Author Topic: How to customize key caps?  (Read 3248 times)
Offline Silencer67
« on: Fri, 16 August 2013, 13:41:01 »
Hello everyone! I just purchased my first Mechanical Keyboard (CS Storm Quickfire tk) and I've been looking into custom key caps. My search led me to these forums and I thought someone here could answer a few questions I had about custom key caps.
First off, I was wondering how keycaps can be customized like this:
http://store.ggwpapparel.com/product/pre-order-clg-logo-key-cap
How do you take a normal solid black key and get a symbol into it? I'm looking to maybe pick up customizing key caps as a hobby. Not so much making key caps themselves but buying solid black key caps and customizing them like putting a logo or symbol into it. What would I need to get started? Can someone point me in the direction of a thread or something to help me get started? I'd greatly appreciate it!
I would like to thank everyone in advance for their time! Have a great day!
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Re: How to customize key caps?
« Reply #1 on: Fri, 16 August 2013, 13:54:44 »
It's very hard to print on your own. Have a read through this to see how legends (The symbols on keycaps) are produced: http://deskthority.net/wiki/Keycap_printing
At home, most people produce novelty caps by creating their own molds, and/or painting pre-manufactured ones.
Offline Silencer67
« Reply #2 on: Sat, 17 August 2013, 03:33:26 »
I can't do something like Laser Etching?
Offline MOZ
  • Busy making stuff
« Reply #3 on: Sat, 17 August 2013, 06:52:21 »
If you saw the link, yes, you can , it is one the ways keycaps are printed.
Offline mythe
« Reply #4 on: Sat, 17 August 2013, 12:25:54 »
The cheapest and most practical way would probably be to go through wasdkeyboards.  It's only $15 for 2 keys: http://www.wasdkeyboards.com/index.php/custom-keycap.html
If you decide to laser etch your own then you need a laser engraver.  I think you can get a cheap engraver for around $500, but idk if ones that cheap are precise enough to detail a keycap.  It might be worth it if you are planning to engrave a ton of keys.
Otherwise, you can also get hobby waterslides and print out a decal.  Those won't be as durable but it might be practical in some cases.  The biggest downside is that you can't print in white unless you have a special printer.
« Last Edit: Sat, 17 August 2013, 12:29:20 by mythe »
Offline mindoculus
« Reply #5 on: Tue, 20 August 2013, 18:16:48 »
the custom key design on WASD is a nice  option.
what type of images are best ? what's the sweet spot for resolution where details are not blurred or sacrificed? any pictures of actual custom WASD keys ?
