Author Topic: Ducky 3 Shine Keyboard Space Bar Sticks Sometimes  (Read 3831 times)
Offline dman777
« on: Tue, 13 August 2013, 08:13:23 »
I have a Ducky Shine 3 Keyboard which I really like. However, the space bar seems to stick when coming back up 50% of the time. It comes back up but it will stick mid point then finish coming up by itself. Is there anything I can do to fix this?  I already threw the box away. I replaced the space cap with the extra r space bar that Ducky inlcuded that has the Ducky emblem on it.
Offline Ekruceal
Re: Ducky 3 Shine Keyboard Space Bar Sticks Sometimes
« Reply #1 on: Tue, 13 August 2013, 08:37:01 »
It should go away as you wear the keyboard in.  It usually happens when there's too much stabilizer grease underneath the key.
« Reply #2 on: Tue, 13 August 2013, 08:53:11 »
Are you sure you got the space bar seated properly and completely?
« Reply #3 on: Tue, 13 August 2013, 17:33:09 »
Try removing it and replacing it, making sure that the stems are correctly inserted and there is no damage underneath.
Offline dman777
« Reply #4 on: Wed, 14 August 2013, 10:18:19 »
I removed  it and resat it this time allowing the spacebar to be higher. It no longer sticks but the spacebar is higher than the other keys in that row. Is it supposed to be like that? Also, I noticed there are 3 leds but only the middle one turns on. Is that normal?
Offline dman777
« Reply #5 on: Wed, 14 August 2013, 11:13:45 »
Ugh, it started to stick again. I think it has the do with the black stabilizers on the side of the switch.  Any suggestions? I already threw away the box so I can't exchange it for another one and I don't want to send it back for a repair.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #6 on: Wed, 14 August 2013, 12:35:01 »
Elitekeyboards sells some keyboard lube that might help with the stab stickiness.
« Reply #7 on: Wed, 14 August 2013, 16:44:08 »
The Shine 3 has special functions to adjust the extra LEDs under the space bar - have a look in the manual.
Offline dman777
« Reply #8 on: Thu, 15 August 2013, 06:26:49 »
Here's a video of it sticking if anyone can identify what is wrong or if this is just normal from being new:
Offline elton5354
« Reply #9 on: Thu, 15 August 2013, 06:32:33 »
Probably the stabilizer wire came off on one side.  You can try to plug it back to place.
Offline dman777
« Reply #10 on: Thu, 15 August 2013, 06:49:30 »
Wow, I didn't see any wires at the stabilizers when I had the keycap spacebar off. Are they underneath? How would I get to them?
« Last Edit: Thu, 15 August 2013, 06:53:53 by dman777 »
« Reply #11 on: Thu, 15 August 2013, 06:54:40 »
You'll have to open the board up. It's between the plate and PCB.
Offline dman777
« Reply #12 on: Thu, 15 August 2013, 08:56:18 »
Do I just need to take the 2 screws out in the back? I was thinking about trying this at work if it is quick and easy.
« Reply #13 on: Thu, 15 August 2013, 16:49:32 »
Are you able to try a different space bar in case this one is slightly deformed?
Offline dman777
« Reply #14 on: Thu, 15 August 2013, 20:55:44 »
naw, i got rid of the other space bar so i can't test it.
how do i get the keyboard apart? i took out the 2 bottom screws but its still tightly together.
« Reply #15 on: Thu, 15 August 2013, 21:15:45 »
This post covers Ducky Shine 2 disassembly - hopefully it is similar.
Offline jonathanyu
« Reply #16 on: Thu, 15 August 2013, 21:27:27 »
did you check your space bar is in a right shape? maybe it get stuck with other key
Offline dman777
« Reply #17 on: Thu, 15 August 2013, 21:31:43 »
Here is the one of the stabilizers of the space bar. Sometimes it comes up but very slowly and has hardly any pressure. Are they supposed to be like that?
« Last Edit: Thu, 15 August 2013, 21:33:15 by dman777 »
« Reply #18 on: Thu, 15 August 2013, 21:37:58 »
Yes, that's normal.
Cherry stabilisers do not have a spring under the end stems, just in the switch.
The stabiliser is just to make sure that if you press one side of the space bar down, the other side goes down at the same time, and causes the switch to activate.
Otherwise the space bar would just tilt to one side if not pressed in the exact centre.
Offline dman777
« Reply #19 on: Thu, 15 August 2013, 21:43:15 »
I guess it must be the space bar itself then. Maybe I should try and file the outer edge of the stabilzer poles under the spacebar?
Offline dante
« Reply #20 on: Thu, 15 August 2013, 22:19:16 »
Get MX Dark Grays. That will take care of sticky stabilizers :D
« Reply #21 on: Thu, 15 August 2013, 22:43:27 »
Although you said you have tried two space bars - the original one and Ducky's replacement.
It is unlikely, although possible, that the two space bars are deformed in the same way.
Ideally you would try a third space bar from another manufacturer before resorting to more drastic methods.
