Author Topic: The SmallFry KB, AKA jdcarpe loves 40%  (Read 303544 times)
Re: The SmallFry KB, AKA jdcarpe loves 40%
« Reply #200 on: Sat, 14 September 2013, 08:38:32 »
Maybe I can't see it, but what is the point of keeping the GH60 mounts points? The PCB is much to fit the Poker in any case.
If you do want to make it somewhat compatible, then keep the mount points so that the 40% PCB centers on the GH60 PCB?
I'd say the mounting holes are being added just in "case." :P
I know the MOQ is probably ridiculous, but one day maybe there could be a reduced size, Poker-style injection molded plastic tray case for it. Which would have mounting standoffs, of course. And then we would be glad the mounting holes were there.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #201 on: Sat, 14 September 2013, 08:40:54 »
Maybe me point was not clear, what I meant was, why in the exact same places as the GH60?
« Reply #202 on: Sat, 14 September 2013, 08:45:42 »
Oh, well maybe I was confusing when I suggested they be in the same relative positions. I just meant maybe there could be a slot hole on each side between the bottom row and the ZXCV row. And between tab and A. And under the enter key. And maybe one between a couple of keys in the center. That's all. :)
Offline MOZ
  • Busy making stuff
« Reply #203 on: Sat, 14 September 2013, 08:47:57 »
Ahh, now I understand.
As for case, I don't know if there would be aa injection molded plastic case for it, however, there will be an acrylic case for it :D
Can't wait.
Offline n0rvig
« Reply #204 on: Tue, 17 September 2013, 00:00:50 »
jdcarpe, you are ridiculously / insanely cool at this keyboard thing. okbye.
« Reply #205 on: Tue, 17 September 2013, 03:06:15 »
<3
Offline regack
« Reply #206 on: Tue, 17 September 2013, 19:54:30 »
Further along, moved mounting holes, need to sanity check and post files to github...
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
« Reply #207 on: Tue, 17 September 2013, 20:19:00 »
Oh my! It looks amazing regack!
HHKB Pro 2   SmallFry Keyboard
Offline MOZ
  • Busy making stuff
« Reply #208 on: Tue, 17 September 2013, 20:22:41 »
For the third row from the top I would suggest supporting 1+1.25, besides the 1.25+1 on the right shift.
« Reply #209 on: Tue, 17 September 2013, 21:24:06 »
Yeah, if it's possible to add support for this, that would be nice.
« Reply #210 on: Tue, 17 September 2013, 21:33:54 »
Looking really good you two.  I really need to see the map of the Fn layer.  Where is that?
« Reply #211 on: Tue, 17 September 2013, 22:08:49 »
Something like this:
« Reply #212 on: Thu, 19 September 2013, 22:44:09 »
Now I want one even though it won't support dvorak.
The only change I'd consider for the function layer is to make the arrowkeys
V<>
Which makes more sense to me than what you have
<V>
Also, where is the , key? I know . is on the main area
« Last Edit: Thu, 19 September 2013, 22:45:41 by dorkvader »
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #213 on: Fri, 20 September 2013, 00:22:49 »
This looks great.  I'm looking forward to seeing a nate set on one of these.
Offline regack
« Reply #214 on: Fri, 20 September 2013, 13:06:58 »
I'm not sure why the slotted holes don't render properly.
- Added option for 1.25+1.0 or 1.0+1.25 for the right-shift
- LEDs for the 1.0+1.25 arrangement are 'flipped' so they share a common anode (with the regular layout).
- Added back missing slot on right right side
Offline MOZ
  • Busy making stuff
« Reply #215 on: Fri, 20 September 2013, 13:21:28 »
Beautiful as ever. This is the one with the integrated SMD components, right?
Offline regack
« Reply #216 on: Fri, 20 September 2013, 13:40:33 »
Yes, same components as the keypad, so we're kind of prototyping this one with that...
Offline MOZ
  • Busy making stuff
« Reply #217 on: Fri, 20 September 2013, 13:44:11 »
We are? I got to get a case ready then! When did this happen? Noone told me! ><
Anywho, I am in, please, please, please!
We can save some dough maybe by getting components for both of these together and also save on shipping if you guys want me to do the case. Should have told me earlier and we would have saved on those nuts/bolts. Oh well.
« Reply #218 on: Fri, 20 September 2013, 13:46:14 »
Moz I think he meant the keypad prototype is also a test for the ideas/design/parts to be used in the 40% board
Offline MOZ
  • Busy making stuff
« Reply #219 on: Fri, 20 September 2013, 13:57:56 »
In other words, I got over-excited?
« Reply #220 on: Fri, 20 September 2013, 14:01:05 »
I believe so.
« Reply #221 on: Fri, 20 September 2013, 23:03:08 »
The PCB...she is beautiful.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #222 on: Fri, 11 October 2013, 18:24:34 »
I've been watching this for awhile, anything required to help with beta testing?
« Reply #223 on: Fri, 11 October 2013, 18:28:48 »
We just need to get the SMT PCB design completed. I think regack is probably just busy. Once the design is finished, I will look into getting a few PCBs made for testing, before opening up group buy ordering.
Offline hcry4
  • HHKB Hoarder
« Reply #224 on: Fri, 11 October 2013, 22:28:39 »
Thanks for the update! Keep up the great work guys!
Offline MOZ
  • Busy making stuff
« Reply #225 on: Sat, 12 October 2013, 00:25:00 »
Last I discussed this with regack be was finalising the SMT and looking to add extendability features.
Offline regack
« Reply #226 on: Wed, 16 October 2013, 16:11:11 »
Update...
  • pulled extra pin for ROW5 from ATMEGA pin 8/PB0
  • added GPIO4, GPIO5, GPIO6 connectors to ATMEGA pins 26/PD6, 22/PD5, 11/PB3
  • ran ROW and GPIO connections to 1.27mm header pins on right-side of board for interconnect
So, with all those extra io connections, you should still be able to keep the CAPS/FN LED as well as the WASD LEDs and still have room to add a 4x6 keypad run from the same firmware... though someone would have to write that firmware.
« Reply #227 on: Wed, 16 October 2013, 16:13:12 »
Update...
Very awesome, regack! Thank you for the major update!!
Offline MOZ
  • Busy making stuff
« Reply #228 on: Wed, 16 October 2013, 16:25:59 »
Update...
Great work ;)
Offline bearcat
« Reply #229 on: Wed, 16 October 2013, 23:23:06 »
Nice looking PCB!  Can't wait for the group buy :)
Offline komar007
    • komar's blog
« Reply #230 on: Thu, 17 October 2013, 00:17:30 »
I love this board!
It's just a shame I probably wouldn't be able to use such a small kb...
Where is the chip? On the other side than shown?
Offline MOZ
  • Busy making stuff
« Reply #231 on: Thu, 17 October 2013, 05:07:42 »
Yeah, all the controller components and usb connector are on the other side
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #232 on: Thu, 17 October 2013, 05:53:58 »
i will literally sell my soul to get my hands on one of these
Offline Pacifist
  • on hiatus
« Reply #233 on: Sun, 20 October 2013, 19:22:50 »
After thinking about it, I would totally get one. This+Ghpad=all I need
Offline neoezekiel
    • My GW2 Guild - The Fallen Souls [SouL]
« Reply #234 on: Mon, 21 October 2013, 10:34:59 »
I am in for at least a pair when this gets to the point that we can start  a GB for a kit version. I'm So Excited I Can Barely Contain Myself :D
WTB: Cherry G80-2550, GnCC/CCnG sets, led mx greens, mx dark greys, Plate Design Service, Case Design Service
Offline thoere
« Reply #235 on: Mon, 21 October 2013, 17:46:51 »
Didn't realize there was going to be a group buy for this.
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #236 on: Wed, 23 October 2013, 00:22:48 »
Update...
BIG Spamimg Love for this !!
« Reply #237 on: Mon, 28 October 2013, 09:07:41 »
Okay, so I know this is not even near group buy status yet, but I do want to recommend something to everyone who is interested in getting one (eventually). As you probably know by now, 7bit is running Doubleshot Replacements Round 5 (Honeywell) at Deskthority. These are SA-profile (thick) double shot ABS keycaps from Signature Plastics.
He has included (at snoopy's suggestion) a kit specifically designed for this layout. To order the keycaps for this 40% keyboard, you would need to order:
HONEY/FORTY
HONEY/SPACE625
Big thanks to 7bit for including this set in his group buy!! :thumb:
http://deskthority.net/marketplace-f11/doubleshot-replacements-round-5-honey-sphericals-t6732.html
« Last Edit: Mon, 28 October 2013, 09:36:43 by jdcarpe »
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #238 on: Mon, 28 October 2013, 09:26:11 »
Thanks for the heads up jd! I just added the set to my order.
Offline panpipe
« Reply #239 on: Mon, 28 October 2013, 09:29:34 »
This is the cutest keyboard ever. Now my 60% looks fat and stupid.
Offline MOZ
  • Busy making stuff
« Reply #240 on: Mon, 28 October 2013, 09:36:05 »
Special thanks to snoopy and 7bit.
Jdcarpe, can you post the keycaps needed specifically for the 40%, and add that info to the OP. I'd like them to be added to every future GB.
« Reply #241 on: Mon, 28 October 2013, 09:37:32 »
HONEY/FORTY
HONEY/SPACE625
New page bump.
« Reply #242 on: Mon, 28 October 2013, 09:41:47 »
Sure.
Row 2: 1u Esc, 1u Del or Backspace
Row 3: 1.25u Tab, 1.75u Return or Enter
Row 4: 1.75u Shift, 1.25u Shift, 1u Fn
Row 4 (SA Row 3): 1.25u Ctrl, 1u Win or Del, 1u Alt; optional layout: 1.25u >., 1.25u ?/
« Last Edit: Mon, 28 October 2013, 10:04:49 by jdcarpe »
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #243 on: Mon, 28 October 2013, 09:56:12 »
Now I really can't wait until this happens :D
I think it will look really good with the honeywell keys.  :cool:
Offline Latin00032
« Reply #244 on: Mon, 28 October 2013, 09:56:52 »
HONEY/FORTY
HONEY/SPACE625
Now I know I need this kit.
Offline MOZ
  • Busy making stuff
« Reply #245 on: Mon, 28 October 2013, 09:57:31 »
Forgot the 1u R2 Esc.
« Reply #246 on: Mon, 28 October 2013, 10:05:01 »
Fixed, thank you.
Offline MOZ
  • Busy making stuff
« Reply #247 on: Mon, 28 October 2013, 10:12:15 »
Let's dub this the 40%/SmallFry kit.
« Reply #248 on: Mon, 28 October 2013, 11:54:54 »
7bit cares not for the affairs of GHers.
« Reply #249 on: Mon, 28 October 2013, 12:03:54 »
I think MOZ was referring to the add-on kit for this 40%/SmallFry keyboard, a la tsangan and moogle kits.
And 7bit seems to care somewhat, as he monitors things here. He's just not active in discussions.
