Author Topic: [IC] Plate Buy  (Read 26679 times)
Offline The_Beast
  • I like wood ಠ_๏
[IC] Plate Buy
« on: Mon, 09 September 2013, 15:39:14 »
This is mostly stemming from this thread but I'd like to have a questionnaire filled out before I move ahead with any plans
Plate and PCB interest check
Details if I proceed:
Payment window closing around November 14th if stainless is chosen and earlier if anodized
Packing around Nov. 29th
Shipping in the week or two afterwards
This is not a group buy
Anodized plates will cost more than Stainless Steel
I don't plan on offering that many colors if people want anodized
I have not had anything anodized from this place before
  - I may run some plates prior to the buy, but I'm not 100% sure
Plate Questionnaire
Fill out the questionnaire and let me know what you think in the comments below
View Responses
« Last Edit: Tue, 10 September 2013, 11:32:15 by The_Beast »
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Re: [IC] Plate Buy
« Reply #1 on: Mon, 09 September 2013, 15:54:51 »
An estimated pricing would really help before filling out the form.
Offline The_Beast
  • I like wood ಠ_๏
Re: [IC] Plate Buy
« Reply #2 on: Mon, 09 September 2013, 15:56:02 »
Mid $30s, low $40s without shipping for stainless. Anodized, I just don't really know
Offline asdfjkl36
  • blue shirt guy
Re: [IC] Plate Buy
« Reply #3 on: Mon, 09 September 2013, 16:21:25 »
Interested in a plate. Form filled.
Offline acantha
  • Aure Entuluva
Re: [IC] Plate Buy
« Reply #4 on: Mon, 09 September 2013, 16:25:00 »
same here, and though i said i preferred stainless steel, i'll do a alu one as well. i just need a plate.
All the Happy Hacking Things
Offline Vintage
Re: [IC] Plate Buy
« Reply #5 on: Mon, 09 September 2013, 18:14:49 »
Hmmm hope alu is not too much more expensive.
Excited for this buy nonetheless.
CM QFR w/ MX Reds  | Logitech G900
Offline LechnerDE
Re: [IC] Plate Buy
« Reply #6 on: Tue, 10 September 2013, 04:43:05 »
Filled the form.
Hopefully the pricing will be affordable ;)
Offline CalmB4tehPwn
  • Demon of the Fall
Re: [IC] Plate Buy
« Reply #7 on: Tue, 10 September 2013, 05:06:39 »
I'm still willing to pay for the first rack of anodizing, if we go that route. Assuming it is indeed 30 bucks a rack, and you want to do a test run before the actual GB. But I'm seriously, and entirely, sold on the HHKB model that JDCarpe mocked up.
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
Offline BliTzKiN
Re: [IC] Plate Buy
« Reply #8 on: Tue, 10 September 2013, 10:17:26 »
Form filled! Really glad to see this progressing :D
Offline The_Beast
  • I like wood ಠ_๏
Re: [IC] Plate Buy
« Reply #9 on: Tue, 10 September 2013, 11:33:43 »
Responses are now viewable
Offline thebeargentile
Re: [IC] Plate Buy
« Reply #10 on: Tue, 10 September 2013, 12:05:08 »
Very nice.  A black plate would be amazing.
Offline xavierblak
Re: [IC] Plate Buy
« Reply #11 on: Tue, 10 September 2013, 15:17:39 »
Any chance for at 7bit layout? I know it's not popular but it one of the main reasons I got a phantom but I haven't been able to source a plate yet.
Offline kwago
Re: [IC] Plate Buy
« Reply #12 on: Wed, 11 September 2013, 08:09:05 »
ANSI 1.5 would allow you to use a winkeyless cherry ds set, correct?
Re: [IC] Plate Buy
« Reply #13 on: Wed, 11 September 2013, 08:22:05 »
That is correct. :)
Offline dragonxx21
Re: [IC] Plate Buy
« Reply #14 on: Wed, 11 September 2013, 10:00:52 »
What's the difference between a universal TKL and one specific to the Phantom? Also, is there any links/images showing the differences between the layouts, such as the difference between the Ansi 125 and the Ansi 150?
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline xavierblak
Re: [IC] Plate Buy
« Reply #15 on: Wed, 11 September 2013, 10:32:04 »
These are univeral plates and these are phantom plates.
Basically the universal plate leaves room above the arrow cluster for the controller pcb on filco and QFR boards. While the phantom plate allows you to populate that area on a phantom with additional keys.
So the universal plate should work on a phantom but a phantom plate won't work on off the shelf tkl boards.
Offline dragonxx21
Re: [IC] Plate Buy
« Reply #16 on: Wed, 11 September 2013, 10:35:39 »
Any idea on pricing for the anodized plates?
Keyboards Owned:
Offline jonathanyu
Re: [IC] Plate Buy
« Reply #17 on: Wed, 11 September 2013, 13:17:06 »
Are the holes that for the screw different between these two plate?
Re: [IC] Plate Buy
« Reply #18 on: Wed, 11 September 2013, 13:48:36 »
No, the screw holes are not the issue. The Filco controller daughterboard needs a cutout in the plate in order to fit into the PCB. The Phantom plates don't have this cutout, because the controller for the Phantom (Teensy 2.0) is soldered to the back of the PCB. This allows the Phantom PCB to allow for 5 more switches in that area, instead of a controller.
Here are some illustrations why:
Filco plate:
Phantom ANS125 plate:
Filco controller (programmable replacement controller, by bpiphany)
(not my image)
Here is an ANS150 plate:
  • Demon of the Fall
Re: [IC] Plate Buy
« Reply #19 on: Wed, 11 September 2013, 16:45:04 »
Black is getting far too many votes.
Boooriiiing.
Re: [IC] Plate Buy
« Reply #20 on: Wed, 11 September 2013, 16:45:51 »
Boooriiiing.
What color do you want for our test run plates? Blue?
  • Demon of the Fall
Re: [IC] Plate Buy
« Reply #21 on: Wed, 11 September 2013, 17:01:38 »
I'd be happy paying for blue, green, or brown.
Re: [IC] Plate Buy
« Reply #22 on: Wed, 11 September 2013, 17:05:33 »
Boooriiiing.
Opinion + logic
Black is a safe first colour, other colours like the ones you suggested are not. More runs at a later date.. sure, why not.
Offline jonathanyu
Re: [IC] Plate Buy
« Reply #23 on: Wed, 11 September 2013, 17:54:38 »
 only the most popular one will produce ?
  • Demon of the Fall
Re: [IC] Plate Buy
« Reply #24 on: Wed, 11 September 2013, 20:39:40 »
Boooriiiing.
Opinion + logic
But thats the thing, we already have black and grey and silver plates available. Colots are "unsafe" but I know I'm not alone in wanting an unsafe color.
Give me cyan, or fuschia or lavender
Re: [IC] Plate Buy
« Reply #25 on: Wed, 11 September 2013, 20:40:48 »
Available where? Sure, they were in past GBs, but they are not easily 'available'.
Offline Vintage
Re: [IC] Plate Buy
« Reply #26 on: Wed, 11 September 2013, 20:50:49 »
I agree; was sad to see how many people were in favor of black. IDK what the point of getting anodized is if you want black IMO.
  • Demon of the Fall
Re: [IC] Plate Buy
« Reply #27 on: Wed, 11 September 2013, 20:53:30 »
I didnt say easily available, but I already have a black uTKL and a raw SS phantom plate on the way. Clearly they're available if you're looking.
What I have not been able to find any off, is color. Any color, except hints of red.
Offline jonathanyu
Re: [IC] Plate Buy
« Reply #28 on: Wed, 11 September 2013, 20:56:36 »
Boooriiiing.
Opinion + logic
I agree that black is a safe color. It can be match with most of the color.  But in my opinion, gold match white caps very good.
Offline TLSC.wipeOut
  • "Who dares, wins"
Re: [IC] Plate Buy
« Reply #29 on: Wed, 11 September 2013, 20:59:22 »
As long as its an ANSI150 plate for the phantom pcb... I think I won't be too picky with the colour, so black seems fine to me too ^^
OTD 456GT with Lubricated 68g Gold Spring MX Clears and GMK Dolch Keycap set
WTB: KMAC2 kit
Re: [IC] Plate Buy
« Reply #30 on: Wed, 11 September 2013, 21:00:07 »
Sure, they're available.. But to what degree? How many people have them & want to sell them? How many people want them?
I reckon the number of people who want them minus the number of people who have them & want to sell them is higher than the number of people who want a colour that isn't black.
Re: [IC] Plate Buy
« Reply #31 on: Wed, 11 September 2013, 21:01:58 »
Personally the black anodized plate I have is very nice!!
Offline jonathanyu
Re: [IC] Plate Buy
« Reply #32 on: Wed, 11 September 2013, 21:03:16 »
same, I really want a gold one, but I can accept all color as long as it is ANSI 150
how is the color compare to stock Filco plate?
« Last Edit: Wed, 11 September 2013, 21:04:56 by jonathanyu »
  • Demon of the Fall
Re: [IC] Plate Buy
« Reply #33 on: Wed, 11 September 2013, 21:45:11 »
The amount of people that jumped when I mentioned being interested in tracking down someone who can Annodize in Cyan, I feel is indicative of a neglected demographic. If The_Beast wants to keep this GB simple, and just do Black, or no color at all, then I might have to push forward with my own GB and track down someone who can do Cyan for us, and a few non-standard, interesting colors like it.
Offline argyakrivos
Re: [IC] Plate Buy
« Reply #34 on: Thu, 12 September 2013, 06:23:25 »
It's not THAT easy to find a plate... I've been trying to find an ANSI 125 plate for my phantom but I'm having trouble finding one! It's either the people who sell them bundles them with a keyboard and switches (making the purchase very expensive), or they're selling other plate variations (e.g. ISO, WFD, etc.).
Offline kps
Re: [IC] Plate Buy
« Reply #35 on: Thu, 12 September 2013, 10:11:12 »
Hi The_Beast,
Would there be any possibility of adding one or more custom plates? Metal and finish are not important to me and I'd happily take a mix from different leftover space. (I'm looking at doing a large terminal-plus board and could easily split the different sections.)
If so, is there a particular preferred key template to use, or criteria for inside corner kerf and whatnot?
Offline The_Beast
  • I like wood ಠ_๏
Re: [IC] Plate Buy
« Reply #36 on: Thu, 12 September 2013, 10:39:58 »
I'd much rather do stainless since I like it a lot and it's easier for me, but the people of GH seem to want anodized aluminum.
In terms of plates, I'm thinking of running an ANSI150 Phantom Plate and a uTKL which should work as a phantom plate with the exception of doing the numberpad on the right side because the controller goes there.
Colors, it looks like black is the clear winner with purple, gray and red as strong seconds.
Offline dragonxx21
Re: [IC] Plate Buy
« Reply #37 on: Thu, 12 September 2013, 11:10:24 »
I'd rather have stainless steel as well.
Keyboards Owned:
Offline Hellmark
Re: [IC] Plate Buy
« Reply #38 on: Thu, 12 September 2013, 11:40:15 »
I want a bare stainless one. Leaning towards phantom ansi125.
Phantoms you can get PCB's no problem, but the plates are the trickier part.
Edit: raw stainless, so I can polish it, and make it shiny and pretty.
« Last Edit: Thu, 12 September 2013, 11:45:32 by Hellmark »
  • "Who dares, wins"
Re: [IC] Plate Buy
« Reply #39 on: Thu, 12 September 2013, 11:48:41 »
hmm well my main goal here is to get hold of a plate for the phantom, preferrably the ansi150 layout, whether its a stainless steel or anodized aluminum.. I'd be happy with it.
I guess if you already know the quality of the stainless steel from the place you are getting these from with a $30-40 price range I'm down for one ^^
WTB: KMAC2 kit
Re: [IC] Plate Buy
« Reply #40 on: Thu, 12 September 2013, 12:29:48 »
This isn't meant to slight you, personally, because several newer members have expressed the same sentiment, but...
FOR ABOUT TWO YEARS NOW IT HAS BEEN ALMOST IMPOSSIBLE TO OBTAIN A PHANTOM PCB IF YOU MISSED THE GROUP BUYS. ONLY IN THE LAST FEW DAYS HAS IT BEEN EVEN POSSIBLE TO ORDER A PHANTOM PCB FROM A STOREFRONT. SO THE CAVALIER ATTITUDE ABOUT HOW EASY IT IS TO OBTAIN A PHANTOM PCB MAY BE A BIT IRRITATING TO THOSE OF US WHO HAD TO WAIT MONTHS OR EVEN YEARS TO GET OURS.
/rant
Offline MOZ
  • Busy making stuff
Re: [IC] Plate Buy
« Reply #41 on: Thu, 12 September 2013, 13:25:34 »
/rant
Thank you, I've waited for about 2 months, and even the ErgoDox PCB. We can't be thankful enough to MK for selling these on-demand. I know I hunted and asked many of those who placed orders in the ErgoDox R2, if they could order extra PCBs, and even mailed Massdrop repeatedly. Thankfully they agreed and had the PCB only GB.
So be thankful that the Phantom PCB is now available.
However my hunt has begun again with the search for yet another PCB. I am now looking for the GH60 PCB.
Re: [IC] Plate Buy
« Reply #42 on: Thu, 12 September 2013, 13:31:37 »
/rant
Aswell as those who STILL haven't received their R2 order :rolleyes:
Offline Hellmark
Re: [IC] Plate Buy
« Reply #43 on: Thu, 12 September 2013, 13:46:46 »
/rant
Oh, I know it only has been extremely recently. I may only be recently active, but I have lurked around here for about 4 years. A change to be easier to obtain, is still a change, whether it happened a year ago, or yesterday.
Offline argyakrivos
Re: [IC] Plate Buy
« Reply #44 on: Thu, 12 September 2013, 14:22:03 »
Does this mean that you won't be running an ANSI125 one?
Re: [IC] Plate Buy
« Reply #45 on: Thu, 12 September 2013, 14:49:34 »
uTKL is ANSI 125.
Offline Hellmark
Re: [IC] Plate Buy
« Reply #46 on: Thu, 12 September 2013, 16:39:28 »
Doing Phantom150 and uTKL is fine for me, since that still gives a ANSI125 option.
Although thinking about it, my primary want for stainless steel, is for a stripped down keyboard, where the plate doubles as a face, but with both uTKL and Phantom, that isn't an option as their are holes around the arrows. That said, it really doesn't matter too much which material it is, although I still give stainless steel the edge because if it is cheaper.
Offline argyakrivos
Re: [IC] Plate Buy
« Reply #47 on: Thu, 12 September 2013, 18:02:19 »
All right, since uTKL is ANSI125 then I'm fine with that. I actually prefer stainless steel as well - better material and lower price.
If there's gonna be a uTKL plate with stainless steel, and the price is decent enough, then I will definitely get at least two plates.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: [IC] Plate Buy
« Reply #48 on: Thu, 12 September 2013, 22:32:26 »
I think a Phantom plate that supported 10x and 8x spacebars would be pretty cool. Ditto for GH60
edit: sandblasted and anodized plates would look pretty amazing.
Offline The_Beast
  • I like wood ಠ_๏
Re: [IC] Plate Buy
« Reply #49 on: Thu, 12 September 2013, 22:34:10 »
I don't think you can have a 8x or a 10x since it would more than likely hit a switch cutout. If it does hit a cutout, that stabilizer would need to be PCB, which the phantom doesn't support.
However, I could be wrong *waits for Jd*
