Author Topic: [IC] Clear keycaps set  (Read 7341 times)
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« on: Sat, 31 August 2013, 13:55:46 »
The recent GB by kinruan for switch cover top had clear switch covers and these look great with clear caps from SP, specially if you have applied stickers.
You can check out the images here: http://geekhack.org/index.php?topic=46446.msg1023490#msg1023490
So I'm jest gauging if there is enough interest for a GB for these keycaps:
If there is we can have a GB for these
Offline Tym
Re: [IC] Clear keycaps set
« Reply #1 on: Sat, 31 August 2013, 14:13:53 »
Dont SP already sell this fairly cheap like $40?
Offline MOZ
  • Busy making stuff
« Reply #2 on: Sat, 31 August 2013, 14:22:35 »
Yeah, they do for 104 keyset.
I figured, if we have good numbers we can get better pricing, and more options, maybe with legends?
Offline domoaligato
Offline MOZ
  • Busy making stuff
« Reply #4 on: Sat, 31 August 2013, 15:08:08 »
feng sells the kbc clear sets also
http://www.ebay.com/itm/KBC-Semi-Clear-ABS-104-Keyset-Cherry-MX-Keycaps-/330853929008?pt=LH_DefaultDomain_0&hash=item4d086e5030
i have those, due to their darker tone, unless you have LEDs installed the sticker color doesn't show on the transparent covers, only the color of the cover shows through.
Offline LechnerDE
« Reply #5 on: Sat, 31 August 2013, 17:17:25 »
I am interested. I don't know whether we need legends for these - they would limit the see trough effect wouldn't they?
Maybe engraving is an option?
Offline MOZ
  • Busy making stuff
« Reply #6 on: Sat, 31 August 2013, 17:23:33 »
I'll contact SP and find out.
