Author Topic: Files for switch stickers - UPDATE: Designs uploaded.  (Read 39650 times)
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Re: Files for switch stickers
« Reply #50 on: Tue, 06 August 2013, 11:28:13 »
Offline MOZ
  • Busy making stuff
« Reply #51 on: Tue, 06 August 2013, 11:58:17 »
Offline MOZ
  • Busy making stuff
« Reply #52 on: Tue, 06 August 2013, 13:31:27 »
nubbinator, jdcarpe, got a chance to get those scans done? :D
Offline MOZ
  • Busy making stuff
« Reply #53 on: Tue, 06 August 2013, 14:18:17 »
Got the files from kbd, I was only off by 100th of a mm on some dimension.
SO the design is done! Woot!
« Reply #54 on: Tue, 06 August 2013, 14:25:47 »
Sorry, the scanner didn't work last night (no compatible drivers for it anywhere), so I was going to try and find another scanner I could use today.  Do you no longer need the scan?
Offline MOZ
  • Busy making stuff
« Reply #55 on: Tue, 06 August 2013, 15:18:25 »
Nope, not needed, thanks anyways.
I will get the latest design plotted and test.
If any members have easy access to a plotter and don't mind testing, it would be greatly appreciated.
Thanks.
Offline Photoelectric
« Reply #56 on: Tue, 06 August 2013, 18:45:55 »
As for switch stickers stabling PCB mounted switches. Would people like two sided adhesive stickers? But, I think that would make opening the switches a big PITA.
Definitely not, because the stickers extend outside the limits of the switch housing, so all that adhesive on the top side would be accumulating dust and dirt.
I should also add that the adhesive on all the stickers I've used is really weak anyway.  It would not make switches more difficult to open, but I stand by the dirt sticking issue.
« Last Edit: Tue, 06 August 2013, 18:48:20 by Photoelectric »
Offline MOZ
  • Busy making stuff
Re: Files for switch stickers - UPDATE: Designs uploaded.
« Reply #57 on: Tue, 06 August 2013, 18:53:16 »
vinyl sheets in general have adhesive which isn't too strong, this si something I have noticed. Usually it does not leave any residue as well, however on its own it will not peel of as easily. Magic!
As for double sided sticker, that was a brain-fart.
Offline KHAANNN
« Reply #58 on: Sun, 07 June 2015, 04:27:17 »
Going to test 3d printing the O version today, I have to find a mac compatible decent cad program first to convert it to .stl/.svg tho
The reason for 3d printing is availability, I don't want to order them online and wait weeks, also plastic could improve the effectiveness of the stickers
Until today, I thought the stickers were mostly aesthetical/placebo based, however I haven't been enjoying the wobble of my keycaps, after a bit of research I realised that these stickers were to reduce the wobble of the switch top, I previously didn't grasp/try to grasp the working principle
Anyway, I would appreciate any advice if anyone else tried 3d printing stickers before, especially sticker height-wise
