Author Topic: Springs?  (Read 4081 times)
Offline Rafen
Springs?
« on: Thu, 20 June 2013, 21:23:58 »
I am looking for a place to buy different springs for my cherry reds. Something stiffer but I am not sure what kind of springs to buy or where to purchase them. Any help would be appreciated. I am looking for a spring that would give me a 55g actuation force.
Re: Springs?
« Reply #1 on: Thu, 20 June 2013, 21:27:16 »
Sherryton's Originitiveco.com. 55g would be lighter than your current Reds. 62g is slightly heavier than MX Reds. Check out my review in my signature for more details.
Re: Springs?
« Reply #2 on: Thu, 20 June 2013, 21:28:17 »
He said 55g actuation force. Try 65-75g bottom out force springs.
Offline graboy
Re: Springs?
« Reply #3 on: Thu, 20 June 2013, 21:28:47 »
Sherry's got some over here, I'm pretty sure the site is working correctly now, as he had some difficulty earlier on.
Edit: Wow, ninja'd by two posts.
Re: Springs?
« Reply #4 on: Thu, 20 June 2013, 21:30:32 »
I can't read, sorry.
Offline Rafen
Re: Springs?
« Reply #5 on: Thu, 20 June 2013, 21:45:22 »
Thanks will being buying some of those soon.
Do you know how many springs are in an order for $8? It doesn't say on his site anywhere unless I overlooked it.
« Last Edit: Thu, 20 June 2013, 21:49:54 by Rafen »
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
Re: Springs?
« Reply #6 on: Fri, 21 June 2013, 01:39:07 »
you should get over a hundred in the origintive pack, thats how many were in my packs of 45g, 62g, and 65g
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
Re: Springs?
« Reply #7 on: Fri, 21 June 2013, 14:19:36 »
Awesome site.
you are the owner? Seems to be owned by some GHeer ...
I'm interested in the springs too but 9 bucks each seems kinda way expensive for me (I saw it right? It's 9 bucks each???)
« Last Edit: Fri, 21 June 2013, 14:23:24 by agodinhost »
Offline Glod
    • YouTube Channel
Re: Springs?
« Reply #8 on: Fri, 21 June 2013, 14:24:23 »
Awesome site.
http://geekhack.org/index.php?board=137.0
its 9$ for a pack of 104 springs, thats pretty cheap to me
Offline agodinhost
    • Dr Ian O Xaman
Re: Springs?
« Reply #9 on: Fri, 21 June 2013, 17:22:15 »
Awesome site.
Yup, for 100 springs it's okay - I didn't saw any info regarding the quantity in the package and then I assumed only one ...
