Author Topic: [IC] Geekhack 6th Anniversary Custom Engraved Cherry MX Keychains  (Read 27247 times)
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Geekhack is reaching it's 6th anniversary, and what better way to celebrate than with some custom limited run merchandise.
This interest check is to gauge if members would be interested in a custom engraved Cherry MX keychain. Blue only, however switch top will be removable and then you can mod the switch, bottom would be glued.
The keychain will be made from three (maybe two) layers of acrylic, of thickness: 1.5mm, 3.5mm, 4mm  (or 5mm and 4mm) from top to bottom.
Color scheme and design will look like this:
Your username or text of choice\image will be engraved on the front, and "6" on the back. Each member will only be allowed to buy one.
Price would be somewhere between $1-$2, with $3 shipping, and then the usual paypal fees and optional $1 to GH funds.
The design is _not_ set in stone and I am open to ideas, but the theme is the 6th Anniversary, and no you may not have more than one.
Although I will do a GB for "similar" custom engraved keychains much later.
« Last Edit: Sat, 10 August 2013, 03:37:08 by mohitgarg »
Offline JPG
  • Model F is my new passion!
There is an error on your prototype, it should be written Gucchi, but nice idea still!  :p
Offline MOZ
  • Busy making stuff
Fixed
This is very cool!  I'd be interested.  :)
Offline JPG
Fixed
 :thumb:
I'd tap that. I'm in.
Offline tobr1an
This gets a Thumbs UP!
Offline lcs
  • Lover of Grape Drank
  • はやく
Also in mohit!
Offline Xenderwind
id be in for one for sure.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline MOZ
  • Busy making stuff
Updated OP with these questions:
 1. Removable switch or fixed switch with removal top?
 2. Keycap or not? If yes, let's think of a design and we can get it UV printed/dye-subbed depending on the design and numbers.
Re: [IC] Official Geekhack 6th Anniversary Custom Engraved Cherry MX Keychains
« Reply #10 on: Fri, 09 August 2013, 21:33:38 »
1) Fixed switch with removable top if possible
2) No cap
Offline lcs
  • はやく
« Reply #11 on: Fri, 09 August 2013, 21:34:18 »
2) No cap
Same for me.
Offline gnubag
« Reply #12 on: Fri, 09 August 2013, 21:36:23 »
2) No cap
+1
and if you could ship this with the switch stickers it would be awesome.
Offline acantha
  • Aure Entuluva
« Reply #13 on: Fri, 09 August 2013, 21:37:48 »
i'd definitely be interested.
1. removable
2. i could go either way
All the Happy Hacking Things
Offline MOZ
  • Busy making stuff
« Reply #14 on: Fri, 09 August 2013, 21:40:14 »
I could, but it will depend on what pace both GBs go.
Offline Xenderwind
« Reply #15 on: Fri, 09 August 2013, 21:41:01 »
2) No cap
+1
+2
« Reply #16 on: Fri, 09 August 2013, 21:41:47 »
I also vote no white layer. I would prefer Orange/Black/Orange. If this is going to be on a keychain, white will get dirty FAST.
Offline MOZ
  • Busy making stuff
« Reply #17 on: Fri, 09 August 2013, 21:45:23 »
Considered, how about white in the middle?
Offline CalmB4tehPwn
  • Demon of the Fall
Re: [IC] Geekhack 6th Anniversary Custom Engraved Cherry MX Keychains
« Reply #18 on: Fri, 09 August 2013, 23:31:10 »
Hey, count me in. I can drop a few bucks on this.
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
« Reply #19 on: Fri, 09 August 2013, 23:32:52 »
Same issue. If we're really going to be putting this in our pockets and what not, any white will get dirty fast from daily usage.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #20 on: Fri, 09 August 2013, 23:33:36 »
I'm in.
Offline MOZ
  • Busy making stuff
« Reply #21 on: Fri, 09 August 2013, 23:40:12 »
Since I am leaning towards, having fixed switch with removable top, I may end up just having two layers also.
Will find out on Monday, what thickness acrylic is available for orange and black.
« Reply #22 on: Fri, 09 August 2013, 23:40:48 »
Did you run this by mkawa?
Offline MOZ
  • Busy making stuff
« Reply #23 on: Fri, 09 August 2013, 23:43:13 »
« Reply #24 on: Fri, 09 August 2013, 23:49:23 »
Why limit to one per person?
If the price is that cheap?
Offline oaklandishh
« Reply #25 on: Fri, 09 August 2013, 23:51:38 »
I would definitely get one for that price! sounds great!
Offline Dubsgalore
« Reply #26 on: Fri, 09 August 2013, 23:51:48 »
fixed switch and no cap at all and i'm in
Offline Xenderwind
« Reply #27 on: Fri, 09 August 2013, 23:52:25 »
I kinda like it.  Since they're customized and maybe people won't sell them.  Also it may be easier on him to just deal with since it would be a smaller order.
« Reply #28 on: Fri, 09 August 2013, 23:56:19 »
Need an anniversary cap to.
Offline gnubag
« Reply #29 on: Fri, 09 August 2013, 23:57:08 »
i think that a limit of 2 should be ok and reasonable (if OP is ok with that), since I would have one with my keys and one on my desk to play around with.
Offline Dubsgalore
« Reply #30 on: Fri, 09 August 2013, 23:59:25 »
reading more, i vote with cap'n, no white layer at all :))
ehh not necessarily
Offline Badwrench
  • ummmm.....I forgot
« Reply #31 on: Sat, 10 August 2013, 00:02:48 »
Count me in.
Fixed switch with removable top, and 2 or 3 layers (minimum of Black and Orange).  No cap.
« Reply #32 on: Sat, 10 August 2013, 00:04:24 »
I'm curious why everyone is so strongly against caps for this.  Can someone share their thoughts?  I'm rather indifferent, so I can go either way, but some people seem to feel strongly.
Offline MOZ
  • Busy making stuff
« Reply #33 on: Sat, 10 August 2013, 00:05:17 »
Xenderwind said it, it is a limited edition special for the anniversary, thus every user will get only one, I don't want to saturate the world with too many "limited" editions ;)
If you read the small text at the end of the OP, you shall have a smile.
Offline Badwrench
« Reply #34 on: Sat, 10 August 2013, 00:08:46 »
Main reason for me is to keep the GB simple and cost low.  In addition I would think it would shorten the lead time as well.
Offline gnubag
« Reply #35 on: Sat, 10 August 2013, 00:09:55 »
for the lazy
Offline quake4mhg
« Reply #36 on: Sat, 10 August 2013, 00:16:45 »
It's gonna be our profile pictures! I'm in  :D
« Last Edit: Sat, 10 August 2013, 00:19:32 by quake4mhg »
Offline Glissant
« Reply #37 on: Sat, 10 August 2013, 00:27:12 »
I would care about the switch,  but if you go for a cap it should be in the regular Geek Hack style and be in colors wr promise never to make them in again :p
I'm in no matter what happens lol
« Reply #38 on: Sat, 10 August 2013, 00:49:52 »
This is a GH anniversary buy right? What better cap to put on it than one of the myriad of GH caps. We should just keep this simple and do the keychain. Turn around and actually getting stuff soon is preferable than waiting for 3-6 months for caps to be made and then another 1-2 months for sorting and shipping.
Offline gnubag
« Reply #39 on: Sat, 10 August 2013, 00:51:30 »
also you had to pay more for the keycaps and shipping from another source.
however, you would have a NEW GH keycap....
« Reply #40 on: Sat, 10 August 2013, 00:55:19 »
Good point.  It'd be cool to have a super unique cap that's only available through this, but you're right timing is an issue.
Offline jebbs
« Reply #41 on: Sat, 10 August 2013, 01:06:11 »
Design looks fine to me.
As for the switch, I'd prefer it didn't have one, but I wouldn't complain if it did end up having one.
Offline Dubsgalore
« Reply #42 on: Sat, 10 August 2013, 01:08:23 »
there we go
this is also 6 years and not 1, 5 or 10
« Reply #43 on: Sat, 10 August 2013, 01:09:23 »
Why did no one tell me about KEYCHAINS!!!??? Yes! KEYCHAINS!
« Reply #44 on: Sat, 10 August 2013, 01:15:10 »
This started literally 4 hours ago.  :P
« Reply #45 on: Sat, 10 August 2013, 01:16:12 »
Oh. Thank goodness. Yes, I love keychains. More to my collection of 6 uniques.
Offline MOZ
  • Busy making stuff
« Reply #46 on: Sat, 10 August 2013, 03:38:11 »
Looks like this is a gold idea. :D
Offline Neal
  • Skype: iNewbcake
« Reply #47 on: Sat, 10 August 2013, 05:18:03 »
I still don't have a keychain, I'm in.
Offline CommunistWitchDr
  • >implying keyboards
« Reply #48 on: Sat, 10 August 2013, 05:29:28 »
I'd get one. No way I'd carry it around since it would be so bulky, but I would set it on my desk and click it because that sounds fun.
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #49 on: Sat, 10 August 2013, 05:45:56 »
ill take one good sir
