Author Topic: Strange IBM unsaver terminal keyboard on ebay  (Read 3392 times)
« on: Wed, 26 June 2013, 19:25:08 »
I know that these have been seen and discussed here, but I can't remember what the final verdict was.
http://www.ebay.com/itm/IBM-KEYBOARD-104-KEY-DATA-ENTRY-P-N-09F4231-/111106005494?pt=PCA_Mice_Trackballs&hash=item19de6f19f6
When a fool gains power, the first thing he does is silence the wise.
The Next thing he does is gather other fools around him.
The final thing he does is destroy the Nation.
- Plato
Offline AKIMbO
  • HHKBro
Re: Strange IBM unsaver terminal keyboard on ebay
« Reply #1 on: Wed, 26 June 2013, 19:26:19 »
Pretty sure those are rubber domes.
| KBD75 (box reds)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Wed, 26 June 2013, 19:28:54 »
Make an offer, I'm sure you can get it cheaper than list (I offered a lower amount and it was accepted, but I didn't really want it, even just to look at it)
« Reply #3 on: Wed, 26 June 2013, 19:31:50 »
I don't want it, I have way too many goofy keyboards already. The 2 switches shown look to be totally different types.
- Plato
« Reply #4 on: Wed, 26 June 2013, 20:20:34 »
These are honeywell rubber domes. They also exist in a non data-entry layout.
Also, data entry layout is weird, like old cardpunches.
You can see the domes in the penultimate picture. But, despite that, all the "model F" type unsavers yet discovered have the raised section of the case go all the way across, instead of the step down on both sides as seen here.
Here's a good picture of both, illustrating the difference:
http://kishy.dyndns.org/?attachment_id=373
Here are some of the previous posts about this:
http://geekhack.org/index.php?topic=34794.msg643895#msg643895
(kishy deleted many of his posts, but elrick has quoted him here)
http://geekhack.org/index.php?topic=39283.msg766951#msg766951
http://geekhack.org/index.php?topic=41011.msg817704#msg817704
And of course, kishy's page on them on his website
http://kishy.dyndns.org/?p=63
Should be an excellent rubberdome keyboard, if anyone is interested in acquiring another of those.
« Last Edit: Wed, 26 June 2013, 20:24:21 by dorkvader »
« Reply #5 on: Wed, 26 June 2013, 20:33:25 »
I guess this also means that you could move domes around for something closer to an ANSI layout.
The spacebar seems to have something off-center, but I can't figure it out in Kishy's photos.
- Plato
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #6 on: Wed, 26 June 2013, 21:33:15 »
I remember those!  They were good keyboards.  Can they be Soarered?
 - Ron I samwisekoi
Offline Techno Trousers
  • ʘ_ಠ
« Reply #7 on: Wed, 26 June 2013, 22:06:40 »
My rule of thumb is any time it has "Soft Touch" or "Quiet" as part of the description, it's a rubber dome and time to move on. Matias Quiet Touch keyboards excepted, I guess.
« Reply #8 on: Thu, 27 June 2013, 02:13:16 »
 - Ron I samwisekoi
I haven't tried of course, but I would expect so.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #9 on: Fri, 28 June 2013, 15:44:37 »
Made a low-ball offer and it was accepted by the seller.  One will be in my hands in a week or so.
Pics and feedback at that time.
 - Ron | samwisekoi
Offline KillerBee
« Reply #10 on: Fri, 28 June 2013, 19:10:54 »
do you think maybe you can use the case in your Model M ssk project?
IBM Model M 1386304 Nov. 1985
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #11 on: Fri, 28 June 2013, 19:49:54 »
No, too big.  I'm going to look it over, power it up, and maybe drop in a Soarer.
Then it will go onto a display shelf, I think.
 - Ron I samwisekoi
« Reply #12 on: Sat, 29 June 2013, 00:02:37 »
 - Ron | samwisekoi
Excellent! These have been relisted a few times, so I'm sure low offers will be accepted. It's good to hear that that is the case. These should be really excellent rubberdomes.
Instead of a soarer, you can likely use the teensy to read the matrix directly, just a thought.
