Author Topic: These gold caps are pretty awesome!  (Read 5219 times)
Offline jameslr
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
Re: These gold caps are pretty awesome!
« Reply #1 on: Tue, 30 July 2013, 23:14:22 »
Those look to be zinc...
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline jameslr
« Reply #2 on: Tue, 30 July 2013, 23:23:19 »
They probably are, but they're plated to look like gold. I didn't mean to imply they're solid gold.
Offline YoungMichael88
  • HHKB Wannabe
« Reply #3 on: Tue, 30 July 2013, 23:29:13 »
I have those and I love them. They fit tight tho. Really tight.
Offline jameslr
« Reply #4 on: Tue, 30 July 2013, 23:35:40 »
Nice!! I'll never get them, just thought they were neat novelty caps. How do they feel?
Offline The_Ed
« Reply #5 on: Tue, 30 July 2013, 23:36:48 »
So tight you have to break your switches to remove them I've heard...
R.I.P.ster
  • HHKB Wannabe
« Reply #6 on: Tue, 30 July 2013, 23:45:44 »
nah not that tight. You just have to be careful when removing them. I've had them on and off a few times for modding. I have them on reds and the weight of the caps make the switch soo light and it makes for a very smooth feeling, I love it but also really like heavy switches too. And the sound is very cool they "shimmer". Clink clink clink
Offline Photoelectric
« Reply #7 on: Wed, 31 July 2013, 00:05:12 »
I have the silver versions (newer better fitting molds) for Esc and arrow keys.  Too heavy to be used on normal switches for typing.  Maybe on stiff switches like stock Clears and similar.  They also sound clanky and metallic.  I'd stick with them as novelty caps and would not recommend them for alpha keys.
Offline The_Ed
« Reply #8 on: Wed, 31 July 2013, 00:09:19 »
Titanium spacebars are where the ****'s at if you like metal keycaps. I ordered 2 THICK ones from R2, and will likely sell my thin R1 for a slight markdown considering they don't wear.
R.I.P.ster
  • HHKB Wannabe
« Reply #9 on: Wed, 31 July 2013, 00:12:55 »
Yea all my mods and shift, enter etc are the newer silver colored ones and they all fit very loose so I needed to put a small square piece of painters tape on the stems and press the tape into the stems with the switch so they would fit a little tighter. Actually I had to use two layers of tape. If I didn't I could have held the board upside down and with a little shake they would have fell off. Are yours the same?
« Reply #10 on: Wed, 31 July 2013, 00:21:14 »
Yes.  Well not that loose, but I use Teflon tape myself.
  • HHKB Wannabe
« Reply #11 on: Wed, 31 July 2013, 00:28:41 »
I'm no typing champion so typing on them even on reds wasn't a big deal to me. I used it as my daily driver for months and months. I really do like how they feel. But that's the beauty of this hobby. We like what we like.
Offline Narcix
« Reply #12 on: Wed, 31 July 2013, 03:15:59 »
Very nice looking board  :D
Keycool 87 Grey PBT with mx blues
  • HHKB Wannabe
« Reply #13 on: Wed, 31 July 2013, 03:29:35 »
Thanks. For a poker it's very heavy now! Metal plate, metal case, metal caps. I should weigh it some day.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #14 on: Wed, 31 July 2013, 05:33:15 »
I have the silver ones for the alphas. Very Nice. They will go onto my ErgoDox soon.
I need mods though, anyone selling?
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #15 on: Wed, 31 July 2013, 08:11:06 »
390Y is about $39... Is that really so expensive?
TOO BAD FOR YOU
              Phantom 62g MX Whites
« Reply #16 on: Wed, 31 July 2013, 08:15:41 »
plus shipping and agent fees
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #17 on: Wed, 31 July 2013, 08:31:47 »
Last time I checked it was about 100Y to 1 USD. The hell happened.
EDIT: I was doing Yen not Yuan :p My bad :)) Too many currencies with the same letter! (And apparently symbol?!?!?)
DOUBLE EDIT: If it were yen it'd be $4 haha
« Last Edit: Wed, 31 July 2013, 08:33:58 by oTurtlez »
TOO BAD FOR YOU
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #18 on: Wed, 31 July 2013, 09:01:00 »
They do look kind of cool
Offline jameslr
« Reply #19 on: Wed, 31 July 2013, 10:27:29 »
I would like some gold mods if they ever make them I might pick them up. I didn't see any of them though. I don't think I would want them on alphas considering what people have said about them. Damn near $90 (after shipping and fees) for alphas alone is pretty pricey though.
Offline MOZ
  • Busy making stuff
« Reply #20 on: Wed, 31 July 2013, 10:49:04 »
I've been in the hunt for Mods (2x, 1.5x) and some blanks as well for the ErgoDox.
Anyone interested in a GB, so we can get Feng to get these again.
  • HHKB Wannabe
« Reply #21 on: Wed, 31 July 2013, 12:49:38 »
The user Feng is the guy who gets these things made from MKC. He has said that there will be no more gold caps made as the failure rate is too high. So whatever you see for sale are just left over from the first round he had made. Once it all sells you're only chance is buying them from someone second hand.
« Reply #22 on: Wed, 31 July 2013, 17:57:19 »
Mine has some wear.
Well, strictly speaking you can see scratches in the polished surface now that I've used it so much. I expect sandblasted wouldn't have this issue as much.
Offline The_Ed
« Reply #23 on: Thu, 01 August 2013, 00:57:46 »
Scratches?! What part of your thumb is hard enough to scratch titanium?!
R.I.P.ster
