Author Topic: What Keyboard Are You Using Now?  (Read 5012920 times)
Offline timerwin63
Re: What Keyboard Are You Using Now?
« Reply #4250 on: Wed, 13 April 2016, 00:54:11 »
so, are the switches hotswappable on that board?  hows the side button is it clicky at all and do you actually use it often ?
Yup, the switches are hot-swappable on this one. The side button feels pretty good. It's got a nice sharp click to it, and it feels great. I use it a lot for F keys and playing flash games (since my arrows are bound to WASD on the function layer). I'd also use it a lot more for things like LED control, media controls, etc, but I don't actually know how to program the board or where to find instructions for it, as it's a pretty obscure piece of hardware.
« Last Edit: Wed, 13 April 2016, 01:13:40 by timerwin63 »
Roses are red, violets are blue. They don't think it be like it is, but it do.
Offline iLLucionist
  • Topre is Love.
« Reply #4251 on: Wed, 13 April 2016, 05:15:41 »
Unfortunately, I'm using my mbp built-in keyboard more and more as I'm more on the road. #cry
Offline Tangtawan
« Reply #4252 on: Wed, 13 April 2016, 05:49:15 »
Novatouch TKL with Blank Thick PBT caps
IBM Model M 1995
KBT One 108 - Cherry MX White
Tt eSport Challenger Ultimate
My boards : Model F AT (6450200), Industrial M (1394950), Model M SSK (1391472), Model M13 (13H6705), Model M (1390131), Focus FK-2001 (ALPS SKCM Blue), HHKB Pro 2, Realforce 87U 55g, KBP V80 Matias Click, TADA68 (Gateron Reds), Filco Majestouch 2 TKL (67g Ergo Clears), Cherry G80-11800 (Ergo Clears), KBT One 108 (MX White), Ducky One TKL RGB (MX Black), Filco Majestouch Tenkeypad (MX Brown), Leopold FC210TP (MX Red)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #4253 on: Wed, 13 April 2016, 07:11:09 »
Now I'm curious. Any of the switches pop out while you change the keycaps? :)
Edit - Oh man, I found the video demonstration of someone removing a recap. :eek: That is awesome
« Last Edit: Wed, 13 April 2016, 07:14:24 by csmertx »
Offline timerwin63
« Reply #4254 on: Wed, 13 April 2016, 07:48:31 »
It's actually surprisingly solid. I've got a video out there somewhere where I struggle to pull the right Shift switch out of the board for a couple of seconds. Partly because of the tools I was using, but mostly because they just hold really well. I've only had one switch accidentally pull on me, and the switch was old an worn at that point, so it wasn't properly grabbing the plate anyway.
Offline carmenohio
« Reply #4255 on: Wed, 13 April 2016, 19:42:15 »
My daily driver is a Quickfire Rapid MX Blue with PBT blanks.
Also have an RK-9000 (MX Blues), a Novatouch, and a Unicomp Ultra Classic.
Offline dante
« Reply #4256 on: Thu, 14 April 2016, 11:55:40 »
I'm currently flipping back and forth between a Dell KB-522 and HP KU-0901 (both rubberdomes) depending on my number pad needs.
« Reply #4257 on: Thu, 14 April 2016, 11:58:27 »
Long time no see. :D
You haven't given up on mechanicals have you??
Offline dante
« Reply #4258 on: Thu, 14 April 2016, 13:03:39 »
Mostly yes, mostly.
« Last Edit: Thu, 14 April 2016, 13:16:28 by dante »
Offline jackstar7
« Reply #4259 on: Tue, 19 April 2016, 18:06:13 »
Now it shall be the Ducky/Topre 30g that just arrived. It types as I hoped it would and the silence is golden.
My 103U and 87U-Silent may find use elsewhere... but this is going to be my main until such time as it gives out on me, as I won't give up on it.
« Last Edit: Wed, 20 April 2016, 08:46:27 by jackstar7 »
Topre 30g 104U-Silent --- 87U-Silent and 103U are now backups only
Offline snozberries
  • Aww yiss!
« Reply #4260 on: Wed, 20 April 2016, 12:19:22 »
Leopold FC660M - MX Reds (Daily Driver)
QFR TKL - MX Blues
These are my first boards and I just bought them in the past week. The QFR just sort of happened, planning on painting or possible giving it to a friend.
Offline sek1ne
  • Sek-eye-n
« Reply #4261 on: Wed, 20 April 2016, 12:29:20 »
Currently on an HP KU-0316. It's kind of a piece of crap.
Biking is fun.
« Reply #4262 on: Sun, 24 April 2016, 01:44:02 »
Lexmark SSK :)
135317-0
Offline MasterZebra
« Reply #4263 on: Sun, 24 April 2016, 09:13:52 »
I decided to dive in head first and I started with a HHKB Pro 2 with blank white caps. Looking to start some modifications soon.  :cool:
Offline Otesanek
« Reply #4264 on: Sun, 24 April 2016, 23:08:26 »
Hell yeah. Solid choice. What kind of mods are you considering?
« Reply #4265 on: Mon, 25 April 2016, 00:13:24 »
Welcome to the club :)
Offline rurushu
« Reply #4266 on: Mon, 25 April 2016, 02:36:39 »
My main is a Rosewill Rk-9000 Cherry MX Blues and secondary is a Rantopad MXX with Gateron Blues, my other boards are collecting dusts  ^-^
now researching into Topre as the temptation form the Land of Cup Rubber is very attractive.
I can never use laptop keyboards once I tried mechanical, heck, now cant even type properly on rubberdomes... the force required is too much to actuate a key  :(
it is time for you to go mechanical and ditch those built-in keyboards  ;D
Offline Malenky
« Reply #4267 on: Mon, 25 April 2016, 06:32:22 »
Offline iLLucionist
  • Topre is Love.
« Reply #4268 on: Mon, 25 April 2016, 06:40:14 »
I've tried that by putting my HHKB on top of my laptop like other people seem to do. But it never really worked for me :(
Offline rurushu
« Reply #4269 on: Mon, 25 April 2016, 09:16:59 »
but wouldn't putting the HHKB or any other 60% board on top of the laptop makes typing kind of... "suffocating"?
Because you are being so close to the laptop screen and the keyboard might cover your part of your screen (specifically the bottom part) when you type?
For me, I put my TKL board INFRONT of the laptop. This works best for me  :D
Offline bmilcs
  • bryan | bmilcs
    • bmilcs world
« Reply #4270 on: Mon, 25 April 2016, 09:34:08 »
http://www.amazon.com/iGotTech-Cable-Clips-Management-System/dp/B00V3KM1Y4/ref=sr_1_10?ie=UTF8&qid=1461594747&sr=8-10&keywords=wire+management
It's the little things in life :). This is fantastic for your mouse and keyboard wire, toward the edge of your desk. I am also using them for my tablet + cell charger, allowing the cables to stay put even while I adjust my standing desk to the seated position.
TGR.JANE.V2 #40/40 <3 // TOKYO60 #1 // KBD75  #1 #2 #3 #4 // ES87  #1 #2 #3 #4 #5
INCOMPLETE  Duck Orion v3, 2 pcb black on black (might sell, pm me)  | SOUTHPAW.65
Offline alienman82
« Reply #4271 on: Mon, 25 April 2016, 09:39:30 »
removed.
« Last Edit: Thu, 01 March 2018, 15:26:15 by alienman82 »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #4272 on: Mon, 25 April 2016, 10:16:14 »
Lexmark SSK :)
Oh god, Lexmark!
:rolleyes:
It looks amazing with the rgby modifiers. That clack :eek:
Offline rurushu
« Reply #4273 on: Mon, 25 April 2016, 10:23:13 »
Still using this guy:
Dayum... I can feel your mouse screaming of suffocation there.... so little space  :-X
Offline alienman82
« Reply #4274 on: Mon, 25 April 2016, 10:51:06 »
removed.
« Last Edit: Thu, 01 March 2018, 15:26:01 by alienman82 »
Offline guster11
« Reply #4275 on: Mon, 25 April 2016, 12:16:20 »
The rk-9000 actually is a pretty decent board, I used mine for the past 3 years or so with no issues with the USB port. Linear alps are making me think about selling it since I never use it anymore.
Offline venyv
« Reply #4276 on: Mon, 25 April 2016, 13:12:56 »
Ergodox Infinity with Zealio 65G switches
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
« Reply #4277 on: Mon, 25 April 2016, 14:44:29 »
Using an ErgoDox EZ, Gateron browns, DCS blank keycaps. Slowly learning to touch type properly. Gonna take a while, but the keyboard is lovely. So much fun will be had!
Offline Anole
« Reply #4278 on: Mon, 25 April 2016, 14:47:16 »
My chattering Varmilo VA87M :(
Offline Waateva
« Reply #4279 on: Mon, 25 April 2016, 14:48:02 »
WASD V2 with Greens per usual at work.
Offline iLLucionist
  • Topre is Love.
« Reply #4280 on: Mon, 25 April 2016, 15:07:02 »
Slowly... starting... to enjoy my.... kul with clears again.
Offline clacktalk
  • circa 2015
« Reply #4281 on: Mon, 25 April 2016, 16:07:52 »
dell laptop rubber dome because i've been too lazy to program macros on my hasu controller
going to buck up and finish it tonight so that i can swag out at work asap with kk mods and other secret/non-secret topre artizan tech
all i'm hearing in my head is "boom, here comes the" on repeat. i can't even finish the lyrics because i don't know them. i don't even know what song that is
pray i don't go insane before the caps reach my eager hands
diary of a clacktalk
radio_killah: too much frank
Offline saxophone
« Reply #4282 on: Wed, 27 April 2016, 12:26:27 »
This thing at work. It's pretty much perfect. Super heavy coupled with nice feet ensures it doesn't even budge from the spot even the slightest unless if you lift it up. TKL size with numpad (my works involves lots of punching in numbers). Uses Cherry MX Brown switches, personal favorite after trying out kailh brown, gateron brown, cherry blue, ootemu brown and blue. The keycaps on the main part has been replaced with low profile mxboard 3.0 ones. Spacebar is flipped so my thumb can rest against the flat side rather than the edge.
Offline alienman82
« Reply #4283 on: Wed, 27 April 2016, 12:29:18 »
removed.
« Last Edit: Thu, 01 March 2018, 15:24:02 by alienman82 »
Offline toidbb
« Reply #4284 on: Wed, 27 April 2016, 12:32:44 »
These are the boards I brought to school which I switch between all the time  :thumb:
Quite the collection... I see that you switched to winkeyless on the red TKL, by leaving the switches bare. Giving it that custom look.
I kid, I kid. You definitely have your choices on what to use there.
My keyboard for today. Kaliet 22-Mini
« Last Edit: Wed, 27 April 2016, 12:35:23 by toidbb »
Offline alienman82
« Reply #4285 on: Wed, 27 April 2016, 12:34:22 »
removed.
« Last Edit: Thu, 01 March 2018, 15:23:56 by alienman82 »
Offline bocahgundul
  • a seal
« Reply #4286 on: Wed, 27 April 2016, 17:40:41 »
I'm using my ****ty rubber dome but boy I don't know why but they're not mushy
« Reply #4287 on: Thu, 28 April 2016, 06:09:13 »
Lexmark SSK :)
Oh god, Lexmark!
:rolleyes:
Teehee :)
But it would be nice if both Shifts were the same shade of green :rolleyes:
Offline ItsBarney01
« Reply #4288 on: Thu, 28 April 2016, 06:12:21 »
Fairly simple, just your stock standard corsair K65 with cherry mx reds.  :thumb:
Sorry if that is a bit boring  :p
^^^Click for instagram^^^
Offline Data
« Reply #4289 on: Thu, 28 April 2016, 06:45:54 »
Back on KUL ES-87 with MX browns at work, rocking the Midnight key set... at least until my GH-122 is built.
« Reply #4290 on: Thu, 28 April 2016, 07:34:39 »
the vintage blacks on kmac are kinda growing on me.................... just kinda though.
Offline trenzafeeds
  • **** off
« Reply #4291 on: Thu, 28 April 2016, 07:43:04 »
whaaat? Sifo likes linear switches????
demik will never leave.
Unless he gets banned.
« Reply #4292 on: Thu, 28 April 2016, 07:46:36 »
kinda gross i know but theoretically you can type faster on them.
also i was playing a lot of counterstrike so it was nice to have them for that. gonna rotate clears back in soon though lol
Offline trenzafeeds
  • **** off
« Reply #4293 on: Thu, 28 April 2016, 07:47:51 »
nah dude, blacks are my favourite mx switch. you just always talk about how much you hate them.
« Reply #4294 on: Thu, 28 April 2016, 07:51:17 »
i've now used them enough that they're bearable. still far from preferable, slightly enjoyable.  zzz
Offline mind_funeral
  • savior of lost fortunes
« Reply #4295 on: Thu, 28 April 2016, 10:05:23 »
Poker 2 Gateron browns in a Poker 3 case!  Rockin DCS Midnight caps with Twilight mods!  White backlights in SIP sockets!
Poker II.3 with Gateron Browns and SIP sockets,  Midnight/Twilight DCS
KBP V60 with Gateron Clears, EnjoyPBT Cyrillics
Topre Type Heaven
« Reply #4296 on: Thu, 28 April 2016, 13:09:44 »
Oh he was talking about a different type of blacks.
Offline drsauced
« Reply #4297 on: Thu, 28 April 2016, 13:10:20 »
Just got a Wyse WY60 to work with Soarer's Converter. Vintage blacks and doubleshots, these old Wyse keyboards are really nice and solid. I need to take it apart and clean it again, though, it smells of old ashtray and spoiled yogurt.
135706-0
« Last Edit: Thu, 28 April 2016, 13:13:19 by drsauced »
Filco Ninja 104 Tactile w/Imsto PBT caps | Deck Legend Ice Linear | FC200RT Clear w/Danger Zone | Topre 87U 45g EK | '89 & '93 1391401 | Ping is Life
Offline Mattr567
« Reply #4298 on: Thu, 28 April 2016, 18:28:05 »
Like those blue legends. Haven't seen those before on a WYSE.
IBM P77, SKCC Green, 1984
Offline alienman82
« Reply #4299 on: Thu, 28 April 2016, 18:34:01 »
removed.
« Last Edit: Thu, 01 March 2018, 15:23:15 by alienman82 »
