Author Topic: What Keyboard Are You Using Now?  (Read 5187456 times)
0 Members and 6 Guests are viewing this topic.
Offline Floody
  • Formerly Flood
  • But is it?
Re: What Keyboard Are You Using Now?
« Reply #4350 on: Mon, 09 May 2016, 18:26:52 »
Cherry G81-3100SDU with glorious OG dyesubs and not-so-glorious MY switches... I like how MY switches sound though... It's actually a really pleasant sound... but that's about it. LOL!
Well, actually the case is absolutely beautiful too! So time to find me a Leeku 3000 PCB so I can use it :D
I think I would take breaks by just sliding a card back and forth.
Offline Keycap
« Reply #4351 on: Mon, 09 May 2016, 20:39:20 »
Currently using my old QuickFire TK with MX Blues because all of my Alps boards are in the process of restoration, and my Unicomp Unsaver is undergoing an ANSI mod.
The MX Blues really aren't that bad, pretty smooth for newer Cherry switches actually. But the click noise is driving me nuts. I enjoy the click sound from switches like buckling springs and Blue Alps, but this is just... no.
Offline phosphoric
« Reply #4352 on: Mon, 09 May 2016, 21:45:08 »
typing on my alps64 with undamped cream alps on my phone with a usb adapter :-)
Let's get this straight. There is nothing cool about keyboards we're all lame as fk.
speak for yourself
Offline alienman82
« Reply #4353 on: Mon, 09 May 2016, 22:35:42 »
removed.
« Last Edit: Thu, 01 March 2018, 15:16:01 by alienman82 »
Offline itzmeluigi
  • ПБТ
« Reply #4354 on: Mon, 09 May 2016, 22:39:42 »
hhkb for the last week.  The black legends are super hard to see.  I might get a type s
Nice im using the same, gray HHKB with black legends. I wish type s was available in gray instead of white.
Offline alienman82
« Reply #4355 on: Mon, 09 May 2016, 22:40:41 »
removed.
« Last Edit: Thu, 01 March 2018, 15:15:57 by alienman82 »
Offline itzmeluigi
  • ПБТ
« Reply #4356 on: Mon, 09 May 2016, 22:51:35 »
I cannot ever remember the keys above the backspace.  The fn layer is so hard to remember  :confused:
Yeah it took me a while to get used to the ~ key new position especially since one of the layouts i use puts a letter on that key.  I love the FN layer though, i like how all the nav functions are next to each other.
Offline ashraf
« Reply #4357 on: Mon, 09 May 2016, 23:13:45 »
Finally finished putting this keyboard together.  Custom painted KUL with 65g Zealios and Penumbra SA.
More here: http://imgur.com/a/0edSF
how did you paint this? looks amazing
KUL top covers are actually very easy to paint!  I started off with light sanding using 500 grit sandpaper and running water.  After that I sprayed 2 layers of primer, 6 layers of undercoat (matte white) and topcoat (neptune blue).  Waited 12 hours for the paint to cure and then finished it off with 2000 grit sandpaper to make everything nice and smooth.
Rosewill RK-9000, Poker 2 MX Blues, HHKB 2, IBM Model M
Offline Mattr567
« Reply #4358 on: Mon, 09 May 2016, 23:22:54 »
The SGI Granite has cemented itself as a daily for me. I love the uniqueness of the body and the funny font on the caps. It reflects the attitude of Silicon Graphic's at the time. Plus you cant go wrong with lovely grey plate SKCM Oranges and Alps dyesubs in a well built chassis  ^-^ They feel so solid and thock so nicely.
IBM P77, SKCC Green, 1984
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #4359 on: Tue, 10 May 2016, 00:03:35 »
They're chihuahua approved.  Touch it and lose a finger, MOFOs ;) .
Unfortunately your poor chihuahua would have to dislodge his bottom jaw to even bite the fingernail tip of my left pinkie.
Should of bought a decent American Staffordshire breed, so that at least it can take half my hand off when I try to touch your HHKB.  Not that it would ever happen.
« Last Edit: Tue, 10 May 2016, 00:06:07 by Elrick »
Offline henz
  • What?
« Reply #4360 on: Tue, 10 May 2016, 03:13:57 »
a tex phantom, with some vintage blacks
Offline svn
« Reply #4361 on: Tue, 10 May 2016, 03:53:51 »
typing on a vortex pok3r with reds. i really like it, but i would love to have a heavier case :(
also sometimes use the filco tkl with browns.
« Last Edit: Tue, 10 May 2016, 04:12:14 by svn »
Offline Brewi
  • Descent into Madness
« Reply #4362 on: Tue, 10 May 2016, 09:47:42 »
Was using my DS3 with blues to get one last kick out of it before I sell it, but now I'm back to my poker with browns. The aluminum case really gives keystrokes a much more satisfying and "deeper" sound than a plastic case. Definitely my best keyboard-related purchase so far.
Still getting used to DSA though; it's definitely a different typing experience.
B.Pad & B.87 w/ gat greens - GH60 w/ kailh pro purples
« Reply #4363 on: Tue, 10 May 2016, 14:33:20 »
nobody cares
Offline alh84001
« Reply #4364 on: Wed, 11 May 2016, 05:36:49 »
Work: apple laptop keyboard, it's the worst.
Actually, I'm quite fond of Apple's scissor-switch keyboard. I'm at work right now and typing on Apple Keyboard with Numeric Keypad and while it obviously could be better it could be a lot worse as well. Keyboards on the newer cheap Lenovo laptops are maybe the ****tiest keyboards I have typed on.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #4365 on: Wed, 11 May 2016, 05:42:31 »
My old G560 Lenovo's keyboard is still in damn near pristine condition after five years of use. Barely any shine on the keycaps and the scissor switches feel about the same as when I bought the thing. Damn shame the keyboard outlived the motherboard :'(
« Reply #4366 on: Wed, 11 May 2016, 05:45:12 »
currently using my Air. feels like typing on cardboard. i brought my hhkb with me but forgot to bring a cable. a hasu controller or the new BT version would have been pretty nice right now.
Offline Lohup
    • Lohup Custom Cables
« Reply #4367 on: Wed, 11 May 2016, 06:26:55 »
Leopold FC660C, stock except for red ESC key.
Offline Brammm87
« Reply #4368 on: Wed, 11 May 2016, 06:28:43 »
Got my Topre today.
pls gief bbv2
Offline alh84001
« Reply #4369 on: Wed, 11 May 2016, 06:50:47 »
Are you working on some Xbox development or is the controller there just for usual stuff? :)
Offline Brammm87
« Reply #4370 on: Wed, 11 May 2016, 07:44:42 »
Usual stuff :p was playing Forza 6 Apex.
pls gief bbv2
Offline E3E
« Reply #4371 on: Wed, 11 May 2016, 20:25:32 »
My second Alps hotswap-modded Duck Eagle that's caseless. Put it on a little keyboard platform I made for my Rapoo KX way back when. :P It's piggy-backing at the moment.
Alps SKCM Brown,
IBM 5140 PBT caps dyed black
Alps DCS Modifiers
Tai Hao 6.25u space bar
Carbon Fiber plate
Definitely dig the tactile browns.
Pretty much as tall as a beamspring at the moment, haha
« Last Edit: Wed, 11 May 2016, 20:27:03 by E3E »
Offline Mattr567
« Reply #4372 on: Wed, 11 May 2016, 22:19:46 »
Alps SKCM Brown,
Alps DCS Modifiers
Carbon Fiber plate
Those dyed 5140 caps look great!
Offline dannrawr
« Reply #4373 on: Wed, 11 May 2016, 23:01:43 »
dell sk-8135 at office and Poker II at home, still waiting for my custom TKL to arrive
WTF any Bruce, Cosmonauts
Offline dannrawr
« Reply #4374 on: Wed, 11 May 2016, 23:06:30 »
oh that penumbra  :cool: :cool: :cool:
« Reply #4375 on: Wed, 11 May 2016, 23:11:39 »
ENVKX
I usually use tactile switches, but I am slowly falling in love with the linears I put on this keyboard.
The exact same thing is happening to me.  I have always insisted on Browns or Ergo Clears.  Suddenly I'm falling in love with this incredible board full of old Blacks.
Buttery smooth, and the sound is fantastic.
« Reply #4376 on: Thu, 12 May 2016, 00:56:39 »
that cable is way too long man
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #4377 on: Thu, 12 May 2016, 19:26:12 »
My last week with cheapie Vortex PBT's. 62g Ergoclears deserve better.
« Last Edit: Fri, 13 May 2016, 20:53:08 by bmilcs »
TGR.JANE.V2 #40/40 <3 // TOKYO60 #1 // KBD75  #1 #2 #3 #4 // ES87  #1 #2 #3 #4 #5
INCOMPLETE  Duck Orion v3, 2 pcb black on black (might sell, pm me)  | SOUTHPAW.65
Offline NewbieOneKenobi
« Reply #4378 on: Thu, 12 May 2016, 20:41:43 »
Majestouch 1, tenkeyless, blues, no mods, no red keys.
Offline supamesican
« Reply #4379 on: Thu, 12 May 2016, 20:58:23 »
Home: unicomp endurapro until my model f comes in and I get a converter
work: hhkb
back up home pc: rubber until next week when my fk-2001 comes in.
Offline waitinginexile
  • Nathan O.
« Reply #4380 on: Thu, 12 May 2016, 22:08:50 »
Got my Topre today.
Looks really nice! I've been meaning to pick up a Topre board for a while now. Do you like it so far?
i am zeal-less i am feel-less
Offline Suembeaux
« Reply #4381 on: Fri, 13 May 2016, 00:49:33 »
Love your pics, keep it up.
My g80-3000 has been taking a majority of my attention lately. Need to start slimming down, but I somehow keep finding every excuse not to.
A bunch of stuff. Someone teach me how to properly solder.
/u/Shartastical
Offline JigsawSaint
« Reply #4382 on: Fri, 13 May 2016, 01:56:20 »
Leopold 660m - blues (stock navy pbt keycaps) @ work
Filco Majesouch-2 - blues (black on carbon pvt keycaps) @ home (pc1)
Ducky Shine 4 (69-Fire Edition) - grey-blank pbt keycaps & green-blank pvt keycaps (mods/num (gray), std (green)) @ home (pc2)
Offline VereChi
« Reply #4383 on: Fri, 13 May 2016, 03:27:38 »
GH60 diyer.so Ver. With Cherry mx blue
EVIL 2.0 Titanium Grey with Cherry mx clear/krytox 103/Gon 62G
(Aluminum 6063 TKL design and manufactured by the same author of ZZ96)
Offline SBJ
  • Tactile pls
« Reply #4384 on: Fri, 13 May 2016, 03:33:14 »
Got my Topre today.
That Realforce is HUGE, looks BADASS.
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
« Reply #4385 on: Fri, 13 May 2016, 05:19:29 »
 Switched to an ErgoDox EZ full time. Blanks, Gateron Browns, and my own rather unconventional layout.
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #4386 on: Fri, 13 May 2016, 08:58:43 »
Varmilo va87 with gateron browns and tai-hao sunshine would be my daily driver.
I also have a ducky shine 2 with cherry mx blues for my typing pleasure.
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #4387 on: Fri, 13 May 2016, 09:50:13 »
Thanks man! I just wish I had something cool to share. 2 Sets of Gateron blank sets inbound, so that should help :)
Do you shoot?
Offline Khers
  • Schrödinger's box
« Reply #4388 on: Fri, 13 May 2016, 14:52:57 »
« Last Edit: Tue, 03 July 2018, 08:33:40 by Khers »
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #4389 on: Fri, 13 May 2016, 14:56:37 »
Nice.
What kind of ALPS switches did you use?
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Khers
  • Schrödinger's box
« Reply #4390 on: Fri, 13 May 2016, 15:12:23 »
« Last Edit: Tue, 03 July 2018, 08:33:31 by Khers »
Offline alienman82
« Reply #4391 on: Fri, 13 May 2016, 15:24:57 »
removed.
« Last Edit: Thu, 01 March 2018, 15:13:24 by alienman82 »
Offline Khers
  • Schrödinger's box
« Reply #4392 on: Fri, 13 May 2016, 15:33:32 »
« Last Edit: Tue, 03 July 2018, 08:33:24 by Khers »
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #4393 on: Fri, 13 May 2016, 20:34:26 »
« Last Edit: Fri, 13 May 2016, 22:40:41 by bmilcs »
Offline Daspartic
  • IBM is love IBM is life
« Reply #4394 on: Fri, 13 May 2016, 21:03:52 »
Typing on my new Acer 6011 with blue alps, loving it!
IBM Displaywriter (82 key) | IBM Model F 4704 (107 key) |  IBM Model F AT x3 | IBM Model F XT | IBM Model F 3104 x2 | IBM 6112884 (Green Tee mount Alps) | Realforce 87u (55g) | IBM Model M 1390131 x2 | IBM Model M (1391401 '88) | Leopold FC500R (MX Browns) | Wang (725-5971) (Salmon Alps) | Acer 6011 (SKCM Blue Alps) | White Fox (65 g Zealios) | XMIT keyboard (Hall Effect)
Offline mason
  • have fun with her, ryan
« Reply #4395 on: Fri, 13 May 2016, 21:04:41 »
HHKB, duh
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #4396 on: Fri, 13 May 2016, 22:24:24 »
Sheesh!
https://geekhack.org/index.php?topic=45475.msg1960209#msg1960209
I feel I am just simply repeating myself.
I just felt like I just repeated myself.
This thread has to DIE DIE DIE!
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #4397 on: Fri, 13 May 2016, 22:44:09 »
Sheesh!
Nice patio
« Last Edit: Fri, 13 May 2016, 22:46:46 by bmilcs »
Offline alienman82
« Reply #4398 on: Fri, 13 May 2016, 22:45:34 »
removed.
« Last Edit: Thu, 01 March 2018, 15:13:14 by alienman82 »
« Reply #4399 on: Fri, 13 May 2016, 22:46:31 »
Swiftkey.
