Author Topic: What Keyboard Are You Using Now?  (Read 5186844 times)
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
Re: What Keyboard Are You Using Now?
« Reply #4000 on: Thu, 10 March 2016, 01:51:51 »
I am waiting for my Keyboardio M01, my first mechanical keyboard (not counting some old ones I used on my dad's computer back in the days). For the time being, in preparation for a split keyboard, I am using a TypeMatrix 2030, and the laptop's (Lenovo W541) keyboard in a kind-of split setup: one hand types on the left half of the laptop, the other on the right side of the TypeMatrix.
I get weird looks, but it is reasonably comfortable. And funny too, to boot.
Offline PadawanGeek
« Reply #4001 on: Thu, 10 March 2016, 07:20:57 »
Just bought an Armaggeddon Hornet MKA-5R RGB keyboard, yes, I know it has Kailh Blue but it looks great, I like the aluminum top plate, and Kailh Blue feels and sounds quite similar to Cherry Blue. Since this is my new toy, you can be sure I'd be using it for a while....
« Last Edit: Thu, 10 March 2016, 07:23:20 by PadawanGeek »
Offline E3E
« Reply #4002 on: Thu, 10 March 2016, 10:45:22 »
Offline jbondeson
« Reply #4003 on: Thu, 10 March 2016, 10:56:06 »
Just an FYI, but it's more comfortable when there are keycaps on top of the stems  ;)
I'm rocking this little guy at work:
I really need to build a riser for my tray case  ^-^
Offline E3E
« Reply #4004 on: Thu, 10 March 2016, 11:06:55 »
Alps FTW!
Yeah man, I think you could easily something to give the case some incline. Looks really nice though. The yellowed space bar actually matches the color of the wood very nicely, ironic as that might be.
Yeah, I've been retrobrighting the darn thing since yesterday. The caps are all I need now, but they take forever.  :rolleyes:
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #4005 on: Thu, 10 March 2016, 11:21:59 »
I think I can see myself in your spacebar
Offline jbondeson
« Reply #4006 on: Thu, 10 March 2016, 12:17:23 »
It was right under a magnifying lamp, but yes it's very shiny.
Someone on DT is experimenting with light sandblasting to remove shine, with all my AEK spacebars I'll have to look into it!
Offline E3E
« Reply #4007 on: Thu, 10 March 2016, 13:00:29 »
This is an idea I've had for a long time; I just don't have the cash for a compressor with all this money going toward keyboards and what not. :P
Wet sanding with a fine grit sandpaper or polishing cloth (micron) can remove shine, but I think sandblasting is the only real way to restore texture. Matte clear coat can do this too, but there's a lot of reasons why that's unfavorable.
Offline smarmar
  • It don't mean a thing if it ain't got that swing
    • Short Stories from an Old Library
« Reply #4008 on: Thu, 10 March 2016, 16:32:14 »
I recently liberated 5 mid-late '90s (I'm guessing) rubber dome KBs from someone whom was giving them away: 3 Compaq KB-3923s, Micro Innovations Turbo-Trak, and a Mitsumi KFKEA4XT, all in various states of dishevelment. They all work perfectly but given their physical appearance and soldering iron scars they look as though they were used in a component factory or something. I think I'll hold on to the Mitsumi and Micro. Next to the Dell Quiet Keys Mitsumi are the best-feeling dome kb. The Micro has unusual function keys and "Power", "Sleep", and "Wake" keys that don't seem to register with any of my computers.
1992 IBM Model M | Tesoro Durandal[Browns] | Hi-Tek Series 725[Space Invaders] | Tandy Enhanced[Sliders] | Dell Quiet Keys | Mitsumi[AT]
Offline smarmar
« Reply #4009 on: Thu, 10 March 2016, 16:35:03 »
130775-0
Offline alienman82
« Reply #4010 on: Thu, 10 March 2016, 16:40:24 »
removed.
« Last Edit: Thu, 01 March 2018, 15:53:19 by alienman82 »
Offline E3E
« Reply #4011 on: Thu, 10 March 2016, 17:33:37 »
I got an 8 gallon compressor from Home Depot for $25 when they had a crazy promo going on.  Normally $300 marked to $$150.  Then 50% off clearance for $75.  They gave me $50 for signing up for a credit card I never used (not even for the compressor).  I've had it for a long time.
 :eek:
 :confused:
Lucky!
Offline y11971alex
  • Looking for Toronto meetup
« Reply #4012 on: Fri, 11 March 2016, 12:32:35 »
I am typing this on the Rapoo V500S with backlighting and blue switches (that's the official product name) right now.
I'm hesitant to call these switches "Cherry MX Blue clones" because their feel isn't altogether similar to the Cherry MX switches, and the spacebar feels a little wonky.  I'll give this keyboard a 75/100... my Model F AT received a 95 on that scale.
Offline tstackhouse
    • Bloghouse
« Reply #4013 on: Fri, 11 March 2016, 12:53:03 »
I've been enjoying my MX Clear Pok3r for quite some time.  I much prefer clears over the browns that my ES-87 has, since I've been trying to practice not bottoming out.
Offline Prelim
« Reply #4014 on: Fri, 11 March 2016, 13:02:40 »
GH60, now with custom acrylic wristrest ;)
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline axtran
« Reply #4015 on: Fri, 11 March 2016, 22:18:05 »
Just finished my endgame board--a TMK64 build: http://imgur.com/a/kSKOs
I've been this Apple-mode ever since I bought my Mac Pro.
MX Silent > MX Vintage Black > Everything Else
« Reply #4016 on: Fri, 11 March 2016, 22:33:31 »
hhkb, like always
« Reply #4017 on: Fri, 11 March 2016, 22:37:55 »
hhkb, like always
Other keyboards exist?
« Reply #4018 on: Fri, 11 March 2016, 22:38:31 »
not that i know of
« Reply #4019 on: Sun, 13 March 2016, 16:28:01 »
Offline Mattr567
« Reply #4020 on: Tue, 15 March 2016, 22:25:11 »
demik's HHKB :p
IBM P77, SKCC Green, 1984
« Reply #4021 on: Wed, 16 March 2016, 04:37:26 »
Offline bocahgundul
  • a seal
« Reply #4022 on: Wed, 16 March 2016, 05:16:55 »
Digilog realforce
been loving the feeling but I need to get an ergodox
Offline pwade3
« Reply #4023 on: Wed, 16 March 2016, 09:11:27 »
Some stock Dell piece of mushy sadness.
Got a Shine 5 at home, been debating what I want for at work.
Offline toidbb
« Reply #4024 on: Wed, 16 March 2016, 11:19:35 »
Using this beauty at work today Green Alps, Alps64 pcb, and AW (Alpine Winter) keyset.
Offline steelcity
« Reply #4025 on: Wed, 16 March 2016, 11:36:45 »
currently typing on a mx blue shine 4, but have a fc900 with browns next to me on my work computer, and another of the latter at my office downtown.  i do have a third fc900 with browns on the way to replace this shine, and i also have the new ducky topre 104 45g on the way to try out.  i now also have like 5 or 6 keyboards to unload...lol
Offline axtran
« Reply #4026 on: Wed, 16 March 2016, 11:48:02 »
Today's an ALPS day. SKCL Green and E3E's Glamorous plate. ;)
Offline bocahgundul
  • a seal
« Reply #4027 on: Wed, 16 March 2016, 20:47:58 »
What's this"E3E's Glamorous plate"
Offline kiwi99
  • that's a gnarly dookie
« Reply #4028 on: Thu, 17 March 2016, 00:54:30 »
He has some pics of it there, sparkly
http://imgur.com/a/jLYzX
Offline E3E
« Reply #4029 on: Thu, 17 March 2016, 02:24:29 »
Some plates I painted up for Axy using the same colorshift paint I've used for my FAME:
Offline axtran
« Reply #4030 on: Thu, 17 March 2016, 08:26:59 »
Not many people noticed the FAME's paintjob... but I did and I'm addicted! :thumb:
Offline Vlada011
« Reply #4031 on: Thu, 17 March 2016, 10:21:39 »
I use Deck 87 Francium Pro, White Backlight, Cherry MX Brown Switches.
I bought before one month from mechanicalkeyboards.
Deck Hassium Pro and Francium Pro keyboards now arrive with rubber and on feets.
I saw different version of Deck keyboards with different fonts...
I ask specific version as on Deck site and on mechanicalkeyboard site...
Someone don't like that fonts but I like them very much, I insist on them...
Newer feets on back side with rubber...
http://imgur.com/lSHVkCc
« Reply #4032 on: Thu, 17 March 2016, 13:22:52 »
Dang!  Missed seeing this until now.  That's really cool.
Offline Melchior
« Reply #4033 on: Thu, 17 March 2016, 15:06:05 »
Ducky One (MX Red, Blue LEDs).
Solid action, no wobble (unlike the last MX keyboard I had....).
Status LEDs are Too Damm BRIGHT!
Also sane USB implementation, both HID mode and BIOS compatible HID mode work correctly.
Ducky ONE    |   CM Recon
Offline aptivaboy
« Reply #4034 on: Thu, 17 March 2016, 15:32:44 »
An IBM Model M, proudly made in the USA, with a born on date of September 3rd, 1987. I would have just been starting my junior year at college when this bad boy rolled off the assembly line.
The one true keyboard. The keyboard of power. With twelve function keys to rule them all.
She still clicks like she's brand new, and she's heavy enough to use as a blunt force weapon when the Zombie Apocalypse strikes. And seriously, who amongst us isn't secretly looking forward to the Zombie Apocalypse?
I thought not.  ;D
« Last Edit: Thu, 17 March 2016, 19:11:04 by aptivaboy »
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
« Reply #4035 on: Thu, 17 March 2016, 18:48:59 »
RealForce Topre 87U 55G W/ Filco TKL Wood Wrist rest....my true endgame honestly..outside of maybe an Artisan or two.  Only thing left is to get a FC660C or HHKB for travel.  All my Cherry and Kailh boards have been in boxes ever since.
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline Mattr567
« Reply #4036 on: Thu, 17 March 2016, 20:14:51 »
Offline FoxWolf1
  • 154
« Reply #4037 on: Thu, 17 March 2016, 20:56:00 »
Swapped my old Noppoo Tank back in for my desktop today. Needs periodic thorough cleanings or it starts to chatter, but with that dealt with for the time being, it's still going strong. Lives up to its name, in fact: it is very rare for input devices to survive this long in my possession, especially ones that I actually use. Of course, the keycaps are a shiny mess at this point...may or may not decide to do something about that. We'll see.
Offline bocahgundul
  • a seal
« Reply #4038 on: Sat, 19 March 2016, 06:04:39 »
its indeed glamorous
Offline klennkellon
  • I like bottoming out
« Reply #4039 on: Sat, 19 March 2016, 13:29:34 »
I have ascended to the Model M. BS are best clicky switch.
I am now using the Model M for everything, but I'm going to get a gamepad like a Tartarus for gaming.
Offline livingspeedbump
    • KeyChatter
« Reply #4040 on: Sat, 19 March 2016, 15:05:39 »
If you want to use a real BS keyboard, get a Model F. Capacitive BS is so far superior than BS over membrane.  :rolleyes:
<- My Collection (so far)
Offline klennkellon
« Reply #4041 on: Sat, 19 March 2016, 15:38:38 »
I'd like too, but the weird layouts turn me off.
Offline xondat
  • i'm not a star
« Reply #4042 on: Sat, 19 March 2016, 17:57:01 »
Rubber dome fite me
Offline alienman82
« Reply #4043 on: Sat, 19 March 2016, 17:58:34 »
removed.
« Last Edit: Thu, 01 March 2018, 15:49:28 by alienman82 »
Offline WOMBO
« Reply #4044 on: Sat, 19 March 2016, 19:34:11 »
=D?
Offline alienman82
« Reply #4045 on: Sat, 19 March 2016, 19:37:17 »
removed.
« Last Edit: Thu, 01 March 2018, 15:49:24 by alienman82 »
Offline FLFisherman
  • I'd rather be fishing.
« Reply #4046 on: Sat, 19 March 2016, 19:38:15 »
Offline alienman82
« Reply #4047 on: Sat, 19 March 2016, 19:42:48 »
removed.
« Last Edit: Thu, 01 March 2018, 15:49:22 by alienman82 »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #4048 on: Sat, 19 March 2016, 20:03:45 »
=D?
dat thing LOL
What is this and why does it exist?
It's for a game cube online game from Japan
That thing is insanely expensive! I guess because people collect Game Cube stuff?
Offline climbalima
  • likes building stuff
« Reply #4049 on: Sun, 20 March 2016, 11:55:39 »
My planck!
