Teensy keyboard converters?  (Read 3130 times)
Offline 1391406
« on: Sat, 08 June 2013, 13:08:58 »
Why hasn't some entrepreneurial soul started such a service?  Personally, I don't feel like making one for the same reason I don't make my own bread, but I'd buy one if I knew where they were sold pre-built.
EDIT: Title
« Last Edit: Sat, 08 June 2013, 13:16:02 by 1391406 »
Offline alaricljs
  • I be WOT'ing all day...
Re: Pre-made Teensy's?
« Reply #1 on: Sat, 08 June 2013, 13:09:51 »
Huh?  You buy teensy's at pjrc.com.   What do you _really_ mean?
Filco w/ Imsto thick PBT
Offline 1391406
« Reply #2 on: Sat, 08 June 2013, 13:11:22 »
What, and the ones they sell are ready to work as adapters for various keyboards right out of the box?
Offline alaricljs
« Reply #3 on: Sat, 08 June 2013, 13:17:08 »
A teensy is just an atmega breakout.  It's a finished product with a trademarked name.  If you are looking for a Soarer XT converter or one of the other converters as a pre-made package (which technically does not require using a teensy as a base) then no... nobody is doing that yet.
Offline 1391406
Re: Pre-made Teensy keyboard converters?
« Reply #4 on: Sat, 08 June 2013, 13:20:43 »
I would think most members here are familiar with what I'm alluding to when I invoke the words Teensy keyboard adapter(ie. Soarers converter), but I'm curious as to why no one has started such a service selling them pre-built. Seems like it would be profitable. I mean, I'd definitely buy one, and I tend to think a lot of other keyboard enthusiasts would, too.
Offline alaricljs
« Reply #5 on: Sat, 08 June 2013, 13:22:04 »
Yes, now that you've actually said so I know that's what you're talking about.
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #6 on: Sat, 08 June 2013, 13:28:40 »
Wouldn't be easier to use one active ps2/usb adapter?
Offline 1391406
« Reply #7 on: Sat, 08 June 2013, 13:30:59 »
For an XT or terminal keyboard?
Offline 1391406
« Reply #8 on: Sat, 08 June 2013, 13:43:09 »
Hagstrom sells an XT adapter that works well(I bought one), but it costs $49.95 and isn't programmable.
