Author Topic: New CoolerMaster MECH  (Read 16439 times)
Offline Topre
Re: New CoolerMaster MECH
« Reply #50 on: Fri, 16 August 2013, 02:15:45 »
This is most likely the ugliest keyboard I have ever seen.  Even worse than some of the worst unicorn vomit boards.
You must have never seen the Azio Mech4 or Mech5.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #51 on: Fri, 16 August 2013, 03:19:13 »
Nope not yet but I will look it up when I get home from work.
Offline viralbug
« Reply #52 on: Fri, 16 August 2013, 03:21:49 »
I have seen this keyboard in person. Unfortunately, I have seen a very limited number of decent keyboards, so can't really comment on the quality, so please take my words with a pinch of salt.
As some people have mentioned, it isn't really for GH people. It's more "gamer" oriented. I personally liked the feel/finish of the keyboard and it seemed decent quality to me. The shape might not appeal to a lot of people here, but it does look a bit better without the plastic handles or whatever they are. That plastic just makes it totally hideous IMO. Again, since it's geared more towards the normal crowd, the design isn't what we normally see here.
An interesting feature of the Mech that I was told was, it has an audio DAC inside. I'm a bit skeptical about this since the specifications on CM's page don't mention that. But it certainly would be interesting if it actually has a DAC. USB 3.0 is a plus point. The one I saw had white LED backlighting, not sure if it comes in other colors or if it is customizable. The backlighting looked nice to me.
« Last Edit: Fri, 16 August 2013, 03:25:08 by viralbug »
Offline viralbug
« Reply #53 on: Fri, 16 August 2013, 03:36:14 »
So to go along with this keyboard, CM Storm also released a mouse and headset as part of their Aluminum Series:
http://www.cmstorm.com/en/products/keyboards/MECH/
http://www.cmstorm.com/en/products/peripherals/Reaper/
http://www.cmstorm.com/en/products/audio/Pulse-R/
Yeah they're apparently coming up with complete kits for gamers. Keyboard+mouse+headset. There's gonna be some all white kit too I think.
I gotta check some of the promotional material I have and will post more.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #54 on: Fri, 16 August 2013, 03:41:14 »
Thanks ViralBug for the info.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #55 on: Fri, 16 August 2013, 04:58:02 »
Gamers love their toys lol.
SmallFry! <3
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #56 on: Fri, 16 August 2013, 09:27:56 »
Alu Case Everywhere  :p
Offline CommunistWitchDr
  • >implying keyboards
« Reply #57 on: Fri, 16 August 2013, 17:21:16 »
I'm just sad major manufacturers take "aluminum case" to mean "a sheet of thin aluminum covering the product" instead of solid thick aluminum. It would be amazing if a mainstream manufacturer had a thick cnc aluminum case.
Offline esoomenona
  • Gnillort?
« Reply #58 on: Fri, 16 August 2013, 17:26:28 »
Nobody would buy it. Companies have to make a profit, as well as numbers. If they spent tons of time and money to have cases CNC milled, and they didn't sell, what then?
Vortex tried to provide aluminum cases with some sort of profit, and look at what happened with them. It just doesn't work for the average consumer. Does anyone take into account that when we buy Korean Kustom keyboards, we're almost essentially getting them at cost. What if someone tacked on more money for their profit? Would you want to buy it?
Offline do_Og@n
« Reply #59 on: Fri, 16 August 2013, 17:32:39 »
I think the handle is used for the 1 or 2 zombies you'll whack with it and then it breaks and you get eaten. Of course the person next to you using the Model F AT will rule the world with his godly zombie killing keyboard.
Even if they had this in the tenkeyless format I still wouldn't get it. I hate having a keyboard that can't fit a complete set of keycaps.
« Last Edit: Sat, 17 August 2013, 10:10:40 by do_Og@n »
Offline UniClown
« Reply #60 on: Fri, 16 August 2013, 17:43:43 »
Every time you turn on the computer you gotta start up that rapid fire engine  :))
« Reply #61 on: Fri, 16 August 2013, 17:57:58 »
Quote from: HendyZone link=topic=46945.msg1000550#msg1000550 date=1376663276
Vortex had a low quality aftermarket case. And kmac deals in very low volume. A stock board, produced in extreme volumes, could have significantly lower cost than a kmac. I'm not talking aircraft grade aluminum either, just halfway decent solid metal.
Offline Niomosy
« Reply #62 on: Fri, 16 August 2013, 18:43:15 »
Red, brown, and... green switches?  I can see some green switch fans buying it just for that.
 :blank: in the specifications column, they said it only have blue brown red
Ahhh.  On the main page it shows green.  At first I thought that an interesting third switch choice, particularly over black.
Offline Grimey
« Reply #63 on: Fri, 16 August 2013, 21:25:52 »
This is pretty 90s kid cool, perhaps the 20 year rule of style applies here as well.
Erlang your pants off
Offline elttaboi
« Reply #64 on: Fri, 16 August 2013, 22:05:29 »
looks kinda meh tbh
i would have preferred them giving their quickfires a metallic top cover and maybe some underglow
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #65 on: Fri, 16 August 2013, 23:28:55 »
And I thought the Model M takes up deskspace  :eek:
Looks really corny to me.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #66 on: Fri, 16 August 2013, 23:36:29 »
this is a backlit board. that should scream "GAMER" (possibly casual) to you. many gamers prefer backlit boards with lit legends because it makes their lives a bit easier, and they're not that picky about key legending, quality or feel.
CM designed the new XT and stealth for you. as my review of the XT more or less states, the XT is a brilliant little design that has everything that the average geekhacker wants, and nothing they don't want. frankly, i don't think it's an exaggeration to say that you have carter (and his design team of course) to thank for this; both the proper market segmentation and the extraordinarily appropriate designs of the XT and stealth for the geekhack market. if you're not all that interested in a huge backlit board, well, no big surprise. leave those boards to the people who do want them (and yes, they definitely exist).
Offline Topre
« Reply #67 on: Sat, 17 August 2013, 00:09:41 »
I can think of a few things that I don't exactly like about the Quickfire XT, but they are small things that won't matter too much. The thing I dislike the most about the Quickfire XT is the USB port, I would personally prefer a micro-B or mini-B instead of a regular sized USB A port.
Offline MOZ
  • Busy making stuff
« Reply #68 on: Sat, 17 August 2013, 06:54:19 »
I agree, props to CM for catering both the markets, unlike many other "gaming" keyboard manufacturers
Offline morpheus
« Reply #69 on: Sat, 17 August 2013, 08:03:46 »
It just needs a quad laser.
Offline oryan_dunn
« Reply #70 on: Sat, 17 August 2013, 21:31:19 »
Would you prefer the Mini/Micro B for size reasons, or because an A port on a client device is non-standard?
I can't tell, but it looks like they may have wised up and used a full sized USB B port on this keyboard.  Hopefully they'll change the port to a full sized B for the XTS.
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #71 on: Sun, 18 August 2013, 00:59:06 »
C'mon guys, we all know what that handle's for!
So, it includes a Guitar strap too?
« Last Edit: Sun, 18 August 2013, 01:04:02 by wetto »
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
« Reply #72 on: Sun, 18 August 2013, 03:42:27 »
Wearable computing ;)
« Reply #73 on: Sun, 18 August 2013, 06:22:33 »
I can see it now, they hired a new lead designer who has spent years designing keyboards, only to realize they weren't computer keyboards.
Offline vun
  • Just one more thing
« Reply #74 on: Sun, 18 August 2013, 06:58:04 »
Did Mad Catz purchase Cooler Master?
Seems like it :P
Not enough LED screens for showing important ingame intel.
Damn, I miss those screens!
I call bull**** on the fact that ANYONE has ever actually used those screens... It makes zero sense to look down and away from the main screen.
I found the LCD on my old G15 to be incredibly useful when gaming, so there. Now that I'm back to one monitor I really miss having one, although I never used it for realtime game info. It was, however, heaps useful to check the song playing, I could use Miranda with the LCD to chat with people while in-game, and idk what games you've played, but if you have zero downtime while playing FPS you're either cheating or playing something ****ty like FFA/DM.
Offline dmbr
« Reply #75 on: Mon, 19 August 2013, 16:26:06 »
It has macros and it's CoolerMaster. That's good...
« Last Edit: Mon, 19 August 2013, 16:28:30 by dmbr »
Offline Thimplum
  • Master of all Ponies
« Reply #76 on: Mon, 19 August 2013, 16:29:18 »
Seems like it :P
Which are SOOO important.
TP4 FOR ADMIN 2013
Offline Quardah
    • DeliTech
« Reply #77 on: Tue, 20 August 2013, 13:26:17 »
Mech4 is defenetly the most horrible board i've ever seen. Mech5 isn't so bad.
Also my friend purchased the new CM Mech we're talking about in this thread, and he was pretty surprised to see it's red backlite. Also he said it's worth it.
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
Offline wetto
« Reply #78 on: Tue, 20 August 2013, 14:25:31 »
Most likely:
MX Brown = White LEDs
MX Blue = Blue LEDs
MX Red = Red LEDs.
My collection:
Offline Quardah
    • DeliTech
« Reply #79 on: Tue, 20 August 2013, 14:38:18 »
Most likely:
MX Blue = Blue LEDs
MX Red = Red LEDs.
Nope, he has MX blue and Red LEDs.
Pretty weird.
Poker II - Brown MX
Offline Inklebert
« Reply #80 on: Tue, 20 August 2013, 14:39:51 »
I can't say I'm a fan of the handle on the side o.O
