Author Topic: Keycap Stats  (Read 10693 times)
Offline TheSoulhunter
  • ~ BOOO ~
Keycap Stats
« on: Sat, 31 August 2013, 07:33:37 »
The goal is to collect data about keycaps, weight / dimensions / thickness / profile / material / etc.
Did some weight measurements for the start:
Weight / Source / Material / Profile / Row
3,10g / Hammer / Titanium / OEM / QWER
3,00g / Hammer / Titanium / OEM / ASDF
3,10g / Scarface / Aluminum / Cherry / SF0
2,80g / Scarface / Aluminum / Cherry / SF2
1,35g / Imsto / PBT DyeSub / Cherry / ESC
1,25g / GMK / ABS DS / Cherry / ESC
1,20g / SP / PBT / E-Sports
1,10g / SP / PBT / DSA
1.10g / SP / BB Crystal Cap / SP / ESC
1,10g / KBC / PBT (Engraved) / OEM / QWER
1,00g / KBC / Old PBT (Blank) / OEM / QWER
1,05g / SP / Clear PC / SP / ESC
1,00g / SP / PC DS / SP / ESC
0,90g / SP / ABS DS / SP / ESC
0,90g / SP / Clear PC / SP / QWER
0,85g / SP / ABS DS / SP / ESC
0,80g / SP / Clear PC / SP / ASDF
0,85g / WASD / Blank ABS / OEM / ESC
0,80g / WASD / Blank ABS / OEM / QWER
_______________________________________________________________________________________________
EDIT: 02 Sep 2013
Kenmai9 made a shared spreadsheet, feel free to add your stats...
https://docs.google.com/spreadsheet/ccc?key=0AgcCxy9yJbwWdFMwdlNHNlVOdW9SLTc1UkJLZ00wRUE&usp=sharing
EDIT: 02 Sep 2013
Added domoaligato's clacks to the list...
EDIT: 02 Sep 2013
Added more caps to the list...
EDIT: 03 Sep 2013
Added Hammer's 2nd gen Titanium spacebar to the list...
EDIT: 03 Sep 2013
Still looking for:
- Cherry ABS caps
- Cherry POM caps
- Zinc caps
- Aluminum spacebars
- 2nd gen Titanium spacebars
- Relegendable Tipro/POS caps
- Girldc caps
- Feng metal caps
- Brobots
- Stock Topre caps
- Stock Filco caps
- SP SA caps
- More...
« Last Edit: Tue, 03 September 2013, 01:35:17 by TheSoulhunter »
A Ghost From The Past
  • ~ BOOO ~
Re: Keycap Stats
« Reply #1 on: Sat, 31 August 2013, 07:33:56 »
Reserved to add more stats in future!
Feel free to contribute... :D
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Re: Keycap Stats
« Reply #2 on: Sat, 31 August 2013, 14:24:57 »
Great work!
Re: Keycap Stats
« Reply #3 on: Sat, 31 August 2013, 14:29:09 »
Cool idea. Imsto PBT is cherry profile though :)
  • ~ BOOO ~
Re: Keycap Stats
« Reply #4 on: Sat, 31 August 2013, 14:39:37 »
Fixed! Thx!
Offline Moosecraft
  • HHKB Pro
Re: Keycap Stats
« Reply #5 on: Sat, 31 August 2013, 15:02:46 »
No BSP?
Offline domoaligato
Re: Keycap Stats
« Reply #6 on: Sat, 31 August 2013, 15:03:52 »
Click Clacks
MX
Hardcore White
2.43g / Click Factory / Plastic/ Cherry/ ESC
CandyCorn
2.18g / Click Factory / Plastic/ Cherry/ ESC
  • ~ BOOO ~
Re: Keycap Stats
« Reply #7 on: Sat, 31 August 2013, 15:42:22 »
Click Clacks
MX
Hardcore White
CandyCorn
Thanks for contributing!
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
Re: Keycap Stats
« Reply #8 on: Sat, 31 August 2013, 15:49:16 »
Click Clacks
MX
Hardcore White
CandyCorn
You should define if it is a blank or a skull and if blank which row. The skulls should be a bit more heavy, cause the skullface is on top of the normal keycap.
  • ~ BOOO ~
Re: Keycap Stats
« Reply #9 on: Sat, 31 August 2013, 16:00:13 »
Perhaps for non mass produced caps we should add images?
Offline domoaligato
Re: Keycap Stats
« Reply #10 on: Sun, 01 September 2013, 13:10:45 »
sorry that candycorn was blank and the hardcore white is a skull
here is the weight of the candycorn mx tricolor skull
2.39g
edit: added that it is mx
« Last Edit: Sun, 01 September 2013, 13:15:12 by domoaligato »
Offline domoaligato
Re: Keycap Stats
« Reply #11 on: Sun, 01 September 2013, 13:14:51 »
candycorn blank mx arrow kit
1.54g
1.63g
1.46g
1.53g
candycorn blank mx wasd kit
1.55g
1.57g
1.57g
1.58g
Offline divito
Re: Keycap Stats
« Reply #12 on: Sun, 01 September 2013, 20:34:33 »
This information needs to be in a table. Keeping up with slashes and following the different lengths as things get added will be a nightmare.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
  • ~ BOOO ~
Re: Keycap Stats
« Reply #13 on: Mon, 02 September 2013, 03:31:30 »
Kenmai9 made a spreadsheet, thx!
I edited the 1st post...
« Last Edit: Mon, 02 September 2013, 03:56:48 by TheSoulhunter »
  • ~ BOOO ~
Re: Keycap Stats
« Reply #14 on: Mon, 02 September 2013, 04:00:39 »
Someone got stock cherry caps (ABS and POM), zinc caps, or some aluminum spacebars to measure?
I got Jelly POMs and a 1st gen Hammer titanium spacebar, but lack the stuff mentioned above...
  • ~ BOOO ~
Re: Keycap Stats
« Reply #15 on: Mon, 02 September 2013, 04:42:06 »
Did some edits...
33798-0
  • ~ BOOO ~
Re: Keycap Stats
« Reply #16 on: Mon, 02 September 2013, 05:11:50 »
1.54g
1.63g
1.46g
1.53g
1.55g
1.57g
1.57g
1.58g
Thanks! But could you add which weight correspondents to what cap? ^^;
Offline divito
Re: Keycap Stats
« Reply #17 on: Mon, 02 September 2013, 19:22:33 »
I was wondering...why not also include pictures for the type of available cap, including the source/period in which is was created/produced. For newer members like me, it might interesting to know what key caps were made where, and when, etc...
It would be like a key cap compendium. All names, pics, dates, and stats collected here, etc...
Offline jonathanyu
Re: Keycap Stats
« Reply #18 on: Mon, 02 September 2013, 19:43:04 »
cool. i got a question. what will happen when putting a hammer 1st gen space bar on to a 45g spring switch?
Offline ComradeSniper
  • HHKB Pro
Re: Keycap Stats
« Reply #19 on: Mon, 02 September 2013, 19:52:43 »
Since the weight is spread out over a fairly wide area, I imagine that it wouldn't actuate the switch, but would be an incredibly light spacebar.
  • ~ BOOO ~
Re: Keycap Stats
« Reply #20 on: Tue, 03 September 2013, 01:30:26 »
As ComradeSniper wrote, the force needed for actuation will decrease somewhat, the key will feel lighter...
We estimated that probably only a "thick style" stainless-steel spacebar would be enough to get anywhere close to self-actuation ;)
  • ~ BOOO ~
Re: Keycap Stats
« Reply #21 on: Tue, 03 September 2013, 01:41:18 »
Actually "Mr. Keyboard Science" and me already did this way back then, but it was lost!
Gonna do it again as soon I find the time and effort... ;P
Offline divito
Re: Keycap Stats
« Reply #22 on: Tue, 03 September 2013, 02:41:36 »
I don't mind helping/researching if we decide on a way to collect and disseminate the information in a digestible way. I'm interested to learn and see all the options from years gone by. It'd be a good experience and source of information for people, as well we use the community's collective knowledge and experience for itself.
Offline domoaligato
Re: Keycap Stats
« Reply #23 on: Tue, 03 September 2013, 03:12:53 »
way back machine?
  • ~ BOOO ~
Re: Keycap Stats
« Reply #24 on: Tue, 03 September 2013, 03:14:14 »
That's cool! Perhaps you could setup some sort of "catalog" where we enter:
- Production year
- Manufacturer
- GB handler / Seller
- Production #
- Original Price
- Material
- Profile
- Mugshot
New key-sets could be entered easily each time a GB is done...
For older ones we need to do some research and talking (ie. permission to use images).
  • ~ BOOO ~
Re: Keycap Stats
« Reply #25 on: Tue, 03 September 2013, 03:17:30 »
Perhaps we should start by thinking up some standard for submissions...
Which info? Formatted in which way? What should images show? How? Resolution and framing? Etc. etc.
Offline divito
Re: Keycap Stats
« Reply #26 on: Tue, 03 September 2013, 03:30:33 »
- Production year
- Manufacturer
- Production #
- Original Price
- Material
- Profile
- Mugshot
Hmm. Not home at the moment, but I can throw some simple code together to host on my site and that can be a place to enter everything.
Should get back tomorrow, and we can try to hash out more details over the next little bit.
  • ~ BOOO ~
Re: Keycap Stats
« Reply #27 on: Tue, 03 September 2013, 03:36:56 »
- Production year
- Manufacturer
- Production #
- Original Price
- Material
- Profile
- Mugshot
Sounds cool! Joint venture with joint rights to content?
Got a website as well, but it's not finished yet ^^;
  • ~ BOOO ~
Re: Keycap Stats
« Reply #28 on: Mon, 09 September 2013, 14:57:23 »
Ok, started taking images...
Let's do 800x800 for single caps, 1200x800 for spacebars or wide keycap arrangements!
Offline tricheboars
  • Keyboards are Important!
Re: Keycap Stats
« Reply #29 on: Mon, 09 September 2013, 14:58:54 »
i can measure some SP SA caps but i dont have a digital scale.
  • ~ BOOO ~
Re: Keycap Stats
« Reply #30 on: Mon, 09 September 2013, 15:11:57 »
A analog caliper should work... ^^
Mainly interested in thickness (walls) and height (bottom to highest point).
