Author Topic: Badwrench's hopefully not too bad QFR top mods.  (Read 59186 times)
Offline Badwrench
  • ummmm.....I forgot
« on: Sun, 25 August 2013, 07:56:34 »
I have some ideas, but will post something once the tops arrive.
Ok, getting started.  Covers arrived - one grey, one black.  Also picked up some materials to wrap them  ;).  Not sure how this is going to work, but that's part of the fun.
33816-0
Close up of the black material:
33818-1
Yup, it's alligator print.
« Last Edit: Mon, 02 September 2013, 10:06:18 by Badwrench »
Offline Badwrench
Re: Badwrench's hopefully not to bad QFR top mods.
« Reply #1 on: Sun, 25 August 2013, 07:56:54 »
First one is done.   :thumb:
33832-0
33834-1
33838-2
« Last Edit: Mon, 02 September 2013, 11:46:52 by Badwrench »
Offline Badwrench
Re: Badwrench's hopefully not too bad QFR top mods.
« Reply #2 on: Mon, 02 September 2013, 11:47:38 »
Quick preview before better pictures when there is more light.
33894-0
Better pics:
33957-1
33959-2
33961-3
« Last Edit: Tue, 03 September 2013, 11:11:27 by Badwrench »
Offline Tym
« Reply #3 on: Mon, 02 September 2013, 11:49:11 »
What does it feel like?
« Reply #4 on: Mon, 02 September 2013, 11:50:05 »
That's really cool.
I was thinking of doing something similar, so now I've gotta go hoard magazines.
Offline JPG
  • Model F is my new passion!
« Reply #5 on: Mon, 02 September 2013, 11:51:56 »
Hippies, they are everywhere!
Good job man, looks very good!
Offline AGmurdercore
« Reply #6 on: Mon, 02 September 2013, 12:14:36 »
This looks really interesting, good job!
What the hell am I even doing
Offline Badwrench
« Reply #7 on: Mon, 02 September 2013, 13:19:48 »
It is completely glued, so there is no loose cloth, but overall it is very soft.  I used just enough glue to get a good bond, but not enough to soak through and make the cloth feel like plastic.
Offline Photoelectric
« Reply #8 on: Mon, 02 September 2013, 13:30:28 »
Awesome, I'm always a fan of color, and you have loads of it on the first cover :D  It's got something of an impressionist style and watercolor look, while also looking velvety and textured.
Offline Badwrench
« Reply #9 on: Mon, 02 September 2013, 13:37:13 »
Thanks.  There were a ton of different fabrics, so I went with something a bit over the top.  This one was also a proof of concept for me before I try the other fabric.  This fabric was very thin, so I didn't have to sand any of the plastic down to clear the keys, but the alligator print is very think and will require quite a bit of filing to make room.
« Reply #10 on: Mon, 02 September 2013, 13:38:37 »
I wonder if you can coat it with something to make it durable and washable.  Some kind of a nylon clear coat or some such--something that wouldn't cause yellowing either.
Offline Badwrench
« Reply #11 on: Mon, 02 September 2013, 13:41:23 »
I was thinking of using some 3M fabric sealer (like the stuff used on convertible tops) to keep it bright and help keep oils and dirt from staining it.
Offline Badwrench
« Reply #12 on: Sun, 08 September 2013, 19:51:12 »
Well, since I had a third cover, I figured I would try something different.  Color is a light teal/sky blue over pearl white scallops.  This is before clear.  Gonna let is gas out a cure a couple days before clear.
34661-0
34663-1
Offline Badwrench
« Reply #13 on: Mon, 09 September 2013, 15:31:35 »
Well, it was beautiful out today, so I put the cover out to cure and what do you know, ready for clear.  Clear is on and now it is mounted.
Cable is actually teal, but it always photographs blue  :rolleyes:
34774-0
34776-1
34780-2
« Last Edit: Mon, 09 September 2013, 15:34:10 by Badwrench »
« Reply #14 on: Mon, 09 September 2013, 15:34:09 »
Better pics:
I missed this before, this is absolutely awesome. I love it!!
« Reply #15 on: Mon, 09 September 2013, 19:18:55 »
Approved/voted/+1
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #16 on: Tue, 10 September 2013, 08:43:09 »
I love the tie-dyed look -- that is awesome!
Quote from: Samuel Adams
Offline thebeargentile
« Reply #17 on: Tue, 10 September 2013, 08:52:36 »
All of those look awesome.  I'm interested to see how well the fabric ones hold up... I think the sealer is a great idea, but if you end up using it regularly, I wonder to what how long it will take to show wear.  We'll need a followup!  :D
Offline Jixr
« Reply #18 on: Tue, 10 September 2013, 10:03:41 »
do a real leather one!
« Reply #19 on: Tue, 10 September 2013, 12:15:16 »
^such a hand-e-cap :D  LOVE IT!!!
Offline do_Og@n
« Reply #20 on: Sat, 14 September 2013, 14:09:43 »
Color inspired by a hand-e-cap.....awesome job on this.
Offline Badwrench
« Reply #21 on: Sat, 14 September 2013, 14:51:26 »
Yup.  Could not help it, such a great color.  As an added bonus, should match quite well with the incoming Miami set.  Acid vision FTW!
Offline viatical08
« Reply #22 on: Sun, 15 September 2013, 00:50:56 »
Where did you get those covers? Link?
Quickfire Stealth Blues
« Reply #23 on: Sun, 15 September 2013, 03:47:59 »
Offline Badwrench
« Reply #24 on: Sun, 29 September 2013, 13:02:45 »
Ok, tried something different, and well, keyboard science failure:
37312-0
New finding.  QFR top can't cope with 105C temps.
« Reply #25 on: Sun, 29 September 2013, 13:05:31 »
By the way, what's the color that you used for the turquoise keyboard above?  It looks suspiciously close to a desktop case I painted with Rust-Oleum satin "Aqua" that's standing in my living room :)  I love that color.
« Last Edit: Sun, 29 September 2013, 13:07:11 by Photoelectric »
Offline Badwrench
« Reply #26 on: Sun, 29 September 2013, 13:15:33 »
Ding ding....winner.  It was the closest color I could find for my hand-e cap.  It is a nice soft blue with just a touch of teal.  Unfortunately, it makes the pearl while look very silver.  Before I taped off for the scallops, I had the whole thing in the pearl white and it looked very white.
37314-0
Offline do_Og@n
« Reply #27 on: Sun, 29 September 2013, 13:18:06 »
I have to admit.....I cried a little. At least your other top turned out awesome!
« Reply #28 on: Sun, 29 September 2013, 20:17:48 »
Could be the start of a new ergonomic keyboard.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #29 on: Mon, 30 September 2013, 07:03:25 »
Can't make keyboard science without melting some cases. +1 to you, Badwrench, for having the balls to post failures.
Offline Badwrench
« Reply #30 on: Mon, 30 September 2013, 17:39:29 »
Got a little bored and added a little something.  Made my stencil from some print outs in special elite font, and sprayed in royal blue.  I re-wetsanded the whole thing and recleared.  Will polish tomorrow after curing.
37368-0
« Reply #31 on: Mon, 30 September 2013, 17:41:35 »
:)  Another person to do a stencil!
http://geekhack.org/index.php?topic=47490.msg1025719#msg1025719
Came out great!!
Offline Badwrench
« Reply #32 on: Mon, 30 September 2013, 17:44:54 »
Came out great!!
Yeah, yours gave me the idea, but mine came out a little janky.  I cut mine directly on the case by putting the painters tape down and taping the print out over that.  I then cut it directly and pulled the letters out the leave the area to be painted.
Hope I didn't step on any toes.
« Reply #33 on: Mon, 30 September 2013, 17:52:16 »
Not at all!  I've been so tired lately, I'm disappointed with myself for not doing enough on my projects!  It's great that the stencil actually works :)  I'll add mine soon.
The jagged edges are intentional though! ;)
Offline Badwrench
« Reply #34 on: Mon, 30 September 2013, 17:55:01 »
Cool, thanks.  What I meant by janky on mine was the second e and the k, look closely.  Good from far, but far from good.
« Reply #35 on: Mon, 30 September 2013, 17:56:27 »
Oh, if you hadn't said anything, I wouldn't have even noticed!  It's all pretty coherent with the font :)  And I'm a fan of that aqua - Miami theme, of course!
You have my vote with this one!
Offline Angrychair
« Reply #36 on: Mon, 21 April 2014, 20:51:18 »
hah man good work and good laughs on that warped board!
Sprit60      Poker II      Code                  Corsair K70
Offline blackbox
« Reply #37 on: Fri, 13 June 2014, 18:44:12 »
That alligator skin one was very cool!
The LAN table!
Offline barkinos98
  • Illinois
« Reply #38 on: Mon, 04 August 2014, 15:59:46 »
that geekhack edition QFR looks great man :)
also, you should somehow adapt that top and make a dali edition QFR :D
Happy Hacking Professional 2  | Logitech G710+ | Quickfire Rapid MX Clears
Offline Anole
« Reply #39 on: Mon, 09 February 2015, 19:21:08 »
That tie-die board is shmexy! I gotta try that!  :p
Offline just66in
« Reply #40 on: Fri, 23 October 2015, 19:26:26 »
Wow, the work in this is sooo good. Well  done!!
Offline FranklinScudder
  • Clack
« Reply #41 on: Tue, 03 November 2015, 13:00:18 »
The material one looks AMAZING! How did you get the corners so neat? seriously 10/10 would try myself  :thumb:
            WTB | CMYK Mods
Offline Badwrench
« Reply #42 on: Tue, 03 November 2015, 20:50:14 »
Thank you.  I had a ton of fun doing these up.  The corners just took a bit of measuring and trimming before applying the spray adhesive to make sure they lined up perfectly.   I have had a ton of practice over the years doing car upholstery and motorcycle seats (along with the odd household re upholstery here and there).
