Author Topic: Anyone tell me if these are Cherry Legends?  (Read 4913 times)
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« on: Sun, 16 June 2013, 03:45:10 »
Looking for some info on the caps that came with a board I bought today, anyone know if these are Cherry legends?
Offline MKULTRA
  • telling it how it is
Re: Anyone tell me if these are Cherry Legends?
« Reply #1 on: Sun, 16 June 2013, 04:25:34 »
I'd reckon they are.
« Reply #2 on: Sun, 16 June 2013, 04:51:30 »
Those look like delicious cherry doubleshots.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Sun, 16 June 2013, 06:39:47 »
Indeed, looks very similar to G80-0929 though the casebody is a bit different. You should open it and see if it has a G80 model on the inside on the PCB. What a nice find. I find it interesting the keycaps are so brilliant looking compared to the casebody. Give it some retrobright loving.
« Last Edit: Sun, 16 June 2013, 06:41:50 by IvanIvanovich »
Offline bueller
  • MX baller
« Reply #4 on: Sun, 16 June 2013, 06:42:12 »
Good idea, I'll grab a screwdriver and report back!
Offline bueller
  • MX baller
« Reply #5 on: Sun, 16 June 2013, 06:47:59 »
Only identifying mark on the PCB was TH-5150. After looking around it looks like this was some sort of IBM 5150 clone.
« Reply #6 on: Sun, 16 June 2013, 07:11:23 »
Do the keycaps look like Cherry doubleshots on the inside?
Offline bueller
  • MX baller
« Reply #7 on: Sun, 16 June 2013, 07:14:48 »
Yup, black and white cross hatching.
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #8 on: Sun, 16 June 2013, 10:29:37 »
Look that space bar  :))
  • CM QFR (Clears) | CM QFR (Blues) | KBT Poker II (62g Browns) | CM Alcor
« Reply #9 on: Sun, 16 June 2013, 15:13:48 »
That is a real man's space bar!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #10 on: Sun, 16 June 2013, 15:14:27 »
Man, I really thought that was a Model F at my first glance
Offline Tym
« Reply #11 on: Sun, 16 June 2013, 15:16:46 »
I bet you could see that spacebar from space! :P
« Reply #12 on: Sun, 16 June 2013, 16:52:51 »
It really raises the bar on space bars!
Offline Photoelectric
« Reply #13 on: Sun, 16 June 2013, 17:12:52 »
And yet that bar still did not run out of usable space...
« Reply #14 on: Sun, 16 June 2013, 17:16:34 »
After all these puns I could do with a drink!
Is there any space at the bar?
Offline Broadmonkey
« Reply #15 on: Mon, 17 June 2013, 03:12:43 »
That is a really nice keyboard.
Could you take a picture of it with some of the keys taken of? that way it's much easier to tell which switches it uses.
