Author Topic: [FS] "old" Cherry MX Blacks - Cherry Stabilizers  (Read 31129 times)
Offline whiskytango
  • Trade Count: (0)
  • Don't touch the trim
Interesting. I did not notice this when desoldering them, but then again I was in hurry-up mode. I wish I could tell you exactly which board(s) those came off of, but I was just desoldering them, sorting the switch housing types out, and throwing them into a pile. I have never heard of WYSE boards using dark grays, but you're right, those don't exactly look black. Never had any dark grays in my possession (that I knew of) to compare to though. I understood though that dark grays would be noticeably stiffer than a black.
Good eye though. Definitely will be paying more attention now as I sort switches.
Offline Photoelectric
  • Trade Count: (1)
I hope someone who's seen them will pitch in.  I did not expect them, so I opened at least one of the questionable switches and one of the definite gray switches and took out the springs into the big spring pile (for cleaning) before I realized that I had a gray stem on my hands.  I tried to look for an obviously different spring to put back in, but, I couldn't identify one!  As far as I can tell, the springs look the same.  And the natural variation in color did not help--some were more silver, some were a bit oxidized.  I'll have to open the other two gray switches and double-check.  Could someone comment on Dark Gray springs vs. Black/Clear springs in terms of appearance?
Offline deazncy
  • Trade Count: (0)
Are those "old" black stems the same as mx red stems? I want to replace the blue stems on my poker so I can make it mx reds, but I was wondering if those black stems were identical to that of reds so that I can just use the black stems instead of trying to find red ones.
“Do not pray for an easy life, pray for the strength to endure a difficult one” -Bruce Lee
  • Trade Count: (0)
Pretty sure the only difference between a Red and a Black switch is the spring. Stems are the same.
Offline mashby
  • Trade Count: (0)
  • What Up Shoney? (ツ)_/¯
    • Mashby
I added Dark Grey (Linear) switches to my MX-Black Poker and they are noticeably heavier than an MX-Black switch. I only have two left, which I plan on using on another board, otherwise I'd send one to you.  :-[
Below is a photo of what they look like.
Key Caps & Switches by Michael Ashby, on Flickr
Offline whiskytango
  • Trade Count: (0)
As far as I know, yes they are identical. I have done exactly what you said, used stems from some old blacks from a WYSE and springs from a blue to make a red. They call this a "ghetto red". I put them side by side with some modern reds and couldn't tell a real difference. What little difference I could tell I think had more to do with the fact that the reds were on a Leopold and the ghetto reds were on a Rosewill.
If all you need are the stems, and you don't need your blue stems, I will trade you, stem for stem. I like blues with black springs...
  • Trade Count: (1)
Thank you--yours are much lighter in color!  I can see a clear difference.  So then mine are not Dark Grays but use some uncommon and odd gray plastic for Black stems... which is just confusing!!!
Offline BlueBär
  • Trade Count: (0)
To compare the springs maybe just press them against each other (one stem against the the other).
  • Trade Count: (1)
Yeah, I could do that.  But the most likely answer is that my odd gray switches are just plain MX Blacks from some random batch that used dark gray plastic in place of black.  The switches feel the same, and according to Mashby, I would notice the difference with Dark Grays being quite stiff.  Maybe they are some sort of "transition" switches, when the change was happening with the logo from "vintage" Blacks to "modern" Blacks.
Offline MKULTRA
  • Trade Count: (0)
  • telling it how it is
Got my keys today!  Look great on my Filco.  The colors were nearly an exact match, not even noticeable.  Thanks man.
Offline JPG
  • Trade Count: (0)
  • Model F is my new passion!
I got my switches today at the post. Thx a lot Whiskytango!
Also, first thing I did was to take 2 switches out and "test" them in my hands since the only switch I ever tried is the brown on my Filcos. And the second thing I did was to open a switch, see what it looked like, and change the spring for a 65g spring I had (got tem from someone on GH, and I think he told me they were from originative or similar).
And the first thing I realised is that both springs are VERY different. First, the stock "vintage" spring is shorter, has fewer coils and is maybe darker in color (probably because it's old). So, since I have no stock blue/red/brown spring, or a stock black "modern" black spring, I would be very happy if anyone having all 3 of them could take a picture of them besides one another?
I tried to take a picture of my 2 springs together, but my camera sucks hard and was unable to do so...
  • Trade Count: (1)
By the way, those springs regain their shine and clean up nice if you put them into a small glass filled with 91% alcohol for a few minutes :)  Not completely back to silver, but much cleaner after the dip.
Offline do_Og@n
  • Trade Count: (0)
I don't think those are Dark Grey's. They might be from a different plastic batch of vintage black stems though.
Dark Grey's are as firm as normal grey's or greens but linear (as others have stated).
Here are some pics for comparison:
29282-029284-129286-2
Offline Neal
  • Trade Count: (0)
  • Skype: iNewbcake
Got mine today, thanks!
Offline codyeatworld
  • Trade Count: (0)
Got mine yesterday, thanks very much sir! The set is very clean and a great match to the moogle.
I just need a wyse tsangan!
Offline nilpt
  • Trade Count: (0)
Re: WYSE - Cherry MX Blacks - "Vintage" Blacks - Cherry Stabilizers - Imsto PBT
« Reply #115 on: Thu, 01 August 2013, 16:30:21 »
Set 22 arrived.
Thank you very much.
IBM 1391410 / Qume terminal keyboard (teensy 2++)
Offline iAmAhab
  • Trade Count: (0)
  • Established member
« Reply #116 on: Fri, 09 August 2013, 16:46:03 »
Just wanted you to know I got my stuff and everything was in good condition.
Offline j2c8w6f8
  • Trade Count: (0)
« Reply #117 on: Wed, 04 September 2013, 05:01:16 »
pmed
Offline AGmurdercore
  • Trade Count: (0)
« Reply #118 on: Wed, 04 September 2013, 05:11:53 »
YGPM ;)
What the hell am I even doing
Offline devilockz
  • Trade Count: (0)
« Reply #119 on: Wed, 04 September 2013, 05:40:41 »
can i have the WYSE keycaps set #6 ? and can you quote me the price for shipping to M'sia?
thank you so much
Offline devilockz
  • Trade Count: (0)
« Reply #120 on: Mon, 23 September 2013, 23:50:11 »
hey bro, got my package today. and thanks for the extra gift. Great Seller. :thumb: :thumb: :thumb: :thumb: :thumb: 5 thumbs up for u.
36609-0
Offline MOZ
  • KING OF THE NEWBIES
  • Trade Count: (0)
  • Busy making stuff
« Reply #121 on: Tue, 24 September 2013, 05:24:33 »
Any stabs left?
Offline whiskytango
  • Trade Count: (0)
Re: [FS] WYSE sets - "old" Cherry MX Blacks - Cherry Stabilizers
« Reply #122 on: Tue, 24 September 2013, 09:32:25 »
Any stabs left?
I have a few stabs and switches left...
Offline r3dx
  • Trade Count: (0)
« Reply #123 on: Tue, 24 September 2013, 11:11:58 »
Just submitted an order  :D
Filco MJ2 Ninja | CM Storm QFR | CM Storm QFR | IBM Model M | IBM Model M SSK | ErgoDox |
LZ-GH
Offline r3dx
  • Trade Count: (0)
« Reply #124 on: Tue, 24 September 2013, 19:27:43 »
Invoice paid.
LZ-GH
Offline BliTzKiN
  • Trade Count: (0)
« Reply #125 on: Sat, 28 September 2013, 07:44:00 »
YGPM
Offline josh
  • Trade Count: (0)
  • Since 2011
« Reply #126 on: Sat, 28 September 2013, 08:23:44 »
Ok, are these Dark Grays?  When testing them (unmounted, pressing with fingers), I can't really tell a difference between them and regular MX Blacks.  Could be a small difference that I'd feel once they are mounted--I don't know.
Pure Black stems are on the left side: front, and one far back.  Middle left is undecided...  It's not pure black, but also quite dark to be gray...
I have 2 more of the ones like the "undecided" switch.  3 total of the obviously gray ones.
well i have some... ;D
and also have some pics for you
OTD 356CL Gunmetal | OTD 356CL Black | OTD 356CL DGE | OTD 356 Mini Military Green | OTD 356 Pad | TGR Jane V2 Blue Grey | TGR Jane V2 Pink | TGR Jane V2 ce E-White | TGR Alice Prototype 1.0 | TGR Alice Pink Silver Two Tone | TGR Alice Polycarbonate | TGR 910 RE Red | TGR 910 ce Silver | TGR x GAF 910 Black | TGR x GAF 910 Purple | Noxary Vulcan Pro Silver | Noxary Evija HG | Keycult No.2/65 Unfinished Red | Realforce 101 | Realforce 10 Year Anniversary | Realforce 23U | HHKB Professional White | HHKB Professional Charcoal | HHKB Snow 25th Anniversary Japan Edition
  • Trade Count: (1)
« Reply #127 on: Sat, 28 September 2013, 10:51:39 »
Interesting :)  I find these gray-black stems a bit more gritty than "normal" black stems, although my sample size is small.
Offline mashby
  • Trade Count: (0)
    • Mashby
Re: [FS] "old" Cherry MX Blacks - Cherry Stabilizers
« Reply #128 on: Fri, 18 October 2013, 18:16:28 »
Got the key caps in safe and sound and thrilled with how good they look. Thank you whiskey tango
WYSE Close Up by cpkey, on Flickr
Really thrilled with the "thick" set to see how different they are from the standard SP thin series.
WYSE Thick vs Thin by cpkey, on Flickr
Offline Pacifist
  • Trade Count: (0)
  • on hiatus
« Reply #129 on: Sun, 01 December 2013, 01:28:36 »
Sorry to bump an old thread but what's the functional difference between plate and pcb mounted stabs?
Offline do_Og@n
  • Trade Count: (0)
« Reply #130 on: Sun, 01 December 2013, 01:46:52 »
Plate mounted ones don't have those two plastic pieces on the bottom and they can only be mounted to a plate. The PCB mounted ones have to use special/specific PCB's that have the cutouts for those two plastics pieces. But, you can also cut those off to turn them into Plate mounted.
Hope that helps
Offline Pacifist
  • Trade Count: (0)
  • on hiatus
« Reply #131 on: Sun, 01 December 2013, 02:14:31 »
Hope that helps
thanks!
I need a pcb mounted cherry stab, so this won't cut it as it doesn't have the things that poke into the pcb
Offline whiskytango
  • Trade Count: (0)
« Reply #132 on: Sun, 01 December 2013, 21:54:15 »
thanks!
That is correct. Sorry, I don't have any more PCB stabs available right now. Plate only.
  • Trade Count: (1)
« Reply #133 on: Mon, 02 December 2013, 00:22:13 »
Sweet ive been looking for blacks, thanks man
  • Trade Count: (1)
« Reply #134 on: Sat, 07 December 2013, 13:47:28 »
Thanks for the switches man! :D
