Author Topic: Where to get foam for under pcb?  (Read 2910 times)
Offline ___q
« on: Wed, 19 June 2013, 09:58:31 »
On some of the used custom keyboards I've acquired, there has been a piece of foam in the bottom of the case under the PCB, presumably to deaden some of the bottoming-out sound by filling up that hollow space.  These keyboards also sound great.
I have a Filco in one of the vortex aluminum cases which I did not put any such foam in, and it doesn't sound nearly as nice as the customs.  Where can I buy foam like this which is safe for the pcb?  Searching on Amazon for words like 'foam' and 'memory foam' isn't particularly helpful.
Offline damorgue
    • Personal portfolio
Re: Where to get foam for under pcb?
« Reply #1 on: Wed, 19 June 2013, 09:59:51 »
I believe the one commonly used is actually a shelf liner.
Offline jcrouse
« Reply #2 on: Wed, 19 June 2013, 10:00:06 »
Michaels (hobby store). Cheap and many nice colors to choose from, if that matters.
Offline damorgue
« Reply #3 on: Wed, 19 June 2013, 10:01:26 »
http://www.amazon.com/Grip-Shelf-Drawer-Liner-Black/dp/B000KFSOFI
Rubber shelf liner, like the one above is the one I was thinking of.
« Reply #4 on: Wed, 19 June 2013, 10:04:59 »
I used a rubber/foam kitchen drawer liner from Target.
« Reply #5 on: Wed, 19 June 2013, 10:05:59 »
I line the bottom of my boards with nudes of CPTBadAss.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #6 on: Wed, 19 June 2013, 13:05:59 »
I see how it is!
